yangtao0559 发表于 2018-12-12 22:51
英伟达Jetson_AGX_Xavier_Developer_Kit_Carrier_Board B03版本 原理图PCB
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUEREFDESSOT323D_3PIN_CC_SOT323-BAS70W-05,1PAIR - COMMON CATHODE,70V,0.1A,1V@15MA,70MA,091-0023-000-091-0023-000 CR501SOT323D_3PIN_CC_SOT323-BAT54CW,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000-091-0022-000 D1SOT323D_3PIN_AA_SOT323-BAT54AWG,1PAIR - COMMON ANODE,30V,1A,0.5V@0.3A,0.3A,090-0288-000-090-0288-000 D2SOT323D_3PIN_CC_SOT323-BAT54CW,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000-091-0022-000 D3DIODE_SMD_SOD523_BD_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 D4TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D20TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E05U06,2DIFFPAIR,UNI-DIRECTIONAL,5.5V,10UA,6V,10V@1A,0.5PF,090-0231-000-090-0231-000 D21TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E05U06,2DIFFPAIR,UNI-DIRECTIONAL,5.5V,10UA,6V,10V@1A,0.5PF,090-0231-000-090-0231-000 D22TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D23TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E05U06,2DIFFPAIR,UNI-DIRECTIONAL,5.5V,10UA,6V,10V@1A,0.5PF,090-0231-000-090-0231-000 D24TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D29TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D30TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D31TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-AZ1045-04F,2DIFFPAIR,UNI-DIRECTIONAL,5V,1.5UA,6V,12V@3.5A,0.65PF,091-0054-000-091-0054-000 D35TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D38TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D39TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D40DIODE_SMD_010X060D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 D42DIODE_SMD_SOD523_BD_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 D47DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D48DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D49SOT323D_3PIN_CC_SOT323-BAT54CW,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000-091-0022-000 D50DFN18_P050_055X015_3XT006X005D_ESD_DFN18-MG2040MUTAG,OTHER,UNI-DIRECTIONAL,5V,1UA,5.5V,11.4V@8A,0.42PF,091-0080-000-091-0080-000 D501SOT23_6D_ESD_DIFFPAIR_SOT23_6-AZC199-04S,2DIFFPAIR,UNI-DIRECTIONAL,5V,1UA,6V,11V@6A,1.7PF,091-0053-000-091-0053-000 D502SOT23_6D_ESD_DIFFPAIR_SOT23_6-AZC199-04S,2DIFFPAIR,UNI-DIRECTIONAL,5V,1UA,6V,11V@6A,1.7PF,091-0053-000-091-0053-000 D503DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D504DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D505DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D506DIODE_SMD_SOD523_BD_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 D507TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000 D508DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D509DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000 D510DIODE_SMD_SOD923D_ESD_SOD923-ESD9X5.0ST5G,1LINE,UNI-DIRECTIONAL,5V,1UA,6.2V,12.3V@8.7A,65PF,090-0134-000-090-0134-000 D511DIODE_SMD_SOD923D_ESD_SOD923-ESD9X5.0ST5G,1LINE,UNI-DIRECTIONAL,5V,1UA,6.2V,12.3V@8.7A,65PF,090-0134-000-090-0134-000 D512DIODE_SMD_SOD923D_ESD_SOD923-ESD9X5.0ST5G,1LINE,UNI-DIRECTIONAL,5V,1UA,6.2V,12.3V@8.7A,65PF,090-0134-000-090-0134-000 