老吴 发表于 2018-10-8 23:52
TC358870XBG 做的HDMI 转MIPI DSI  方案PCB和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEJ201BM14B-30_BM14B-30DS-0_4V_BM14B(BM14B(0_8)-30DS-0_4V(51)BM14B-30DS-0_4VJ202BM14B-30_BM14B-30DS-0_4V_BM14B(BM14B(0_8)-30DS-0_4V(51)BM14B-30DS-0_4VJ501CPJ-235_CPJ-235_IO_CPJ-235CPJ-235CPJ-235J5000CON40A_AXE540124T_AXE540124AXE540124AXE540124TJ5300TEST_POINT_11_SIP5_50_PWR_INPWR_INSIP5_50J5301TEST_POINT_0_SIP2_80_LEDLEDSIP2_80J5303CI4402S_CI4402M_50_CI4402SCI4402sCI4402M_50L521INDUCTOR_MIPF2016D_2.2UH2.2uHMIPF2016DL522INDUCTOR_MIPF2016D_2.2UH2.2uHMIPF2016DL523INDUCTOR_MIPF2016D_2.2UH2.2uHMIPF2016DL524INDUCTOR_MIPF2016D_2.2UH2.2uHMIPF2016DL5000L_0_MIPF2016D_2.2UH2.2uHMIPF2016DL5001L_0_MIPF2016D_2.2UH2.2uHMIPF2016DL5300L_0_0402_CC_2NH2nH0402_CCL5301L_0_0402_CC_1NH1nH0402_CCL5302L_0_0402_CC_3NH3nH0402_CCL5303L_0_0402_CC_2NH2nH0402_CCQ5000FET PMOS_SOT23_WPM2015-3/TRWPM2015-3/TRSOT23Q5001NPN4_SOT23_80508050SOT23Q5002NPN4_SOT23_80508050SOT23Q5301NPN4_SOT23_80508050SOT23T1CON5_2_ANT5036_BLEANTBLE ANTANT5036TP1T POINT R_TP_1MM_TPOINT RT POINT RTP_1MMTP2T POINT R_TP_1MM_TPOINT RT POINT RTP_1MMTP3T POINT R_TP_1MM_TPOINT RT POINT RTP_1MMTP4T POINT R_TP_1MM_TPOINT RT POINT RTP_1MMTVS5000DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS5001DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS5002DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS5400DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPU15S-35380A_0_WDFN-6L_RT8010RT8010WDFN-6LU522TPS65135RTER_QFN16_0_5_TPS65135TPS65135RTERQFN16_0_5U525TPS65135RTER_QFN16_0_5_TPS65135TPS65135RTERQFN16_0_5U529S-35380A_0_WDFN-6L_RT8010RT8010WDFN-6LU5000S-35380A_0_SOT-23-5_RT8059RT8059SOT-23-5U5001S-35380A_0_SOT-23-5_RT8059RT8059SOT-23-5U5002RT9451_2_P-VFBGA80-0707-0_65-00TC358870XBGP-VFBGA80-0707-0_65-001U5003OPA357AIDBVR_0_SOT23-5_RT9013-1RT9013-12GB/NCSOT23-5U5006WM8750_3_SOIC14L_CS4354CS4354SOIC14LU5100OPA357AIDBVR_0_SOT23-5_RT9013_1RT9013-18GBSOT23-5U5300TEST_POINT_14_PVQFN-N40_CC2541FCC2541F256PVQFN-N40U5302RT9013_SOT-23-5_RT9013-33GBRT9013-33GBSOT-23-5U5303OPA357AIDBVR_0_SOT23-5_RT9013_1RT9013-18GBSOT23-5Y5000Y_OSC_4PIN_SMD3225_48MHZ48MHzSMD3225Y5300CRYSTAL_1_SMD3225_32MHZ32MHzSMD3225Y5301CRYSTAL_XTAL_3215_32768HZ32768HzXTAL_3215
配套小板
