topdenzengzhi 发表于 2018-11-12 21:41
华硕K42F笔记本电脑主板PCB文件共享 6层6647Pins
**** Hidden Message *****
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDESL0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzAL10L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzAL11L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzAL12SOT23_APECNPN_SOT23_SOT23_APEC_DISCRETE_MMMBT1815LAQ1SOT23_H43NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904AQ2NB_C7343D_H79CAP_NB_C7343D_H79_DISCRETE_330U330UF/2VCE0604NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VCE1603NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VCE1703C3528CAP_C3528_DISCRETE_47UF/6.3V47UF/6.3VCE5001C3528CAP_C3528_DISCRETE_47UF/6.3V47UF/6.3VCE5101C3528CAP_C3528_DISCRETE_47UF/6.3V47UF/6.3VCE5102C3528_H47_RD9CAP_C3528_H47_RD9_DISCRETE_47UF47UF/6.3VCE5201C3528_H47_RD9CAP_C3528_H47_RD9_DISCRETE_47UF47UF/6.3VCE5202LED_3P_126X59_HARVLED_3P_HARVA_LED_3P_126X59_HARVAMBER/GREENCHR_LED1L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzCL1L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzCL3C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3101C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3102C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3103C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3104C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3105C_ARRAY_8P_79X49_H28C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VCN3106SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002CQ2R0402R_R0402_DISCRETE_10KOHM10KOhmCR234R8P0402_H204R8PS_4R8P0402_H20_DISCRETE_10K10KOhmCRN2NB_TPC16B_P16_50TEST_POINT_NB_TPC16B_P16_50_TPCTPC16B_P16_50CT1NB_TPC16B_P16_50TEST_POINT_NB_TPC16B_P16_50_TPCTPC16B_P16_50CT2SOIC_56P_20_555X319ICS9LPRS427BGLFT_SOIC_56P_20_55ICS9LPRS427CGLFTCU1XTAL_4P_126X98_EPSCRYSTAL_SMD_24GND_XTAL_4P_126X914.31818MhzCX1C0402C_C0402_DISCRETE_0.01UF/25V0.01UF/25VCX5120SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWD2202SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWD2204SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWD2701SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWD2702SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWD3001SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWD3702SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWD4503SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWD4504SOT323DUAL_DIODE_CONVERT_1ANODE_SOT32BAV99W_LD4506SOT323DUAL_DIODE_CONVERT_1ANODE_SOT32BAV99W_LD4507SOT23_S6_H43IP4220CZ6_SOT23_S6_H43_DISCRETEIP4220CZ6D4601SOD323_H35DIODE_SOD323_H35_DISCRETE_1SS351SS355D4606D0603VPORT_0603_D0603_DISCRETE_EGA10EGA10603V05A1D4612NB_SOT23_S6_NATIONAL_REDUCEAZ1015_04SR7F_NB_SOT23_S6_NATIOAZC099-04SD5201NB_SOT23_S5_SC70_FAIRCHILDDF5A_NB_SOT23_S5_SC70_FAIRCHILDDF5A6.8FUD6005SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWD6101NB_D_SUB_15P_2HD_RA_SY_LF2D_SUB_15P_2HOLD_SYIN_NB_D_SUB_1D_SUB_15PD-SUB1FPC_12P_20_2HD_RA_ENT_BFPC_CON_12P_2HOLD_KEC_FPC_12P_2ZIF_CON_12PDEBUG1DDR3_DIMM_204P_24_4HOLD_FXCDDR3_DIMM_204P_4HOLD_DDR3_DIMM_DDR3_DIMM_204PDIMM1DDR3_DIMM_204P_24_4H_MO_REVDDR3_DIMM_204P_4HOLD_DDR3_DIM_1DDR3_DIMM_204PDIMM2POLYSWITCH_2P_1206_ACM_H33POLY_FUSE_POLYSWITCH_2P_1206_AC0.35A/6VF3301POLYSWITCH_2P_1206_ACM_H33POLY_FUSE_POLYSWITCH_2P_1206_AC0.35A/6VF4802POLYSWITCH_2P_1206_H71POLY_FUSE_POLYSWITCH_2P_1206_H71.5A/6VF5201WTOB_4P_49_2HOLD_ACESFPC_4P_2HOLD_WTOB_4P_49_2HOLD_AWTOB_CON_4PFAN1NB_H_CT315CB217D138_P2HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138H6501NB_H_CT315CB217D138_P2HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138H6502NB_H_CT315CB217D138_P2HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138H6503NB_H_CT315CB217D138_P2HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138H6504NB_H_CT252B189D94_P2HOLE_PTH_NB_H_CT252B189D94_P2_CCT252B189D94H6514NB_H_C252D94_P2HOLE_PTH_NB_H_C252D94_P2_C252D9C252D94H6515NB_H_C252D94_P2HOLE_PTH_NB_H_C252D94_P2_C252D9C252D94H6516NB_H_CT252B189D94_P2HOLE_PTH_NB_H_CT252B189D94_P2_CCT252B189D94H6517NB_