D513DIODE_SMD_034X016_CUTOUTLED_SMD_2PIN-EASRR3216WA1,5V,0.1A,3.15V,25MA,WHITE,092-0241-000-092-0241-000 DS2LED_SMD_0603_STLED_0603-LED_SMD_0603,5V,60MA,2.35V,25MA,GREEN,092-0073-000-092-0073-000 DS701CON_MINIPEX_075_SMT_RA_M2CON_M2_PCI_EXP_SMD77_KEYM-1-2199125-4,FEMALE,0.5,90,N/A,NO,NO,NO,NO,50V,0.5 A,080-1500-000-080-1500-000 J1CON_DCPWR_JACK_006_TH_RA_100X130CON_PWR_JACK_CON_6PIN-2DC-G213-B73F,FEMALE,4.7MM,90,NA,YES,NO,NO,NO,N/A,N/A,064-0347-000-064-0347-000 J2CON_MIRMEZ_699_BGA_ST_P009_P013_P015_REVERSECON_B2B_699_CVM_65X11_MIRROR-MIRMEZ_CVM,FEMALE,0.9MM,0,NA,NO,NA,NA,NO,30V,1.2 A,080-1489-000-080-1489-000 J3CON_SD_UFS_019_SMD_RA_P011_P009_123X135CON_SD_SOCKET_SMD25-1010170469,RECEPTACLE,0.7MM,90,N/A,NO,YES,NO,YES,100V,0.5 A,220-0134-000-220-0134-000 J4CON_PEX_164_SMT_ST_P010CON_PCI_EXPRESS_PHY-X16-SMD-10146065-113Y0LF,FEMALE,1.0MM,0,YES,YES,NO,NO,NO,N/A,N/A,080-1496-000-080-1496-000 J6CON_MISC_004_SMD_RA_M_P013_WTB_BCON_B2W_1X4_SMD_MT2-50279-0040N-003,MALE,1.25MM,90,YES,YES,NO,NO,NO,0MV,0 MA,080-1638-000-080-1638-000 J9CON_PEX_098_SMT_ST_P010_P2822CON_PCI_EXPRESS_PHY-X8-SMD-CON_PCIEXP_X8_P2822,FEMALE,1.0MM,0,YES,YES,NO,NO,NO,N/A,N/A,080-1497-000-080-1497-000 J28CON_HDR_002X020_SMD_RA_M_P025HDR_2X20_SMD-G2100CE04C-008-H,MALE,2.54MM,90,N/A,NO,NO,N/A,N/A,080-1659-000-080-1659-000 J30CON_EDGE_USB_005_SMT_RA_F_074X058_CUTOUTCON_USB_MICRO_B_10-2UB2158-001111F,FEMALE,0.65,90,YES,NO,YES,NO,YES,100.0V,0.5 A,064-0276-000-064-0276-000 J501CON_HDR_002X005_SMD_ST_M_P013_CHDR_2X5_NORM-FTSH-105-01-L-DV-K,MALE,1.27MM,0,NO,YES,NO,350V,3.3 A,064-0203-000-064-0203-000 J502CON_QSH_060_SMT_ST_P005CON_B2B_60_F_NORM-QSH-030-01-L-D-A-K-TR,FEMALE,0.5MM,0,YES,YES,NO,NO,N/A,125.0V,1.0 A,080-1344-000-080-1344-000 J503CON_HDMI_019_SMT_RA_F_P005_DCON_HDMI_HDMI_A_SMD-HDMI_A_SMD_REVERSE,FEMALE,0.5MM,90,YES,YES,NO,NO,YES,N/A,N/A,080-0943-000-080-0943-000 J504CON_MINIPEX_075_SMT_RA_M2CON_M2_PCI_EXP_SMD77_KEYE-2199125-4,FEMALE,0.5MM,90,N/A,NO,NO,NO,NO,N/A,N/A,080-1499-000-080-1499-000 J505CON_USB_ESATA_016_TH_RA_F_187X134CON_SATA_TH_RA_16-1853116-0N025T-H,FEMALE,1.27MM,90,YES,YES,YES,NO,YES,30V,1.5 A,080-1503-000-080-1503-000 J507CON_HDR_002X004_SMD_ST_M_P025HDR_2X4_NORM-2821-08-02-5.84/3.8-0-PT-HSF,MALE,2.54MM,0,YES,NO,NO,500V,3 A,080-1647-000-080-1647-000 J508CON_QSH_120_SMT_ST_P005CON_B2B_120_F_NORM-CON_QSH_SMT_2X60_P050,FEMALE,0.5MM,0,YES,YES,NO,NO,NO,NA,9999MA,080-1346-000-080-1346-000 J509CON_EDGE_MJ08_008_SMT_RA_F_CUTOUTCON_RJ45_RJ45_10PIN-G7400CE04-002-H,FEMALE,1.02MM,90,YES,YES,YES,YES,YES,-1.0V,-1.0 A,080-1332-000-080-1332-000 J510CON_HDR_002X005_SMD_ST_M_P025_KEY8HDR_2X5_KEY8_AUDIO-P0001-01012-001,MALE,2.54MM,0,YES,NO,NO,N/A,N/A,080-1630-000-080-1630-000 J511CON_USB_024_SMT_RA_F_089X082CON_USB3_TYPEC_30PIN_B-UT12113-116B2-7H,FEMALE,N/A,90,N/A,N/A,N/A,N/A,YES,N/A,5A,065-0687-000-065-0687-000 J512CON_USB_024_SMT_RA_F_089X108CON_USB3_TYPEC_28PIN_B-MJ8A5A-Y280-412,RECEPTACLE,0.5MM,90,YES,YES,YES,NO,YES,100V,0.25 A,064-0305-000-064-0305-000 J513CON_HDR_003_SMD_ST_M_P025HDR_1X3_SMD-2811-03-B1-02-5.84/3.8-PT-HSF,MALE,2.54MM,0,YES,NO,NO,500V,3 A,080-1641-000-080-1641-000 