250W PFC+LLC 电路97%效率AC-DC
原理图与PCB均为EAGLE格式
**** Hidden Message *****
Part Value Device Package Library Sheet
C1 2.2n C-USC0603 C0603 rcl 1
C2 1u C-USC0603 C0603 rcl 1
C3 1.5n C-USC0603 C0603 rcl 1
C4 2.2u C-USC0603 C0603 rcl 1
C5 100p C-USC0603 C0603 rcl 1
C6 4.7n C-EUC1206 C1206 rcl 2
C7 4.7n C-EUC1206 C1206 rcl 2
C8 4.7n C-EUC1206 C1206 rcl 2
C9 1u C-USC0603 C0603 rcl 1
C10 220n BFC233820224 BFC233820224 Passives 1
C11 2.2n VY2_CAP_SAFETY VY2_CAP_SAFETY Passive 1
C12 2.2n VY2_CAP_SAFETY VY2_CAP_SAFETY Passive 1
C13 120UF_450V 120UF_450V 18MMX33.5MM_LAYDOWNPassive 1
C14 3.3u/400V CPOL-USE3.5-8 E3,5-8 rcl 1
C15 100n C-EUC1812 C1812 rcl 1
C16 100n C-EUC1812 C1812 rcl 1
C17 0.1u C-USC0603 C0603 rcl 1
C18 3.3u/400V CPOL-USE3.5-8 E3,5-8 rcl 1
C19 0.1u C-EUC0603 C0603 rcl 2
C20 100n C-USC1206 C1206 resistor 1
C21 10u C-USC0805K C0805K resistor 1
C22 100u/16v ELE_CAP_D5MM_P2MMELE_CAP_D5MM_P2MM Passive 1
C23 .1u C-EUC1812 C1812 rcl 2
C24 .1u C-EUC1812 C1812 rcl 2
C25 .1u C-EUC1812 C1812 rcl 2
C26 470u CPOL-USE3.5-8 E3,5-8 rcl 2
C27 .1u C-EUC0603 C0603 rcl 2
C28 1u C-EUC0603 C0603 rcl 2
C29 10u C-EUC0805K C0805K rcl 2
C30 .1u C-EUC0603 C0603 rcl 2
C31 4.7u C-EUC0805 C0805 rcl 2
C32 1u C-EUC0603 C0603 rcl 2
C33 .1u C-EUC0603 C0603 rcl 2
C34 1u C-EUC0603 C0603 rcl 2
C35 .1u C-EUC0603 C0603 rcl 2
C36 68n C-EUC0603 C0603 rcl 2
C37 .1u C-EUC0603 C0603 rcl 2
C38 820u CPOL-USE5-10.5 E5-10,5 rcl 2
C39 470u CPOL-USE3.5-8 E3,5-8 rcl 2
C40 100u C-EUC1210 C1210 rcl 2
C41 100u C-EUC1210 C1210 rcl 2
C42 100u C-EUC1210 C1210 rcl 2
C43 100u C-EUC1210 C1210 rcl 2
C44 22n PHE450-886MIL PHE450-886MIL Passives 2
C45 330p C-EUC0805K C0805K rcl 2
C46 330p C-EUC0805K C0805K rcl 2
C47 820u CPOL-USE5-10.5 E5-10,5 rcl 2
C48 220p C-EUC1206 C1206 rcl 2
C49 .1u C-EUC0603 C0603 rcl 2
C50 4.7u C-EUC0805 C0805 rcl 2
C51 10n C-EUC0603 C0603 rcl 2
C52 1u C-EUC0603 C0603 rcl 2
C53 2.2n C-EUC0603 C0603 rcl 2
C54 1n C-EUC0603 C0603 rcl 2
C55 100u C-EUC1210 C1210 rcl 2
C56 100u C-EUC1210 C1210 rcl 2
C57 10n C-USC1206 C1206 rcl 1
C58 10n C-USC1206 C1206 rcl 1
C59 4.7u C-EUC0805 C0805 rcl 2
C60 820u CPOL-USE5-10.5 E5-10,5 rcl 2