H_C252D94_P2HOLE_PTH_NB_H_C252D94_P2_C252D9C252D94H6518NB_H_O122X102DO122X102NHOLE_NPTH_NB_H_O122X102DO122X10O122X102DO122X102NH6526NB_H_O122X102DO122X102NHOLE_NPTH_NB_H_O122X102DO122X10O122X102DO122X102NH6527HOLE_C276D276NHOLE_NPTH_HOLE_C276D276N_C276D2C276D276NH6528NB_SATA_CON_22P_4HD_SAN_RASATA_CON_22P_4HOLD_TC_NB_SATA_CSATA_CON_22PHDD1LED_3P_126X59LED_3P_3NC_LED_3P_126X59_DISCREGREENHDD_LED1NB_HDMI_19P_4H_H210_LF2HDMI_CON_19P_4HOLD_CRE_NB_HDMI_HDMI_CON_19PHDMI_CON1NB_PH_JACK_6P_4HD_SI_LF2PHONE_JACK_6P_4HD_SINH_NB_PH_JAPHONE_JACK_6PHP_MIC1SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3001SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3002SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3003SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3004SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3005SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3006SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3007SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3301SHORTPIN_R0603SL_0603_SHORTPIN_R0603_SHORT LASHORT LANDJP3302NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINJP4601NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINJP4602NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINJP4603NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPJRST2001NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPJRST2002FPC_CON_24P_39_2HOLDFPC_CON_24P_2HOLD_RD9_FPC_CON_2FPC_CON_24PKB_CON1L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2601L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2605L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2608L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2609L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2610L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2704L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2705L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2706L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL2707L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL3001CHOKE_2P_158X177INDUCTOR_CHOKE_2P_158X177_DISCR4.7UHL3301L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzL3621L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzL4502L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzL4507L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL4590L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL4591L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL4592CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzL4801CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzL4802CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzL4803CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzL4804L0603BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL4810L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzL5201CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzL6101WTOB_40P_20_4HOLD_RAWTOB_CON_40P_4HOLD_PEX_WTOB_40PWTOB_CON_ 40PLVDS1L0603INDUCTOR_L0603_DISCRETE_0.082UH0.082uHLX4601L0603INDUCTOR_L0603_DISCRETE_0.082UH0.082uHLX4602L0603INDUCTOR_L0603_DISCRETE_0.082UH0.082uHLX4603CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzLX5201CHOKE_4P_79X47_FUKUICOMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzLX5202NB_SATA_13P_4HOLD_SANTA_LF2SATA_CON_13P_4HOLD_ALLTOP_NB_SASATA_CON_13PODD1C7343D_H87CAP_C7343D_H87_DISCRETE_100UF/6100UF/6.3VPCE8101C7343D_H87CAP_C7343D_H87_DISCRETE_100UF/6100UF/6.3VPCE8102C7343D_H75CAP_C7343D_H75_DISCRETE_15UF/2515UF/25VPCE8212NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VPCE8301NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VPCE8302C7343D_H75CAP_C7343D_H75_DISCRETE_15UF/2515UF/25VPCE8313CESMD_260X260_SMD122X74_NICCAP_CESMD_260X260_SMD122X74_NIC27UF/25VPCE8801NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_470U470uF/2VPCE8802NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_470U470uF/2VPCE8803CESMD_260X260_SMD122X74_NICCAP_CESMD_260X260_SMD122X74_NIC27UF/25VPCE8804NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_470