sii9000 发表于 2018-2-6 12:47
PCIMX7D7DVM10SA 开发板封装库整套-ALLEGRO格式
有以下主要封装,有需要的下载提取
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1LED_LED0805__GREENGreenLED0805D2LED_LED0805__REDREDLED0805D3DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123D4DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123D5LED_LED0805__ORGORGLED0805D6LED_LED0805__GREENGreenLED0805D7LED_LED0805__REDREDLED0805D12LED_LED0805__LEDLEDLED0805D13LED_LED0805__LEDLEDLED0805D14BAT54A_SOT323__BAT54ABAT54ASOT323D15BAT54A_SOT323__BAT54ABAT54ASOT323D16DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123D17ZDIODE_SOD523__MM5Z5V1ST1GMM5Z5V1ST1GSOD523D20DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123D24BAT54A_SOT323__BAT54ABAT54ASOT323D25DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123D26DIODE_SCHTKY_0_SOD123__1N5819HW1N5819HW-7-FSOD123F1FUSE_F1206__FUSEFUSEF1206FL1TDK_FILTER_DEA20_1_LFB0603_4_3_LFB182G45SG9A272LFB0603_4_3J1DC POWERJACK_1_DCJ140X90P3__COCONN_DCPOWERDCJ140X90P3J2CONN_HDR_2X1_CON2B60X50P20__CONCONN_BATINCON2B60X50P20J3RTC_1_BATS4P75D150L_CONN_BATCONN_BATBATS4P75D150LJ6SD_CARD_1_SD11_6B280X180_CONN_SCONN_SDSD11_6B280X180J7SIMCARD_0_SIMCARD6B163X157_CONCONN_SIMSIMCARD6B163X157J8MINIPCIE_1_PCIEMINIS52_2_2P8_CCONN_PCIePCIEMINIS52_2_2P8J9CON20_0_HDMIS19_4P5_CONN_HDMICONN_HDMIHDMIS19_4P5J10CONN_UFL_0_ANTS3L_CONN_COAXIALCONN_CoaxialANTS3LJ11UART-DEBUG_UART-DEBUG_UART-DEBUUART-DEBUGUART-DEBUGJ12H10_SMT_0_HS2X5_2JZ_CONN_JTAGCONN_JTAGHS2X5_2JZJ13UART-DEBUG_UART-DEBUG_UART-DEBUUART-DEBUGUART-DEBUGJ15VAF5-1908_6_AUDIO5_CONN_HPCONN_HPAUDIO5J16VAF5-1908_6_AUDIO5_CONN_MICCONN_MICAUDIO5J17CONN_HDR_4X1_H4M__CONN_SPEAKERCONN_SPEAKERH4MJ18FPC14_FPC14_2W23P5_CONN_SMARTCACONN_SMARTCARDFPC14_2W23P5J19DB9_DB2M9_2_CONN_CANCONN_CANDB2M9_2J20HEADER5_2_H2X5MY_CONN_MFICONN_MFIH2X5MYJ22HEADER5_1_HS2X4_2MZ_CONN_ADCCONN_ADCHS2X4_2MZJ25USB_MICRO_1_USBMICRO5_6A__CONN_CONN_USBUSBMICRO5_6AJ26USB_A_USB4_4AS_CONN_USBCONN_USBUSB4_4ASJ2748F-01GY2DPL2NL_2_RJ45_48F-01GYCONN_RJ45RJ45_48F-01GY_P14_4J2848F-01GY2DPL2NL_4_RJ45_48F-01GYCONN_RJ45RJ45_48F-01GY_P14_4J29FPC15_15_FPC2X15_4P4_A_CONN_CSICONN_CSIFPC2X15_4P4_AJ30FPC15_6_FPC2X12_0P4_CONN_DSICONN_DSIFPC2X12_0P4J31HDR2X10_HS2X10_2JZ_CONN_TAMPERCONN_TAMPERHS2X10_2JZL1PINDUCTOR_L66X66__2.2UH2.2uHL66X66L2PINDUCTOR_L66X66__2.2UH2.2uHL66X66L3PINDUCTOR_L25X20__1.5UH1.5uHL25X20L4PINDUCTOR_L25X20__1.5UH1.5uHL25X20L5PINDUCTOR_L25X20__1.5UH1.5uHL25X20L6PINDUCTOR_L25X20__2.2UH2.2uHL25X20L7PINDUCTOR_L25X20__1.5UH1.5uHL25