查看: 1223|回复: 0
老师给看一下吧,画的难看,错误无数,要交智商税了.
1元学习PADS(4期)
发表于 2018-4-19 19:25:47 | 显示全部楼层 |阅读模式
*PADS-ECO-V10.0-MILS*
*REMARK*  old file: D:\study\电路设计\逆天PCB 4月班\第四期视频\www.NTpcb.com-1元学习PADS-第4期-项目1上课资料\校验原理图的文件\GL850G_asc.asc
*REMARK*  new file: C:\PADS Projects\ecogtmp1.asc
*REMARK*  created by ECOGEN (Version 6.4v) on 2018/4/19 19:23:37
PART DIFFERENCES
OLD DESIGN                                        NEW DESIGN
Ref-des    Part-typeecal                           Ref-des    Part-typeecal
EC1   C0805                                       EC1   C0603
EC5   C0805                                       EC5   C0603
EC2   CED-6_3-2_5                                 EC2   CED-6_3_2_5
EC3   CED-6_3-2_5                                 EC3   CED-6_3_2_5
EC4   CED-6_3-2_5                                 EC4   CED-6_3_2_5
EC6   CED-6_3-2_5                                 EC6   CED-6_3_2_5
NET DIFFERENCES
DGND                                              GND
N15274073                                         $$$53
N15275140                                         $$$3109
N15275302                                         $$$1093
N15275414                                         $$$3105
N15278057                                         $$$2074
N15278073                                         $$$3098
N15289456                                         $$$30317
SWAPPED GATE DIFFERENCES
SWAPPED PIN DIFFERENCES
UNMATCHED NET PINS IN OLD DESIGN
DGND                EC5.2
DM1                 DOWN1.2    U1.27
DM2                 DOWN2.2    U1.2
DM3                 DOWN3.2    U1.8
DP1                 U1.28    DOWN1.3
DP2                 DOWN2.3    U1.3
DP3                 DOWN3.3    U1.9
VCC                 EC5.1    F1.2
VCC_USB             F1.1
UNMATCHED NET PINS IN NEW DESIGN
DGND                C6.1    C1.1    C2.1    C3.1    C4.1    C5.1
                    R7.1    R3.1    C8.1    C9.1    C10.1    R5.1    U1.15
                    EC1.2    J1.2    UP1.5    UP1.G1    DOWN4.G1    DOWN3.G1    DOWN2.G1
                    DOWN1.G1    UP1.G2    DOWN4.G2    DOWN3.G2    DOWN2.G2    DOWN1.G2    UP1.G3
                    UP1.G4
DM1                 U1.27
DM2                 U1.2
DM3                 U1.8
DM4                 DOWN3.2    DOWN2.2    DOWN1.2
DP1                 U1.28
DP2                 U1.3
DP3                 U1.9
DP4                 DOWN3.3    DOWN2.3    DOWN1.3
VCC                 F1.1    EC5.2
VCC_USB             F1.2
ATTRIBUTE DIFFERENCES
Attribute Level    [ OLD DESIGN Parent -> NEW DESIGN Parent ]
          Attribute Name           Old Value                New Value
PART    C6 -> C6
          Value                    <no attr>                0.1uF
RULES DIFFERENCES    (Values in mils)
Object Type    Object Name [ OLD DESIGN -> NEW DESIGN ]    Rule Type
          Rule Name                Old Value                New Value
DEFAULT        CLEARANCE
          TRACK_TO_TRACK           <no rule>                6.000000
          VIA_TO_TRACK             <no rule>                6.000000
          VIA_TO_VIA               <no rule>                6.000000
          PAD_TO_TRACK             <no rule>                6.000000
          PAD_TO_VIA               <no rule>                6.000000
          PAD_TO_PAD               <no rule>                6.000000
          SMD_TO_TRACK             <no rule>                6.000000
          SMD_TO_VIA               <no rule>                6.000000
          SMD_TO_PAD               <no rule>                6.000000
          SMD_TO_SMD               <no rule>                6.000000
          COPPER_TO_TRACK          <no rule>                6.000000
          COPPER_TO_VIA            <no rule>                6.000000
          COPPER_TO_PAD            <no rule>                6.000000
          COPPER_TO_SMD            <no rule>                6.000000
