碎碎思 发表于 2018-11-28 18:02
4层-可控制汽车 HVAC压缩机的无刷直流 (BLDC)电机参考设计PCB
**** Hidden Message *****
原理图与
PCB
4层PCB设计,927Pins
FootprintCommentLibRefDesignatorDescriptionQuantity Printed Circuit BoardPCB!PCBPrinted Circuit Board11210_280CGA6P3X7S1H106K250ABCGA6P3X7S1H106K250ABC100,C102, C107, C114, C115, C118, C119, C303, C304, C305CAP, CERM, 10 µF, 50V, +/- 10%, X7S, AEC-Q200 Grade 1, 1210100603GCM188R71H103KA37DGCM188R71H103KA37DC101,C112, C526CAP, CERM, 0.01 µF,50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 060330805_HVCGA4J3X8R1C105K125ABCGA4J3X8R1C105K125ABC103CAP, CERM, 1 µF, 16V, +/- 20%, X8R, AEC-Q200 Grade 0, 080510805_HVGCM21BR70J106KE22LGCM21BR70J106KE22LC104CAP, CERM, 10 µF, 6.3V, +/- 10%, X7R, AEC-Q200 Grade 1, 080510805_HVGCM21BR72A473KA37LGCM21BR72A473KA37LC105,C111, C125, C126CAP, CERM, 0.047 µF,100 V, +/- 10%, X7R, AEC-Q200 Grade 1, 080540805_HVGCM21BR71H104KA37KGCM21BR71H104KA37KC106,C108CAP, CERM, 0.1 µF, 50V, +/- 10%, X7R, AEC-Q200 Grade 1, 080520603CGA3E2C0G1H103J080AACGA3E2C0G1H103J080AAC109CAP, CERM, 0.01 µF,50 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 060310603CGA3E1X7R1V105K080ACCGA3E1X7R1V105K080ACC110CAP, CERM, 1 µF, 35V, +/- 10%, X7R, AEC-Q200 Grade 1, 060310603GCM1885C2A102JA16DGCM1885C2A102JA16DC113CAP, CERM, 1000 pF,100 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 060311210_280CGA6P1X7S3D222M250AACGA6P1X7S3D222M250AAC116CAP, CERM, 2200 pF,2000 V, +/- 20%, X7S, AEC-Q200 Grade 1, 121011210_280CGA6P3X7R1H475K250ABCGA6P3X7R1H475K250ABC117CAP, CERM, 4.7 µF, 50V, +/- 10%, X7R, AEC-Q200 Grade 1, 121010603CGA3E2X8R1E104K080AACGA3E2X8R1E104K080AAC120,C121, C122, C123, C127, C300, C309, C403, C404, C405, C406, C408, C411, C413,C415, C525CAP, CERM, 0.1 µF, 25V, +/- 10%, X8R, AEC-Q200 Grade 0, 0603160603CGA3E2X7R2A103K080AACGA3E2X7R2A103K080AAC124CAP, CERM, 0.01 µF,100 V, +/- 10%, X7R, AEC-Q200 Grade 1, 060310603CGA3E2X7R1H473K080AACGA3E2X7R1H473K080AAC301,C407, C410, C412CAP, CERM, 0.047 µF,50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 060340603C0603C102J5RACAUTOC0603C102J5RACAUTOC302,C517, C518, C519, C521, C524, C527CAP, CERM, 1000 pF,50 V, +/- 5%, X7R, AEC-Q200 Grade 1, 0603, CAP, CERM, 1000 pF, 50 V, +/- 5%,X7R, AEC-Q200 Grade 1, 0603, CAP, CERM, 1000 pF, 50 V, +/- 5%, X7R, AEC-Q200Grade 1, 0603, CAP, CERM, 1000 pF, 50 V, +/- 5%, X7R, AEC-Q200 Grade 1, 0603,CAP, CERM, 1000 pF, 50 V,+/- 5%, X7R, AEC-Q200 Grade 1, 0603, CAP, CERM, 1000pF, 50 V,+/- 5%, X7R, AEC-Q200 Grade 1, 0603, CAP, CERM, 1000 pF, 50 V,+/-5%, X7R, AEC-Q200 Grade 1, 060370603CGA3E3X7R1H154K080ABCGA3E3X7R1H154K080ABC306,C307, C308CAP, CERM, 0.15 µF,50 V, +/- 10%, X7R, AEC-Q200 