超微E300-9D-8CN8TP开箱拆解
开箱https://image.koolshare.cn/attachment/forum/201912/06/203147mb94pvh7iuaxbbxp.jpg
▲E300-9D-8CN8TP的包装盒,采用牛纸皮盒子。上面还贴了倍联德的发货单
https://image.koolshare.cn/attachment/forum/201911/28/134041x2849x532dyvdisx.jpg
▲打开包装箱。可以看到内部的机器被泡棉包裹,可以避免运输过程中的磕碰。右侧是配件盒
https://image.koolshare.cn/attachment/forum/201911/28/134541k5pml9lb15232j44.jpg
▲打开配件盒。可以看到内部的配件
https://image.koolshare.cn/attachment/forum/201911/28/134912p8y2zk4oyys4hv99.jpg
▲美标电源线
https://image.koolshare.cn/attachment/forum/201911/28/134937zcfd66liindf6xli.jpg
▲电源适配器
https://image.koolshare.cn/attachment/forum/201911/28/134958dk53v73ujn5mww05.jpg
▲电源适配器接头带锁定功能,可以防止电源线意外脱落
https://image.koolshare.cn/attachment/forum/201911/28/135028p5al18hhaybzbuy6.jpg
▲电源适配器规格12V 12.5A,150W功率
https://image.koolshare.cn/attachment/forum/201911/28/135100epoha9sfqoujx9qc.jpg
▲SATA供电数据二合一线
https://image.koolshare.cn/attachment/forum/201911/28/134605cmfoevvsof6tssz7.jpg
▲盒中所有配件一览。有PCIe支架和矮挡板各一个,美标电源线一根,150W可锁定电源适配器一个,SATA供电数据二合一线一根,扎带和螺丝若干
https://image.koolshare.cn/attachment/forum/201911/28/135155ve8kuyvqfzysk40d.jpg
▲E300-9D-8CN8TP正面。从左往右依上而下分别是DC插口一个,IPMI管理接口一个,USB3.0接口两个,四个千兆RJ45 LAN口,两个10GbE RJ45 LAN口,两个10G SFP+ LAN口,VGA接口一个
https://image.koolshare.cn/attachment/forum/201911/28/135619z0exxa7ldhloyha7.jpg
▲E300-9D-8CN8TP侧面做了开孔,有利于热量散出。另外,侧面也预留了1U支架安装孔位,方便有需求的用户上机架安装
https://image.koolshare.cn/attachment/forum/201911/29/115405hsgvzqkqmeszakzv.jpg
▲1U支架的安装方式如上图所示。使用原装支架的好处就是可以把电源适配器一并收纳其中,使E300-9D-8CN8TP在机柜中更加简洁与美观。
https://image.koolshare.cn/attachment/forum/201911/28/135929s1014gt41sq0ytex.jpg
▲左侧黑色金属网部分是风扇进风口,右侧两个红色按钮分别是Reset按钮和电源按钮,它们的上方是工作状态指示灯
https://image.koolshare.cn/attachment/forum/201911/28/140209jbv3v43xq4r13k31.jpg
▲E300-9D-8CN8TP顶盖部分
https://image.koolshare.cn/attachment/forum/201911/28/140322uqbpbe8gyweb11fe.jpg
▲底部铭牌,台湾制造
拆解
https://image.koolshare.cn/attachment/forum/201911/28/164440cf6b85arbrbbargb.jpg
▲首先打开顶盖,内部还有一层安装SATA硬盘的托架
https://image.koolshare.cn/attachment/forum/201911/28/203219j42gz9gnngimi0dz.png
▲SATA硬盘安装方式如图所示,该支架只支持2.5寸硬盘的安装,而3.5寸硬盘因为体积太大,安装后无法装回托架
https://image.koolshare.cn/attachment/forum/201911/28/174556a0xgbx8ai4qyxrgg.jpg
▲拆下SATA硬盘的托架后就能看到内部的结构了,MBD-X11SDV-8C-TP8F主板的电源只连接了12V 8Pin,24Pin ATX电源并没有连接。MBD-X11SDV-8C-TP8F主板是支持DC 12V直接供电的
https://image.koolshare.cn/attachment/forum/201911/28/174628n72er64c74vxoh06.jpg
▲拆下超微E300-9D-8CN8TP的风扇支架,支架上固定有三个4-PIN PWM暴力扇
https://image.koolshare.cn/attachment/forum/201911/30/005506h5wawsqd8hhh551z.jpg
▲风扇型号是W40S12BMA5-57,厂商是Nidec,规格DC12V 0.12A,尺寸为40x40x28mm,最高转速能达到8500 R. P. M。三个风扇一起转动,噪音可想而知
https://image.koolshare.cn/attachment/forum/201911/28/174833i8xwb5de8bxwf8fb.jpg
▲拆下CPU散热装甲。超微E300-9D-8CN8TP的CPU部分没有采用主动散热结构,CPU的散热完全靠暴力扇强劲的风力
