老吴 发表于 2019-4-14 21:03
20层Freescale T4240QDS vxworks7.0 24核 PowerPC 开发板 PCB和原理图 da
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BATTERY_SKT_3V_SKT_BAT_225X886_WBA-3B2 USKT_BAT_225X886_3VD29LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603D30LED_LED_0603_IC_0.9MM_370-75079REDLED_0603D31LED_LED_0603_IC_0.8MM_370-75078BLUELED_0603D32LED_LED_0603_IC_0.9MM_370-75079REDLED_0603D33LED_LED_0603_IC_0.9MM_370-75079REDLED_0603D55LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603D56LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603D57LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603D58LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWLED_0603D63LED_LED_0603_IC_0.9MM_370-75079REDLED_0603D64DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123D65DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123D66DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GSOD123D67DIODE_SOD123_A_IC_1.35MM_480-78CMHD3595SOD123_AD68DIODE_SOD123_A_IC_1.35MM_480-78CMHD3595SOD123_AD69LED_LED_0603_IC_0.9MM_370-75079REDLED_0603D70LED_LED_0603_IC_0.9MM_370-75079REDLED_0603F25INDUCTOR_FERRITE_IND_0805_DISCR1000@100MHZIND_0805F31BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603AF32BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603AF35IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603F53BEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1IND_0603AJ2CONN_HDR_4X2_HDR2X4_2P54_TH_RA_PLUG 2X4 RAHDR2X4_2P54_TH_RAJ3PCIEXPRESS_MIDBUSPROBE_GEN_X16_CONN_PCIEX16_LAICONN_PCIEX16_LAIJ4PCIEXPRESS_MIDBUSPROBE_GEN_X16_CONN_PCIEX16_LAICONN_PCIEX16_LAIJ15CONN_HDR_3X1_HDR103_IO_9.45MM_2HDR_1X3HDR103J22DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ23DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ24CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR 1X7CON_7_SATA_V_SMJ25SIG_TIE_100X200_SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J26CON_SATA_PLUG7_CON_7_SATA_V_SM_HDR 1X7CON_7_SATA_V_SMJ27ATX_12V_PWR_CONN8_CONN_2X4_165_CON 2X4CONN_2X4_165_THJ30CONN_PWR_12X2_CON_ATXPWR_2X12_ACON_2X12_PWRCON_ATXPWR_2X12_AJ38CONN_HDR_5X2_HDR205_4W_IO_9.65MCON_2X5HDR205_4WJ40MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ41MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ49QTH-030-02-L-D-A_CON_60_QTH_0P5CONNECTOR_60PW/2GUIDECON_60_QTH_0P5_SM_2GUIDEJ51DSD9M_DUALDB-9MM_IO_31.75MM_2102XDB9DUALDB-9MMJ53CON_USB_8P_F_4SH_CON_USB_8F_TH_USB_TYPE_A_DUALCON_USB_8F_TH_RAJ54USB_MINI_AB_RECEPTACLE_CON_USB_USB_TYPE_ABCON_USB_5F_0P65_SM_RAJ55CONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19CON19_SDCARD_28X16_SMJ60CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ75QTH060_CON_120_0P5MM_SM_2GUIDE_CONNECTOR_120PW/2GUIDECON_120_0P5MM_SM_2GUIDEJ83CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ84CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ85CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ86CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ87PCI_EXPRESS_CONN16_A_CON_PCIE16W3GD-164AN63B52UWCON_PCIE164_1_SMJ88CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ89PCI_EXPRESS_CONN16_A_CON_PCIE16W3GD-164AN63B52UWCON_PCIE164_1_SMJ90CONN_PCI_EXPRESS_X8_A_CON_PCIE_CON 98 PCIE SMTCON_PCIE_98F_40_SMJ91CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ92CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ93CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ94CONN_2X35_CON2X35_SKT_0P8_SM_IOCONN SKT 70CON2X35_SKT_0P8_SMJ95CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ96CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ97CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ98CONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20CONN2X20_20X7MM_PCI_EXTJ101MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ102MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ103MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ104MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ105HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102J107HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102J110DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ111DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ200DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ201DDR3_240P_CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ202MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ203MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ204HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102J216CONN_HDR_8X2_HDR208_B_IO_9.86MMCON_2X8HDR208_BJ217CONN_HDR_8X2_HDR208_B_IO_9.86MMCON_2X8HDR208_BJ218HDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR 1X3HDR1X3_THJ221CONN_HDR_3X2_HDR203_IO_8.58MM_2HDR_2X3HDR203J223HDR-1X8_JUMP1X8-6040_IO_8.382MHDR_1X8JUMP1X8-6040J224CON_2X15_HDR_CON30_2P54_8P81X38SSW-115-02-F-D-RACON30_2P54_8P81X38P61MM_CJ225ATX_12V_PWR_CONN8_CONN_2X4_165_CON 2X4CONN_2X4_165_THJ226MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ229MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ230HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102J231MMBX_SMT_F_CUST_CON_SMA_IO_9.53CON 1 SMACON_SMAJ232HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2HDR102J233CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SMJ234CONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2HDR102_STAG_SML1ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311L2ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311L3ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311L4ETQP6F_2P_IND2_410X311_DISCRETE175nHIND2_410X311L6COIL_IND_IHLP-5050_DISCRETE_6.50.33uHIND_IHLP-5050L40INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016AL41INDUCTOR_IND_2016A_DISCRETE_1.810UHIND_2016AL42INDUCTOR_IND_2016_DISCRETE_1.6M2.2UHIND_2016L43IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603L44DLW43_CHOKE_0805_DISCRETE_1.4MM90OHMCHOKE_0805L45IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603L46IND_IND_0603_DISCRETE_1MM_180-760 OHM 100MHZIND_0603L47DLW43_CHOKE_0805_DISCRETE_1.4MM90OHMCHOKE_0805L82BEAD_FERRITE_IND_0603A_DISCRE_1BLM18KG121TN1IND_0603AP4RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ45 13X2PORTSCON_RJ45_2X1_MAG_LEDQ1TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4Q2TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q3TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q4TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4Q5TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q6TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q7TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4Q8TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q9TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q10TRANS_NMOS_3P_TDSON_0P65_3P4X3PBSZ060NE2LSTDSON_0P65_3P4X3P4Q11TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q12TRANS_NMOS_5P_TDSON_1P27_5P35X6CSD17312Q5TDSON_1P27_5P35X6P35Q13MOSFET_N_8P_TDSON8_1P27_6X5MM_IBSC080N03MSGTDSON8_1P27_6X5MMQ14MOSFET_N_8P_TDSON8_1P27_6X5MM_IBSC080N03MSGTDSON8_1P27_6X5MMQ15MOSFET_N_8P_TDSON8_1P27_6X5MM_1BSC020N03MSGTDSON8_1P27_6X5MMQ16MOSFET_N_8P_TDSON8_1P27_6X5MM_1BSC020N03MSGTDSON8_1P27_6X5MMQ17NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904SOT23RT1THERMISTOR_NTC_RC0805_OV_DISCRE6.8KRC0805_OVSW9SW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTSW_DIP16_8POS_SMSW11SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SWSW12SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SWSW13SW_TACT-SPST-2_SM_6_22X6_38_SW_DTSMW-69R-V-T/R6_22X6_38_SWU1T4240_BGA1932_1MM_45X45MM_IC_3.T4240PSE1T1ABGA1932_1MM_45X45MMU2OSC3_XTLOSC4_5X7_5_IC_1.55MM_2366.666MHzXTLOSC4_5X7_5U6INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U7INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U8INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U9INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U10INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U22CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U31TPS51200_QFN_10_0P5_3X3_IC_1.0TPS51200QFN_10_0P5_3X3U56ZL6105_QFN_36P_QFN36_0P5_6X6_ICZL6105QFN36_0P5_6X6U76MAX811_SOT143-25X60_IC_1.22MM_MAX811SOT143-25X60U77IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15U781G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U79IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15U80INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTMSOP_10_0P5_3X3U83IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15U84100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5U85ADG804_MSOP10_60X12_IC_1.10MM_3ADG804YRMMSOP10_60X12U92IC_ISL8201_QFN_15P_QFN15_15X1_1ISL8201MIRZQFN15_15X15U93100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5U97PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5U99ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C02C-XHM-BTSSOP8U101ATMEL_SERIAL_EEPROM_64K-1_TSSOPAT24C02C-XHM-BTSSOP8U102DS3232S_SO20W_IC_2.67MM_315-767DS3232SO20WU1031G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U104ADT7481_MSOP10_60X12_IC_1.10MM_ADT7481ARMZMSOP10_60X12U1061G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U110SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5U111S29GL01GS_56P_TSOP56_IC_1.2MM_3S29GL01GS11TFI010TSOP56U112CONN_HDR_25X2_CON_FTR-125-01-S-HDR_2X25CON_FTR-125-01-S-DU113SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5U114SN74LVC_SOT-23-5_IC_1.45MM_312-SN74LVC1G86SOT-23-5U115AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8U116AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8U120SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16U121SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16U138VSC8641_EP-100LQFP_LQFP100_0P4_VSC8641XKOLQFP100_0P4_12X12MMU139VSC8641_EP-100LQFP_LQFP100_0P4_VSC8641XKOLQFP100_0P4_12X12MMU230MT29F4G08ABBDAH4_VFBGA63_0P8_9XMT29F4G08ABBDAH4VFBGA63_0P8_9X11U262A3PE1500-676P_FBGA676_1MM_27X27A3PE1500-FGG676FBGA676_1MM_27X27U272IC_ISL8201_QFN_15P_QFN15_15X15_ISL8204MIRZQFN15_15X15U274FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU278SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16U279SN74CB3Q3253DGVR_TVSOP16_IC_1.2SN74CB3Q3253TVSOP16U285SST25WF040_SO8_1P27_4X5_IC_1.75SST25WF040SO8_1P27_4X5U287SN74CB3Q3257DGVR_TVSOP16_0P4_4XSN74CB3Q3257DGVRTVSOP16_0P4_4X3U2928T49N222A_48P_QFN48_0P5_7X7_TAB8T49N222A-100NLGI8QFN48_0P5_7X7_TAB5P65U293NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U294NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U295NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U296FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU297FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU302PCA9521D_SO8_TSSOP8_A_IC_1.1MM_PCA9521DPTSSOP8_AU303PCA9521D_SO8_TSSOP8_A_IC_1.1MM_PCA9521DPTSSOP8_AU304NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MMU305NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MMU306NVT2003DP_TSSOP10_TSSOP10_0P5_3NVT2003DPTSSOP10_0P5_3X3MMU307FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU308FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU315FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU316FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU317FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU318TPS51200_QFN_10_0P5_3X3_IC_1.0TPS51200QFN_10_0P5_3X3U320NC7SP08_SC70-5_A_IC_1.1MM_312-7NC7SP08SC70-5_AU321LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EPU322LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EPU325IC_ISL8201_QFN_15P_QFN15_15X1_1ISL8201MIRZQFN15_15X15U326100201_SO_10_SC70-5_IC_1.1MM_31SN74CBTLV1G125DCKRSC70-5U327ISL8010X_DFN_10P_DFN10_0P5_3X3_ISL80103IRAJZDFN10_0P5_3X3U333NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U334NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U3381G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U3391G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U340MAX4906ELB_0_DFN_10_0P4_2X2_MAXMAX4906FELB+DFN_10_0P4_2X2_MAXIMU341TXS0206_BGA20_0P4_1P6X2_NSP_IC_TXS0206BGA20_0P4_1P6X2_NSPU342TXS0206_BGA20_0P4_1P6X2_NSP_IC_TXS0206BGA20_0P4_1P6X2_NSPU343LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1U345LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1U346LTC2912-2_TSOT23_8_0P65_2X1_IC_LTC2912CTS8-2TSOT23_8_0P65_2X1U3516V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MMU3526V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MMU3536V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MMU3546V31021NLGI8_MLF_20P_TQFN20_0P56V31021NLGI8TQFN20_0P5_4X4MMU355PCA9547_24P_TSSOP24_0P65_7P9X4PPCA9547PWTSSOP24_0P65_7P9X4P5U358IDT840NT4_48P_QFN48_0P5_7X7_TABIDT840NT4-01AKQFN48_0P5_