J514IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmL1IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmL2IND_NONRKO_SMD_076X076L_7_6X7_6-4.7UH,[],20%,5.5A,10A,0.04OHM,[ ]@[ ],[ ],[ ],131-0255-000-131-0255-000,4.7UH4.7uHL3IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmL4IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmL5IND_NONRKO_SMD_106X102L_SMD_420X400-2.2UH,[],20%,12A,25A,0.009OHM,[ ]@[ ],[ ],[ ],131-0282-000-131-0282-000,2.2UH2.2uHL502IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmL503IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmL504IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmL505IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmL506IND_NONRKO_SMD_115X103L_SMD_420X400-1UH,METALDUST,20%,14.5A,18A,0.006OHM,0@0HZ,0HZ,0DECIBEL,130-0846-000-130-0846-000,1UH1uHL507IND_NONRKO_SMD_076X076L_7_6X7_6-2.2UH,ALLOYCORE,20%,10A,10A,0.0132OHM,[ ]@[ ],[],0DECIBEL,130-0436-000-130-0436-000,2.2UH2.2uHL508IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmL509IND_NONRKO_SMD_076X076L_7_6X7_6-4.7UH,[],20%,5.5A,10A,0.04OHM,[ ]@[ ],[ ],[ ],131-0255-000-131-0255-000,4.7UH4.7uHL513IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,33.33%,[],1.7A,0.05OHM,[ ],N/A,N/A,100-0105-000-100-0105-000,30OHM30ohmLB1IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,33.33%,[],1.7A,0.05OHM,[ ],N/A,N/A,100-0105-000-100-0105-000,30OHM30ohmLB2IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmLB3IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB4IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB5IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB6IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB7IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB8IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB9IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB10IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmLB11IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmLB16IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmLB17IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,25%,[],2A,0.1OHM,[ ],N/A,N/A,100-0165-000-100-0165-000,30OHM30ohmLB501IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,33.33%,[],1.7A,0.05OHM,[ ],N/A,N/A,100-0105-000-100-0105-000,30OHM30ohmLB502IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmLB503IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmLB504MECH_RECT_01050X01050_HOLESMOUNTING_HOLE_X28-P2822_MOUNTING_HOLES MEC1MEC_STANDOFF_PTH_620C380PMEC_STANDOFF_SMD-SMDMECH STDF_06MM,155-0608-000-155-0608-000 MEC2MEC_STANDOFF_PTH_620C380PMEC_STANDOFF_SMD-SMDMECH STDF_06MM,155-0608-000-155-0608-000 MEC501DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q1SOT23_3_BQ_FET_P_ENH_SOT23_1G1D1S-SM2309PSAC-TRG,-30V,95MOHM@10V/ 150MOHM@4.5V / [ ]@2.5V,-3.1A,-12.5A,20V,1.4W,6.8NC@10V / 3.1NC@4.5VB Q2SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q3SOT23_3_BQ_FET_P_ENH_SOT23_1G1D1S-SM2309PSAC-TRG,-30V,95MOHM@10V/ 150MOHM@4.5V / [ ]@2.5V,-3.1A,-12.5A,20V,1.4W,6.8NC@10V / 3.1NC@4.5VB Q4SOT23Q_FET_N_ENH_SOT23_1G1D1S-AO3402,30V,52MOHM@10V/ 65MOHM@4.5V / -1000MOHM@2.5V,3.4A,15A,12V,1W,[ ]@10V / [ ]@4.5V / []@2.5V,30B