U470uF/2VPCE8805NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_470U470uF/2VPCE8806C7343D_H75CAP_C7343D_H75_DISCRETE_15UF/2515UF/25VPCE8914NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VPCE9101C7343D_H75CAP_C7343D_H75_DISCRETE_15UF/2515UF/25VPCE9115NB_C7343D_H83CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VPCE9201C7343D_H75CAP_C7343D_H75_DISCRETE_15UF/2515UF/25VPCE9202SOT323DUAL_DIODE_CONVERT_1ANODE_SOT_1BAT54SWPD8101SOT323DUAL_DIODE_CONVERT_1ANODE_SOT_1BAT54SWPD8102SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWPD8103SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD8301SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWPD8302SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD8481SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD8482SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD8601SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD8602SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWPD8603SOT323BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWPD8801SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWPD8902SOD323_H37DIODE_SOD323_H37_DISCRETE_1N4141N4148WSPD9101SOT323DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWPD9102NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8101NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8102NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8103NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8104NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8105NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8106NB_1MM_OPEN_5MIL_FLASH_LF3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILPJP8108NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8109NB_1MM_OPEN_5MIL_FLASH_LF3MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILPJP8110NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8301NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8302NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8303NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8304NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8305NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8306NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8307NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPPJP8701NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPPJP8702NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPPJP8703NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPPJP8704NB_OPEN2_5MIL_PT3MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPPJP8705NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP8902NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8903NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP8904NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9101NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP9102NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9103NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP9104NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9105NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9201NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9202NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP9203NB_3MM_OPEN_5MIL_LF3MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILPJP9204NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9205NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9206NB_PWR_FB_SHORT_PTSHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINPJP9207L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL0601L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8102L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8103INDUCTOR_2P_291X260INDUCTOR_INDUCTOR_2P_291X260_DI4.7UHPL8110INDUCTOR_2P_291X260INDUCTOR_INDUCTOR_2P_291X260_DI4.7UHPL8111L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8301L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8302CHOKE_2P_453X394_CYNINDUCTOR_CHOKE_2P_453X394_CYN_D0.56UHPL8303L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8481L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8482L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8483SHORTPIN_R0402SL_0402_SHORTPIN_R0402_SHORT