RK3368 挂两个DDR3 4K高清 TVBOX PCB和原理图
论坛上3368 的资料不少。核对了下面圈黄色的稍有不同,才发上来共享。NamePCB DecalValuePart TypeANT2200ANT_JACKANTANT_JACKC2612CAP_DIP7MM5102/2KVCAP_DIP7MM5C2613C0402100NFC0402C2614CAP_DIP7MM5102/2KVCAP_DIP7MM5C2615C1206102/2KVC1206C2616C1206102/2KVC1206CM500MTM-C100UF/16VMTM-CCM2001MTM-C47UF/16VMTM-CCN500CON6_2.54MMNCCON6_2.54MMD500SOT_23BAT54CSOT_23D501SOD1231N4148WSOD123D1100ESD0402ESD5451NESD0402D1101ESD0402ESD5451NESD0402D2100SOD1231N5819SOD123D2101SOD1231N5819SOD123D2300ESD0402ESD5471XESD0402D2301ESD0402ESD5471XESD0402D2302ESD0402ESD5471XESD0402D2303ESD0402ESD5471XESD0402D2304ESD0402ESD5471XESD0402D2305ESD0402ESD5471XESD0402D2306ESD0402ESD5471XESD0402D2500SOT_23BAT54SSOT_23D2501ESD0402ESD5451NESD0402D2502ESD0402ESD5451NESD0402ED2100ESD0402ESD5471XESD0402ED2101ESD0402ESD5471XESD0402ED2102ESD0402ESD5471XESD0402ED2103ESD0402ESD5471XESD0402F500R12060RR1206F2000R08050RR0805H500H3.4MMH3.8MMH3.8MMH501H3.4MMH3.8MMH3.8MMIR500TO92ECBIRM-3638TO92ECBJ500DC36-DDC-208DC36-DJ501XH-2-2_54NC/XH-2-2_54XH-2-2_54J502DC3P-5VNC/DC-002DC3P-5VJ503CON4_2.54NC/CON4_2.54CON4_2.54J504LED-DIPLEDLED-DIPJ2100HDMI_DIPHDMI_AHDMI_DIPJ2300CON_10PIN_1.25CON_10PIN_1.25CON_10PIN_1.25J2500AV3-DAV_CONNECTORAV3-DJP2600RJ45-DRJ45SRJ45-DL500IND3X3A0.24UHIND3X3L501IND3X31UHIND3X3L502IND3X33.3UHIND3X3L503IND3X33.3UHIND3X3L700L0603180R-100ML0603L701L0603180R-100ML0603L800L0603180R-100ML0603L2000L0603D90R-100ML0603DL2001L0603D90R-100ML0603DL2200IND3X33.3UHIND3X3L2201L0603180R-100ML0603L2202L04022.7NHL0402L2500L0603180NHL0603L2600L0603180R-100ML0603M500MARKMARKMARKM501MARKMARKMARKM502MARKMARKMARKM503MARKMARKMARKM504MARKMARKMARKM505MARKMARKMARKQ500SOT_23S8050SOT_23Q501SOT_23S8050SOT_23Q502SOT_23S8050SOT_23Q503SOT_23S8050SOT_23Q505SOT_23WPM3407-3/TRSOT_23Q700SOT238050SOT23Q2100SOT_323WNM2021-3/TRSOT_323Q2101SOT_323WNM2021-3/TRSOT_323Q2102SOT_323WNM2021-3/TRSOT_323Q2300SOT_23WPM2015-3/TRSOT_23SW1100TS-019RECOVERTS-019SW1102SW4-SKQG-5_2X5_2H1_5BRECOVER1SW4-SKQG-5_2X5_2H1_5BU500SOP8ZQ2996SOP8U501SOT_23_5TT2102SOT_23_5U502WLCSP-20SYR827WLCSP-20U503DFN8_2R00X2R00X0R80_TETA3451D21DFN8_2R00X2R00X0R80_TU504SOT_23_5ETA3486SOT_23_5U505SOT_23_5PT5108E23E-18SOT_23_5U506SOT_23_5ETA3486SOT_23_5U507SOT_23_5TT2102SOT_23_5U508SOT_23_5TT2102SOT_23_5U509SOT_23_5PT5108E23E-33SOT_23_5U510SOT_23_5PT5108E23E-18SOT_23_5U511ROCKCHIPSRK_LOGOROCKCHIPSU512SOT_23CE8809C263MASOT_23U513MSOP8_3R00X3R00X1R10HYM8563MSOP8_3R00X3R00X1R10U515SOT_23ME082SOT_23U600BGA453_19R00X19R00X1R40RK3368BGA453_19R00X19R00X1R40U700SOT35374LVC1G04/NC7SZ04SOT353U1600FBGA96_14R00X11R00X1R20K4B4G1646QFBGA96_14R00X11R00X1R20U1601FBGA96_14R00X11R00X1R20K4B4G1646QFBGA96_14R00X11R00X1R20U1700SOT_23_5PT5108E23E-18SOT_23_5U1800BGA169_18R00X14R00X1R20KLMAG2GEAC-B031BGA169_18R00X14R00X1R20U1900TSOP48_18R40X12R10X1R20H27UBG8T2DTR-BCTSOP48_18R40X12R10X1R20U2001SOT_23ESD5302FSOT_23U2002SOT_23_5SY6280AACSOT_23_5U2003SOT_23ESD5302FSOT_23U2200SOT_23_6NL27WZU04SOT_23_6U2201AP6XXXRTL8189ETVAP6XXXU2500RK1000QUAD64RK1000-SRK1000QUAD64U2501TSSOP14-0.65MMTPF632TSSOP14-0.65MMU2600QFN40_58DP83848NQFN40_58U2601SOIC16HR601680SOIC16USB2000USB_BUSBDIP90CEUSB_BUSB2001USB_BUSBDIP90CEUSB_BY500CRY2_6R90X1R40X1R3032.768KHZCRY2_6R90X1R40X1R30Y700CRY4_3R20X2R50X0R8024MHZCRY4_3R20X2R50X0R80Y2200CRY4_3R20X2R50X0R8026MHZCRY4_3R20X2R50X0R80 PCB和原理图一起打包。回复可见
**** Hidden Message ***** 看看 可以可以 可以可以