Grade 1, 060330603CGA3E2C0G1H470J080AACGA3E2C0G1H470J080AAC400,C401, C402CAP, CERM, 47 pF, 50V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 060330603CEU3E2X7R2A332K080AECEU3E2X7R2A332K080AEC414CAP, CERM, 3300 pF,100 V,+/- 10%, X7R, AEC-Q200 Grade 1, 060310603CGA3E2NP01H101J080AACGA3E2NP01H101J080AAC500,C507, C512CAP, CERM, 100 pF, 50V, +/- 5%, C0G/NP0, AEC-Q200 Grade 0, 060330603CGJ3E2X7R1C104K080AACGJ3E2X7R1C104K080AAC501,C503, C505, C509, C511, C513, C515CAP, CERM, 0.1 µF, 16V, +/- 10%, X7R, AEC-Q200 Grade 1, 060370603CGA3E1X7S1C225M080ACCGA3E1X7S1C225M080ACC502,C504, C506, C508, C510, C514, C516CAP, CERM, 2.2 µF, 16V, +/- 20%, X7S, AEC-Q200 Grade 1, 060370603GCM188R71C104KA37JGCM188R71C104KA37JC520,C522CAP, CERM, 0.1 µF, 16V,+/- 10%, X7R, AEC-Q200 Grade 1, 060320603CGA3E2C0G1H220J080AACGA3E2C0G1H220J080AAC528CAP, CERM, 22 pF, 50V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 060310603C0603C103J3GECAUTOC0603C103J3GECAUTOC529CAP, CERM, 0.01 µF,25 V, +/- 5%, C0G/NP0, AEC-Q200 Grade 1, 06031SMASS25S-E3/5ATSS25S-E3/5ATD100,D102Diode, Schottky, 50V, 2 A, AEC-Q101, SMA2SMC_265SS3H10HE3_A/ISS3H10HE3_A/ID101Diode, Schottky, 100V, 3 A, AEC-Q101, SMC1SMC_265TPSMD26ATPSMD26AD103Diode, TVS, Uni, 26V, 42.1 Vc, AEC-Q101, SMC1WL-SMCW_YELLOW150060YS75000150060YS75000D104LED, Yellow, SMD1SMAB360AM-13-FB360AM-13-FD300,D301, D302, D311, D312, D313Diode, Schottky, 60V, 3 A, AEC-Q101, SMA6SOD-523RB520SM-40FHRB520SM-40FHD303,D304, D305, D306, D307, D308, D314, D315, D316, D317, D318, D319Diode, Schottky, 45V, 0.2 A, AEC-Q101, SOD-52312SOD-323ZLLS400QTAZLLS400QTAD309,D310, D400, D401, D402, D403, D404, D405, D406, D409, D410, D411, D412, D413Diode, Schottky, 40V, 0.52 A, AEC-Q101, SOD-32314SMAUS1J-E3/5ATUS1J-E3/5ATD320,D321, D322Diode, Ultrafast, 600V, 1 A, AEC-Q101, SMA3NY PMS 4400025 PHNY PMS 440 0025 PHNY PMS 440 0025 PHH1,H2, H3, H4Machine Screw, Round,#4-40 x 1/4, Nylon, Philips panhead4Keystone_1902C1902C1902CH5,H6, H7, H8Standoff, Hex,0.5"L #4-40 Nylon4Phoenix_172567217256721725672J100Terminal Block, 4x1,2.54 mm, Green, TH1Phoenix_171495517149551714955J300Terminal Block, 2x1,6.35mm, Green, TH1Phoenix_171496817149681714968J301Terminal Block, 3x1,6.35 mm, TH1Mill-Max_800-10-003-10-001000800-10-003-10-001000800-10-003-10-001000J302Header, 100mil, 3x1,TH1Molex_001591214000159121400015912140J500Header, 100mil, 7x2,SMT10805_HVBKP2125HS600-TBKP2125HS600-TL500Ferrite Bead, 60 ohm@ 100 MHz, 3 A, 08051Label_650x200Size: 0.65" x0.20 "THT-14-423-10LBL1Thermal TransferPrintable Labels, 0.650" W x 0.200" H - 10,000 per roll1TO-220ABIXYP15N65C3D1IXYP15N65C3D1, IXYSQ300,Q301, Q302, Q303, Q304, Q305Transistor, IGBT, 