老吴 发表于 2018-3-15 17:21
IMX6Q+TW8836AT+DS90UB947-Q1+USB2517i+FM1288GA1+BD37033FV 主板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BAT-1220_CR1220_CR1220CR1220CR1220BZ1TMB12A_BUZZER2-300_TMB12ATMB12ABUZZER2-300D1LED_SD0805A_GLEDGLEDSD0805AD2LED_SD0805A_GLEDGLEDSD0805AD3SMAJ15CA_TVS-SMA_SMAJ6.0ASMAJ6.0ATVS-SMAD4DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D5DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D6DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D7DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D8SMAJ15CA_TVS-SMA_SMAJ6.0ASMAJ6.0ATVS-SMAD9DIODE TVSBI-DIR_TVS-SOD-523_AZAZ5125-01/NCTVS-SOD-523D10DIODE TVSBI-DIR_TVS-SOD-523_AZAZ5125-01/NCTVS-SOD-523D11SMAJ15CA_TVS-SMA_SMAJ6.0ASMAJ6.0ATVS-SMAD12DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D13DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D14DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D15DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D16DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D17DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D18SM712_0_SOT23-1_SM712SM712SOT23-1D19SM712_0_SOT23-1_SM712SM712SOT23-1D20SM712_0_SOT23-1_SM712SM712SOT23-1D21DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D22DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D23DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D24DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D25DIODE TVSBI-DIR_SOD-323_SD12CSD12CSOD-323D26DIODE_1_TVS-SMB_SM5821BSM5821BTVS-SMBD27DIODE_1_SOD-323_PMEG3020EJPMEG3020EJSOD-323D28SMAJ15CA_0_TVS-SMC_SMDJ28CASMDJ28CATVS-SMCD29DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D30DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D31SMAJ15CA_TVS-SMA_SMAJ6.0ASMAJ6.0ATVS-SMAD32DIODE_1_TVS-SMB_B360B360TVS-SMBD33DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523D34DIODE TVSBI-DIR_TVS-SOD-523__1AZ5125-01TVS-SOD-523FB1B0603-120R/100MHZ_SL0603_120OH120 OHM/2A@100MHzSL0603FB2INDUCTOR_SL0805_120OHM/3A@100M120 OHM/3A@100MHzSL0805FB3INDUCTOR_SL0805_120OHM/3A@100M120 OHM/3A@100MHzSL0805FB5INDUCTOR_SL0805_120OHM/3A@100M120 OHM/3A@100MHzSL0805FB6INDUCTOR_SL0805_120OHM/3A@100M120 OHM/3A@100MHzSL0805FB7INDUCTORBEAD_SL0805_120 OHM/3A120 OHM/3A@100MHzSL0805FB8INDUCTORBEAD_SL0805_120 OHM/3A120 OHM/3A@100MHzSL0805FB9FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB10FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB11INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FB13INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FB14INDUCTOR_2_SL0603_120OHM/2A@10120 OHM/2A@100MHzSL0603FB15INDUCTOR_SL0402_BLM15HD102SN1BLM15HD102SN1SL0402FB16INDUCTOR_SL0402_BLM15HD102SN1BLM15HD102SN1SL0402FB17FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB18FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB19FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB20FB,120OHM,2A,25%,0603,0.05DC_147 