生成网表报错,请求大神帮助
生产网表报错,请求大声帮助Loading... F:\NEW/pstchip.dat
Loading... F:\NEW/pstxprt.dat
Loading... F:\NEW/pstxnet.dat
packaging the design view...
Exiting... "D:\Cadence\SPB_16.6\tools\capture\pstswp.exe" -pst -d "F:\NEW\GAC_IDU_DRIVER_NXP\GAC_IDU_DRIVER_INFINEON.DSN" -n "F:\NEW" -c "D:\Cadence\SPB_16.6\tools/capture/allegro.cfg" -v 3 -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"
INFO(ORCAP-32005): *** Done ***
* Updating Allegro PCB Editor Board
INFO(ORCAP-32040): Updating Allegro PCB Editor Board
Spawning... netrev.exe-y 1 -n -i "F:\NEW" "F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd" "F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd"
Reading File : F:/NEW/pstchip.dat
(00:00:00.06)
Reading File : F:/NEW/pstxprt.dat
(00:00:00.01)
Reading File : F:/NEW/pstxnet.dat
(00:00:00.01)
Starting to process component instances
Finished component instance processing
Starting to check device models
netrev run on May 5 13:50:40 2018
DESIGN NAME : 'GAC_IDU_DRIVER_INFINEON'
PACKAGING ON Sep 10 2012 04:46:09
1 errors detected
No oversight detected
No warning detected
cpu time 0:03:44
elapsed time0:00:02
Exiting... netrev.exe-y 1 -n -i "F:\NEW" "F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd" "F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd"
( Allegro Netrev Import Logic )
( Drawing : GAC_IDU_DRIVER_INFINEON.brd )
( Software Version : 16.6P004 )
( Date/Time : Sat May 05 13:50:40 2018 )
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_DELETE_FIRST_SEGMENT FALSE;
RIPUP_RETAIN_BONDWIRE FALSE;
RIPUP_SYMBOLS ALWAYS;
Missing symbol has error FALSE;
SCHEMATIC_DIRECTORY 'F:\NEW';
BOARD_DIRECTORY 'F:/NEW/GAC_IDU_DRIVER_NXP/allegro';
OLD_BOARD_NAME 'F:/NEW/GAC_IDU_DRIVER_NXP/allegro/GAC_IDU_DRIVER_INFINEON.brd';
NEW_BOARD_NAME 'F:/NEW/GAC_IDU_DRIVER_NXP/allegro/GAC_IDU_DRIVER_INFINEON.brd';
CmdLine: netrev.exe -y 1 -n -i F:\NEW F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd F:\NEW\GAC_IDU_DRIVER_NXP\allegro\GAC_IDU_DRIVER_INFINEON.brd
------ Preparing to read pst files ------
Starting to read F:/NEW/pstchip.dat
Finished reading F:/NEW/pstchip.dat (00:00:00.06)
Starting to read F:/NEW/pstxprt.dat
Finished reading F:/NEW/pstxprt.dat (00:00:00.01)
Starting to read F:/NEW/pstxnet.dat
Finished reading F:/NEW/pstxnet.dat (00:00:00.01)
------ Oversights/Warnings/Errors ------
#1 Run stopped because errors were detected
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
1 errors detected
No warning detected
cpu time 0:03:44
elapsed time0:00:02
Allegro Footprints read from directories listed in the section 'Allegro Footprints' of the initialization file.
请求大神帮助 貌似配置文件allegro.cfg路径没设置对吧,请检查一下 同一个网表,其他人的allegro能打开,但是我的打不开,库的路径等都是一样的,请这是什么问题?