Q5SOT323Q_NPN_SOT323_1B1C1E-MMST3904-7-F,40V,[],0.2A,0.2A,6V,0.2W,305-0052-000-305-0052-000 Q6DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q7DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q8SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q9SOT23Q_FET_N_ENH_SOT23_1G1D1S-AO3402,30V,52MOHM@10V/ 65MOHM@4.5V / -1000MOHM@2.5V,3.4A,15A,12V,1W,[ ]@10V / [ ]@4.5V / []@2.5V,30B Q10SOT23_3_BQ_FET_P_ENH_SOT23_1G1D1S-SM2309PSAC-TRG,-30V,95MOHM@10V/ 150MOHM@4.5V / [ ]@2.5V,-3.1A,-12.5A,20V,1.4W,6.8NC@10V / 3.1NC@4.5VB Q11SOT23_3_BQ_FET_P_ENH_SOT23_1G1D1S-SM2309PSAC-TRG,-30V,95MOHM@10V/ 150MOHM@4.5V / [ ]@2.5V,-3.1A,-12.5A,20V,1.4W,6.8NC@10V / 3.1NC@4.5VB Q12SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q13DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q14DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q15SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q16MULTI_SMD_SOT669_LFPAK_BQ_FET_P_ENH_LFPAK-FDMS6681Z,-30V,3.2MOHM@10V/ 5MOHM@4.5V / [ ]@2.5V,-21.1A,-600A,25V,2.5W,241NC@10V / 136NC@4.5V / []@2.5V,3B Q17SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q18SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q19SOT23Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / 9999NC@4.5VB Q20SOT23Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / 9999NC@4.5VB Q21SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q22SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q23SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q24SOT23Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / 9999NC@4.5VB Q25SOT23Q_PNP_SOT23_1B1C1E-MMBT4403,40V,[],0.6A,0.6A,5V,0.225W,305-0002-000-305-0002-000 Q26SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q30SC70_6Q_FET_N_ENH_SOT363-NTJD4001N,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.25A,0.25A,20V,0.272W,[ ]@10V / [ ]@4.5V / []@B Q31SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q53SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q54SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q67SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q75SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q77SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q78SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / B Q79SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q80SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q81SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q82SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q83SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q84SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q86SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q87SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q88SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q90SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q91SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q92DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q93DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q94DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q95DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q96DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V/ 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / []@2.5V,B Q97SC70_6Q_FET_N_ENH_SOT363-NTJD4001N,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.25A,0.25A,20V,0.272W,[ ]@10V / [ ]@4.5V / []@B Q98SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q99SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q101SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V/ 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V/ 0NC@B Q501SOT723Q_FET_P_ENH_SOT723-NTK3139P,-20V,950MOHM@10V/ 950MOHM@4.5V / 950MOHM@2.5V,-0.78A,-1.2A,6V,0.45W,[ ]@10V / [ ]@4.5V / []@2.5VB Q502SOT723Q_FET_P_ENH_SOT723-NTK3139P,-20V,950MOHM@10V/ 950MOHM@4.5V / 950MOHM@2.5V,-0.78A,-1.2A,6V,0.45W,[ ]@10V / [ ]@4.5V / []@2.5VB Q503MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-FDPC5030SG,30V/ 30V,5MOHM,2.4MOHM@10V / 6.5MOHM,3MOHM@4.5V / [ ],[ ]@2.5V,17A / 25A,227A /503A,20V / 1B Q504MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-FDPC5030SG,30V/ 30V,5MOHM,2.4MOHM@10V / 6.5MOHM,3MOHM@4.5V / [ ],[ ]@2.5V,17A / 25A,227A /503A,20V / 1B Q505SOT23Q_FET_N_ENH_SOT23_1G1D1S-NTR4003NT1G,30V,-1000MOHM@10V/ 1500MOHM@4.5V / -1000MOHM@2.5V,[ ],1.7A,20V,0.83W,[ ]@10V / [ ]@4.5V B Q506SOT23Q_FET_N_ENH_SOT23_1G1D1S-FDV301N,25V,-1000MOHM@10V/ 4000MOHM@4.5V / -1000MOHM@2.5V,0.22A,0.5A,8V,0.35W,[ ]@10V / 0.7NC@4.5V /B Q507SOT23Q_FET_N_ENH_SOT23_1G1D1S-FDV301N,25V,-1000MOHM@10V/ 4000MOHM@4.5V / -1000MOHM@2.5V,0.22A,0.5A,8V,0.35W,[ ]@10V / 0.7NC@4.5V /B Q508SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q510SOT23Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,[],0.6A,[ ],6V,0.3W,305-0005-000-305-0005-000 Q511MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-AOE6930,30V/ 30V,6.2MOHM,1.2MOHM@10V / 7MOHM,1.05MOHM@4.5V / [ ],[ ]@2.5V,19A / 48A,88A/ 340A,20V / 12B Q512MULTI_SMD_SOT669_LFPAK_BQ_FET_P_ENH_LFPAK-AON6411,-20V,2.1MOHM@10V/ 2.5MOHM@4.5V / 3.6MOHM@2.5V,-47A,-340A,12V,7.3W,330NC@10V / 140NC@4.5V /0NC@2.5VB Q513SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q514SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q515SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q516SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q517SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q519MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-AOE6930,30V/ 30V,6.2MOHM,1.2MOHM@10V / 7MOHM,1.05MOHM@4.5V / [ ],[ ]@2.5V,19A / 48A,88A/ 340A,20V / 12B Q520MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-FDPC5030SG,30V/ 30V,5MOHM,2.4MOHM@10V / 6.5MOHM,3MOHM@4.5V / [ ],[ ]@2.5V,17A / 25A,227A /503A,20V / 1B Q521SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q522SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q523SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q524SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q525SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q526SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V/ 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VB Q527MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-FDPC5030SG,30V/ 30V,5MOHM,2.4MOHM@10V / 6.5MOHM,3MOHM@4.5V / [ ],[ ]@2.5V,17A / 25A,227A /503A,20V / 1B Q528SOT23Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / 9999NC@4.5VB