xiaopeng001 发表于 2018-11-12 16:31
AM574x的PCB和原理图(12层,6011 PIN)
ValuePCB FootprintQuantityPart ReferenceSK1545sk15451D1SMCJ5.0ASMCJ26CA1D2MMSD103T1sod-1231D3MMSD103T1sod-1231D4Green LEDsm_led_08051D13MBR0520LT1mbr0520L1D14MBR0520LT1mbr0520L1D15Red_Green_Blue_LEDLED-SM12101D19PMEG2010DFN1006D-21D20Red_Green_Blue_LEDLED-SM12101D22Red_Green_Blue_LEDLED-SM12101D23TLVH431sot23-3-44m1D24TLVH431sot23-3-44m1D25Fuse 8Afuse-01541F110HF70ACB2012091FB8150OHM800mAsm-7351-ind-08051FB19Power Jack RAPC712RAPC7121J1RJ-45 10_100MbCNRJ45-1X1WLED1J3HEADER 5HEADER_5X11J4RJ-45 10_100MbCNRJ45-1X1WLED1J5RJ-45 10_100MbCNRJ45-1X1WLED1J6HEADER 5HEADER_5X11J7RJ-45 10_100MbCNRJ45-1X1WLED1J8HEADER 12x2hdr2x121J9RJ-45 GigabitCNRJ45-1X1WLED-598M1J10RJ-45 GigabitCNRJ45-1X1WLED-598M1J12Conn_DB9FNorComp_db9F_SMD1J14SCHA5B0200SD-MICRO-SCHA5B03001J15XF2M-3215-1ACNXF2M-3215-1A1J16XF2L-0625-1ACNXF2L-0625-1A1J17MIPI JTAG 60pinCNQSH030DA1J18USB_MicroABZX62-AB-5PA1J19DNIHDR4X1RA-108M1J1_1Header_30x2_FemaleHDR2X30-2mm-177m1J2110018783-11000TLFCN_10018783-11000TLF1J22USB3_0_StdAcn_lpaf3102nl1J23HDMIConnAsmd_hdmia_ra1J24Header 15x2 FemaleHDR2X15-344M1J37HEADER 2header_2x11J43USB_MicroABZX62-AB-5PA1J45HEADER 4HDR1x4-330M1J46HEADER 2header_2x11J47HEADER 2header_2x11J49HEADER 2header_2x11J504.7uHvlcf5020t1L1DA2304-ALDA23041L2NFM21PC474FILT-NFM21PC1L3ACM2012ACM2012H1L111.0uHind_ihlp1616ab1L20NFM21PC474FILT-NFM21PC1L214.7uHsmd_slf7055t1L22NFM21PC474FILT-NFM21PC1L24NFM21PC474FILT-NFM21PC1L25NFM21PC474FILT-NFM21PC1L263.3uHvlcf5020t1L28DLW21SN900HQ2Lfilt-dlw21s1L29DLW21SN900HQ2Lfilt-dlw21s1L30DLW21SN900HQ2Lfilt-dlw21s1L31DLW21SN900HQ2Lfilt-dlw21s1L32ACM2012ACM2012H1L33NFM21PC474FILT-NFM21PC1L34NFM21PC474FILT-NFM21PC1L35THT-14-423-101LBL1Shunt0.1innone1M1PROC053DNP1PCB1BSS138SOT23-31Q6FDT434PSOT223-41Q7FDT434PSOT223-41Q8BSS138SOT23-31Q25MMBT2907Asot23-3-44m1Q26MMBT2907Asot23-3-44m1Q27B3SLSW_B3SL-1022P1SW1B3SLSW_B3SL-1022P1SW2B3SLSW_B3SL-1022P1SW3TPTH_TP_50021TP1DNITH_TP_50021TP1_1TP1mmtp_smd1mmcircle1TP2TP1mmtp_smd1mmcircle1TP3TP1mmtp_smd1mmcircle1TP6TP1mmtp_smd1mmcircle1TP7TPTH_TP_50021TP8TPTH_TP_50021TP9TPTH_TP_50021TP10TPTH_TP_50021TP11TP1mmtp_smd1mmcircle1TP24AM5749ABZXEABGA23X23-760-117M1U1DNIX2SON1X1-4-16M1U1_1SN74LVC1G07u_5_dck1U2S25FL256Ssoic_16pin_dw1U4MT41K256M16TW-107:Pbga9x14-961U5MT41K256M16TW-107:Pbga9x14-961U6MT41K256M16TW-107:Pbga9x14-961U7TPS51200drcpso_10pin1U8TLK105Lqfn5x5-32-39m1U9TLK105Lqfn5x5-32-39m1U13TLK105Lqfn5x5-32-39m1U15TLK105Lqfn5x5-32-39m1U17PicoHaptics 