topdenzengzhi 发表于 2018-12-16 15:15
采用SF106982MPAFR2设计的MM912_P812小型发动机控制板原理图与PC
2层463PIN
Part      Value             Package             Library          Position (inch)       Orientation
BDM         MA03-2SM          MA03-2SM            con-lstb         (0.20748425 0.51607087) R0
C4          .01 uF            C0603               rcl            (0.82256693 1.21233465) R270
C5          .1 uF             C0603               rcl            (0.17990551 1.2479685) MR0
C7          1000 pF         C0402               rcl            (0.19993307 1.39237402) R180
C8          .1 uF             C0402               rcl            (0.20691339 0.74191732) R180
C9          .01 uF            C0603               rcl            (2.61937795 1.1599252) R270
C10         .01 uF            C0603               rcl            (0.95772835 1.46933858) R0
C11         .01 uF            C0603               rcl            (2.52012598 1.16316929) R270
C12         .01 uF            C0603               rcl            (2.93982283 1.1627874) R270
C13         .01 uF            C0603               rcl            (2.71816142 1.16224409) R270
C14         .1 uF             C0603               rcl            (2.75846063 0.15585039) R180
C16         .1 uF             C0603               rcl            (2.91558661 0.7148189) R0
C19         .1 uF             C0402               rcl            (0.88080709 0.92373622) R0
C20         .1 uF             C0402               rcl            (1.05156299 0.56825591) MR270
C21         .01 uF            C0402               rcl            (0.88741339 1.20589764) R270
C22         .01 uF            C0603               rcl            (0.49337402 1.68942913) R180
C23         .01 uF            C0402               rcl            (1.43229134 1.31551969) R90
C24         .01 uF            C0402               rcl            (1.17508661 1.73610236) R0
C25         .01 uF            C0402               rcl            (1.29211811 1.42542913) R0
C26         .01 uF            C0402               rcl            (1.17459055 1.6608622) R180
C27         .01 uF            C0603               rcl            (0.46877165 1.18873228) R180
C28         .01 uF            C0402               rcl            (0.65731496 1.71061811) R0
C29         .01 uF            C0603               rcl            (3.38015748 1.68298031) R0
C31         .01 uF            C0603               rcl            (0.80132677 1.44273228) R180
C32         .01 uF            C0402               rcl            (1.04149213 1.86120472) R90
C33         33 uF/50V         PANASONIC_E         rcl            (1.98481102 0.62594488) R180
C34         1 uF            C0603               rcl            (1.52255906 0.63088189) R180
C35         22 uF/10V         PANASONIC_B         rcl            (1.68538583 0.68011811) R270
C36         .01 uF            C0603               rcl            (1.64862205 1.53066142) R90
C37         .01 uF            C0603               rcl            (1.14600394 1.45103543) R90
C38         .01 uF            C0603               rcl            (1.22729134 1.53435827) R90
C40         .1 uF             C0402               rcl            (0.7610315 0.9243937) R0
C41         .1 uF             C0402               rcl            (0.52258268 0.70481496) MR90
C42         100 pf            C0402               rcl            (0.15930315 0.64322441) MR90
C43         .01 uF            C0603               rcl            (0.65306693 1.45069291) R270
C44         .01 uF            C0603K            rcl            (1.78953543 1.32943701) R90
C45         .01 uF            C0603               rcl            (2.47999606 1.78791339) R90
C50         .01 uF            C0603               rcl            (1.06564173 1.45076772) R90
C51         .1 uF             C0402               rcl            (1.40281496 0.74124409) R0
C52         .01 uF            C0603               rcl            (2.09614567 1.45955118) R0
C55         .01 uF            C0603               rcl            (2.95683465 1.45364567) R0
C56         .01 uF            C0603               rcl            (3.33719291 1.29060236) R270
C57         .01 uF            C0603               rcl            (2.70655512 1.45120866) R0
C58         .01 uF            C0603               rcl            (1.25569685 1.23804331) R180
CAN1      MA2-2SM         MA2-2SM             con-lstb         (1.29532283 0.6077126) R0
D1          STPS3L60S         SMC               diode            (1.83864173 1.05052362) R90
D2          SMBJ5339B         SMB               diode            (0.86725197 1.81071654) R180
D3          BAS716            SOD523            diode            (1.66985039 1.11029134) R270
D5          MMBZ27VCL         SOT23               diode            (2.07575984 1.7167126) R0
D6          SS12            DO214AC             diode            (1.71424016 1.8216063) R270
D7          SMBJ24A         SMB               diode            (2.99371654 1.78658661) R90
D8          SMBJ24A         SMB               diode            (2.62497244 1.78003543) R90
GND         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (0.25285433 1.88801575) R0
MCUTEST   MA01-1SM          MA01-1SM            con-lstb         (1.30811811 0.95337402) R0
