全志A10 PCB文件挂4个DDR3 6层平板电脑PCB文件和原理图共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBAT702BAT1_SPK_PAD_BAT3.7VBAT3.7VSPK_PADBAT703BAT1_BAT-5_5MM_BAT3.7VBAT3.7VBAT-5_5MMCN3CN_0_0_5K-AX-20PWB-T_GC0308GC03080_5K-AX-20PWB-TCON1AT070TN93_4_LCD_HSD070IDW_60P_BNCLCD_HSD070IDW_60P_BOTTOMCON1001HDMI19_TYPE_C_MINI-HDMI-A_HDMI_HDMI_TYPE_CMINI-HDMI-ACON1306RT9266PE_10_CON_0_5C-6PBX_CON_0con_0_5c-6pbxCON_0_5C-6PBXD31N4500_0_SOD-323_NC/1N4148NC/1N4148SOD-323D11DIODE_DUAL_SOT-23_BAT54SBAT54SSOT-23D13DIODESCHOTTKY_DO_214AC_NC/SS34NC/SS34DO_214ACD14DIODESCHOTTKY_DO_214AC_SS34_SS34DO_214ACD7011N4500_SOD-323_1N41481N4148SOD-323D702DIODESCHOTTKY_SOD123_ZMM5V6_ZMM5V6SOD123D7031N4500_LED0603_LED-RLED-RLED0603D801DIODE_SCHOTTKY_SOD123_MBR130LSFMBR130LSFT1SOD123D802DIODE_SCHOTTKY_SOD123_IN4148IN4148SOD123D11181_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402D11191_1.5KE100A_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402D1303DIODESCHOTTKY_SOD123_MBR130LSFMBR130LSFT1SOD123D1304DIODE_DUAL_0_SOT-23_BAT54SBAT54SSOT-23D1305DIODESCHOTTKY_SOD123_15V15VSOD123D1306DIODE_DUAL_1_SOT-23_BAT54SBAT54SSOT-23D1307DIODESCHOTTKY_SOD123_6.8V6.8VSOD123D1308DIODE_DUAL_0_SOT-23_NC/BAT54SNC/BAT54SSOT-23DC701USB_MINI-B_0_DC-045B_IC_DC-IN-5DC-IN-5V-2aDC-045BEMI1R-PACK4_1_ICMEF212P900M_ICMEF21ICMEF212P900MICMEF212P900MEMI2R-PACK4_1_ICMEF212P900M_ICMEF21ICMEF212P900MICMEF212P900MESD706DIODE TVSLC_0_ESD0402_ULCE0512ULCE0512A015FRESD0402ESD707DIODE TVSLC_0_ESD0402_ULCE0512ULCE0512A015FRESD0402ESD708DIODE TVSLC_0_ESD0402_ULCE0512ULCE0512A015FRESD0402ESD1106DIODE TVSLC_0_ESD0402_ESD5V/4KESD5V/4KV/5PFESD0402ESD1206DIODE TVSLC_0_ESD0402_ULCE0505ULCE0505A015FRESD0402FB701INDUCTOR_R1206_100M/120R3A100M/120R 3AR1206FPC1RT9266PE_2_CON_1_0C-4PBX_FPC_4PFPC_4PIN_0.5PHCON_1_0C-4PBXHQ1301PMOS_SOT-23_AO3423AO3423SOT-23HQ1302PMOS_SOT-23_NC/AO3423NC/AO3423SOT-23J6USB-A_0_USB-A-4PIN-SMD-1_USB-AUSB-AUSB-A-4PIN-SMD-1J1101HP_JACK_2_PJ-381_PJ-328ZPJ-328ZPJ-381J1201USB_MINI_SOCKET_USB-5P_USB_OTGUSB_OTGUSB-5PJ12024 HEADER_0_DIP-4PIN_4HEADER_34 