X20L8IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L100504CHOKEWCM-2012-900TCKS4B14X20WL11IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L12IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L13IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L14IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L15IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L16INDUCTOR_L0402_1NH1nHL0402L17INDUCTOR_L0402_1NH1nHL0402L18PINDUCTOR_L1008__2.2UH2.2uHL1008L400504CHOKEWCM-2012-900TCKS4B14X20WL410504CHOKEWCM-2012-900TCKS4B14X20WL42IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L43IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L44PINDUCTOR_L0805__4.7UH4.7uHL0805L54PINDUCTOR_L0805__4.7UH4.7uHL0805L55INDUCTOR_L0402_1NH1nHL0402L56INDUCTOR_L0402_1NH1nHL0402L57IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L58IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L590504CHOKEWCM-2012-900TCKS4B14X20WL600504CHOKEWCM-2012-900TCKS4B14X20WL610504CHOKEWCM-2012-900TCKS4B14X20WL620504CHOKEWCM-2012-900TCKS4B14X20WL63IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L64IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L65IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L66IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402L67PINDUCTOR_L1008__2.2UH2.2uHL1008L68IND_L0402__120OHM@100MHZ120 OHM@100MHZL0402MG1MGX_2_MHS230D134_MGXMGXMHS230D134MG2MGX_2_MHS230D134_MGXMGXMHS230D134MG3MGX_2_MHS230D134_MGXMGXMHS230D134MG4MGX_2_MHS230D134_MGXMGXMHS230D134Q2AO4447A_4_DFN8FR_AON3419AON3419DFN8FRQ5MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q6MOSFET_P_0_SOT23_123_AO3407AAO3407ASOT23_123Q7MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q8MM3904_2_SOT23_123_MMBT3904MMBT3904SOT23_123Q10MOSFET_P_0_SOT23_123_AO3407AAO3407ASOT23_123Q16MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q172N1132_1_SOT23_123_MMBT2907MMBT2907SOT23_123Q21MOSFET_P_0_SOT23_123_AO3407AAO3407ASOT23_123Q24MOSFET_P_0_SOT23_123_AO3407AAO3407ASOT23_123Q25MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q29MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q30MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q31MOSFET_N_0_SOT23_123_2N70022N7002SOT23_123Q32AO4447A_4_DFN8FR_AON3419AON3419DFN8FRQ34AO4447A_4_DFN8FR_AON3419AON3419DFN8FRQ35BCM8576BS_2_SOT363_6_BCM857BSBCM857BSSOT363_6Q36MOSFET_N_0_SOT23_123_DMN2005K-7DMN2005K-7SOT23_123RN23RESARRAY_8P4R0402_10K10K8P4R0402S1SWPUSHBUTTON_0_SWS4B60S_B3S-10B3S-1000SWS4B