LASHORT LANDPL8651SHORTPIN_R0402SL_0402_SHORTPIN_R0402_SHORT LASHORT LANDPL8652SHORTPIN_R0402SL_0402_SHORTPIN_R0402_SHORT LASHORT LANDPL8653L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8801L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8802CHOKE_2P_453X394INDUCTOR_CHOKE_2P_453X394_DISCR0.36UHPL8803L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8804L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8805CHOKE_2P_453X394INDUCTOR_CHOKE_2P_453X394_DISCR0.36UHPL8806L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8901L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL8902INDUCTOR_2P_394X402INDUCTOR_INDUCTOR_2P_394X402_DI10UHPL8903L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL9101L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL9102INDUCTOR_2P_291X260INDUCTOR_INDUCTOR_2P_291X260__12.0UHPL9103L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL9104INDUCTOR_2P_291X260INDUCTOR_INDUCTOR_2P_291X260__12.0UHPL9105L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL9201L0805_H43BEAD_L0805_H43_DISCRETE_70OHM/170Ohm/100MhzPL9202INDUCTOR_2P_287X260INDUCTOR_INDUCTOR_2P_287X260_DI0.68UHPL9203WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8101EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8102EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8103EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8104WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8301WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8302WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8303WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8304SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ8340SOT353NPN_PNP_SOT353_SOT353_DISCRETE_UMC4NPQ8503SOT353NPN_PNP_SOT353_SOT353_DISCRETE_UMC4NPQ8504EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8509EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8510EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8512EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8513SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ8601WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8801WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8802WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8803WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8804WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8806WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ8807SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ8808SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ8809SOIC_8P_50_201X236P_MOS_SO8_SOIC_8P_50_201X236_DIEMB07P03GPQ8903EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8904EMB20N03VSI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VPQ8905SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ8906SOT23_H43NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904PQ8907WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ9101WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ9102SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ9140WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ9202WPAK_7P_50_201X240RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0PQ9203SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NPQ93124R8P0402_H204R8PS_4R8P0402_H20_DISCRETE_1KO1KOHMPRN92014R8P0402_H204R8PS_4R8P0402_H20_DISCRETE_1KO1KOHMPRN9202SHORTPIN_R0402SL_0402_SHORTPIN_R0402_SHORT LASHORT