OHM/0.5A@100MHzSL0603FB21FB,120OHM,2A,25%,0603,0.05DC_147 OHM/0.5A@100MHzSL0603FB22FB,120OHM,2A,25%,0603,0.05DC_147 OHM/0.5A@100MHzSL0603FB23FB,120OHM,2A,25%,0603,0.05DC_147 OHM/0.5A@100MHzSL0603FB24FB,120OHM,2A,25%,0603,0.05DC_147 OHM/0.5A@100MHzSL0603FB36FB,120OHM,2A,25%,0603,0.05DC_21K OHM/2A@100MHzSL0603FB37FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB38FB,120OHM,2A,25%,0603,0.05DC_21K OHM/2A@100MHzSL0603FB39FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB40FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB41INDUCTOR_SL0603_1KOHM/2A@100MH1K OHM/2A@100MHzSL0603FB42INDUCTOR_SL0603_1KOHM/2A@100MH1K OHM/2A@100MHzSL0603FB43INDUCTOR_SL0603_1KOHM/2A@100MH1K OHM/2A@100MHzSL0603FB44INDUCTOR_SL0603_1KOHM/2A@100MH1K OHM/2A@100MHzSL0603FB45INDUCTOR_SL0603_1KOHM/2A@100MH1K OHM/2A@100MHzSL0603FB46FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHzSL0603FB47INDUCTOR_SL0805_120OHM/3A@100M120 OHM/3A@100MHzSL0805FB48INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FB49FB,120OHM,2A,25%,0603,0.05DC_3120 OHM/3A@100MHzSL0805FB50FB,120OHM,2A,25%,0603,0.05DC_3120 OHM/3A@100MHzSL0805FB51FB,120OHM,2A,25%,0603,0.05DC_4120 OHM/3A@100MHz/NCSL0805FB52FB,120OHM,2A,25%,0603,0.05DC_4120 OHM/3A@100MHz/NCSL0805FB53INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FB54INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FB55INDUCTOR_SL0603_120OHM/2A@10_1120 OHM/2A@100MHz/NCSL0603FB58FB,120OHM,2A,25%,0603,0.05DC_4120 OHM/3A@100MHz/NCSL0805FB59FB,120OHM,2A,25%,0603,0.05DC_3120 OHM/3A@100MHzSL0805FB60FB,120OHM,2A,25%,0603,0.05DC_5120 OHM/2A@100MHz/NCSL0603FB63INDUCTOR_SL0603_120OHM/2A@100M120 OHM/2A@100MHzSL0603FM1MARK_MARK_MARKmarkMARKFM2MARK_MARK_MARKmarkMARKFM3MARK_MARK_MARKmarkMARKFM4MARK_MARK_MARKmarkMARKJ1CON4A_IDC4-80-240_SMD_IDC4_2.0_IDC4_2.0_SMDIDC4-80-240_SMDJ3CON6A_IDC6-80-240_SMD_IDC6_2.0_IDC6_2.0_SMDIDC6-80-240_SMDJ4CON8A_IDC8-80-240_SMD_IDC8_2.0_IDC8_2.0_SMDIDC8-80-240_SMDJ5CON8A_IDC8-80-240_SMD_IDC8_2.0_IDC8_2.0_SMDIDC8-80-240_SMDJ6CAM-K23HN_HSD4_0_CAM-K23HNCAM-K23HNHSD4_0J7CAM-K23HN_HSD4_0_CAM-K23HNCAM-K23HNHSD4_0J8CON3_CON3-80-314X296_CON3_2.0/NCON3_2.0/NCCON3-80-314X296J9CON16A_IDC-16-100-100-200_IDC16IDC16_2.54IDC-16-100-100-200J10CON40A_IDC40-80-240_SMD_IDC40_2IDC40_2.0_SMDIDC40-80-240_SMDJ11CON40A_IDC40-80-240_SMD_IDC40_2IDC40_2.0_SMDIDC40-80-240_SMDJ12CON10A_7_ISO_18_ISO_18ISO_18ISO_18J13ISO_9_ISO_36_ISO_36ISO_36ISO_36J14ISO_3_ISO_26_ISO_26ISO_26ISO_26J15CAM-K23HN_HSD4_0_CAM-K23HNCAM-K23HNHSD4_0L1IND_CDRH2-200-287X271_JSHC0650HJSHC0650H-100M-GCDRH2-200-287X271L2IND_CDRH2-200-287X271_JSHC065_1JSHC0650H-150M-GCDRH2-200-287X271L3IND_CDRH2-200-287