sisi9000 发表于 2018-4-22 22:29
UPD61214F1+PAM0140BYC+RDA5815S+SGM809-RXN3 做的机顶盒PCB --没画完
NamePCB DecalValuePart TypeCN1CON-4/2MM-904PIN/2.0MMCON-4CON1CON-7/2MMCON-7/2.0MMCON-7CON2CON-D10/2.5MMNC/CON-D10/2.5MMCON-10CON3CON-D10/2.5MMNC/CON-D10/2.5MMCON-10CON7CON-12/2MMCON-12/2MMCON-12CON10CON-2/2.5MMCON-2/2.5MMCON-2D1DIO-1210LL4007DIODED2DIO-12100RDIODED18SOD523RB521S30DIODE_SCHOTTKYD20DIO-1210NC/LL4007DIODED100DIO-1210LL4007DIODEF1FUSE0RFUSE-2PF3TP-SMD(0.5)16x16mm_height 16mm min(For cpu)HEAT_SINKH1HOLE(0.5)HOLEH2HOLE(0.5)HOLEJ1CON-6/2.54MM6PIN/2.54MMCON-6J2CON-4/2.54MMNCCON-4J3AV3NCAV3J4RCA_CUT_RGBRCA 3x2 (2Layer with shield)RCA_CUT_RGBJ5RCA_CUT_RGBRCA 3x2 (2Layer with shield)RCA_CUT_RGBJ12SIMMSMISIMMJT2F-JACK/4P-1RFFJACKL202SMD3.5/32.2uH&1AFBM1MARK/CWopenMARKM2MARKopenMARKM5MARKopenMARKM6MARK/CWopenMARKM8MARKopenMARKM10MARK/CWopenMARKQ1SOT-23MMBT3904NPNQ2SOT-23MMBT3904NPNQ3SOT-23MMBT3906PNPQ5SOT-23MMBT3904NPNQ6SOT-23MMBT3904NPNQ10SOT-23MMBT3904NPNQ14SOT-23MMBT3906PNPQ47SOT-23MMBT3904NPNQ48SOT-23MMBT3904NPNQ103SOT-23MMBT3904NPNQ700SOT-23MMBT3904NPNU1BGA208UPD61214F1-D10-FN7-AUPD61214F1U2SOT23-6\0.95_3X3.2FP6377S5CTR/1AFP6377U3TSOP66H5DU2562GTR-E3CDDRIU4MSOP-10ES7145LVCS4345U5DFN-8PAM0140BYCPAM0140U6SOT23-6\0.95_3X3.2FP6377S5CTR/1AFP6377U7SOIC8FT24C128A-ISG-TEEPROMU8KX8050_EVBG71BQW200_G71U10SC70-5SGM9113YC5G/TRSGM9113U13SOT-223LM1117S/1.2VAMS1117U14BGA-48/8.15X6.15GD29GL064CAB-70GS29GL064A/BGA48U15TQFP100HD2501_LQFPHD2501_LQFPU17SOT-323SGM809-RXN3SG809U24SOIC8LM4558(+/-15V)4558U109LM317LM317LM317UA03RDA_QFN_44MM_24PRDA5815SRDA5815SX1HOLE-9openHOLE-9X2HOLE-9openHOLE-9X3HOLE-9openHOLE-9Y2XTAL-3PINNCXTAL-3PINY3XTAL-3PIN27MHZ(+/-20PPM)_20PFXTAL-3PINZ1SMBNC/ESD5Z3V3-2/TRZD
sisi9000 发表于 2018-4-22 22:32
mini 发表于 2018-4-23 00:21
cdl511 发表于 2018-4-23 01:11
看看,谢谢分享
wangy2000 发表于 2018-4-23 07:19
好作品,收藏,谢谢,分享。
linyuanfei 发表于 2018-4-23 08:50
好作品
zengfanlong 发表于 2018-4-23 09:00
不错
zhutao19880518 发表于 2018-4-23 09:18
zhifang88 发表于 2018-4-23 10:39
稍微详细介绍一下特点
minipcie 发表于 2018-4-23 22:41
好工整, 好漂亮
查看完整版本: UPD61214F1+PAM0140BYC+RDA5815S+SGM809-RXN3 做的机顶盒PCB --没画完