          COPPER_TO_COPPER         <no rule>                6.000000
          TEXT_TO_TRACK            <no rule>                6.000000
          TEXT_TO_VIA              <no rule>                6.000000
          TEXT_TO_PAD              <no rule>                6.000000
          TEXT_TO_SMD              <no rule>                6.000000
          OUTLINE_TO_TRACK         <no rule>                6.000000
          OUTLINE_TO_VIA           <no rule>                6.000000
          OUTLINE_TO_PAD           <no rule>                6.000000
          OUTLINE_TO_SMD           <no rule>                6.000000
          OUTLINE_TO_COPPER        <no rule>                6.000000
          DRILL_TO_TRACK           <no rule>                6.000000
          DRILL_TO_VIA             <no rule>                6.000000
          DRILL_TO_PAD             <no rule>                6.000000
          DRILL_TO_SMD             <no rule>                6.000000
          DRILL_TO_COPPER          <no rule>                6.000000
          SAME_NET_SMD_TO_VIA      <no rule>                6.000000
          SAME_NET_SMD_TO_CRN      <no rule>                6.000000
          SAME_NET_VIA_TO_VIA      <no rule>                6.000000
          SAME_NET_PAD_TO_CRN      <no rule>                6.000000
          MIN_TRACK_WIDTH          <no rule>                6.000000
          REC_TRACK_WIDTH          <no rule>                6.000000
          MAX_TRACK_WIDTH          <no rule>                6.000000
          DRILL_TO_DRILL           <no rule>                6.000000
          BODY_TO_BODY             <no rule>                6.000000
          SAME_NET_TRACK_TO_CRN    <no rule>                6.000000
DEFAULT        ROUTING
          LENGTH_MINIMIZATION_TYPE <no rule>                TOTAL
          TRACE_SHARE              <no rule>                ON
          VIA_SHARE                <no rule>                ON
          AUTO_ROUTE               <no rule>                ON
          RIPUP                    <no rule>                ON
          SHOVE                    <no rule>                ON
          ROUTE_PRIORITY           <no rule>                3
          MAX_NUMBER_OF_VIAS       <no rule>                -1
          VALID_LAYER              <no rule>                顶面
          VALID_LAYER              <no rule>                底面
          VALID_VIA_TYPE           <no rule>                *USE_CURRENT*
          SHOVE_PROTECTED          <no rule>                OFF
DEFAULT        HIGH_SPEED
          MIN_LENGTH               <no rule>                0.000000
          MAX_LENGTH               <no rule>                50000.000000
          STUB_LENGTH              <no rule>                0.000000
          PARALLEL_LENGTH          <no rule>                1000.000000
          PARALLEL_GAP             <no rule>                200.000000
          TANDEM_LENGTH            <no rule>                1000.000000
          TANDEM_GAP               <no rule>                200.000000
          MIN_DELAY                <no rule>                0.000000
          MAX_DELAY                <no rule>                10.000000
          MIN_CAPACITANCE          <no rule>                0.000000
          MAX_CAPACITANCE          <no rule>                10.000000
          MIN_IMPEDANCE            <no rule>                50.000000
          MAX_IMPEDANCE            <no rule>                150.000000
          SHIELD_NET               <no rule>                OFF
          SHIELD_GAP               <no rule>                200.000000
          MATCH_LENGTH_TOLERANCE   <no rule>                200.000000
          MATCH_LENGTH             <no rule>                OFF
          AGGRESSOR                <no rule>                OFF
NET CLASS DIFFERENCES
ADDED CLASS NETS
REMOVED CLASS NETS
myfirst.sch (82 KB, 下载次数: 1)
论坛开启做任务可以
额外奖励金币快速赚
积分升级了
