armclub 发表于 2018-7-1 13:38
EP3C25F324+SSRAM 256Kx36+EPM3128AT+ADG3308 PCB和SCH
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBUTTON4SW-BUTTON_SW-TACT-6X6_TACTSWTACT SWSW-TACT-6X6CN5CA_CA-AVE-0603-8_0.1U0.1UCA-AVE-0603-8CONF_DONELED_LED-0805_LEDBLEDBLED-0805CPU_RESETSW-BUTTON_SW-TACT-6X6_TACTSWTACT SWSW-TACT-6X6D1SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD2SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD3SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD4SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD5BAT54S_SOT-23_BAT54SBAT54SSOT-23D6SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD7BAT54S_SOT-23_BAT54SBAT54SSOT-23D8SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD9BAT54S_SOT-23_BAT54SBAT54SSOT-23D10SCHOTTKYDIODE_DO-214AC_SM340ASM340ADO-214ACD11BAT54S_SOT-23_BAT54SBAT54SSOT-23D12BAT54S_SOT-23_BAT54SBAT54SSOT-23FID10FIDUCIAL_FID35R_FIDUCIALFIDUCIALFID35RFLASH_CENLED_LED-0805_LEDBLEDBLED-0805J1QSH-090-ALTERA_CON-QSH-180A_QSHQSH-090-ALTERACON-QSH-180AJ2JACK-DC_JACK-DC_2MM_DC_12VDC_12VJACK-DC_2MMJ3JACK-USB-B_JACK-USB-B_USBB-TYPUSB B-TYPEJACK-USB-BJ4HEADER2X5_CON-2X5M_2-54MM_JTAGJTAGCON-2X5M_2-54MMJ5CPLDSIP_CON-2X5_2MM_CPLDISPCPLD ISPCON-2X5_2MMJP8SIP2-R_SIP2_SIP2SIP2SIP2L1INDUCTOR-1_IND-SPD0735_0.47UH0.47UHIND-SPD0735L2INDUCTOR-1_IND-SPD0735_6.8UH6.8UHIND-SPD0735L3INDUCTOR-1_IND-SPD0735_6.8UH6.8UHIND-SPD0735L4INDUCTOR-1_IND-SPD0735_6.8UH6.8UHIND-SPD0735L5INDUCTOR_L-0603_BEADBEADL-0603L6INDUCTOR_L-0603_BEADBEADL-0603L7INDUCTOR_L-0603_BEADBEADL-0603LOADLED_LED-0805_LEDBLEDBLED-0805MH6MH_MTG-250D126_GNDGNDMTG-250D126POWERLED_LED-0805_LEDBLEDBLED-0805Q6BJT-NPN_SOT-23_80508050SOT-23RECONFIGURESW-BUTTON_SW-TACT-6X6_TACTSWTACT SWSW-TACT-6X6REG1LTM4603EV_LGA-118_LTM4603EV-1LTM4603EV-1LGA-118REG2LTC3413_TSSOP-16E_LTC3413LTC3413TSSOP-16EREG3LT1959_SOIC-8_LT1959LT1959SOIC-8REG4LT1959_SOIC-8_LT1959LT1959SOIC-8REG5LT1959_SOIC-8_LT1959LT1959SOIC-8REG6REG-SOT-223_SOT-223_LT1117CST-3LT1117CST-3.3SOT-223RS1RES_R-1206_10M10mR-1206RS2RES_R-1206_10M10mR-1206SCLTEST_POINT_TP1_SIPSIPTP1SDATEST_POINT_TP1_SIPSIPTP1SW1SW-PUSH_SW-PUSH-8X8_POWERSWPOWER SWSW-PUSH-8X8TC1CAPT_CAPAE-D_47U/16V47U/16VCAPAE-DTC2CAPT_CAPAE-D_220U/6.3V220U/6.3VCAPAE-DTC3CAPT_CAPAE-D_220U/6.3V220U/6.3VCAPAE-DTC4CAPT_CAPAE-D_220U/6.3V220U/6.3VCAPAE-DTPRES_TP-0603_00TP-0603U1EP3C25F324_FBGA-324_(S1+S2+S3+SEP3C25F324FBGA-324U2ADG3304_TSSOP-14_ADG3304ADG3304TSSOP-14U374245_TSSOP-20_74HC24574HC245TSSOP-20U4DDR4MX16X4_TSOP-66_DDR 4MX16X4DDR 4Mx16x4TSOP-66U5SSRAM512KX36_TQFP-100N_SSRAM 2SSRAM 256Kx36TQFP-100NU6FLASH32MX16_1_EASY_BGA-64_FLASFLASH 32Mx16EASY_BGA-64U7EPM3128A_TQFP-100_EPM3128ATEPM3128ATTQFP-100U8FT245BM_LQFP-32_FT245BLFT245BLLQFP-32U9EEPROM_SOIC-8_93LC46B93LC46BSOIC-8U10ADG3308_TSSOP-20_ADG3308ADG3308TSSOP-20Y1OSC_OSC-5X7MM_50MHZ50MHZOSC-5X7MMY2OSC_OSC-5X7MM_24MHZ24MHZOSC-5X7MM
armclub 发表于 2018-7-1 13:40
bingo426 发表于 2018-7-1 14:02
风中思雨 发表于 2018-7-1 15:39
longxuekai 发表于 2018-7-1 16:12
来看一下的了
龙凯1989 发表于 2018-7-1 18:28
谢谢分享
wangy2000 发表于 2018-7-2 08:19
下来,学习,提高,收藏。谢谢。
ldj186 发表于 2018-7-2 08:32
很漂亮
as3218710 发表于 2018-7-2 08:36
vickey168 发表于 2018-7-2 08:55
8AT+ADG3308 PCB和SCH
查看完整版本: EP3C25F324+SSRAM 256Kx36+EPM3128AT+ADG3308 PCB和SCH