Q701RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,200PPM,215-0142-000-0.01OHM,215-0142-0000.01ohmRS501RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,200PPM,215-0142-000-0.01OHM,215-0142-0000.01ohmRS502RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,200PPM,215-0142-000-0.01OHM,215-0142-0000.01ohmRS505RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,200PPM,215-0142-000-0.01OHM,215-0142-0000.01ohmRS506SW_04_TH_RA_1XONOFF_085X073SW_SPST_PB_TH4_2GND-2SWNTC304-AE1D-B160B,FEMALE,4.5MM,90,NO,NO,YES,12.0V,50.0 MA,280-0143-000-280-0143-000 S501SW_04_TH_RA_1XONOFF_085X073SW_SPST_PB_TH4_2GND-2SWNTC304-AE1D-B160B,FEMALE,4.5MM,90,NO,NO,YES,12.0V,50.0 MA,280-0143-000-280-0143-000 S502SW_04_TH_RA_1XONOFF_085X073SW_SPST_PB_TH4_2GND-2SWNTC304-AE1D-B160B,FEMALE,4.5MM,90,NO,NO,YES,12.0V,50.0 MA,280-0143-000-280-0143-000 S503XFMR_SMD_24_151X071TR_ENET_MAGCOM_SOP24-M3295NL,1:1,1500V(RMS),0HZ..100MHZ,50OHM..50OHM,295-0036-000-1:1,295-0036-0001:01T501LTPT28C49PLABTESTPOINT_B28-LABTESTPOINT TP1QFN056Q_P050_0080_T044X044U_ENET_88E1512P_QFN56-88E1512PB2-NNP2C000,ETHERNET,115-2543-000-115-2543-000 U1SOT23_5U_POWER_SW_SOT23_5C-APL3511DBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1238-000-115-1238-000 U2QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U3QFN056Q_P040_0075_T041X049_VIASU_PCIE2SATA_88SE9170_QFN56-88SE9171A2,SATA,115-2464-000-115-2464-000 U4DFN08_P127_060X050_T035X044U_MEM_FL_SER_512KX8_SON8-86MHZ,2.7V..3.6V,MX25L4006EZNI-12G,170-0239-000-170-0239-000 U5DFN10_P050_030X030_T026X018U_VREG_NCV59748_DFN10-NCV59748MWADJTBG,LOWDROPOUT,60MV@1.5A,0.8V..3.6V,2%,0.8V,5.5V,1.5A,1W,315-0975-000-0.8V,315-0975-0000.8VU6BGA_0004_P050_009X009U_SW_LOAD_BGA04-TPS22908,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1127-000-115-1127-000 U7QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVELSHIFTER,115-1921-000-115-1921-000 U8QFN032Q_P050_055X055_T038X038U_BUCKBOOST_DRV_1PH_USB_PD_QFN32-NCP81239MNTXG,BUCK/BOOST,1PH,1.2MHZ,I2C,28V..0MV,1%,0.5V,28V,5A,2.1W,316-0604-000-0.5V,316-06A0.5VU9QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVELSHIFTER,115-1921-000-115-1921-000 U11SC70_5U_BUF_OD_SC70_5-SN74AUP1G07,BUFFER- OPEN DRAIN,115-0970-000-115-0970-000 U12BGA_0004_P050_009X009U_SW_LOAD_BGA04-TPS22908,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1127-000-115-1127-000 U14QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U16XSOP10_P050_030X030U_SWREG_TPS53015_XSOP10-TPS53015,BUCK,1PH,500KHZ,NONE,0.77V..7V,1%,0.773V,28V,10A,50W,316-0314-000-0.773V,316-0314-0000.773VU17DFN08_P050_030X020_T016X016U_MEM_EE_3WIRE_DFN8-2MHZ,2.5V..5.5V,93LC56CT-I/MNY,174-0188-000-174-0188-000 U54QFN024Q_P050_0042_T025X025U_I2C_EXP_TCA9539_QFN24-TCA9539RTWR,I/OEXPANDER,115-2536-000-115-2536-000 U55QFN064Q_P050_0090_T043X043U_USB_FT4232H_QFN64-FT4232HQ,USBPERIPHERAL,115-2142-000-115-2142-000 U56QFN014R_P050_0030X0025_T017X012U_LEVSHFT_FXL5T244_MLP14-FXL5T244BQX,OTHER,115-2537-000-115-2537-000 U57SC70_6U_LEVSHFT_3STATE_SC70_6-SN74LVC1T45DCKR,LEVELSHIFTER,115-2544-000-115-2544-000 U58DFN06_P050_015X010U_BUF_3_STATE_DFN06_OEH-NC7SZ126L6X,BUFFER- TRI-STATE,115-0398-000-115-0398-000 U60SC70_6U_LEVSHFT_3STATE_SC70_6-SN74LVC1T45DCKR,LEVELSHIFTER,115-2544-000-115-2544-000 