armclub 发表于 2019-11-19 00:21
HI3521AV100+GV7704+TXB0106+LT8619B+MT7601 做的视频图像处理板PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1RB521S30T1D_AHSOD523D2DZ3_HSOD882_DZ3DZ3HSOD882D3DZ3_HSOD882_DZ3DZ3HSOD882D4DZ3_HSOD882_DZ3DZ3HSOD882D15D_A_0_HSOD323A_D_AD_AHSOD323AD18DZ3_0_SD1710A_DZ3DZ3SD1710AD19LED_0_SD0805-LED_LEDLEDSD0805-LEDD23LED_0_SD0805-LED_LEDLEDSD0805-LEDD24DZ3_HSOD882_DZ3DZ3HSOD882D25RCLAMP0521P_1_SLP1006P2_RCLAMP0RCLAMP0531TSLP1006P2D27RCLAMP0521P_1_SLP1006P2_RCLAMP0RCLAMP0531TSLP1006P2D28RCLAMP0521P_1_SLP1006P2_RCLAMP0RCLAMP0531TSLP1006P2D29LED_0_SD0805-LED_LED/NCLED/NCSD0805-LEDD30RCLAMP0521P_1_SLP1006P2_RCLAMP0RCLAMP0531TSLP1006P2FB1BEAD0805_SL0402_220R/100MHZ220R/100MHzSL0402ID12ID-BOARD_0_FID10X20_ID-BOARDID-BOARDFID10X20J1DB19S4_0_MOLEX_47151_HDMIHDMIMOLEX_47151J8PWC3_A_0_DC_JACK_DC2.0DC2.0DC_JACKJ10SIP7M2_0_SATA_SIP7M2SIP7M2SATAJ11BNC_BNC_73171-0700_BNCBNCBNC_73171-0700J15IPEX_IPEX_3MM_ANTANTIPEX_3MMJ16DB19S4_1_MOLEX_47151_HDMIHDMIMOLEX_47151J23SIP4_0_SIP-4P-200_SIP4SIP4SIP-4P-200J31RJ45_90_HP_RJ45_90_HP_RJ45_90_HRJ45_90_HPRJ45_90_HPJ36SIP-2P-100_2PIN3_96_2PIN3_962PIN3_962PIN3_96J46CON3_CON1X3P_2_54MM_CON1X3P_2_5con1x3p_2_54mmCON1X3P_2_54MMJ47PJ-393A_PJ-393-SMD_PJ-393APJ-393APJ-393-SMDJ48PJ-393A_PJ-393-SMD_PJ-393APJ-393APJ-393-SMDJ49CON2_CON2_2_54_CON2CON2CON2_2_54J50CON2_CON2_2_54_CON2CON2CON2_2_54J52CON4_4PIN_2_0_180_CON4CON44PIN_2_0_180J53CON4_4PIN_2_0_180_CON4CON44PIN_2_0_180J54CON8_FPC_0_5MM_90_6P_CON8CON8FPC_0_5MM_90_6PJ55BNC_BNC_73171-0700_BNCBNCBNC_73171-0700L15L_0_HSL1008_2.2UH2.2UHHSL1008LB49SMD_BEAD_FB0603_SL0805_FB120RFB120RSL0805M1MARK_HOLE6X3_5_MARKMARKHOLE6X3_5M2MARK_HOLE6X3_5_MARKMARKHOLE6X3_5M3MARK_HOLE6X3_5_MARKMARKHOLE6X3_5M4MARK_HOLE6X3_5_MARKMARKHOLE6X3_5OSC1OSC4P_D_0_XT3225YY_12.288MHZ/NC12.288MHZ/NCXT3225YYRN1RESISTOR DIP4_0_SRN8-0804_2222SRN8-0804RP244RPP_1_SRN8-0804_4X33R4x33RSRN8-0804T1TVS_THYRISTOR_SR0402_ESDESDSR0402T2TVS_THYRISTOR_SR0402_ESDESDSR0402T3TVS_THYRISTOR_SR0402_ESDESDSR0402T4G2401CE_0_STFM24-40-280_G2401CEG2401CESTFM24-40-280U1CLAMP0524P_DFN2510P10E_AZ1045_CCLAMP0524PDFN2510P10E_AZ1045U2CLAMP0524P_DFN2510P10E_AZ1045_CCLAMP0524PDFN2510P10E_AZ1045U3AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U4SPI_NAND_FLASH_0_WSON8-MX25L128SPI_NAND_FLASH_8PINWSON8-MX25L12835ZNU8HI3521AV100_VI_7_BGA437-32-2323HI3521AV100BGA437-32-2323BU10MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU11MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609MU12MP1494S_0_TSOT23-8_MP1495SMP1495STSOT23-8U13BATTERYBATTERYBATTERY-RU15MP1494S_0_TSOT23-8_MP1495SMP1495STSOT23-8U17MP2122_0_TSOT23-8_MP2122MP2122TSOT23-8U18AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045U21GV7704_5_BGA169-11X11X0P56MM-0PGV7704BGA169-11X11X0P56MM-0P8MMU23MT7601_MT7601_MT7601MT7601MT7601U25SN74AVC20T245DGG_TSSOP56-0R50-6SN74AVC20T245DGGTSSOP56-0R50-6R00U29TXB0106_TSSOP16_TXB0106TXB0106TSSOP16U33CAT811_SOT_143_CAT811CAT811SOT_143U37RTL8211D_0_MLF48A-040-0606L_RTLRTL8211EMLF48A-040-0606LU39AT88SC0104CA_SOP8-50-150_ATSHA2ATSHA204ASOP8-50-150U40AT24C08_SOP8-50-150_LT24C08LT24C08SOP8-50-150U41LT8619B_1_QFN76-BLADE_68196819QFN76-BLADEU42TLV320AIC31_1_MLF32-050-0505LE_TLV320AIC31MLF32-050-0505LEU43RT9193_SOT23-5-IPC_TPS79318DBVRTPS79318DBVREPSOT23-5-IPCU44MP1470_1_TSOT23-8_MP2161MP2161TSOT23-8U45SY8008B_0_SOT23_5_SY8008BSY8008BSOT23_5U46MP2122_0_TSOT23-8_MP2122MP2122TSOT23-8U49USB_AF_10MM_USB-AF-10MM-DIP_USBUSB_AF_10MMUSB-AF-10MM-DIPX1X_B_0_HSX4-0302B_24MHZ24MHZHSX4-0302BX2X_0_HSX2-0302_32.768KHZ32.768KHZHSX2-0302X3X_B_HSX4-0302B_25MHZ25MHZHSX4-0302B
armclub 发表于 2019-11-19 00:22
PCB 文件共享。回复可见下载
**** Hidden Message *****
kanxue_nmg 发表于 2019-11-19 01:32
wangy2000 发表于 2019-11-19 07:27
收藏谢谢分享
zhu555_0 发表于 2019-11-19 07:59
谢谢分享
罗塘阮经天 发表于 2019-11-19 08:10
谢谢分享
学海无涯 发表于 2019-11-19 08:14
数字处理的视频,
cityhu 发表于 2019-11-19 08:15
zblin1987 发表于 2019-11-19 08:36
清心如水 发表于 2019-11-19 08:36
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: HI3521AV100+GV7704+TXB0106+LT8619B+MT7601 做的视频图像处理板PCB