https://image.koolshare.cn/attachment/forum/201911/28/175025oc3hl3cmvam9vz3u.jpg
▲最后将MBD-X11SDV-8C-TP8F主板从CSE-E300机箱中拆出
https://image.koolshare.cn/attachment/forum/201911/28/180003tfg9rzzethu3g9zk.jpg
▲MBD-X11SDV-8C-TP8F主板正面一览
https://image.koolshare.cn/attachment/forum/201911/28/175412m8084t21abap0y8z.png
▲MBD-X11SDV-8C-TP8F主板接口介绍。其中LAN1-LAN4是千兆RJ45 LAN口,网卡芯片为Intel i350-AM4。LAN5-LAN6是10GbE RJ45 LAN口,PHY是Intel X557,MAC是Intel X722,MAC集成在CPU中。LAN7-LAN8是10G SFP+ LAN口,MAC是Intel X722,MAC集成在CPU中。除此之外,主板的PCIe3.0x8 SLOT7插槽和PCIe3.0x16 SLOT6插槽都是直通CPU的
https://image.koolshare.cn/attachment/forum/201911/28/180101yxyfjzcvfsgkstxk.jpg
▲Intel Xeon D2146NT处理器,14nm制程,8核心16线程,主频是2.3GHz,最大睿频3.0GHz,80W TDP,支持四通道ECC UDIMM/RDIMM内存
https://image.koolshare.cn/attachment/forum/201911/28/180438ue2wl4woqgo5doxd.jpg
▲在这块散热装甲下的是Intel X557 1Gbps/10Gbps双速率PHY,为LAN5-LAN6提供支持
https://image.koolshare.cn/attachment/forum/201911/28/180551eajqjo48s4opv8o4.jpg
▲Intel i350-AM4千兆网卡芯片。为LAN1-LAN4提供支持
https://image.koolshare.cn/attachment/forum/201911/28/180645dxhxe8oxd31r2138.jpg
▲Realtek RTL8211F千兆PHY芯片。为IPMI管理端口提供支持
https://image.koolshare.cn/attachment/forum/201911/28/180905lmgbb81hb1omc12h.jpg
▲MBD-X11SDV-8C-TP8F主板提供了两个SFF-8643接口,每个SFF-8643接口可以使用SFF8643转4个SFF8482线连接四个SATA3.0硬盘或者直接连接一个NVMe U.2硬盘。除此之外,还提供了四个SATA3.0接口,其中黄色的SATA3.0接口支持SATA DOM
https://image.koolshare.cn/attachment/forum/201911/28/182936c23w8nmfwn33p233.jpg
▲上方是适用于SSD/WAN card的M.2插槽,2242/8规格。它的下方是Nano SIM卡卡槽,给M.2 B-Key WAN card提供支持
https://image.koolshare.cn/attachment/forum/201911/28/184929mekzfzqddfkkld0i.jpg
▲右上方是Mini-PCI-E转mSATA插槽。右下方上是适用于SSD的M.2插槽,支持2280规格的NVMe SSD。Aspeed AST2500,独立的ARM CPU,用于处理IPMI系统数据,同时为VGA接口提供支持。MX25L25635FMI,FLASH芯片,容量大小为32MB。K4A4G165WE-BCRC,DDR4 RAM芯片,电压为1.2V,速率为2400Mbps,容量大小为512MB
https://image.koolshare.cn/attachment/forum/201911/28/190108qbjm8fjez8lx2jxc.jpg
▲MBD-X11SDV-8C-TP8F主板背面一览。CPU散热器背面预装了金属背板,保证了主板的强度
https://image.koolshare.cn/attachment/forum/201911/28/190448btxixjttb0und2jt.jpg
▲GL854G,USB2.0 HUB
https://image.koolshare.cn/attachment/forum/201911/28/195501q3lhraal7amrlrfr.png
▲主板芯片示意图
IPMI
作为一个服务器主板,MBD-X11SDV-8C-TP8F也配备了IPMI系统和独立的管理接口
https://image.koolshare.cn/attachment/forum/201911/28/200627k5eio3f2effndee6.png
▲IPMI中可以看到当前主板上的硬件信息
https://image.koolshare.cn/attachment/forum/201911/28/200621gt1vpb31nigtvgd1.png
▲传感器读取信息中可以查看当前的所有设备温度以及风扇转速和12V、5V、3V电压
https://image.koolshare.cn/attachment/forum/201911/28/201055jcfxsdabay555fa4.png
▲日期和时间要设置准确了
https://image.koolshare.cn/attachment/forum/201911/28/201143oymldk6m3ylfnb4o.png
▲网络设定中可以配置IPv4地址和IPv6地址
https://image.koolshare.cn/attachment/forum/201911/28/201327yowrpoo0gwrwg1r1.png
▲端口设置中设定好自己需要使用到的端口 好东西 不错 了解 板载至强的嘛 谢谢分享!!!!
