shuszhao 发表于 2019-9-13 09:40
Razer Viper 雷蛇毒蝰电竞游戏鼠标 开箱拆解
Razer近期推出的Razer Viper雷蛇毒蝰电竞游戏鼠标,采用由Team Razer电竞选手参与设计和测试的行业领先的鼠标技术,是一款可以颠覆职业赛事的鼠标。它的重量只有69克,搭载7000万次点击耐用度的雷蛇光学鼠标微动,并配备高达16000DPI的Razer 5G光学传感器和柔韧性绝佳的Razer Speedflex超柔线缆,在确保阻力最小的情况下实现无阻碍控制
https://image.koolshare.cn/attachment/forum/201909/04/171248lij4zfvvg1vltiug.jpg
▲雷蛇天猫官方旗舰店购买链接
https://image.koolshare.cn/attachment/forum/201909/04/171929vd3sqpv7flsv3bbx.png
▲Razer Viper雷蛇毒蝰技术规格
开箱
https://image.koolshare.cn/attachment/forum/201909/04/172412y5mmjqva5zvqs5vi.jpg
▲雷蛇毒蝰包装盒正面
https://image.koolshare.cn/attachment/forum/201909/04/172638v61u776eaujujkk6.jpg
▲雷蛇毒蝰包装盒背面
https://image.koolshare.cn/attachment/forum/201909/04/174324xaa1iru0ihaficar.jpg
▲打开包装盒,拿出内部的雷蛇毒蝰鼠标
https://image.koolshare.cn/attachment/forum/201909/04/174417g9a9qqqpzj9sp38s.jpg
▲盒内所有部件
https://image.koolshare.cn/attachment/forum/201909/04/184338hfn2quaun2tbcna9.jpg
▲鼠标一只,说明书一本,官方寄语明信片一张,信仰贴纸一张
https://image.koolshare.cn/attachment/forum/201909/05/102022j7dpaj7p6i7da9l7.jpg
▲鼠标采用对称设计,左右手通用,大小为126.73mmx66.2mmx37.81mm,属于中型鼠
https://image.koolshare.cn/attachment/forum/201909/05/110629w2spur1716pallk6.jpg
▲鼠标的左右键以及尾部的掌托部分使用磨砂材质,能有效抑制指纹的产生,摸起来质感一流。而侧裙位置则是使用了橡胶材质,保证良好的防滑效果
https://image.koolshare.cn/attachment/forum/201909/05/104523rsspl12sptssas7m.jpg
▲对于中等大小的手型非常友好,握感十分舒适
https://image.koolshare.cn/attachment/forum/201909/05/105908bw2czmccwwfwy3nw.jpg
▲鼠标左侧是两个快捷按键,默认是前进与后退,也可以自行定义
https://image.koolshare.cn/attachment/forum/201909/05/110140nb14a4v4r2ca1ar4.jpg
▲鼠标右侧也有两个快捷按键,与左侧对称
https://image.koolshare.cn/attachment/forum/201909/05/111104k8zoqn287z51zqgc.jpg
▲RazerSpeedflex 超柔线缆,柔韧性绝佳,能确保阻力最小的情况下实现无阻碍控制
https://image.koolshare.cn/attachment/forum/201909/05/111246gijf3zy2fa7m787a.jpg
▲USB接口部分印有Razer的Logo,并采用了Razer特有的绿色设计
https://image.koolshare.cn/attachment/forum/201909/05/111717yhwcyh7z7hd1q4p7.jpg
▲鼠标底部是Razer 5G光学传感器和DPI切换按钮,可用于即时在5个不同DPI等级之间切换
https://image.koolshare.cn/attachment/forum/201909/05/112105gffagz5mitjs5paz.jpg
▲鼠标本体实测重量在69.4g,与官方标称的69g相差不大
拆解
https://image.koolshare.cn/attachment/forum/201909/05/122545rrtsem7sie0jm6er.jpg
▲首先拆除鼠标底部的脚贴,露出内部的螺丝。脚贴可以根据自己的喜好自由更换
https://image.koolshare.cn/attachment/forum/201909/05/122804lm53jy8b5m5d6cd5.jpg
▲拧掉螺丝后就能拆下外壳了
https://image.koolshare.cn/attachment/forum/201909/05/123108ivzwyw5gbwwb17wy.jpg