MCUTEST1    MA02-1            MA02-1            con-lstb         (1.33853937 1.09051969) R90
MCUTEST3    MA01-1SM          MA01-1SM            con-lstb         (1.37938189 0.95359843) R0
P1          5566-16         5566-16             con-molex      (2.6 1.45)            MR0
P2          5566-12         5566-12             con-molex      (0.9 1.45)            MR0
Q2          ISL9V2040D3ST   DPAK                transistor       (2.3349252 1.03455906) R0
Q3          IRF7341         TRANSISTOR-FET_SO-8 SuperShreec      (3.19991339 1.77735433) R270
Q4          IRF7341         TRANSISTOR-FET_SO-8 SuperShreec      (2.83376772 1.77757874) R270
Q5          FZT789A         SOT223            zetex            (1.6879252 0.42750787) R270
R1          10K               R0402               rcl            (1.01608661 1.22624016) R0
R2          15K               R0402               rcl            (0.46990551 1.25373622) R180
R3          15K               R0402               rcl            (0.48068898 1.62876378) R180
R4          1K                R0402               rcl            (0.2538937 0.16132677) R0
R5          47K               R0402               rcl            (0.84764567 0.12183465) R180
R6          10K               R0402               rcl            (0.17266535 1.16811417) MR180
R7          3.1K            R0402               rcl            (0.76205906 1.19109843) R90
R10         0               R0805               rcl            (3.35919291 0.4863189) R270
R11         0               R0805               rcl            (3.0375748 0.82516535) R0
R12         0               R0805               rcl            (3.0453189 0.08659055) R180
R13         0               R0805               rcl            (2.74627953 0.48501575) R90
R15         0               R0402               rcl            (0.32569685 1.22409843) R270
R16         15K               R0402               rcl            (1.38856299 1.31504724) R90
R17         16K               R0402               rcl            (1.08333858 1.70551969) R270
R18         16K               R0402               rcl            (1.22139764 1.34116929) R90
R22         31.6K             R0402               rcl            (1.29801969 1.66077953) R0
R24         16K               R0402               rcl            (0.56356299 1.5704685) R270
R28         15K               R0402               rcl            (1.03527559 1.70644094) R270
R31         1K                R2010               rcl            (1.85169291 1.76416929) R270
R32         15K               R0402               rcl            (1.66183858 1.23721654) R0
R33         6.8K            R0402               rcl            (1.72191732 1.52779921) R270
R37         36.0K             R2512               rcl            (2.10259055 1.09321654) R270
R38         4.02K             R1206               rcl            (2.09088583 0.88881102) R180
R39         4.99K             R0402               rcl            (1.08815748 1.86346457) R270
R40         16K               R0402               rcl            (2.24933858 0.70948819) R90
R41         16K               R0402               rcl            (2.29715748 0.70956299) R90
R42         10K               R0402               rcl            (0.76694488 1.00477165) R270
R47         6.8K            R0402               rcl            (0.96550787 0.98806693) R270
R48         10K               R0402               rcl            (0.10772047 0.47846457) MR270
R51         10K               R0402               rcl            (0.65928346 1.66582283) R180
R55         10K               R0402               rcl            (0.10202362 0.28394488) R180
R57         10K               R0402               rcl            (0.53193701 0.98459055) R270
R59         10K               R0402               rcl            (0.8897874 1.66524016) R0
TVS2      SMBJ40            DO214AA             diode            (2.0455 0.38040551)   R0
U$4         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (1.14331496 0.94272835) R0
U$5         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (0.3641063 0.12989764) R0
U$6         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (0.07544882 1.09192126) R0
U$7         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (0.26225197 1.31135827) R0
U$8         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (3.28436614 0.09568898) R0
U$9         PICK_PLACE_TARGET PICK_PLACE_TARGET   Symbols          (3.31225984 1.74072047) R0
U1          SF106982MPAFR2    LQFP100-EP          Freescale_Micro1 (0.78444488 0.55794882) R0
U2          MC33880         32SOICEP_FINAL2   APD            (3.05 0.4)            R90
U3          MAX9924         UMAX10            maxim            (0.17988583 1.24473622) R180
WD_INH_JMPR MA02-1            MA02-1            con-lstb         (0.38027559 0.08168504) R90
XTAL1       RESONATOR         CSTCE               murata-filter    (0.62017323 0.98896063) R180
带刀的老鼠 发表于 2018-12-17 09:11
益达 发表于 2018-12-17 09:46
junkyoung 发表于 2026-7-12 10:13
好好地学习。。。
gfshao 发表于 2026-7-13 08:59
谢谢分享
wangbin88 发表于 2026-7-13 09:01
学习学习
查看完整版本: 采用SF106982MPAFR2设计的MM912_P812小型发动机控制板原理图与PC