C61 100u/16v ELE_CAP_D5MM_P2MMELE_CAP_D5MM_P2MM Passive 1
C62 100u C-EUC1210 C1210 rcl 2
C63 100u C-EUC1210 C1210 rcl 2
C64 68p VY2_CAP_SAFETY VY2_CAP_SAFETY Passive 1
C65 68p VY2_CAP_SAFETY VY2_CAP_SAFETY Passive 1
C68 2.2u PHE450_2U PHE450_2UF Passives 2
C70 820u CPOL-USE5-10.5 E5-10,5 rcl 2
C71 120UF_450V 120UF_450V 18MMX33.5MM_LAYDOWNPassive 1
CX1 330n BFC233820224 BFC233820224 Passives 1
CX2 330n BFC233820224 BFC233820224 Passives 1
CX3 220n BFC233820224 BFC233820224 Passives 1
CY4 2.2n C10R5X7R0 C10R5X7R0 Passives 2
D1 S1M DIODE-DO-214AC DO-214AC diode 1
D2 S3J S3J DO-214AB Passive 1
D3 C3D02060A DIODE-TO220AC TO220ACS-LARGE-DRILL Passives 1
D5 S1J DIODE-DO-214AC DO-214AC diode 1
D6 US1J DIODE-DO-214AC DO-214AC diode 1
D7 DIODE-DO-214AC DO-214AC diode 2
D8 11v MMSZ5241 SOD123 Active 2
D9 DIODE-SOD123 SOD123 diode 2
D10 DIODE-SOD123 SOD123 diode 2
F1 T6.3A/250V FUSE_T6.3A/250V T6.3A.250V_FUSE Passive 1
FB1 60 R-US_R0603 R0603 rcl 1
FB2 60 FB0603 0603 Passives 2
FB3 60 FB0603 0603 Passives 2
J1 3PIN_3.5MM 3PIN_3.5MM 3PIN_3.5MM Connector 1
J2 7461093 BUSHES_3X3_K BUSHES_3X3 Connector 2
J3 7461093 BUSHES_3X3_K BUSHES_3X3 Connector 2
L2 5mH CMC_19X11 CMC_19X11 Passive 1
L4 1mH L-USL1812 L1812 resistor 1
L5 1mH DRA73_INDUCTOR DRA73_INDUCTOR Passive 1
LD1 26uH LDM_13X8MM LDM_13X8MM Passive 1
LD2 26uH LDM_13X8MM LDM_13X8MM Passive 1
LD3 26uH LDM_13X8MM LDM_13X8MM Passive 1
LD4 26uH LDM_13X8MM LDM_13X8MM Passive 1
LF 480uH PFC_INDUCTOR_FR BOBBIN_30/19_10PIN Passive 1
MOV1 MOV-E08A MOV-E08A MOV-E08A Passive 1
PS1 LNK304 LNK304 SO-8C IC 1
Q1 TPH3002PS TPH_HEMT_VERT TPH_TO220VERT Active 1
Q2 TPH3xxxPS TPH_HEMT_VERT TPH_TO220VERT Active 2
Q3 TPH3xxxPS TPH_HEMT_VERT TPH_TO220VERT Active 2
Q4 OPTIMOS_PG-TDSON-8 PG-TDSON-8 Active 2
Q5 OPTIMOS_PG-TDSON-8 PG-TDSON-8 Active 2
R1 110K R-US_R0603 R0603 rcl 1
R2 75k R-US_R0603 R0603 rcl 1
R3 2.37M R-US_R0805 R0805 rcl 1
R4 2.37M R-US_R0805 R0805 rcl 1
R5 2.37M R-US_R0805 R0805 rcl 1
R6 3.3K R-US_R0603 R0603 rcl 1
R7 0R06 R-US_R2512 R2512 rcl 1
R8 11.0K R-US_R0603 R0603 rcl 1
R9 23.2K R-US_R0603 R0603 rcl 1
R10 220k R-US_R1206 R1206 rcl 1