7X7_TAB5P65U359ISL6334IRZ_QFN_40P_QFN40_0P5_6PISL6334DCRZQFN40_0P5_6P1X6P1U360ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3U361ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3U362ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3U363ISL6620CR_DFN10_DFN10_0P5_3X3_IISL6620CRDFN10_0P5_3X3U3648T49N222A_48P_QFN48_0P5_7X7_T_18T49N222A-101NLGI8QFN48_0P5_7X7_TAB5P65U3658T49N222A_48P_QFN48_0P5_7X7_TAB8T49N222A-100NLGI8QFN48_0P5_7X7_TAB5P65U3672-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5U368NC7SZ14_SC70-5_A_IC_1.1MM_312-NC7SZ14SC70-5_AU3692-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5U3712-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5U3722-INPUT_OR_SC70-5_IC_1.1MM_312-NC7SZ32P5XSC70-5U37374-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48U37474-3245_20P_TSSOP20_IC_1.2MM_374CB3Q3245TSSOP20U37574-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48U37674-16210_48P_TVSOP48_IC_1.2MM_3SN74CB3Q16210DGVRTVSOP48U381ICS557_08_TSSOP16_IC_1.2MM_312-6V31023PGGI8TSSOP16U382LTC2804_SSOP16_SSOP16_4P8X3P8MMLTC2804-1SSOP16_4P8X3P8MMU383LTC2804_SSOP16_SSOP16_4P8X3P8MMLTC2804-1SSOP16_4P8X3P8MMU384NC7SZ14_SC70-5_A_IC_1.1MM_312-NC7SZ14SC70-5_AU3852076_2_8P_SOP8-1_IC_1.73MM_312-MIC2076-1YMSOP8-1U386RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6U387RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTSLP1616P6U388VSC3316XJK_196P_BGA196_1P0_15X1VSC3316XYPBGA196_1P0_15X15_C019U389VSC3316XJK_196P_BGA196_1P0_15X1VSC3316XYPBGA196_1P0_15X15_C019U390840NT4_48P_QFN48_0P5_7X7_TAB5P6IDT840NT4QFN48_0P5_7X7_TAB5P65U391FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU392NC7WZ16_SC70-6_IC_0.95MM_312-75NC7WZ16SC70-6U395FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU396FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU397FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU398FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU399FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU400FXL2T245_MICROPAK_10P_IC_0.55MFXL2T245MICROPAK_10PU4018535_31_TSSOP_20P_TSSOP20_IC_1.8535AGI-31LFTTSSOP20U4028535_31_TSSOP_20P_TSSOP20_IC_1.8535AGI-31LFTTSSOP20U4038T49N222A_48P_QFN48_0P5_7X7_T_18T49N222A-101NLGI8QFN48_0P5_7X7_TAB5P65U404871S1022EK_QFN32_QFN32_S134EP_I871S1022EKLFTQFN32_S134EPU405AT24CXX_TSSOP8_IC_1.2MM_334-756AT24C512C-XHD-BTSSOP8U406TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14U407TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14U408FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU409FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU410NC7SB3157_6P_MICROPAK_6P_IC_0.5NC7SB3157L6XMICROPAK_6PU411MTFC4GGQDQ_LBGA_100P_LBGA100_1MN2M400FDB311A3CFLBGA100_1MM_14X18U412TXB0104PWRG4_TSSOP14_IC_1.2MM_3TXB0104PWRG4TSSOP14U413SN74CB3Q3257DGVR_TVSOP16_0P4_4XSN74CB3Q3257DGVRTVSOP16_0P4_4X3U414FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU415FXLP34_MICROPAK_6P_IC_0.55MM_31FXLP34L6XMICROPAK_6PU4181G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70U419LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EPU420LT3070_QFN28_4X5_EP_IC_0.8MM_31LT3070IUFDQFN28_4X5_EPU421NL17SZ126_SC-70_IC_1.1MM_312-80NC7SV126SC-70U422NL17SZ126_SC-70_IC_1.1MM_312-80NC7SV126SC-70U4231G125_SC-70_IC_1.1MM_312-75240_SN74LVC1G125DCKRSC-70VDD_CORE_PL1TESTLOOP_TEST_LOOP_IO_4.8MM_21TEST POINT REDTEST_LOOPXU1N25Q512A11GSF40X_SO16W_IC_2.65MN25Q512A11GSF40FSO16WXU2EN25S64_8P_SO8_W_IC_1MM_342-005EN25S64SO8_WY1XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLFY2XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLFY3XTAL_HC49SDLF_IC_4.5MM_230-778720.1416MHZHC49SDLFY4CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_25MHZXTLOSC4_5X3MM_SMY9XTAL_13Y_XTAL_4_7P2X5P2_IC_1.3M25MHZXTAL_4_7P2X5P2
老吴 发表于 2019-4-14 21:09
PCB 原理图一起打包,5个金币。
其他的一些资料都发上来了。有需要的下载
shyoung 发表于 2019-4-14 21:12
Re:20层Freescale T4240QDS vxworks7.0 24核 PowerPC 开发板 PCB和原理图
老吴太猛了!那个Vxwork7能不能共享一下?
地沟油 发表于 2019-4-14 21:30
yhgwork 发表于 2019-4-14 22:02
老大厉害
tylh 发表于 2019-4-14 22:04
zhifang88 发表于 2019-4-14 22:42
名不虚传
单枪舞九州 发表于 2019-4-15 07:30
支持
十月的皮皮 发表于 2019-4-15 07:47
谢谢分享!
学习学习哦,好东西
页: [1] 2 3 4 5 6 7 8
查看完整版本: 20层Freescale T4240QDS vxworks7.0 24核 PowerPC 开发板 PCB和原理图 da
