topdenzengzhi 发表于 2018-11-14 21:41
AFE4403微型脉动式血氧计参考设计原理图与PCB文件共享
**** Hidden Message *****
DescriptionQuantityFootprintDesignatorCAP, CERM, 0.1uF, 10V, +/-10%,X5R, 020110201C1CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C2CAP, CERAMIC,470nF, 10%, 16V, X5R, 040210402C3CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C4CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C5CAP, TANTALUM,2.2uF, 20%, 10V, 06031C0603_POLC6CAP,TANTALUM,33uF, 20%, 6.3V, 1.5 OHM, 06031C0603_POLC7CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C8CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C9CAP, CERM,0.1uF, 10V, +/-10%, X5R, 020110201C10CAP, CERM,2200pF, 10V, +/-10%, X5R, 020110201C11CAP,TANTALUM,10UF, 20%, 6.3V, 6 OHM, SMT06031C0603_POL1C12LED, GREEN,SMT04021LED_0402D122pin SPO2Module Connector pads1CONN-22PADSJ1RES, 1.0Megohm, 5%, 0.063W, 04021R0402R1RES, 0 ohm,5%, 0.05W, 02011R0201R2RES, 3.3k ohm,1%, 0.05W, 02011R0201R3RES, 47k ohm,1%, 0.05W, 02011R0201R4BGA, 36 PINS1BGA36C50P6X6_304X304X50U1IC, MIXEDSIGNAL MICROCONTROLLER, BGA-641YFF-64U2IntegratedDual Emitter and Photodetector1DCM03U3CRYSTAL, PIEZOCERAMIC RESONATOR, 16.00 MHz, SMD, 0.5%, 15pF, SMD1RESONATOR-1.3X3.2-MURATAY1
带刀的老鼠 发表于 2018-11-14 22:09
桑子亡心 发表于 2018-11-14 22:21
看一下这个,谢啦!!!
风中思雨 发表于 2018-11-14 22:33
经纬 发表于 2018-11-14 22:43
谢谢
1014587981 发表于 2018-11-15 08:27
ilpuyi 发表于 2018-11-15 08:32
doomy 发表于 2018-11-15 08:36
bbkhslhj 发表于 2018-11-15 08:39
ntpcbyanli4111 发表于 2018-11-15 08:48
页: [1] 2 3 4 5 6 7
查看完整版本: AFE4403微型脉动式血氧计参考设计原理图与PCB文件共享