X271_JSHC0650HJSHC0650H-100M-GCDRH2-200-287X271L4IND_CDRH2-200-287X271_JSHC0650HJSHC0650H-100M-GCDRH2-200-287X271L5LDPC0624H-2R2_CDRH2-200-287X271JSHC0650H-1R5M-GCDRH2-200-287X271L6LDPC0624H-2R2_CDRH2-200-287X2_1JSHC0650H-1R0M-GCDRH2-200-287X271L7LDPC0624H-2R2_CDRH2-200-287X2_1JSHC0650H-1R0M-GCDRH2-200-287X271L8LDPC0624H-2R2_CDRH2-200-287X2_1JSHC0650H-1R0M-GCDRH2-200-287X271L38IND_CDRH2-200-287X271_JSHC0650HJSHC0650H-100M-GCDRH2-200-287X271L39IND_CDRH2-0420_JSHC0420H-1R0M-GJSHC0420H-1R0M-GCDRH2-0420L40LDPC0624H-2R2_LOOP2-355-858X434100uH/5ALOOP2-355-858X434L41DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2L42IND_CDRH2-200-287X271_JSHC065_1JSHC0650H-150M-GCDRH2-200-287X271M1CON1_COPCON130_CON1CON1COPCON130M2CON1_COPCON130_CON1CON1COPCON130M3CON1_COPCON130_CON1CON1COPCON130M4CON1_COPCON130_CON1CON1COPCON130Q1NPN-BEC_0_SOT23-1_MMBT3904MMBT3904SOT23-1Q2Q_NPN_SOT23-1_MMBT3904MMBT3904SOT23-1Q3Q_NPN_SOT23-1_MMBT3904MMBT3904SOT23-1Q4Q_NPN_SOT23-1_MMBT3904MMBT3904SOT23-1Q5REFAO3400SOT23-1Q6Q_NPN_SOT23-1_MMBT3904MMBT3904SOT23-1Q7Q_PMOS_SOT23-1_AO3401AAO3401ASOT23-1Q8Q_PMOS_SOT23-1_AO3401AAO3401ASOT23-1Q9BC847AE6327MMBT3904SOT23-1Q10BC847AE6327MMBT3904SOT23-1Q11BC847AE6327MMBT3904SOT23-1Q12Q_PMOS_SOT23-1_AO3401AAO3401ASOT23-1SW1SWITCH_SW4-180X180_SWITCHSWITCHSW4-180X180U1PCIMX6Q5EVT10AA_BGA624_0P8_21X2PCIMX6Q5EVT10AABGA624_0P8_21X21U2MT41J256M16_BGA96_0P8_8P15X14P1MT41K128M16JT-125IT:KBGA96_0P8_8P15X14P15U3MT41J256M16_BGA96_0P8_8P15X14P1MT41K128M16JT-125IT:KBGA96_0P8_8P15X14P15U4MT41J256M16_BGA96_0P8_8P15X14P1MT41K128M16JT-125IT:KBGA96_0P8_8P15X14P15U5MT41J256M16_BGA96_0P8_8P15X14P1MT41K128M16JT-125IT:KBGA96_0P8_8P15X14P15U6THGBM5G5A1JBAIR_BGA169_0P5_12X1THGBM5G5A1JBAIRBGA169_0P5_12X16U7MP1482-SO8H_1_SOP9-50-150_MP230MP2303DNSOP9-50-150U8MP1482-SO8H_1_SOP9-50-150_MP230MP2303DNSOP9-50-150U9MP1482-SO8H_3_SOP9-50-150_MP230MP2303DNSOP9-50-150U10MP1482-SO8H_1_SOP9-50-150_MP230MP2303DNSOP9-50-150U11ISL8024AIRTAJZ_3_QFN17-20-124X1ISL8024AIRTAJZQFN17-20-124X124U12ISL8024AIRTAJZ_3_QFN17-20-124X1ISL8024AIRTAJZQFN17-20-124X124U13ISL8024AIRTAJZ_3_QFN17-20-124X1ISL8024AIRTAJZQFN17-20-124X124U14ISL8024AIRTAJZ_3_QFN17-20-124X1ISL8024AIRTAJZQFN17-20-124X124U15NVP6114A_1_QFN77-16-360X360_NVPNVP6134CQFN77-16-360X360U16USB2517_QFN64USB2517i-JZXQFN64-20-360X360U1724C64_SO-8_24C64/NC24C64/NCSO-8U19FXAS21002CQR1_0_FXAS21002_FXAS2FXAS21002CQR1FXAS21002U20FXLS8471QR1_0_QFN16-20-120X120_FXOS8700CQR1QFN16-20-120X120U21MPL3115A2_1_SOP8-50-200X120_MPLMPL3115A2SOP8-50-200X120U22SHA204A_SOP8-50-150_AHSHA204A/NAHSHA204A/NCSOP8-50-150U23ZT3232LEEN_0_SOP16-50-150_ZT323ZT3232LEENSOP16-50-150U24TLP521_SOP4-50-173_TLP291_1GBTLP291_1GBSOP4-50-173U25TLP521_SOP4-50-173_TLP291_1GBTLP291_1GBSOP4-50-173U26TLP521_SOP4-50-173_TLP291_1GBTLP291_1GBSOP4-50-173U27TJA1042T/3_SOP8-50-150_TJA1042TTJA1042T/3SOP8-50-150U28TJA1042T/3_SOP8-50-150_TJA1042TTJA1042T/3SOP8-50-150U29TJA1042T/3_SOP8-50-150_TJA1042TTJA1042T/3SOP8-50-150U3024C64_SO-8_24C64/NC24C64/NCSO-8U31FM1288_QFP48-050-0707L_FM1288GAFM1288GA1-410QFP48-050-0707LU32MIC5219BM5_SOT23-5_MIC5319-1.8VMIC5319-1.8VSOT23-5U33MIC5219BM5_SOT23-5_MIC5319-1.8VMIC5319-1.8VSOT23-5U34TLV320AIC3268_0_QFN65-20-360X36TLV320AIC3268IRGCRQFN65-20-360X360U35TDA7850_2_TDA7850-V_TDA7850TDA7850TDA7850-VU36BD37033FV-M_0_SOP28-26-208_BD37BD37033FV-MSOP28-26-208U37CH7107B_1_QFN41-16-200X200_CH71CH7107BQFN41-16-200X200U38MP20051DN_1_SOP9-50-150_MP20051MP20051DNSOP9-50-150U39TW8836-LA1-CE_0_QFP128-20-640X6TW8836AT-LB2-GEQFP128-20-640X640U40N25Q032_0_SOP8-50-150_MX25L1606MX25L1606EM1I-12GSOP8-50-150U41IL1117-1.8ET_SOT223_IL1117-1.8IL1117-1.8SOT223U42DS90UB947-Q1_0_QFN65-20-360X360DS90UB947-Q1QFN65-20-360X360-SERU431T45_0_SOP6-26-55_74LVC1T45/NC74LVC1T45/NCSOP6-26-55U441T45_0_SOP6-26-55_74LVC1T4574LVC1T45SOP6-26-55U45MIC5219BM5_SOT23-5_MIC5319-1.8VMIC5319-1.8VSOT23-5U46MP20051DN_1_SOP9-50-150_MP20051MP20051DNSOP9-50-150U47DS90UR907Q_0_QFN37-20-240X240_DDS90UR907QSQQFN37-20-240X240U48MIC5219BM5_SOT23-5_MIC5319-1.8VMIC5319-1.8VSOT23-5U49TPS25940-Q1_6_QFN21-20-160X120_TPS25940-Q1QFN21-20-160X120U50MP1482-SO8H_1_SOP9-50-150_MP230MP2303DNSOP9-50-150U51TPS63060DSC_3_TPS63060_TPS63060TPS63060DSCTPS63060U52IL1117-1.8ET_SOT223_IL1117-3.3IL1117-3.3SOT223U53STM32F105RCT7V_2_QFP64-050-1010STM32F105RCT7VQFP64-050-1010LU54SP706S_SOP8-50-150_SP706SSP706SSOP8-50-150U55DS3231-M_SOP8-50-150_DS3231MZ+DS3231MZ+SOP8-50-150U56BAT54C_SOT23-1_BAT54CBAT54CSOT23-1U57TXB0102_0_SOP20-20-208X170_TXS0TXS0108ERGYRSOP20-20-208X170U58E52241B62C_QFN21-25-200X200_E52E52241B62CQFN21-25-200X200X1XTAL4-5032-24MHZ/20PF_XTAL4-50324MHz/20ppm/18pFXTAL4-5032X2CRYSTAL_CT3215_IC_32.768KHZ/20P32.768KHz/20ppm/12.5pFCT3215X3XTAL4-5032-24MHZ/20PF_XTAL4-50324MHz/20ppm/18pFXTAL4-5032X4XTAL4-5032-24MHZ/20PF_XTAL4-5_118.432MHz/30ppm/16pFXTAL4-5032X5XTAL4-5032-24MHZ/20PF_XTAL4-5_227MHz/20ppm/18pFXTAL4-5032X6CRYSTAL_1_XTAL-2-200-A_27MHZ/1027MHz/10ppm/20pFXTAL-2-200-AX7CRYSTAL_CT3215_IC_32.768KHZ/2_132.768KHz/20ppm/6pFCT3215X8XTAL4-5032-24MHZ/20PF_XTAL4-5_38MHz/20ppm/18pFXTAL4-5032Y1OSC4-7050-24MHZ/3.3V_XTAL4-503227MHz-3.3VXTAL4-5032
老吴 发表于 2018-3-15 17:23
PCB文件共享,回复可见
**** Hidden Message *****
yangjing29 发表于 2018-3-15 17:32
这图看着就强悍
yhgwork 发表于 2018-3-15 19:16
功能强大的IMX6
linyuanfei 发表于 2018-3-15 19:52
强悍
ilpuyi 发表于 2018-3-15 22:30
ntpcbyanli4111 发表于 2018-3-15 22:46
allegro_wh 发表于 2018-3-15 22:51
wcjcn 发表于 2018-3-16 00:32
谢谢坛主分享的好资源。
晨曦37 发表于 2018-3-16 08:24
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: IMX6Q+TW8836AT+DS90UB947-Q1+USB2517i+FM1288GA1+BD37033FV 主板PCB文件共享