304-100pico_304-1001U18SN74LVC1G04SC70-5-43M1U19KSZ9031RNqfn7x7-481U21SN74LVC1G07u_5_dck1U22CDCE913TSSOP5X4-14-47M1U23KSZ9031RNqfn7x7-481U24CDCE913TSSOP5X4-14-47M1U25SN74LVC1G07u_5_dck1U26SN74LVC1G07u_5_dck1U28TPD6E001U_10_RSE1U30TPS61081DRCu_10_drc1U32CAT24C256WSOIC_81U33SN74LVC1G00DCKU_5_DCK1U34SN74LVC1G07u_5_dck1U35TPD2E001DRLRU_5_DRL1U36FT2232HLLQFP64pin1U3793LC56BSOIC_81U38DNI SN74LVC1G07u_5_dck1U39TPS6590375ZWSRbga12x12-169-55m1U3R1Z-3.305HPsmd15x11-6-374m1U40ISO1050so9x6-8-191m1U41EMMC16GBGA11X13-153-39M1U4374LVC1G125SC70-5-43M1U44CDCM9102qfn5x5-32ti-39m1U45TPD12S016pw_24pin_tssop1U46DNI SN74LVC1G07u_5_dck1U47TPD1E10B06tpd1e10b06-2l1U48TPD1E10B06tpd1e10b06-2l1U49TPD1E10B06tpd1e10b06-2l1U50TPS76650soic_81U52TPS63010u_20_dsbga1U62SN74AVC4T245U_16_PW1U63TPD2EUSB30DRTRSOT1X1-3-20M1U64SN74AVC2T244son2x1-8-16m1U65TPS2065DU_8_D1U66SN74LVC1G08sm-so-sc70-51U68SN74LVC1G08sm-so-sc70-51U69SN74LVC1G08sm-so-sc70-51U70SN74LVC1G08sm-so-sc70-51U71SN65HVS882u_28_pwp1U72TPIC2810u_16_d1U73ISO1176Tu_16_dw1U74SN74AVC2T244son2x1-8-16m1U75TPS71712smdsc70-51U76SN65HVD78Dsoic_81U77SN74LVC1G07SC70-5-43M1U78TPS61085MSOP3X3-8-43M1U79TPD1E10B06tpd1e10b06-2l1U80TPD1E10B06tpd1e10b06-2l1U81TPD1E10B06tpd1e10b06-2l1U82TPD1E10B06tpd1e10b06-2l1U83TPD1E10B06tpd1e10b06-2l1U84SN74LVC1G08sm-so-sc70-51U85LP38693ADJSOT-223-51U86TPD1E10B06tpd1e10b06-2l1U87TPD1E10B06tpd1e10b06-2l1U88TC358778BGA7X7-80-39M1U89MT41K256M16TW-107:Pbga9x14-961U90MT41K256M16TW-107:Pbga9x14-961U91TPS51200drcpso_10pin1U92TPD4S012U_6_DRY1U93TPS2051BDU_8_D1U94TPD4E05U06USON2X1-10-22M1U95SN74LVC1G07SC70-5-43M1U96SN74LVC1G07u_5_dck1U97SN74LVC1G08sm-so-sc70-51U9820.000 MHZOSC7X5-71M1X120MHzXTAL2X3-30M1Y116.384MHzxtal3225-39m1Y225MHzSM_OSC_ABM31Y325MHzSM_OSC_ABM31Y412MHzSM_OSC_ABM31Y532.768KHz MC-306MC-3061Y625MHzasf_smd3_2x5mm1Y7
zhifang88 发表于 2018-11-12 18:11
真的好长啊!
yangxf0120 发表于 2018-11-12 20:01
谢谢分享AM574x的PCB和原理图
bidezhi7777 发表于 2018-11-12 21:05
bidinghong 发表于 2018-11-13 08:50
zz60754405 发表于 2018-11-13 09:11
漂亮,,,
baihushan 发表于 2018-11-13 09:48
moqidaodao 发表于 2026-2-3 10:51
感谢分享
pippin 发表于 2026-7-5 00:00
:handshake
wangbin88 发表于 2026-7-5 08:33
感谢分享
查看完整版本: AM574x的PCB和原理图(12层,6011 PIN)