▲顶盖中藏有左右侧键的微动PCB板,通过排线与主PCB板连接
https://image.koolshare.cn/attachment/forum/201909/05/123247q3ycptth73jzj19h.jpg
▲从顶盖中拆出PCB板
https://image.koolshare.cn/attachment/forum/201909/05/123445s9v9g6io6ki2emoj.jpg
▲四个微动都是红点微动,点击干脆利落,回弹迅速
https://image.koolshare.cn/attachment/forum/201909/05/123915ncabtzeh2lhn7ae7.jpg
▲顶盖内部一览。顶盖分两层,里面一层主框架采用打孔设计,能有效降低鼠标重量。外面一层有三个部分,分别是鼠标的左右键和掌托部分的背壳
https://image.koolshare.cn/attachment/forum/201909/05/155311u7uy9vsmmk97z99u.jpg
▲从底座中拿出PCB主板之前,需要掀开滚轮
https://image.koolshare.cn/attachment/forum/201909/05/155541dldrv5md00c38v0c.jpg
▲滚轮部分采用镂空设计,能减去不少重量。最外层包裹有橡胶,可以保证良好的防滑性能
https://image.koolshare.cn/attachment/forum/201909/05/155941naaubowug1o02ija.jpg
▲移除USB与PCB主板的连接线缆
https://image.koolshare.cn/attachment/forum/201909/05/160006fjwzziprrpivppye.jpg
▲从底座中分离PCB主板
https://image.koolshare.cn/attachment/forum/201909/05/160051x4yelcy8r84cc7tr.jpg
▲PCB主板正面,从左往右依次是两个印有Razer Logo的雷蛇光学鼠标微动开关,鼠标中键微动,雷蛇5G光学传感器,主控芯片,RGB灯珠
https://image.koolshare.cn/attachment/forum/201909/05/160353kai6pb6bpz9s7wwe.jpg
https://image.koolshare.cn/attachment/forum/201909/05/160358iek8akdq68v2v8ak.jpg
▲Razer光学鼠标微动开关,具有即时触发的特性和理想的耐用性
https://image.koolshare.cn/attachment/forum/201909/05/161512uqqz1ccdfp1p7cm1.gif
▲当玩家进行一次点击操作后,Razer光学鼠标微动开关会打开其遮光板,让红外光束通过,电子信号就是通过这种方式发送到你的电脑的。这种微动开关可以实现光速级的触发,让玩家在畅玩游戏时可以享受约0.2毫秒的最快响应时间,比传统机械式微动开关快3倍
https://image.koolshare.cn/attachment/forum/201909/05/160651xclbmtbdcvzc2wsr.jpg
▲传统的机械式微动开关通过机械接触发送电信号,当这些接触相互碰撞时,会产生残余回弹效应,从而可能导致多个信号。借助去回弹延迟软件来克服这种回弹效应,确保只会识别单次点击操作。而使用Razer光学鼠标微动开关,无需物理接触即可发送电信号,因此无需克服回弹效应,每次点击操作都会立即触发,并且不会导致意外点击
https://image.koolshare.cn/attachment/forum/201909/05/161048px88xn5qn4tx4z5n.jpg
▲因为不需要机械接触即可传输电信号,所以Razer光学鼠标微动开关不易因大量使用而出现磨损。因此,这种微动开关具备高达约7000万次点击的耐用度,优于之前耐用度最佳的微动开关40%
https://image.koolshare.cn/attachment/forum/201909/05/161648v70dj10fdbyf7ybn.jpg
▲主控芯片是NXP的LPC51U68,基于高能效的Arm Cortex-M0+内核,其CPU工作频率高达100MHz,适用于嵌入式应用,且具有更大的内存资源,包括96KB片上SRAM和256KB带闪存加速器的片上闪存编程存储器。PAW3390光学传感器,拥有原生16000DPI以及高达每秒450英寸 (IPS) 的移动速度/50G加速度
https://image.koolshare.cn/attachment/forum/201909/05/162152bc5hpj1dmxhjphjj.jpg
▲PCB主板背面,可以看到左侧黄色的DPI切换按钮,能够在5个不同DPI等级之间切换
软件
https://image.koolshare.cn/attachment/forum/201909/05/163109xjvnjuxljx3uqxu6.png
▲Razer Synapse 3.0驱动下载链接
