Allegro 导出 GERBER 时候出现错误,不能输出TOP,BOT铜皮,请
求助,Allegro 导出 GERBER 时候出现错误,不能输出TOP,BOT铜皮,大家遇到过吗,怎么解决这样问题?出现一个错误提示:FLASH SYM0 180.000 NO DARK(undefined)
这里的FLASH SYM 没有定义
软件提示信息如下
Results from parameter file ...
DEVICE-TYPE GERBER_RS274X
OUTPUT-UNITS INCHES
FILM-SIZE 2400000 1600000
FORMAT 3.5
ABORT-ON-ERROR NO
SCALE 1
SUPPRESS-LEAD-ZEROESYES
SUPPRESS-TRAIL-ZEROES NO
SUPPRESS-EQUAL YES
UNDEF-APT-CONT NO
PROCESSING FILM < TOP >
TO FILE < D:/Helios_2018/Heliso_JinAo/01_DW_M_RevA01/AD9371-001A_0715_AM_01/gerber/TOP.art > ...
FILM PARAMETERS :
Undefined line width 0.000
Mirror code NONE
Rotate angle NONE
Offset x: 0.000
Offset y: 0.000
Plot negative NO
Suppress unconnected internal padsNO
Draw holes only NO
APERTURES USED:
TYPE SIZE/NAME ROT MIRROR MODE
SQUARE 0.13000 0.000 NO DARK
RECTANGLE0.00984 x 0.01575 90.000 NO DARK
RECTANGLE0.24213 x 0.24213 90.000 NO DARK
OBLONG 0.03400 x 0.01100 0.000 NO DARK
FLASH SYM0 0.000 NO DARK
FLASH SYM0 90.000 NO DARK
FLASH SYM0 270.000 NO DARK
PAD SHAPER040X044-SHAPE 0.000 NO DARK
PAD SHAPER040X065-SHAPE 0.000 NO DARK
ERROR: aborting film - Undefined aperture symbol, cannot continue.
See APERTURES USED table in this file for symbols to provide.
Error in TOP--halting output.Artwork file not generated.
*** ERROR with TOP
SUMMARY:
*** ERROR with TOP
ARTWORK Error
ARTWORK Error
=================================================================== 导出 GERBER 时候出现错误 你看选项有没有添加好,检查一下 找到原因,应为有新器件添加,又是改版的文件,有些封装出现了丢失。更新、补充了库文件,问题解决。