650V, 80 A, TO-220AB6SOT-23FMMT720TAFMMT720TA, DiodesInc.Q306,Q307, Q308Transistor, PNP, 40V, 1.5 A, AEC-Q101, SOT-2330603ERJ-3EKF2002VERJ-3EKF2002VR100,R102, R103, R104RES, 20.0 k, 1%, 0.1W, AEC-Q200 Grade 0, 060340603ERJ-3EKF3303VERJ-3EKF3303VR101RES, 330 k, 1%, 0.1W, AEC-Q200 Grade 0, 060310603TNPW0603100KBEEATNPW0603100KBEEAR105,R400, R401, R402, R415, R416, R417RES, 100 k, 0.1%, 0.1W, AEC-Q200 Grade 1, 060370603ERJ-3EKF2702VERJ-3EKF2702VR106RES, 27.0 k, 1%, 0.1W, AEC-Q200 Grade 0, 06031TNPW0603TNPW06036K34BEEATNPW06036K34BEEAR107RES, 6.34 k, 0.1%,0.1 W, AEC-Q200 Grade 1, 06031TNPW0603TNPW060310K0BEEATNPW060310K0BEEAR108,R113, R322, R323, R324, R406, R407, R408, R409, R411, R412, R413, R414, R422,R423, R425, R429, R430, R439, R440, R442, R446, R449, R450, R452, R456, R459,R460, R525, R526, R527RES, 10.0 k, 0.1%,0.1 W, AEC-Q200 Grade 1, 0603310603SERJ-3GEYJ472VERJ-3GEYJ472VR109RES, 4.7 k, 5%, 0.1W, AEC-Q200 Grade 0, 060310603ERJ-3GEYJ472VERJ-3GEYJ472VR110,R325, R326, R327RES, 4.7 k, 5%, 0.1W, AEC-Q200 Grade 0, 060341206CRCW120660R0KNEAIFCRCW120660R0KNEAIFR111,R112RES, 60, 10%, 0.25 W,AEC-Q200 Grade 0, 120621206CRCW12064R70JNEAHPCRCW12064R70JNEAHPR114,R115RES, 4.7, 5%, 0.75 W,AEC-Q200 Grade 0, 120620603ERA-3AEB301VERA-3AEB301VR116RES, 300, 0.1%, 0.1W, AEC-Q200 Grade 0, 06031TNPV1206TNPV1206499KBEENTNPV1206499KBEENR301,R308, R309, R403, R404, R405, R418, R419, R420, R431, R432, R433RES, 499 k, 0.1%, 1W, 1206121210MCRCW121010R0FKEAHPCRCW121010R0FKEAHPR302,R303, R304, R305, R306, R307, R313, R314, R315, R316, R317, R318RES, 10.0, 1%, 0.75W, AEC-Q200 Grade 0, 1210120603ERJ-3EKF1000VERJ-3EKF1000VR311,R504, R505, R507, R512, R518, R520RES, 100, 1%, 0.1 W,AEC-Q200 Grade 0, 060371206ERA-8APB6341VERA-8APB6341VR312,R410, R421, R436RES, 6.34 k, 0.1%,0.25 W, AEC-Q200 Grade 0, 120640805_HVERJ-6RQF5R1VERJ-6RQF5R1VR319,R320, R321RES, 5.10, 1%, 0.125W, AEC-Q200 Grade 0, 080531206WSLP1206R0100FEAWSLP1206R0100FEAR328,R329, R330, R331, R332, R333RES, 0.01, 1%, 1 W,120660603ERJ-3GEYJ222VERJ-3GEYJ222VR334,R335, R336, R337, R338, R339, R506, R510, R517RES, 2.2 k, 5%, 0.1W, AEC-Q200 Grade 0, 060390603ERJ-3EKF3002VERJ-3EKF3002VR424,R428, R441, R445, R451, R455RES, 30.0 k, 1%, 0.1W, AEC-Q200 Grade 0, 060360603ERA-3AEB242VERA-3AEB242VR426,R427, R443, R444, R453, R454RES, 2.40 k, 0.1%,0.1 W, AEC-Q200 Grade 0, 060360603ERA-3AEB104VERA-3AEB104VR434,R435, R447, R448, R457, R458RES, 100 k, 0.1%, 0.1W, AEC-Q200 Grade 0, 060360603RCA06031K00JNEARCA06031K00JNEAR438,R521, R522, R523, R524RES, 1.0 k, 5%, 0.1W, AEC-Q200 Grade 0, 060350603ERJ-3GEYJ122VERJ-3GEYJ122VR500,R501, R503, R508, R513, R519RES, 