HEADER_3DIP-4PINK1103KEY-2PIN_0_KEY3633A-0_6MM_V0L+V0L+KEY3633A-0_6MMK1104KEY-2PIN_0_KEY3_UBOOTUBOOTKEY3K1105KEY-2PIN_0_KEY3633A-0_6MM_V0L+V0L+KEY3633A-0_6MMK1106KEY-2PIN_0_KEY3633A-0_6MM_V0L+V0L+KEY3633A-0_6MMK1108KEY-2PIN_0_KEY3_RESTRESTKEY3K1109KEY-2PIN_0_K4_HOMEHOMEK4L1INDUCTOR/SM_L0603_INDUCTOR/SMINDUCTOR/SML0603L2INDUCTOR/SM_L0603_INDUCTOR/SMINDUCTOR/SML0603L3INDUCTOR_L0402_NCNCL0402L4INDUCTOR_L0402_3NH3nHL0402L5INDUCTOR_L0402_2.4NH2.4nHL0402L7INDUCTOR_L0603_8.2UH8.2uHL0603L8INDUCTOR_L0603_8.2UH8.2uHL0603L9INDUCTOR_L0603_8.2UH8.2uHL0603L10INDUCTOR_L0603_8.2UH8.2uHL0603L11INDUCTOR_L0402_0R0RL0402L12INDUCTOR/SM_L0603_NCNCL0603L13INDUCTOR_L0603_1.8UH1.8uHL0603L14INDUCTOR/SM_L0603_NCNCL0603L15INDUCTOR/SM_L0603_INDUCTOR/SMINDUCTOR/SML0603L16INDUCTOR/SM_L0603_INDUCTOR/SMINDUCTOR/SML0603L17INDUCTOR/SM_L0603_INDUCTOR/SMINDUCTOR/SML0603L701INDUCTOR_CD42_4.7UH@1.5ADCR<0.4.7uH@1.5ADCR<0.1RCD42L702INDUCTOR_CD42_4.7UH@1.5ADCR<0.4.7uH@1.5ADCR<0.1RCD42L703INDUCTOR_CD42_4.7UH@1.5ADCR<0.4.7uH@1.5ADCR<0.1RCD42L801INDUCTOR_CD42_4.7UH@1.5ADCR<0.4.7uH@1.5ADCR<0.1RCD42L802INDUCTOR_CD42_4.7UH@1.5ADCR<0.4.7uH@1.5ADCR<0.1RCD42L803INDUCTOR_CD42_2.2UH-DCR<0.1R-2A2.2uH-DCR<0.1R-2ACD42L1101INDUCTOR_13_L0402_600R-100M600R-100ML0402L1102INDUCTOR_14_L0402_0R0RL0402L1103INDUCTOR_15_L0402_0R0RL0402L1104INDUCTOR_16_L0402_0R0RL0402L1301INDUCTOR_11_CD42_10UH10uHCD42L1302INDUCTOR_9_CD42_10UH10uHCD42LCD13044_1.3_TFT_LCD_40PIN_LCD-FPC-40PFPC-40PIN-0.5MMLCD-FPC-40PIN_BOTTOMMIC1MICPHONE_MIC6MM_MICPHONEMicphoneMIC6MMMIC1101MICPHONE_MIC4MM_MICPHONEMicphoneMIC4MMOQ1301PMOS_SOT-23_AO3423AO3423SOT-23Q701MOSFET P_SOT23_AO3423AO3423SOT23Q702PNP_SOT23_MMBT3906MMBT3906SOT23Q1102NPN_SOT-23_MMBT3904MMBT3904SOT-23Q1302NPN_3_SOT-23_MMBT3904MMBT3904SOT-23Q1601PMOS_SOT-23_AO3423AO3423SOT-23Q1602NPN_SOT-23_MMBT3904MMBT3904SOT-23RN1306R-PACK4_1_RCA50-8_100R*4100R*4RCA50-8TF1201SDMMCSLOT_0_MINI_TF_MICROSD-TFMICROSD-TF_SLOTMINI_TFU1FM1188_0_LQFP48_XXXXXxxxxxLQFP48U2PCF8563_MSOP-8_NC/PCF8563/AT856NC/PCF8563/AT8563MSOP-8U3AT24_1_SOP8_AT24AT24SOP8U4HT7233_SOT-23_HT7218HT7218SOT-23U5RT9293B_0_SOT23-5_AP1231-2.5VAP1231-2.5VSOT23-5U6TOGGLENAND_2_LGA-60_NAND