R11 1.78M R-US_R0805 R0805 rcl 1
R12 1.8M R-US_R0805 R0805 rcl 1
R13 220k R-US_R1206 R1206 rcl 1
R14 10/1W R-EU_R2010 R2010 resistor 1
R15 2.05k R-US_R0603 R0603 resistor 1
R16 13k R-US_R0603 R0603 resistor 1
R17 13k R-US_R1206 R1206 resistor 1
R18 4.7 R-US_R0805 R0805 rcl 2
R19 1.87k R-US_R0603 R0603 rcl 2
R20 4.7k R-US_R0603 R0603 rcl 2
R21 953k R-US_R0805 R0805 rcl 2
R22 953k R-US_R0805 R0805 rcl 2
R23 953k R-US_R0805 R0805 rcl 2
R24 10k R-US_R0805 R0805 rcl 2
R25 20k R-US_R0603 R0603 rcl 2
R26 5.9k R-US_R0603 R0603 rcl 2
R27 20k R-US_R0603 R0603 rcl 2
R28 0R56 R-US_R0805 R0805 rcl 2
R29 0R56 R-US_R0805 R0805 rcl 2
R30 5.9k R-US_R0603 R0603 rcl 2
R31 2.2k R-US_R0603 R0603 rcl 2
R32 1k R-US_R0603 R0603 rcl 2
R33 14.7k R-US_R0603 R0603 rcl 2
R34 11.0k R-US_R0603 R0603 rcl 2
R35 13.7k R-US_R0603 R0603 rcl 2
R36 750 R-US_R0603 R0603 rcl 2
R37 332 R-US_R0603 R0603 rcl 2
R38 23.2k R-US_R0603 R0603 rcl 2
R39 100 R-US_R0603 R0603 rcl 2
R40 1k R-US_R0603 R0603 rcl 2
R41 7.5k R-US_R0603 R0603 rcl 2
R42 2k R-US_R0603 R0603 rcl 2
R43 150k R-US_R0603 R0603 rcl 2
R44 12.4k R-US_R0603 R0603 rcl 2
R45 DNI R-US_R0603 R0603 rcl 2
R46 0 R-US_R0603 R0603 rcl 2
R47 DNI R-US_R0603 R0603 rcl 2
R48 DNI R-US_R0603 R0603 rcl 2
R49 24k R-US_R0805 R0805 rcl 2
R50 24k R-US_R0805 R0805 rcl 2
R51 7.5k R-US_R0603 R0603 rcl 2
R52 7.5k R-US_R0603 R0603 rcl 2
R53 0 R-US_R0603 R0603 rcl 2
R54 4.7 R-US_R0603 R0603 rcl 2
R55 4.7 R-US_R0603 R0603 rcl 2
R56 0 R-US_R0603 R0603 rcl 2
R57 DNI R-US_R0603 R0603 rcl 2
R58 DNI R-US_R0603 R0603 rcl 2
R59 DNI R-US_R0603 R0603 rcl 2
R60 DNI R-US_R0603 R0603 rcl 2
R61 2.2M R-US_R1206 R1206 rcl 2
R62 2.2M R-US_R1206 R1206 rcl 2
R63 10 R-US_R0805 R0805 rcl 2
R64 10 R-US_R0805 R0805 rcl 2
REC BRIDGE BRIDGE_KBPC8 Passive 1
TDPS251E0D2 LLCDEMO_LARGEDIA2 LLCDEMO_LARGEDIA2LLC_LARGEDIA2 Transformer 2
U1 NCP1654S_200KHZ NCP1654S SO-08 Liang 1
U2 NCP1397B NCP1397 SOIC16N-13 Liang 2
U3 NCP4304B NCP4304 SO-08 Controller2
U4 NCP4304B NCP4304 SO-08 Controller2
U5 NCP431 TL431 SOT23 Active 2
U6 HCPL-817 DIL4-SMD Active 2
U7 NCP4810 NCP4810 SOIC-8 IC 1 谢谢分享 谢谢分享经验 谢谢分享,学习一下 谢谢分享 谢谢分享资源 谢谢分享