U61SC70_6U_LEVSHFT_3STATE_SC70_6-SN74LVC1T45DCKR,LEVELSHIFTER,115-2544-000-115-2544-000 U62QFN016R_P040_0260X0180U_I2C_EXP_TCA6408_UQFN16-TCA6408ARSVR,I/OEXPANDER,115-1529-000-115-1529-000 U63DFN06_P050_015X010U_BUF_3_STATE_DFN06_OEH-NC7SZ126L6X,BUFFER- TRI-STATE,115-0398-000-115-0398-000 U64SOT23_5U_VREG_5PIN_SOT23-5-RT9043-GB,LOWDROP OUT,[ ]@[],2.2V..5.5V,1%,1.2V,5.5V,0.4A,0.4W,315-0783-000-1.2V,315-0783-0001.2VU65QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U66QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVELSHIFTER,115-1921-000-115-1921-000 U67QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH- ANALOG,115-0655-000-115-0655-000 U70QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U71QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U72QFN016R_P050_0040X0035_T026X021U_LEVSHFT_3STATE_QFN16-SN74AVC4T245,LEVELSHIFTER,115-0710-000-115-0710-000 U76QFN020Q_P050_0030_T018X018U_CPU_EFM8SB1_QFN20-EFM8SB10F8G,OTHER,115-2563-000-115-2563-000 U79QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000 U80DFN06_P065_020X020_T016X010_BU_RST_TPS3808_SON6-TPS3808G01QDRVR-Q1,RESET,115-2439-000-115-2439-000 U81DFN08_P050_020X020_T017X010U_POWER_SW_DFN8_C-TPS22965DSGR,2.5V..5.7V,2.5V..5.7V,6A,SWITCH,315-1082-000-315-1082-000 U82SC70_5U_AND_2IN_SC70-5-NC7SVL08,GATES- AND - 2 INPUT,115-1345-000-115-1345-000 U83SC70_5U_BUF_OD_SC70_5-SN74AUP1G07,BUFFER- OPEN DRAIN,115-0970-000-115-0970-000 U85SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER- TRI-STATE,115-1821-000-115-1821-000 U86SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER- TRI-STATE,115-1821-000-115-1821-000 U87SC70_5U_AND_2IN_SC70-5-NC7SVL08,GATES- AND - 2 INPUT,115-1345-000-115-1345-000 U89SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER- TRI-STATE,115-1821-000-115-1821-000 U90SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER- TRI-STATE,115-1821-000-115-1821-000 U91SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER- TRI-STATE,115-1821-000-115-1821-000 U92SC70_5U_XOR_2IN_SC70-NL17SG86DFT2G,GATES- XOR - 2 INPUT,115-2514-000-115-2514-000 U93SC70_5U_AND_2IN_SC70-5-NC7SVL08,GATES- AND - 2 INPUT,115-1345-000-115-1345-000 U94SOT23_5U_LDO_SOT23_5_NOVR-GS7116S5-ADJ-R,STANDARD,0.45V@0.5A,0.8V..5V,2%,0.8V,6.5V,0.5A,0.4W,315-1022-000-0.8V,315-1022-0000.8VU104DFN08_P050_030X020_T016X016U_MEM_EE_I2C_DFN08-1MHZ,1.7V..3.6V,AT24C02D-MAHM-T,174-0159-000-174-0159-000 U501QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH- ANALOG,115-0655-000-115-0655-000 U502XSOP10_P050_030X030U_SWREG_TPS53015_XSOP10-TPS53015,BUCK,1PH,500KHZ,NONE,0.77V..7V,1%,0.773V,28V,10A,50W,316-0314-000-0.773V,316-0314-0000.773VU503SOT23_8U_BUCK_FET_1PH_SOT23_8_NOVR-APW7307AZI-TRG,BUCK,1PH,500KHZ,NONE,0.807V..13V,1%,0.807V,24V,3A,1W,316-0471-000-0.807V,316-0471-0A0.807VU504SOT23_5U_POWER_SW_SOT23_5B-APL3511CBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-0836-000-115-0836-000 U505SO08_048X038_T030X026U_VREG_APL5910_SOP8-APL5932AKAI,ULTRALOW DROP OUT,0.23V@3A,[ ]..5.5V,1.5%,[ ],6V,3A,2W,315-0808-000-315-0808-000,[][ ]U506SOT23_5U_POWER_SW_SOT23_5A-APL3510EBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1235-000-115-1235-000 