10层PCB-XC5VLX30-FFG676+TMS320C6748BZWT4+FT2232D+LAN8710AI-EZ 共享
REFDESCOMP_DEVICE_TYPESYM_NAMED1LED_SMD2DD0805FB1FB-FB0805,0805-0805805FB4FB-FB0805,0805-0805805FB5FB-FB1206,SMDRES-SMDRESSMDRESFB6FB-BLM18HB121SN1,FB_0603-FB_06AFB_0603FB7FB-FB0805,0805-0805805FB12FB-FB0805,0805-0805805J1QSE-020-01-L-D-A-FIT,QSE-020-FBQSE-020-FITJ2DSP_JTAGDSP_JTAGJ3CON2SIP2J4CON2SIP2J6QSE-020-01-L-D-A-NO_FIT,QSE-02AQSE-020J7XH3XH3J9XH3XH3L2LED_SMD-GREEN,D0805-D0805D0805L21INDUCTOR-0.33UHIHLP-2525CZ-01,BPWR_INDUCT7MMU1J30J-51ZKNP5-JJ30J-51ZKNP5-JU2STAL_SMD-25M-GND=0V,VCC=3.3VSTAL_SMDU3TMS320C6748BZWT4FBGA361U4SN74CBTLV3257_RGYRPVQFN-16U5SN74CBTLV3257_RGYRPVQFN-16U6TPS74901RGWQFN-20U7TPS74901RGWQFN-20U8DDR2_2GBX16BITS-MT47H128M16HG,BFPBGA84U9EMI_FILTER-NFM18PC105R0J3D,EMIBEMI_0603U10LAN8710AI-EZQFN32-1U11TPA2016D2RTJPWQFN-20U12LME49724MRSOIC8_PWRU13LME49724MRSOIC8_PWRU14AT_DATA_SERIAL_FLASH-AT45DB161DWSOIC8U15S70GL02GSFLASH_BGA64U16MAX16005CQFN-16-MAX16005U18RC28F320J3C110_WORD-VCC=3.3V,VAFLASH_BGA64U19TPS74901RGWQFN-20U20LED_FULL_COLORLED_FULL_COLORU21LED_FULL_COLORLED_FULL_COLORU22STAL_SMD-30M-GND=0V,VCC=3.3VSTAL_SMDU23STAL_SMD-30M-GND=0V,VCC=3.3VSTAL_SMDU24LED_FULL_COLORLED_FULL_COLORU25TLP291-4SOIC16U26LTC3614IUDDQFN_24U27XC5VLX30-FFG676FG676U28TPS74901RGWQFN-20U29TI_VOLTAGE_REFERENCE_SOT23-REFBSOT-23U30ADAU1961WBCPZQFN32-PWRU31HY601680HR_SOP16U32S70GL02GSFLASH_BGA64U33TLP291-4SOIC16U34MAX488-MAX3490ESA,SOIC8-SOIC8SOIC8U35MARK_POINTERMARK_POINTERU36MAX488-MAX3490ESA,SOIC8-SOIC8SOIC8U37S70GL02GSFLASH_BGA64U38S70GL02GSFLASH_BGA64U40STAL_SMD-30M-GND=0V,VCC=3.3VSTAL_SMDU41FT2232DTQFP48U42EMI_FILTER_451832451832U48EMI_FILTER_451832451832U50TPS74901RGWQFN-20U51MARK_POINTERMARK_POINTERU52EMI_FILTER-TL-470M,EMI_FILTER_BEMI_FILTER_25MMU53MAX488-MAX3490ESA,SOIC8-SOIC8SOIC8U54MAX488-MAX3490ESA,SOIC8-SOIC8SOIC8Y1CRYSTAL-24MHZ,CRY_SMD-CRY_SMDCRY_SMDY2CRYSTAL-32.768KHZ,CRY_SMD-CRY_ACRY_SMDY3CRYSTAL-6MHZ,CRY_SMD-CRY_SMDCRY_SMDY6CRYSTAL-25MHZ,CRY_SMD-CRY_SMDCRY_SMD PCB文件来了。回复可见
**** Hidden Message ***** 谢谢分享PCB-XC5VLX30-FFG676+TMS320C6748BZWT4+FT2232D+LAN8710AI-EZ 多层板可以 进来看看 收藏谢谢分享
