强哥哥 发表于 2018-2-27 10:45
刚学orcad请问报这种错是什么问题呀好着急
{ Using PSTWRITER 16.6.0 d001Feb-27-2018 at 10:20:22 }
#1 ERROR(ORCAP-36036): Multiple pin H18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
Check for incorrect packaging of all devices in U8.
#2 ERROR(ORCAP-36036): Multiple pin J19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#3 ERROR(ORCAP-36036): Multiple pin G18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#4 ERROR(ORCAP-36036): Multiple pin E19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#5 ERROR(ORCAP-36036): Multiple pin B21's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#6 ERROR(ORCAP-36036): Multiple pin D4's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#7 ERROR(ORCAP-36036): Multiple pin G19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#8 ERROR(ORCAP-36036): Multiple pin J17's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#9 ERROR(ORCAP-36036): Multiple pin J20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#10 ERROR(ORCAP-36036): Multiple pin H19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#11 ERROR(ORCAP-36036): Multiple pin K20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#12 ERROR(ORCAP-36036): Multiple pin H21's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#13 ERROR(ORCAP-36036): Multiple pin F20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#14 ERROR(ORCAP-36036): Multiple pin F19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#15 ERROR(ORCAP-36036): Multiple pin E20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#16 ERROR(ORCAP-36036): Multiple pin D21's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#17 ERROR(ORCAP-36036): Multiple pin A5's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#18 ERROR(ORCAP-36036): Multiple pin J18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#19 ERROR(ORCAP-36036): Multiple pin H17's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#20 ERROR(ORCAP-36036): Multiple pin F21's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#21 ERROR(ORCAP-36036): Multiple pin E18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#22 ERROR(ORCAP-36036): Multiple pin F18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#23 ERROR(ORCAP-36036): Multiple pin D3's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#24 ERROR(ORCAP-36036): Multiple pin G20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#25 ERROR(ORCAP-36036): Multiple pin K18's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#26 ERROR(ORCAP-36036): Multiple pin K19's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#27 ERROR(ORCAP-36036): Multiple pin H20's which have different nets connected for U8: PTV-8698(HI3798MV300+2+8), 08_Unit 3_FE PHY_SDIO (121.92, 40.13).
#28 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
梦想舞台ggg 发表于 2018-2-27 16:35
是不是软件没有安装好哦
mingli1998 发表于 2018-2-28 09:04
scalewing 发表于 2018-3-1 09:00
应该是器件含有同名引脚吧,吧同名引脚改一下就好了。
jolly 发表于 2018-3-2 09:15
似水流年 发表于 2018-3-4 11:53
柯云 发表于 2018-3-5 22:35
是不是软件没有安装好
柯云 发表于 2018-3-5 22:36
tobyzhang 发表于 2018-3-8 09:15
是不是U8器件有问题
sopple 发表于 2018-3-8 09:23
器件symble有问题,有重复的引脚
查看完整版本: 刚学orcad请问报这种错是什么问题呀好着急