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC2019CAP_0402_CC_22PF22pF0402_CCC2020CAP_0402_CC_680PF680pF0402_CCD1F5D1/TO_1_LED0603_GRNGRNLED0603D2DIODESCHOTTKY_SOD-123_IN5819WIN5819WSOD-123DOWNTESTLOOP_TP_SMD_1MM_IO_STPM_DOWSTPM_DOWNTP_SMD_1MMEMOTESTLOOP_TP_SMD_1MM_IO_STPM_DOWSTPM_DOWNTP_SMD_1MMJ1CON12_FH52-12S-0P5SH_FH52-12S-0FH52-12S-0.5SHFH52-12S-0P5SHJ2CI4402S_CI4402M_50_CI4402SCI4402sCI4402M_50J3CON2_MIC_6X2P7_MICMICMIC_6X2P7J44HEADER_25_CJT_A2001WV_5P_2MM_MOTORCJT_A2001WV_5P_2MMJ5CON2_0_SIP2P00_4_NC_DEBUG/NCDEBUG/NCSIP2P00_4_NCJ6CON3_SIP3_50_CON3CON3SIP3_50L1IND_IND_VLCF4018_DISCRETE_1U21u2IND_VLCF4018L2IND_IND_SLF6028_DISCRETE_SLF602SLF6028T-4R7M1R6-PFIND_SLF6028LEDA1TESTLOOP_TP_SMD_1MM_IO_LEDA1LEDA1TP_SMD_1MMLEDK2TESTLOOP_TP_SMD_1MM_IO_LEDK2LEDK2TP_SMD_1MMMOTESTLOOP_TP_SMD_1MM_IO_STPM_DOWSTPM_DOWNTP_SMD_1MMQ1PNP BCE_0_SOT-23_PNPPNPSOT-23SH1RES_SHORT-2_SH0805_40_DISCRETE_SOLDER_SHORTSH0805_40SW1EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW2EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW3EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW4EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW5EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW6EDGE_MOUNT_PB_SW_3_PTLGP2_IC_PTPTLGP2PTLGP2SW2001EE-SX1108_OMRON_EE_SX1108_EE-SXEE-SX1108OMRON_EE_SX1108SW2002EE-SX1108_OMRON_EE_SX1108_EE-SXEE-SX1108OMRON_EE_SX1108TP5TESTLOOP_TP_SMD_1MM_IO_SENSOR_ASensor_ATP_SMD_1MMTP7TESTLOOP_TP_SMD_1MM_IO_SENSOR_BSensor_BTP_SMD_1MMTVS1DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPU1MAX8815A_TDFN_2_TDFN10_0P5_3P1XMAX8815AETB+TDFN10_0P5_3P1X3P1U2RT9013_SOT-23-5_RT9013-33GBRT9013-33GBSOT-23-5U41N5465A_3_LQFP32_STM8S105K4T6STM8S105K4T6LQFP32U2003LV8729V_SSOP44K_LV8729VLV8729VSSOP44KU2004SN74ACT244_R-PDSO-G20_74ACT24474ACT244R-PDSO-G20U2005RT9277AB_MSOP8_RT9277ABRT9277ABMSOP8
老吴 发表于 2018-10-8 23:54
整套资料一起共享。里面有多个版本文件。下载自己找需要的。
回复可见下载
**** Hidden Message *****
shuszhao 发表于 2018-10-9 00:14
老吴出品 ,必是精品
yannlin 发表于 2018-10-9 06:08
好资料,看一看,谢谢分享
marktsui 发表于 2018-10-9 06:57
lcfmax 发表于 2018-10-9 07:22
qi2017 发表于 2018-10-9 07:54
感谢分享,学习学习
ldj186 发表于 2018-10-9 08:02
学海无涯 发表于 2018-10-9 08:03
吴老大的精品啊!!
zblin1987 发表于 2018-10-9 08:07
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: TC358870XBG 做的HDMI 转MIPI DSI  方案PCB和原理图(CC2541F