U507SC70_5U_BUF_OD_SC70_5-SN74AUP1G07,BUFFER- OPEN DRAIN,115-0970-000-115-0970-000 U508XSOP14_P065_050X044U_LEVSHFT_ADG3304_TSSOP14-ADG3304BRUZ,LEVELSHIFTER,115-1903-000-115-1903-000 U509SOT23_5U_POWER_SW_SOT23_5A-APL3510EBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1235-000-115-1235-000 U510QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH- ANALOG,115-0655-000-115-0655-000 U511DFN06_P065_020X020_TI063X039_BU_LDO_DFN6-NCP705MTADJTCG,LOWDROPOUT,0.35V@0.5A,0.8V..5.15V,2%,0.8V,5.5V,0.5A,1W,315-1067-000-0.8V,315-1067-0000.8VU512QFN040Q_P050_0065_T047X047U_USB_C_CCG4_QFN40-CYPD4226-40LQXIT,USB,190-82822-0000-000-190-82822-0000-000 U513QFN032Q_P050_055X055_T038X038U_BUCKBOOST_DRV_1PH_USB_PD_QFN32-NCP81239MNTXG,BUCK/BOOST,1PH,1.2MHZ,I2C,28V..0MV,1%,0.5V,28V,5A,2.1W,316-0604-000-0.5V,316-06A0.5VU514SOT89_3U_VREG_3PIN_SOT89_3-AP2204RA-3.3TRG1,STANDARD/FIXED,0.35V@50MA,3.3V..3.3V,2%,1.24V,24V,0.15A,0MW,315-0292-000-1.24V,315-0292-0A1.24VU515QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH- ANALOG,115-0655-000-115-0655-000 U516QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH- ANALOG,115-0655-000-115-0655-000 U517SC70_5U_AND_2IN_SC70-5-SN74LVC1G08,GATES- AND - 2 INPUT,115-0014-000-115-0014-000 U518QFN048Q_P040_0065_T047X047U_ACODEC_ALC5658_QFN48-ALC5658,CONVERTER- AUDIO CODEC,115-2054-000-115-2054-000 U519DFN08_P050_020X010U_FLIPFLOP_D_DFN08-74LVC1G74,LOGIC- D-TYPE FLIP FLOP WITH PRESET/CLEAR,115-0967-000-115-0967-000 U520DFN12_P050_030X020U_PB_SRC0XXX_TDFN12-SRC0GS22D,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-2029-000-115-2029-000 U521QFN040R_P040_0040X0060_T026X046U_USB_TUSB1046_WQFN40-TUSB1046-DCIRNQR,OTHER,115-2448-000-115-2448-000 U522QFN040R_P040_0040X0060_T026X046U_USB_TUSB1046_WQFN40-TUSB1046-DCIRNQR,OTHER,115-2448-000-115-2448-000 U523NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS501NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS502NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS503NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS504NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS505NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORT VS506XTAL_SMD_4_016X012XTAL_4PIN_SMD_16X12-1ZZHAM25000BC0B,25MHZ,20PPM,2PPM,50PPM,7PF,FUNDAMENTAL,085-0306-000-085-0306-000,25MHZ25MHzY1XTAL_SMD_4_016X012XTAL_4PIN_SMD_16X12-1ZZHAM25000BC0B,25MHZ,20PPM,2PPM,50PPM,7PF,FUNDAMENTAL,085-0306-000-085-0306-000,25MHZ25MHzY2XTAL_SMD_4_032X025OSC_4PIN_SMD_32X25-ASHEK4-32.768KHZ-L-T,32.768KHZ,25PPM,5PPM,-1PPM,15PF,086-0179-000-086-0179-000,32.768KHZ32.768KHzY3XTAL_SMD_4_032X025XTAL_4PIN_SMD_32X25-EXS00A-CG02825,12MHZ,15PPM,5PPM,45PPM,10PF,FUNDAMENTAL,085-0167-000-085-0167-000,12MHZ12MHzY4XTAL_SMD_4_032X025OSC_4PIN_SMD_32X25-ASHEK4-32.768KHZ-L-T,32.768KHZ,25PPM,5PPM,-1PPM,15PF,086-0179-000-086-0179-000,32.768KHZ32.768KHzY501
ymz000 发表于 2018-12-12 22:53
shuszhao 发表于 2018-12-13 00:02
相当给力
郑先生 发表于 2018-12-13 08:05
lcfmax 发表于 2018-12-13 08:15
小顺430 发表于 2018-12-13 08:48
wangy2000 发表于 2018-12-13 08:51
好资料,收藏,谢谢。
学习了,谢谢。
lyq751482111 发表于 2018-12-13 08:52
看看怎样的
feichi87 发表于 2018-12-13 08:54
不错,瞧瞧。
页: [1] 2 3 4 5 6
查看完整版本: 英伟达Jetson_AGX_Xavier_Developer_Kit_Carrier_Board B03版本 原理图PCB
