老吴 发表于 2019-10-16 16:49
全志A33(兼容全志A23) 挂4  DDR 平板电脑PCB和
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME3V-T-PTP40_SMDNCTP40_SMDANT1ANTANTANTBT1CON2LI-BATTERY-3_7VCON2DU0BGA63P80B800_1140H135DDR2x8BGA63P80B800_1140H135DU1BGA63P80B800_1140H135DDR2x8BGA63P80B800_1140H135DU2BGA63P80B800_1140H135DDR2x8BGA63P80B800_1140H135DU3BGA63P80B800_1140H135DDR2x8BGA63P80B800_1140H135ED3R0402AU0511P1R0402ESD13C0402NC/AU0561BPC0402ESD14C0402NC/AU0511P1C0402ESD25C0402NC/AU0511P1C0402FB6L0603600R/100ML0603FB102L0603600R/100ML0603GND40TP40_SMDNCTP40_SMDH-2J-HOLDHOLP-PADJ-HOLDH-3J-HOLDHOLP-PADJ-HOLDH-4J-HOLDHOLP-PADJ-HOLDINT40TP40_SMDNCTP40_SMDJ1FPC_60_0D5_BHSD070IDW2FPC_60_0D5_BJ2CK3_5-381B-23B-BAPJ-326CK3_5-381B-23B-BAJ3DC_5P_B3005D-05DBH3_3AACINDC_5P_B3005D-05DBH3_3AJ4PJ-0381_5PH5APJ-326PJ-0381_5PH5AJ6DC-058ACINDC-058J7TFCARD9MICROSD/TF_SLOTTFCARD9J10CON2SPKRCON2J11CON2SPKLCON2J13FPC24-PT05ACON24PINFPC24-PT05AJ22FFC30PINRS7M1609013FFC30PINJ23FPC40_PT05_H2BCON40FPC40_PT05_H2BL1CD321.5uH@2A DCR<0.1RCD32LED1CON2LI-BATTERY-3_7VCON2MIC2MIC4015MicphoneMIC4015MT1PAD_1X2_2_2P-PLCON2PAD_1X2_2_2P-PLP1USB-MIC-001-03-5PH3_1AUSB-MICRO-SOCKETUSB-MIC-001-03-5PH3_1AP2USB-MIC-A01SB141BH2_4AUSB-MICRO-SOCKETUSB-MIC-A01SB141BH2_4AQ1QFN6-2X2H0_8AWPM1481QFN6-2X2H0_8AQ2SOT-23NC/2301SOT-23Q3SOT-23MMBT3904SOT-23Q1-ASOT-232301SOT-23RST40TP40_SMDNCTP40_SMDS1SG-SW4-T06P-35DH3_5APWRSG-SW4-T06P-35DH3_5AS3SG-SW4-T06P-35DH3_5AVOL+SG-SW4-T06P-35DH3_5ASCK1TP40_SMDNCTP40_SMDSDA1TP40_SMDNCTP40_SMDSW4SG-SW4-T06P-35DH3_5AVOL-SG-SW4-T06P-35DH3_5AU4QFN69P0_4B8X8AXP223QFN69P0_4B8X8U5SOT23-6SY7101SOT23-6U6BGA169-PT0_5-12X16H1AeMMC-BGA169BGA169-PT0_5-12X16H1AU7TSOP-48NAND FLASH X8TSOP-48U9SOT23-6STI3540SOT23-6U10SOT23-6AP3032/SY7200ASOT23-6U14SOT23-5SY6280SOT23-5U15BMA222BMA250/SC7A20BMA222U17QFN40-PT0_4-5X5H0_8ARTL8703BSQFN40-PT0_4-5X5H0_8AU23BGA282P0_80B14X14H1_30A33/A23BGA282P0_80B14X14H1_30U30MSOP8LM4890MSOP8U31MMA7660MMA7660FCMMA7660U32DFN8-PT053-H0_8AXPT4890DFN8-PT053-H0_8AU33DFN8-PT053-H0_8AXPT4890DFN8-PT053-H0_8AU34MSOP8LM4890MSOP8U52QFN40GSL1680QFN40U53QFN40-PT0_4-5X5H0_8Axr819QFN40-PT0_4-5X5H0_8AX1CRYSTAL-4P-3225-H1A24M-18pF-50PPMCRYSTAL-4P-3225-H1AX2CRYSTAL_0206H1_4A32.768KHz-18pF-30PPMCRYSTAL_0206H1_4AX4M-49SMD24MHZM-49SMDX6CRYSTAL-4P-3225-H1A24M-18pF-10PPMCRYSTAL-4P-3225-H1A
老吴 发表于 2019-10-16 16:51
PCB 和原理图共享下载。回复可见。
**** Hidden Message *****
yaodaoji 发表于 2019-10-16 17:48
谢谢老吴
gaibian 发表于 2019-10-16 21:33
谢谢分享
wangy2000 发表于 2019-10-17 07:40
收藏谢谢分享
精进攻城狮 发表于 2019-10-17 07:59
linyuanfei 发表于 2019-10-17 09:24
谢谢老吴
i_333333 发表于 2019-10-17 13:48
非常感谢楼主大神分享
1425151571 发表于 2019-10-17 14:48
回 老吴 的帖子
老吴:PCB 和原理图共享下载。回复可见。
[内容隐藏]
 (2019-10-16 16:51) images/back.gif
longly 发表于 2019-10-17 18:26
谢谢分享,下载看一下能不能。
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 全志A33(兼容全志A23) 挂4  DDR 平板电脑PCB和原理图
