M21121+MAX3815做的8X8 HDMI(DVI) 视频切换矩阵PCB和原理图共享 源
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC572CERAMICCAP_C0402_0.1UF0.1uFC0402CON2DIP34_BH2X17-HD_DIP34DIP34BH2X17-HDD1DIODE_0_TS-TO252_DIODE_4PINDIODE_4pinTS-TO252D5BAV70_SOT-23_BAV70BAV70SOT-23D6BAV70_SOT-23_BAV70BAV70SOT-23D7BAV70_SOT-23_BAV70BAV70SOT-23D8BAV70_SOT-23_BAV70BAV70SOT-23D12LED_LED-504_LEDLEDLED-504D13LED_LED-504_LEDLEDLED-504D14BAV70_SOT-23_BAV70BAV70SOT-23D16BAV70_SOT-23_BAV70BAV70SOT-23D17BAV70_SOT-23_BAV70BAV70SOT-23D18BAV70_SOT-23_BAV70BAV70SOT-23D21LED_LED-504_LEDLEDLED-504D22LED_LED-504_LEDLEDLED-504D23LED_LED-504_LEDLEDLED-504D24LED_LED-504_LEDLEDLED-504D25LED_LED-504_LEDLEDLED-504D26LED_LED-504_LEDLEDLED-504FAN2CON2_JH2-HD_CON2CON2JH2-HDFAN3CON2_JH2-HD_CON2CON2JH2-HDFB5MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB6MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB7MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB8MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB9MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB10MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB11MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB17MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB18MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB19MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603FB20MAGNETIC BEAD_FB0603_MAGNETICmagnetic beadFB0603L1INDUCTOR_1_SDR2207_4.7UH16A4.7uH 16ASDR2207M1N-MOSFET_0_SOP8B-150_FDS6298FDS6298SOP8B-150M2N-MOSFET_0_SOP8B-150_FDS9435FDS9435SOP8B-150NPN_1Q_SOT-23_QQSOT-23U2LM1084-3_0.3_TS-TO263_LM1084-3.LM1084-3.3TS-TO263U3LM1084-3_0.3_TS-TO263_LM1084-3.LM1084-3.3TS-TO263U9M21121_0_BGA404C_M21121M21121BGA404CU12LM3478MM_MSOP8E-118_LM3478MMLM3478MMMSOP8E-118U1624C02_SOP8B-154_24C0224C02SOP8B-154U1824C02_SOP8B-154_24C0224C02SOP8B-154U2024C02_SOP8B-154_24C0224C02SOP8B-154U2224C02_SOP8B-154_24C0224C02SOP8B-154U2424C02_SOP8B-154_24C0224C02SOP8B-154U2624C02_SOP8B-154_24C0224C02SOP8B-154U2824C02_SOP8B-154_24C0224C02SOP8B-154U3024C02_SOP8B-154_24C0224C02SOP8B-154U68DIP4_0.08_PWR-4P-H_DIP4_5.08DIP4_5.08PWR-4P-HU69MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U70MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U71MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U72MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U73MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U74MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U75MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U78VIA28_0_MH270D110-8P_VIA28VIA28MH270D110-8PU80VIA28_0_MH270D110-8P_VIA28VIA28MH270D110-8PU81VIA28_0_MH270D110-8P_VIA28VIA28MH270D110-8PU82VIA28_0_MH270D110-8P_VIA28VIA28MH270D110-8PU83DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U84DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U85DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U86MAX3815_0_TQFP48F-7X7-2P0_MAX38MAX3815TQFP48F-7X7-2P0U87DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U88DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U89DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U90DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2U92DVI_2_SUB_2_DVI_X2_DVI_2_SUBDVI_2_SUBDVI_X2 资料比较好,感谢楼主无私分享!! PCB和原理图一起打包。 源码。回复可见
PS 资料没核实正确性。仅供参考。
**** Hidden Message ***** 多谢老吴的共享 谢谢分享M21121+MAX3815做的8X8 HDMI(DVI) 视频切换矩阵PCB和原理图 看起来很好,感谢分享 谢谢分享 看起来不错 谢谢分享!! 谢谢哦哦
