老吴 发表于 2019-2-25 15:54
联泳NT96660高清行车记录仪PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECN1SPEAKER_ASIP02_SPEAKERSPEAKERASIP02CS1CAP_C0603_0.1UF/50V/X7R/MRT_RS_1uF0402CD195SQ015/TO_D-M-FLAT_IN5819/SS34IN5819/SS34D-M-FLATD2DIODESCHOTTKY_2_SMT_SOD-323_CRCRS01SMT_SOD-323J1HDMI TYPE CCONN_2_HDMI19_HDMI(HDMI(MINI)HDMI19J2USBCONN_3_UMB05H229135_USB\MKUSB\MKUMB05H229135JP1J_FPC18_FPC-18PINFPC-18PINFPC18JP2OV-CMOS-SENSOR-FPC24_0_FPC-30PIFPC-30PINFPC-30PINX-BL1INDUCTOR_4_0805LL_10R10R0805LLL2INDUCTOR_4_SMT_SB32_2.2UH2.2uHSMT_SB32L3INDUCTOR_4_0805LL_10R10R0805LLL4INDUCTOR_4_SMT_SB32_2.2UH2.2uHSMT_SB32L5INDUCTOR_4_0805LL_10R10R0805LLL6INDUCTOR_4_SMT_SB32_2.2UH2.2uHSMT_SB32L7INDUCTOR_4_0603C_10R10R0603CL8INDUCTOR_4_0603R_0R/33UH/06030R/33uH/06030603RL9INDUCTOR_4_0603R_0R/33UH/06030R/33uH/06030603RL10INDUCTOR_1206R_TLEC3216D601-2R0TLEC3216D601-2R0TF/12061206RL11INDUCTOR_5_USB-EMI_00USB-EMIL12INDUCTOR_1206R_TLEC3216D601-2R0TLEC3216D601-2R0TF/12061206RMC1TF_0_SMT_TF-CARD_MICROT-F SDMicro T-F SDSMT_TF-CARDR13#22_1%_02112-220Z-00_SMT_R0402_4.7KSMT_R0402R14#22_1%_02112-220Z-00_SMT_R040_11.2kSMT_R0402R15#22_1%_02112-220Z-00_SMT_R040_230KSMT_R0402R16#22_1%_02112-220Z-00_SMT_R040_3470RSMT_R0402R17R_SMT_R0402_22R/TLEA1005D301TF22R/TLEA1005D301TFSMT_R0402R18R_3_R0402_47R47RR0402R19#22_1%_02112-220Z-00_SMT_R0402_4.7KSMT_R0402SW1SWPUSHBUTTON_1_TS-1112N_RESET/RESET/TS-1112NTS-1112NTP1T POINTS_0_T_POINT_S_T POINT ST POINT ST_POINT_STP2T POINTS_0_T_POINT_SA_T POINTT POINT ST_POINT_SAU1RT-DS8097B-SOT-23-6_1_SMT_SOT23RT8059SMT_SOT23-5U2CM2830A_1_SMT_SOT23-5_RT8059RT8059SMT_SOT23-5U3CM2830A_3_WD3A6V1_WD3A6V1WD3A6V1WD3A6V1U4RT8059_0_SMT_SOT23-5_RT8059RT8059SMT_SOT23-5U5RT9193-33_3_SMT_SOT23-5_RT9013-RT9013-18PBSMT_SOT23-5U6RT9166_0_SMT_SOT-23_ELM88331BAELM88331BASMT_SOT-23U7NT96660_7_TFBGA_341P_NT96660NT96660TFBGA_341PU8SERIALFLASH_1_IC-TDFN8-2X2-SSD1108IC-TDFN8-2X2-SSDCP1108AFU9RT9166_0_SMT_SOT-23_TF6206A30MTF6206A30MSMT_SOT-23U10DDRIIIDRAM_6_DDR3-1GB1_DDRIIIDDRIII DRAMNT5CB128M16AP 128Mb*16DDR3-1GB1U11SERIALFLASH_0_SOP8-8L_MX25L640MX25L6406SOP8-8LU12GMA301_4_GMA301_GSENSOR GMA301G sensor GMA301/DA380GMA301U13WM6200RI_0_WM6200RI_WM6200RIWM6200RIWM6200RIU142_0.4GHZ RFMODULE_AMP8761-15_1APM8761AMP8761-15_13U15GMT/G5910_SMT_SOT23-6_GMT/G5910GMT/G5910-50TBUSMT_SOT23-6UPS1IC_MCU_ST801_RS_0_SOP8-8L1_FPT-FPT-8P-M08-1SOP8-8L1Y1CRYSTAL/SM_0_CRY-D3225_12MHZ12MHzCRY-D3225Y2CRYSTAL/SM_1_CRYS2_3R3X1R6-H0R832768Hz/3.3X1.6\H0.85CRYS2_3R3X1R6-H0R85
老吴 发表于 2019-2-25 15:55
PCB文件共享。回复可见 ,ALLEGRO16.6打开。没有原理图
**** Hidden Message *****
经纬 发表于 2019-2-25 17:43
回 老吴 的帖子
老吴:PCB文件共享。回复可见 ,ALLEGRO16.6打开。没有原理图
[内容隐藏]
 (2019-02-25 15:55) images/back.gif
好东西
thanky0u58 发表于 2019-2-25 18:45
yfchen1003 发表于 2019-2-25 19:08
n牛了老大
zhifang88 发表于 2019-2-25 20:51
欢迎又一波大招来袭
huang8089 发表于 2019-2-25 20:54
ntpcbyanli4111 发表于 2019-2-25 21:30
南亭好远 发表于 2019-2-25 22:58
这个可以
学海无涯 发表于 2019-2-26 08:05
好东西,谢谢分享。
页: [1] 2 3 4 5 6 7 8 9
查看完整版本: 联泳NT96660高清行车记录仪PCB文件共享