https://image.koolshare.cn/attachment/forum/201909/05/165814ziicr3449ryglb9h.png
▲主界面会显示当前的Razer设备
https://image.koolshare.cn/attachment/forum/201909/05/165842htcz711h777htg77.png
▲点击鼠标就能进入鼠标的配置界面了,可以看到每个按键的当前功能
https://image.koolshare.cn/attachment/forum/201909/05/165925dhvlic0ilhmne5tb.gif
▲可以自由对鼠标的每个按键的功能进行个性化定义
https://image.koolshare.cn/attachment/forum/201909/05/173614pn7tcfe855ssze6u.gif
▲Razer Viper的DPI有5个等级,可以自由设定每个等级的DPI,还可以分别对X轴和Y轴的DPI进行设置,最高都可以设置为16000DPI
https://image.koolshare.cn/attachment/forum/201909/05/173843ugox58g5mbovoin8.png
▲鼠标的轮询率有125MHz,500MHz,1000MHz三个等级可供选择
https://image.koolshare.cn/attachment/forum/201909/05/174043jjpfsftpi75tbgpi.png
▲不仅如此,通过雷云3.0还可以打开windows鼠标属性进行设置
https://image.koolshare.cn/attachment/forum/201909/05/174815cz7hoq7issbmayos.gif
▲对鼠标的RGB灯光进行亮度调节,Razer Chroma幻彩灯效设定以及关闭灯光等等
https://image.koolshare.cn/attachment/forum/201909/05/195457m8p4q8z275pe6pz5.gif
▲可以将Razer Viper鼠标和游戏关联形成配置文件
灯光
https://image.koolshare.cn/attachment/forum/201909/05/192410ze1jeg3ehhejh3j3.jpg
https://image.koolshare.cn/attachment/forum/201909/05/192410j7mjbj44jbh7766h.jpg
https://image.koolshare.cn/attachment/forum/201909/05/192410xbdtsdssjjapdtbm.jpg
https://image.koolshare.cn/attachment/forum/201909/05/192410xkv7kj5ppjt9wn50.jpg
https://image.koolshare.cn/attachment/forum/201909/05/192410a51fhvd01upufp1u.jpg
https://image.koolshare.cn/attachment/forum/201909/05/192410dx7i7buivx2bv77b.jpg
▲鼠标顶盖掌托部分有一盏RGB灯,用于点亮Logo,中规中矩。没有了杀马特的RGB灯效,能让用户更专注于竞技本身
游戏
https://image.koolshare.cn/attachment/forum/201909/05/193951uo1jkbbgexo9yg9b.jpg
https://image.koolshare.cn/attachment/forum/201909/05/193951ekn7k8gb8a0k39g0.jpg
https://image.koolshare.cn/attachment/forum/201909/05/193952t9uzhztf9b0turks.jpg
https://image.koolshare.cn/attachment/forum/201909/05/193952fa99atle9k7dd7la.jpg
https://image.koolshare.cn/attachment/forum/201909/05/193952wu4zbgzgphb0xvp5.jpg
▲玩绝地求生这种FPS游戏,1000MHz的轮询率保证了Razer Viper鼠标在游戏中移动灵活,定位精准。69克的重量,让你在长时间的游戏中,无论是抓还是卧都非常的轻松惬意
总结
https://image.koolshare.cn/attachment/forum/201909/06/144659sry9ds22zs8s2pjj.jpg
▲Razer Viper是一款融合了最快触发速度、高精度和先进轻量型机身的游戏鼠标, 配备的Razer Speedflex超柔线缆可以让鼠标实现更顺畅的滑动。69克的重量让其在同价位的电竞游戏鼠标中处于领先地位,其装备的Razer光学鼠标微动开关,更能让你在游戏中快人一步。高达16000DPI的灵敏度,让你轻松应付4K甚至更高分辨率的显示器。总而言之,这是一款颜值和性能都在线的游戏鼠标,值得所有游戏爱好者选择
查看完整版本: Razer Viper 雷蛇毒蝰电竞游戏鼠标 开箱拆解