FLASHNAND FLASH x8LGA-60U9TOGGLENAND_2_LGA-60_NAND FLASHNAND FLASH x8LGA-60U10SN74AHCT04_TSSOP14_SN74AHCT04PWSN74AHCT04PWRTSSOP14U14DDR2_3_DDR3_BGA82_F_H5TQ1G83BFRH5TQ1G83BFRDDR3_BGA82_FU27DDR2_4_DDR3_BGA82_F_H5TQ1G83BFRH5TQ1G83BFRDDR3_BGA82_FU28DDR2_2_DDR3_BGA82_F_H5TQ1G83BFRH5TQ1G83BFRDDR3_BGA82_FU33DDR2_1_DDR3_BGA82_F_H5TQ1G83BFRH5TQ1G83BFRDDR3_BGA82_FU501BGA441-AW1623_13_FBGA441C80P19XBGA441-APP_A10FBGA441C80P19X19U701AW1612_2_QFN48_AXP209AXP209QFN48U801RT9293B_0_SOT23-5_1V81V8SOT23-5U802RT9293B_0_SOT23-5_TCS4160/SY800TCS4160/SY8008BSOT23-5U803RT9293B_0_SOT23-5_1V81V8SOT23-5U804RT9293B_0_SOT23-5_TCS4160/SY800TCS4160/SY8008BSOT23-5U805RT9266PE_3_SOT23-6_TCS9208TCS9208SOT23-6U806RT9293B_0_SOT23-5_WL2003E28WL2003E28SOT23-5U1001RRCLAMP0524P_RCLAMP0524P_TDFN10rRClamp0524PRCLAMP0524P_TDFN10U1002RRCLAMP0524P_RCLAMP0524P_TDFN10rRClamp0524PRCLAMP0524P_TDFN10U1003RRCLAMP0524P_RCLAMP0524P_TDFN10rRClamp0524PRCLAMP0524P_TDFN10U1102LY8006_MSOP-8_48904890MSOP-8U1103LY8006_MSOP-8_48904890MSOP-8U1108RT9266PE_2_SOT23-5_TCS9707TCS9707SOT23-5U1201RT9266PE_2_SOT23-5_TCS9707SY628TCS9707SY6280SOT23-5U1301RT9292D_0_SOT23-6_TCS2514TCS2514SOT23-6U1302AP3019_0_SOT23-6_TCS3352TCS3352SOT23-6U1501NAND_FLASH_X8_TSOP48_NANDFLASHNAND FLASH 1TSOP48U1502NAND_FLASH_X8_TSOP48_NANDFLA_1NAND FLASH 2TSOP48U1701MMA7660_1_MMA7660FC_NC/MMA7660FNC/MMA7660FCMMA7660FCU1702MXC6225XU_QFN6-MX6225XU_MXC6225MXC6225XUQFN6-MX6225XUU1703RDA5876_0_QFN40P405X405X90-32N_RDA5876QFN40P405X405X90-32NU1704AT24_1_SOP8_DM2016DM2016SOP8U1705AT24_1_SOP8_MAX705MAX705SOP8WIFI1CON6A_3_USB_WIFI_12X13_RL-UM02BRL-UM02BS-8188CUS-33USB_WIFI_12X13Y2CRYSTAL_XCOL-3_1_2X6_13M13M2X6Y3CRYSTAL_XCOL-3_1_32_768_SMD_14XNC/32.768KHZ32_768_SMD_14X7Y901CRYSTAL_XCOL-3_1_CRY3225_24M24MCRY3225Y902CRYSTAL_XCOL-3_1_32_768_SMD_1_132.768KHZ32_768_SMD_14X7Y903CRYSTAL_XCOL-3_1_CRY3225_26M26MCRY3225 PCB文件和原理图共享。回复可见
**** Hidden Message ***** 网站老大发出来的相信是有代表性的。
回 老吴 的帖子
老吴:PCB文件共享。没原理图。 回复可见[内容隐藏]
(2018-07-30 13:40) images/back.gif
回复可见 谢谢哦,谢谢 阿里够资料 不错