LANDPSL8801NB_QFN_32P_S197_PA_S_H31_4VRT8206AGQW_4VIA_NB_QFN_32P_S197RT8206AGQWPU8101MB_SOT23_S5_MAXUP7714HMA5_MB_SOT23_S5_MAX_IC_UUP7714BMA5-00PU8102MB_QFN_16P_20_S118_PAD_4VRT8202APQW_4VIA_MB_QFN_16P_20_SRT8202APQWPU8301MB_SOIC_8P_197X236_4VIAUP7706U8_4VIA_MB_SOIC_8P_197X23UP7706U8PU8401MB_SOIC_8P_197X236_4VIAUP7706U8_4VIA_MB_SOIC_8P_197X23UP7706U8PU8402MB_QFN_40P_20_S236_PAD_V4RT8856GQW_4VIA_MB_QFN_40P_20_S2RT8856GQWPU8801MB_QFN_32P_20_S197_PAD_A_4VMB39A132_4VIA_MB_QFN_32P_20_S19MB39A132PU8901MB_SOT23_S5_MAXUP7714HMA5_MB_SOT23_S5_MAX_IC_UUP7714BMA5-00PU9021MB_QFN_16P_20_S118_PAD_4VRT8202APQW_4VIA_MB_QFN_16P_20_SRT8202APQWPU9101MB_SOIC_8P_50_197X236_PD_4VUP7711U8_4VIA_MB_SOIC_8P_50_197UP7711U8PU9103MB_QFN_32P_20_S197_RIC_4VIART8152GQW_MB_QFN_32P_20_S197_RIRT8152CGQWPU9201LED_3P_126X59LED_3P_3NC_LED_3P_126X59_DISCREGREENPWR_LED1SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002Q0301SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ2801SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ2802SOT23_H43NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904Q3201SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ3202SO6_H43N_MOS_SO6_SO6_H43_DISCRETE_SI34SI3456BDVQ4504SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002Q4505SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ4511SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ4602SOT23_H43NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904Q4803SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRET_1SI2304BDSQ4810SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002Q5601SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5701SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5702SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5703SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5704SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5705SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5706SOT363_NBUM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NQ5707SOT23_H43N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002Q7502R0402_H16R_R0402_H16_DISCRETE_49.9OHM49.9OhmR0301R0402_H16R_R0402_H16_DISCRETE_750OHM750OhmR03024R8P0402_H204R8PS_4R8P0402_H20_DISCRETE_10K10KOhmRN03014R8P04024R8PS_4R8P0402_DISCRETE_0OHM0OHMRN2001R0603_H24R_R0603_H24_DISCRETE_0OHM0OhmRX4603R0603_H24R_R0603_H24_DISCRETE_0OHM0OhmRX4604NB_SD_SOCKET_9P_5HD_LF2SD_CARD_9P_5HOLD_NB_SD_SOCKET_9SD_SOCKET_9PSD_CON1WTOB_4P_49_RA_ENTERYFPC_4P_2HOLD_WTOB_4P_49_RA_ENTEWtoB_CON_4PSPEAKER_CON1NB_TPC26T_68TEST_POINT_NB_TPC26T_68_TPC26TTPC26TT6101FPC_12P_20_2HOLD_RA_ACESFPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PTOUCH_PAD1SW_5P_315X244_H126TP_SWITCH_5P_DIPT_SW_5P_315X244TACT_SWITCH_5PTP_L_SW1SW_5P_315X244_H126TP_SWITCH_5P_DIPT_SW_5P_315X244TACT_SWITCH_5PTP_R_SW1NB_SOCKET989PZ98927_NB_SOCKET989_IO_SOCKET9SOCKET989U0301NB_BGA_1071P_20_1063X984IBEXPEAK_M_NB_BGA_1071P_20_1063IBEXPEAK-MU2001SC70_S5NC7SZ08M5_SC70_S5_IC_NC7SZ08P5XNC7SZ08P5X_NLU2401SOIC_8P_50_213X311MX25L1605DPI_SOIC_8P_50_213X311MX25L3205DM2I-12GU2801QFP_128P_16_630X630IT8500E_L_QFP_128P_16_630X630_IIT8500E-LU3001QFP_64P_16_354X354_H63JMC251_V10_QFP_64P_16_354X354_HJMC251-V10U3301WD_SOIC_8P_50_197X236ATM_SO_8P_WD_SOIC_8P_50_197X236AT24C08BN-SH-TU3302NB_QFN_48P_20_276X276_9VIAALC269_9VIA_NB_QFN_48P_20_276X2ALC269Q-VA6-GRU3621SOT753SN74LVC1G125DCKR_SOT753_IC_74LV74LVC1G125GVU4601SOT753SN74LVC1G125DCKR_SOT753_IC_74LV74LVC1G125GVU4602QFN_48P_20_276X276_PAD_QLMPS8101_QFN_48P_20_276X276_PAD_QPS8101U4801WTOB_6P_39_2HOLD_RAZIF_CON_6P_2HOLD_WTOB_6P_39_2HOWTOB_CON_6PU7502NB_SOT23_S5_H55G709T1UF_NB_SOT23_S5_H55_IC_G70G709T1UFU7503NB_USB_1X4P_4HD_SUN_LF2USB_CON_1X4P_4HOLD_SUY_NB_USB_1USB_CON_1X4PUSB1NB_USB_1X4P_4HD_SUN_LF2USB_CON_1X4P_4HOLD_SUY_NB_USB_1USB_CON_1X4PUSB2LED_3P_126X59LED_3P_3NC_LED_3P_126X59_DISCREGREENWIFI_LED1XTAL_4P_272X55CRYSTAL_SMD_23GND_XTAL_4P_272X532.768KhzX2001XTAL_2P_236X138CRYSTAL_XTAL_2P_236X138_DISCRET25MhzX2101XTAL_4P_272X55CRYSTAL_SMD_23GND_XTAL_4P_272X532.768KhzX3001XTAL_2P_236X138CRYSTAL_XTAL_2P_236X138_DISCRET25MhzX3301BTOB_60P_20_F_SAMAXK6F60335_BTOB_60P_20_F_SAM_IOBtoB_CON_60PXDP1
yfchen1003 发表于 2018-11-13 08:17
谢谢分享
zblin1987 发表于 2018-11-13 08:29
cdpi5 发表于 2018-11-13 08:58
星空下石头 发表于 2018-11-13 08:58
miaomiao 发表于 2018-11-13 10:03
看看,谢谢分享哦
xianrui1989 发表于 2018-11-13 10:31
谢谢分享,学习一下
yaoguang 发表于 2018-11-13 14:48
bidezhi7777 发表于 2018-11-13 20:19
木子健518 发表于 2018-11-14 17:10
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 华硕K42F笔记本电脑主板PCB文件共享 6层6647Pins