60SS2SWPUSHBUTTON_0_SWS4B60S_B3S-10B3S-1000SWS4B60SS3SWPUSHBUTTON_0_SWS4B60S_B3S-10B3S-1000SWS4B60SS4SWPUSHBUTTON_0_SWS4B60S_B3S-10B3S-1000SWS4B60SSW1SW3_RA_SLIDE_0_SW5B87X45S__SS-1SS-12D01VG2-566SW5B87X45SSW2SW_DIP_8_SWS16JV__DSHP08TSGERDSHP08TSGERSWS16JVSW3SWDIP-2/SM_SWS4JV_GDH02S04GDH02S04SWS4JVTVS6DIODE_TVS_BIDIR_D0402__B72590D0B72590D0050H160D0402U2RT8070ZSP_1_SOP8_1JA_RT8070ZSPRT8070ZSPSOP8_1JAU3RT8070ZSP_1_SOP8_1JA_RT8070ZSPRT8070ZSPSOP8_1JAU4PC32PF3000A1EP_QFN48_1P5B_PC32PPC32PF3000A1EPQFN48_1P5BU7PCIMX7D7DVM10SA_541BGA_V2_BGA54PCIMX7D7DVM10SA_541BGA_V2BGA541XU82G_DDR3_SDRAM_128MX16_3_BGADDR9MT41K256M16HA-125BGADDR96P8B90X130U92G_DDR3_SDRAM_128MX16_3_BGADDR9MT41K256M16HA-125BGADDR96P8B90X130U10EMMC_V5_BGA153P5_MTFC8GACAEAM-1MTFC8GACAEAM-1M WTBGA153P5U13SIL9022A_0_QFN72_1P5C_SII9022ACSiI9022ACNUQFN72_1P5CU14TPS79912YZU_SOT23_5_ME6211C12M5ME6211C12M5GSOT23_5U15CM2020_TSSOP38P5A_CM2020-00TRCM2020-00TRTSSOP38P5AU16LBEH5HMZPC_MODULE58_6P45_(S1+S2LBEH5HMZPC-TEMPMODULE58_6P45U20FXAS21002_0_QFNASY24P5M_FXAS210FXAS21002CQR1QFNASY24P5MU21FXOS8700CQ_1_QFNASY16P5R_FXOS87FXOS8700CQR1QFNASY16P5RU22MPL3115A2_LGA8IR_MPL3115A2MPL3115A2LGA8IRU24WM8960_QFN_33P_QFN32_1P5H__WM89WM8960CGEFL/VQFN32_1P5HU25MC33901WEF_SOIC8JA_MC33901WEFMC33901WEFSOIC8JAU27USBLC6_0_SOT23_6TR_USBLC6-2SC6YUSBLC6-2SC6YSOT23_6TRU28USBLC6_0_SOT23_6TR_USBLC6-2SC6YUSBLC6-2SC6YSOT23_6TRU30SP2526A-2_2_SOIC8JA_SP2526A-1ENSP2526A-1EN-LSOIC8JAU31BCM54220_1_BGA144P10_BCM54220B0BCM54220B0KFBGBGA144P10U33TPS79912YZU_SOT23_5_ME6211C18M5ME6211C18M5GSOT23_5U35TPS73701DRB_QFN8_4_1FR_TPS73701TPS73701DRBQFN8_4_1FRU37TPS3808_SOT23_6TR_TPS3808G30DBVTPS3808G30DBVTSOT23_6TRU4124AA512-I/SN_SOIC8JA_24AA512-I/24AA512-I/SNSOIC8JAU429FGV0241AKLF_3_QFN24_1P5M_IC_PIPI6CFGL201BZDIEXQFN24_1P5MU43TPS3808_4_TSOP12P5R_AAT1239ITP-AAT1239ITP-1-T1TSOP12P5RU44TPS3808_6_SOT23_5_TLV73310PDBVTTLV73310PDBVTSOT23_5U45NT3H1101W0FHK_4_SSOP8CR_TXS0102TXS0102DCURSSOP8CRX1SG615/SM_X4S32X25_32.768KHZ32.768KHzX4S32X25X2SG615/SM_X4S32X25_32.768KHZ32.768KHzX4S32X25X3SG615/SM_X4S32X25_32.768KHZ32.768KHzX4S32X25X4SG615/SM_X4S32X25_24MHZ24MHzX4S32X25Y1CRYSTAL_4_X2S32X15_CM7V-T1ACM7V-T1AX2S32X15Y2CRYSTAL_4_X2S50X32_5XBB240002025XBB24000202TF50Q3X2S50X32Y3CRYSTAL13_X4S32X25_DISCRETE_25M25MHZX4S32X25Y8CRYSTAL_0_X2S50X32_5XBB250002025XBB25000202TF40Q3X2S50X32
sii9000 发表于 2018-2-6 12:48
单枪舞九州 发表于 2018-2-7 06:57
支持
worldof422 发表于 2018-2-7 13:41
nt_lin 发表于 2019-1-15 17:52
下载来学习一下
查看完整版本: PCIMX7D7DVM10SA 开发板封装库整套-ALLEGRO格式