1.2 k, 5%, 0.1W, AEC-Q200 Grade 0, 060360603ERJ-3EKF30R0VERJ-3EKF30R0VR502,R528RES, 30.0, 1%, 0.1 W,AEC-Q200 Grade 0, 060320603ERJ-3GEYJ470VERJ-3GEYJ470VR509,R511, R514, R515, R516RES, 47, 5%, 0.1 W,AEC-Q200 Grade 0, 060350603RMCF0603ZT0R00RMCF0603ZT0R00R529RES, 0, 1%, 0.1 W,AEC-Q200 Grade 0, 06031Wurth_750315445750315445750315445T100Transformer, 25 uH,TH1Keystone512851285128TP505,TP506, TP508, TP509Test Point,Multipurpose, Grey, TH4PWP0014A_NLM5160QPWPRQ1LM5160QPWPRQ1U100Wide Input 65V, 1.5ASynchronous Buck / Fly-Buck(TM) Converter, PWP0014A (TSSOP-14)1PWP0020D_NTPS7B6733QPWPRQ1TPS7B6733QPWPRQ1U101Automotive 450-mAHigh-Voltage Ultra-Low IQ Low-Dropout Regulator, PWP0020D (TSSOP-20)1PWP0020D_NTPS7B6750QPWPRQ1TPS7B6750QPWPRQ1U102Automotive 450-mAHigh-Voltage Ultra-Low IQ Low-Dropout Regulator, PWP0020D (TSSOP-20)1D0008A_NTCAN1042HGVDQ1TCAN1042HGVDQ1U103Automotive FaultProtected CAN Transceiver With Flexible Data-Rate, D0008A (SOIC-8)1DW0016B_HVISO7731FQDWRQ1ISO7731FQDWRQ1U104High Speed, RobustEMC Reinforced Triple-Channel Digital Isolator, DW0016B (SOIC-16)1DCK0005A_NLMT87QDCKRQ1LMT87QDCKRQ1U300Automotive Grade,2.7V-Capable, 10 uA Analog Output Temperature Sensor, DCK0005A (SOT-5)1D0008A_NUCC27712QDRQ1UCC27712QDRQ1U301,U302, U303620-V High-SideLow-Side Gate Driver with 2.5A Peak Output and RobustDrive, D0008A (SOIC-8)3PW0020A_NSN74LVC541AQPWRQ1SN74LVC541AQPWRQ1U304Octal Buffer/DriverWith 3-State Outputs, PW0020A (TSSOP-20)1DBV0005A_NOPA365AQDBVRQ1OPA365AQDBVRQ1U400,U401, U402Automotive Catalog,50 MHz, Low-Noise, Single-Supply Rail-to-Rail Operational Amplifier, 2.2 to5.5 V, -40 to 125 degC, 5-pin SOT23 (DBV0005A), Green (RoHS & no Sb/Br)3DBV0005A_NTLV314QDBVRQ1TLV314QDBVRQ1U4033-MHz, Low-Power,Internal EMI Filter, RRIO, Operational Amplifier, DBV0005A (SOT-5)1D0008A_NLMV393QDRQ1LMV393QDRQ1U404,U406, U407Automotive DualGeneral Purpose Low-Voltage Comparators, D0008A3DCU0008A_NSN74LVC2G74QDCURQ1SN74LVC2G74QDCURQ1U405Automotive CatalogSingle Positive-Edge-Triggered D-Type Flip-Flop with Clear and Preset,DCU0008A (VSSOP-8)1PN0080A_NTMS320F28052FPNQTMS320F28052FPNQU500PiccoloMicrocontroller, PN0080A (LQFP-80)1ABRACON_ABM3BABM3B-20.000MHZ-10-1-U-TABM3B-20.000MHZ-10-1-U-TY500Crystal, 20 MHz, 10pF, SMD1     317
yangxf0120 发表于 2018-11-28 18:27
谢谢分享可控制汽车 HVAC压缩机的无刷直流 (BLDC)电机参考设计PCB文件+原理图
地沟油 发表于 2018-11-28 18:56
bidezhi7777 发表于 2018-11-28 20:44
zhifang88 发表于 2018-11-28 22:00
elecqht 发表于 2018-11-28 22:58
好高级啊,用DSP控制
小顺430 发表于 2018-11-29 08:41
tiny2010 发表于 2018-11-29 08:42
带刀的老鼠 发表于 2018-11-29 09:52
xianrui1989 发表于 2018-11-29 10:12
页: [1] 2 3 4 5 6 7 8
查看完整版本: 4层-可控制汽车 HVAC压缩机的无刷直流 (BLDC)电机参考设计PCB
