armclub 发表于 2019-11-20 23:59
从设计看质量-格力变频空调主板 GRJW842-A43  PC
一个品牌产品质量好不好。从这个电路的设计上就能看到了。。 格力变频空调主板PCB一个。。
图片网上找相似的,版本稍有不同
NamePCB DecalValuePart Type4WAYCON_B2P3-VH-AMCON_B2P3-VH-AM_WHITEAC-LCON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8C21110603_HLH0.1ufCAP_0603_0.1UF_10%_50VCN1CON_B5B-XH-K3CON_B5B-XH-K3_WHITECN2CON_AMP1871843-8_JSTCON_JST_B08B-XASK-1-A_WHITECN3CON_AMP1871843-4_JSTCON_JST_B04B-XARK-1-A_REDCN4CON_AMP1871843-3_JSTCON_JST_B03B-XASK-1-A_WHITECOMUCON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8D1DIO_SOD-123_SMTDIO_1N4148_SMDD2DIO_L7.62W4.2F5.38_S800V/1ADIO_600V_2A_SMDD3DIO_L7.62W4.2F5.38_SA200V/1ADIO_200V_1A_SMDD4DIO_L7.62W4.2F5.38_SA200V/1ADIO_200V_1A_SMDD5DIO_L4.1W1.2F2.9_SZEN_5.6V_0.5W_SMDD6DIO_L7.62W4.2F5.38_SA200V/1ADIO_200V_1A_SMDD8SOT-23_HLHBAT54SLT1GDIO_COMAK_BAT54SLT1G_SOT23D9DIO_L7.62W4.2F5.38_S4007DIO_1N4007_SMDD10DIO_L7.62W4.2F5.38_S4007DIO_1N4007_SMDD11DIO_L7.62W4.2F5.38_S4007DIO_1N4007_SMDD12DIO_SOD-123_SMTDIO_1N4148_SMDD13DIO_BYC20X-600BYC20X-600DIO_BYC20X-600D14DIO_SOD-123_SMTDIO_1N4148_SMDD15DIO_SOD-123_SMTDIO_1N4148_SMDD16DIO_SOD-123_SMTDIO_1N4148_SMDD17DIO_SOD-123_SMTDIO_1N4148_SMDD18DIOSMA200V 2ADIO_200V_2A_SMDD20SOT-23_HLHBAT54SLT1GDIO_COMAK_BAT54SLT1G_SOT23D23DIO_SOD-123_SMTDIO_1N4148_SMDD111DIO_L7.62W4.2F5.38_S4007DIO_1N4007_SMDF00603_HLHFO_0603_100M/600RFU1FUSE_H0.65P1.8D32.2FUSE_T15AH_250V_LEADG1DIO_DB_15A_25A_SINGLE15A/800VDIO_DB_15A_600V_SINGLEIPM1IPM_SCM1230F1IPM_SCM1242MFJTAGCON_DIP14_2.54X2.54_6CON_DIP14_2.54X2.54X11.6_6K1RLY_16A250VAC/12VDC16A 250VAC/12VDCRLY_A_16A250VAC/12VDCK2RLY_PCH-112L2MOJE-SS-112HMFRLY_A_OJE-SS-112HMF_10A250VAC(ZX)K3RLY_PCH-112L2MOJE-SS-112HMFRLY_A_OJE-SS-112HMF_10A250VAC(ZX)K4RLY_PCH-112L2MOJE-SS-112HMFRLY_A_OJE-SS-112HMF_10A250VAC(ZX)L1IND_CM_5MH_10AIND_CM_5MH_10ALED1DIO_LED_0603REDDIO_LED_0603_REDLED2DIO_LED_0603DIO_LED_0603_GREENLED3DIO_LED_0603DIO_LED_0603_YELLOWLX1-1CON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8LX1-2CON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8M1MARKMIS_MARKM2MARKMIS_MARKM3MARKMIS_MARKM4MARKMIS_MARKNCON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8NTC0603_HLHNTCRES_0603_2.1K_1%_0.1WOFANFENGJIZHENZUOCON_B6P-VH-AM-3PECON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8Q1SOT-23_HLH9013BJT_NPN_9013_SOTQ2SOT-23_HLH9013BJT_NPN_9013_SOTRS1RES_CEM_L15W5.5D1015m¦¸RES_CEM_15M_5%_5W(ZX)RS2RES_CEM_L15W5.5D1015m¦¸RES_CEM_15M_5%_5W(ZX)RT1RES_PTC_L18.5W14D10/RES_PTC_MZ-47R-ARV1RES_MOV_W12D7.5L20_YXRES_MOV_MYN15-621KM(ZX)RV2RES_MOV_W12D7.5L20_YXRES_MOV_MYN15-621KM(ZX)RV3RES_MOV_W12D7.5L20_YXRES_MOV_MYN15-621KM(ZX)T1IND_TR_EE22-8PEE22-8PIND_TR_EE22-8PTESTCON_SIP02_TCON_SIP2_2.54X11.6TMP-TESTTMP-TESTTMP-TESTTVS1DSA_FA55-362FA55-362DSA_FA55-362TVS2TVS_SMTCDA70-362CDA70-362M-TMU(BU)CON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8U1IC_QFP13.9X13.9-80IC TMS320F28035PNTIC_MCU_TMS320F28035PNT_1U2IC_SO1.27P6.2-16ULN2003(SOP)IC_MIS_2003_SOPU3IC_SO8AT24C02IC_MIS_24C02N(SOP)U4IC_SO1.27P6.2-8IC_MIS_AT24C16(FLASH)U5IC_DIP8_2.54X7.6224C16IC_MCU_24C16(FLASH)U6IC_DIP8_2.54X7.62_6STR-A6061HDIC_SMPS_STR-A6061HDU7IC_SO2.54P9-4PC817(C)_IC_PC_PC817X2NIP0FU8SOT-23_HLHLM431SBIC_OP_LM431SBU9IC_SO8TPS76633DVOL_TPS76633D(3.3V)U10IC_SO2.54P9-4TLP385(C)_IC_PC_PC817X2NIP0FU11IC_SO2.54P9-4TLP385(C)_IC_PC_PC817X2NIP0FU12IC_SO1.27P6.2-8TC4427AVOA/MC33152V/IRS4427IC_MIS_TC4427AVOA/MC33152V/IRS4427U14IC_SO8LM293ADRIC_OP_LM293ADRU16IC_SO1.27P6.2-14OPA4374AIDIC_OP_OPA4374AIDU17IC_SO1.27P6.2-16ULN2003(SOP)IC_MIS_2003_SOPU18IC_SO1.27P6.2-16ULN2003(SOP)IC_MIS_2003_SOPV(YE)CON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8W(RD)CON_TCP_6.3-0.8Í­²åƬ 6.3¡Á0.8CON_TCP_6.3-0.8Z1TO247-BOTTOM-2IGBT_GT30J122A_30A600V
armclub 发表于 2019-11-21 00:00
各位大佬看看。这个设计如何。从设计,就能看出品牌质量了。。。
**** Hidden Message *****
王国庆2019 发表于 2019-11-21 07:19
这么牛逼,空调主板都可以设计吗
longxuekai 发表于 2019-11-21 07:55
看一下看一下
学海无涯 发表于 2019-11-21 08:16
这个不错啊,学习一下,感谢分享!!
dengyd780510 发表于 2019-11-21 08:38
谢谢分享
weifengbo0302 发表于 2019-11-21 08:49
学习学习
kn1986 发表于 2019-11-21 08:50
谢谢分享
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 从设计看质量-格力变频空调主板 GRJW842-A43  PCB文件
