XCKU060-2FFVA1156E +ADV7511+XC7Z010CLG225+MAX20751EKX+M88E1111 做的一个22
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1TS518FE_FL35ETS518FE-FL35EBAT_TS518_TS621_DUALC20_1UF_04020.1UF402C460470UF_G470UFTANT_DC461470UF_G470UFTANT_DC462470UF_G470UFTANT_DC499330UF_8_3MMX8_3MM330UFCAPR_800_350C911470UF_G470UFTANT_DC915470UF_G470UFTANT_DD1DL4148DL4148MINIMELFD2DFLS1150DFLS1150DIO_DFS1150_7D3DDZ9678_SOD_123DDZ9678SOD_123D4BAT54T1GBAT54T1GSOD_123D5BAT54T1GBAT54T1GSOD_123D10BAT54T1GBAT54T1GSOD_123D11BAT54T1GBAT54T1GSOD_123D12BAT54T1GBAT54T1GSOD_123D13BAT54T1GBAT54T1GSOD_123D14BAT54T1GBAT54T1GSOD_123D15BAS40_04_SOT23BAS40-04SOT_23D19MMSZ4683T1GMMSZ4683T1GSOD_123D32MMSZ4683T1GMMSZ4683T1GSOD_123D33MMSZ4680T1G_SOD_123MMSZ4680T1GSOD_123D35BAT54T1GBAT54T1GSOD_123D36MMSZ4680T1G_SOD_123MMSZ4680T1GSOD_123D37MMSZ4680T1G_SOD_123MMSZ4680T1GSOD_123D38MMSZ4680T1G_SOD_123MMSZ4680T1GSOD_123D39MMSZ4683T1GMMSZ4683T1GSOD_123DP1RCLAMP0524PRCLAMP0524PRCLAMP0524PDP2RCLAMP0524PRCLAMP0524PRCLAMP0524PDP3RCLAMP0524PRCLAMP0524PRCLAMP0524PDP4RCLAMP0524PRCLAMP0524PRCLAMP0524PDS2HSMF-C155LED-GRN-REDHSMF_C15XDS3HSMF-C155LED-GRN-REDHSMF_C15XDS42HSMF-C155LED-GRN-REDHSMF_C15XJ2ASP_134486_01ASP_134486_01ASP_134486_01J3MOLEX-87832-142087832-142087832_1420J4ZX62D_AB_5P8ZX62D_AB_5P8CON_HR_ZX62D_AB_5P8J5HDR_1X3HDR_1X3HDR_1X3J12HDR_1X2HDR_1X2HDR_1X2J14HDR_1X2HDR_1X2HDR_1X2J1539-30-1060_JACK_500X54039-30-1060CON_MOL_5569_6PJ22ASP_134486_01ASP_134486_01ASP_134486_01J23TP_5001_BLACKBLACKTP_KEY_MINIJ24TP_5001_BLACKBLACKTP_KEY_MINIJ25TP_5001_BLACKBLACKTP_KEY_MINIJ26TP_5001_BLACKBLACKTP_KEY_MINIJ27TP_5001_BLACKBLACKTP_KEY_MINIJ34SMA_32K10K-40032K10K-400L532K10K_400_3VIAJ35SMA_32K10K-40032K10K-400L532K10K_400_3VIAJ38TP_5001_BLACKBLACKTP_KEY_MINIJ39SHR_HDR_2X8HDR_BOX_2X8HDR_BOX_2X8J52HDR_2X6_F_RAHDR_2X6_F_RAHDR_F2X6_PMODJ53HDR_2X6HDR_2X6HDR_2X6J54TP_5000_REDDNPTP_KEY_MINIJ58TP_5000_REDDNPTP_KEY_MINIJ63TP_5000_REDDNPTP_KEY_MINIJ65TP_5000_REDDNPTP_KEY_MINIJ70TP_5000_REDDNPTP_KEY_MINIJ73WM2701-ND22_11_2032HDR_1X3_LOCK_MOLEXJ74HDR_2X3HDR_2X3HDR_2X3J77TP_5000_REDDNPTP_KEY_MINIJ78HDR_1X4HDR_1X4HDR_1X4J80HDR_1X2HDR_1X2HDR_1X2J81HDR_1X2HDR_1X2HDR_1X2J82SAMTEC_1X6_RA_0190SAMTEC-TSW-106-22-F-S-RASAMTEC_TSW_106_22_S_RAJ83CON_MOL_10P_5025700893CON_MOL_10P_5025700893CON_MOL_10P_5025700893J84TP_5004_YELLOWYELLOWTP_KEY_MINIJ85TP_5004_YELLOWYELLOWTP_KEY_MINIJ86TP_5000_REDDNPTP_KEY_MINIJ87CCC-J-020CCC-J-020SAMTEC_TRIPC20_THRUJ88TP_5000_REDDNPTP_KEY_MINIJ89CFP2CFP2CON_CFP2_104PJ90CFP2_COVER_SINGLECFP2_COVER_SINGLECON_YAM_CN121G_104_0002J95CFP2_CAGE_SINGLECFP2_CAGE_SINGLECON_YAM_CN121C_104_0002J96U95-T1Y1-100AU95-T1Y1-100ACON_AMP_U95_T_1Y1_100AJ97TP_5000_REDDNPTP_KEY_MINIJ99TP_5000_REDDNPTP_KEY_MINIJ100TP_5000_REDDNPTP_KEY_MINIJ101TP_5000_REDDNPTP_KEY_MINIJ103TP_5000_REDDNPTP_KEY_MINIJ104TP_5000_REDDNPTP_KEY_MINIJ105HDR_1X6HDR_1X6HDR_1X6J106ZX62D_AB_5P8ZX62D_AB_5P8CON_HR_ZX62D_AB_5P8J107TP_5000_REDDNPTP_KEY_MINIJ108TP_5000_REDDNPTP_KEY_MINIJ109TP_5000_REDDNPTP_KEY_MINIJ110HDR_1X2HDR_1X2HDR_1X2L92FERRITE-835FERRITE-835BEAD_LAIRD_28C0236MH1HOLE_MH_125_250MH_125_250MH_250H125P1PCIE_8LANE_EDGEPCIE_8LANE_EDGEPCIE_8LANE_EDGEP3RJ45_HFJ11-1G01E-L12RLRJ45CON_ETH_HFJ111G01E_L12RLP647151-001147151-0011CON23_HDMI_MOLEX_RAQ1FDS6681ZFDS6681ZSOIC_8Q4BSS138BSS138SOT_23Q5BSS138BSS138SOT_23Q6BSS138BSS138SOT_23Q9FDPC8011SFDPC8011SPWRCLIP_33Q17NDS331N_SOT23NDS331NSOT_23Q18SI2300DS_SOT23SI2300DSSOT_23Q22BSS138BSS138SOT_23Q25MMBT3904TMMBT3904TSOT523Q34NDS331N_SOT23NDS331NSOT_23Q35NDS331N_SOT23NDS331NSOT_23Q36BSS138BSS138SOT_23Q37NDS331N_SOT23NDS331NSOT_23Q39FDPC8011SFDPC8011SPWRCLIP_33Q40MMBT3904TMMBT3904TSOT523Q41NDS331N_SOT23NDS331NSOT_23Q42FDPC8011SFDPC8011SPWRCLIP_33Q43FDPC8011SFDPC8011SPWRCLIP_33Q45FDMS8558SFDMS8558SPWR_56Q47FDMS8558SFDMS8558SPWR_56Q48MMBT3904TMMBT3904TSOT523Q49MMBT3904TMMBT3904TSOT523Q51MMBT3904TMMBT3904TSOT523Q52NDS331N_SOT23NDS331NSOT_23Q53NDS331N_SOT23NDS331NSOT_23Q54NDS331N_SOT23NDS331NSOT_23Q55NDS331N_SOT23NDS331NSOT_23Q56NDS331N_SOT23NDS331NSOT_23Q57NDS331N_SOT23NDS331NSOT_23R87WSLP12065L000FEA0.005RES_WSLP_1206R1171WSLP12065L000FEA0.005RES_WSLP_1206R1172WSLP12065L000FEA0.005RES_WSLP_1206R12020_001_SMV_R47230.001RES_SMR_VRP210KX4_0603X410.0KRP_EXB_0603X4RP310KX4_0603X410.0KRP_EXB_0603X4SW11101M2S3AQE21101M2S3AQE2SW_102_1261_EVSW4TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW5TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW6TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW7TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW9TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW10TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW12SDA04H1SBDSDA04H1SBDSW_SDA_8PSW14TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PSW15SDA05H1SBDSDA05H1SBDSW_SDA_10PSW16SDA05H1SBDSDA05H1SBDSW_SDA_10PSW17TL3301EF100QG-NDTL3301EF100QGSW_TL3301_G_4PU1SOC_VU095_FFVA2104_IRONWOODSOC_VU095_FFVA2104_IRONWOODSOC_2104_1MM_IRONU4MAX15301MAX15301TQFN_32_EPU9MAX15301MAX15301TQFN_32_EPU12M24C08-WDW6TPM24C08-WDW6TPTSSOP8_65P440X300MMU13SN74AVC2T245SN74AVC2T245QFN_RSW_10U15MAX16052MAX16052SOT23_6U16BNX016-0150MOHMMURATA_BNX01U19SN74AVC8T245SN74AVC8T245TSSOP_24U24TPS51200DRCTTPS51200DRCTSON10_TPS51200U25SN74LVC1G08SN74LVC1G08SC70_5U26NC7SZ66NC7SZ66P5XSC70_5U28TCA9548APWR_TSSOP_24TCA9548APWRTSSOP_24U30MAX15301MAX15301TQFN_32_EPU32570BAB000544DG_5X710MHZ_TO_810MHZSI570U34CP2105CP2105QFN_24U41TXS0108ETXS0108ETSSOP_20U42TXS0108ETXS0108ETSSOP_20U43TXS0108ETXS0108ETSSOP_20U44TXS0108ETXS0108ETSSOP_20U45TXS0108ETXS0108ETSSOP_20U47SN74AVC4T245SN74AVC4T245QFN_RSV_16U48SN74AVC4T245SN74AVC4T245QFN_RSV_16U49SN74AVC4T245SN74AVC4T245QFN_RSV_16U51SN74AVC8T245SN74AVC8T245TSSOP_24U52ADV7511ADV7511LQFP100_14X14U53SN74AVC1T45SN74AVC1T45SC70_6U57SI5328B-C-GMRSI5328BQFN36_6X6MMU58M88E1111_BAB1C000M88E1111TFBGA_117U60EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU61EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU62EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU63EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU64EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU71NC7SV125NC7SV125SC70_5U74INA333_MSOP-8INA333MSOP_8U75ADG707BRUZ_TSSOP_28ADG707BRUZTSSOP_28U77PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U78PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U80PCA9544ARGYRPCA9544ARGYRVQFN_20U82MAX17502_5V0MAX17502TDFN_10U84SN74AVC1T45SN74AVC1T45SC70_6U86PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U89TCA6416APWRTCA6416ATCA6416APWRU90SN74AVC1T45SN74AVC1T45SC70_6U104SI53340-B-GMSI53340-B-GMQFN16_SI_3X3MMU108PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U109TXS0108ETXS0108ETSSOP_20U111XC7Z010CLG225XC7Z010CLG225CL225U112SN74AVC1T45SN74AVC1T45SC70_6U113SN74AVC1T45SN74AVC1T45SC70_6U114N25Q128AN25Q128ASO16_50P300X413U115DIGILENT_USB_JTAG_2_NCDIGILENT_USB_JTAG_2_NCDIGILENT_USB_JTAG_2_NCU116INA333_MSOP-8INA333MSOP_8U117INA333_MSOP-8INA333MSOP_8U118INA333_MSOP-8INA333MSOP_8U119INA333_MSOP-8INA333MSOP_8U120INA333_MSOP-8INA333MSOP_8U122SI5335A-B02436-GMSI5335A-B02436-GMQFN24_4X4MMU124MAX15053MAX15053WLP_9U125MAX15027MAX15027TDFN_10_3X3_EPU127PCA9306DCTRPCA9306DCTRDCT_R_PDSO_G8U128MAX16050MAX16050TQFN_28_EPU129SN74AUC1G07SN74AUC1G07DCKRSC70_5U130MAX6816MAX6816SOT143U131MAX8892EXKT_SC70_5MAX8892EXK+TSC70_5U132NC7SZ66NC7SZ66P5XSC70_5U133MT28GU01GAAA1EGC-0SITMT28GU01GAAA1EGC-0SITMT28GU01GAAA1EGC-0SITU134TPS51200DRCTTPS51200DRCTSON10_TPS51200U135EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU136EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU137EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU138EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU139EDY4016AABG-DR-F-DEDY4016AABG-DR-F-DFBGA_DDR4_96PU141MT44K16M36RB_093EMT44K16M36RB_093FBGA168_13_5X13_5MMU142MT44K16M36RB_093EMT44K16M36RB_093FBGA168_13_5X13_5MMU143TPS51200DRCTTPS51200DRCTSON10_TPS51200U144NVT2002DPNVT2002DPTSSOP_8U145FS1-Z38-20Z6-10FS1-Z38-20Z6-10ON_AMP_FSI_Z38_20Z6_10U146SN74AVC4T245SN74AVC4T245QFN_RSV_16U147SN74AVC4T245SN74AVC4T245QFN_RSV_16U148SN74AVC4T245SN74AVC4T245QFN_RSV_16U149SN74AVC4T245SN74AVC4T245QFN_RSV_16U150MAX15301MAX15301TQFN_32_EPU151MAX15053MAX15053WLP_9U152TXS0108ETXS0108ETSSOP_20U154MAX13035EMAX13035ETQFN_16U155REF3012AIDBZT_SOT23_3REF3012AIDBZTSOT23_3U156MAX15301MAX15301TQFN_32_EPU157SI53340-B-GMSI53340-B-GMQFN16_SI_3X3MMU158SN74AVC2T245SN74AVC2T245QFN_RSW_10U159VT1697SBFQXVT1697SBFQXHPQFN_19_AU160VT1697SBFQXVT1697SBFQXHPQFN_19_AU161VT1697SBFQXVT1697SBFQXHPQFN_19_AU162VT1697SBFQXVT1697SBFQXHPQFN_19_AU163VT1697SBFQXVT1697SBFQXHPQFN_19_AU164MAX20751EKXMAX20751EKXQFN_36_CU165MAX20751EKXMAX20751EKXQFN_36_CU166MAX20751EKXMAX20751EKXQFN_36_CU167MAX8869EUE18MAX8869EUE18+TSSOP_16_EPU168SN74AVC8T245SN74AVC8T245TSSOP_24X1TPD4S012TPD4S012DRY_6_SONX4XTAL_ABM825.00MHZXTAL_ABM8X5XTAL_CS_023_125X98114.285MHZXTAL_CS_023_125X98X625MHZ_FA23825MHZXTAL_EPSON_FA238X7TPD4S012TPD4S012DRY_6_SON PCB文件共享。没原理图
支持 收藏谢谢分享 谢谢分享
