RK3229(RK3228) TVBOX智能电视盒 PCB文件和原理图共享下载
NamePart TypePCB DecalValueANT1CRYSTAL-4_0ANT4009SSANTCM2000CM_CCD5.0/2.5100uF/10VCM2001CM_CCD5.0/2.5100uF/10VCN2701CON4_2.5MM_DIPCON4_2.54CON4_2.54MM_DIPD2ESD_0R0402(NP)GESD1005H150CR10GPTD12DIODE_2DIO-SMBTVSD13DIODE_2SOD323TVSD1100DIODE_BI_DIR_TRIGESD0402ESD5451ND2102DIODESOD3231N5819D2400DIODE_DOUBLE_FSOT_23BAT54SD2401DIODE_BI_DIR_TRIGESD0402ESD5451ND2402DIODE_BI_DIR_TRIGESD0603EGS06V05A50TD2403DIODE_BI_DIR_TRIGESD0603EGS06V05A50TD2800DIODE_BI_DIR_TRIGESD0402ESD5471XD3004DIODE_2ESD0402TVSED38DIODE_BI-DIR_TRIGE0402NTVS-BV03CWED39DIODE_BI-DIR_TRIGE0402NTVS-BV03CWED41DIODE_BI-DIR_TRIGDO214ACBS3500NED2107DIODE_BI_DIR_TRIGESD0402ESD5471XF2000FUSER08050RF2001FUSER08050RH1H0502H3.8MMH3.8MMH2H0502H3.8MMH3.8MMH3H0502H3.8MMH3.8MMH4H0502H3.8MMH3.8MMIR500IR_RECEIVEIRM-2638IRM-2638J500DC_1DC-008DC-008J1600TF_SD_SOCKETTF_SD702TF_SD_SOCKETJ2100HDMI_A_0HDMIA1912_A15RHDMI_AJ2400PHONEJACK_STEREO_SW_1PHONE_55BPHONEJACKJ2401CON2_1X2KCD117-2P-SKCD117-2P-SL2L0402_1.7NH_ACXL04022n2HL3L0402_1.7NH_ACXL-20162u2HL10INDUCTOR_3L0603BLM18PG181SN1L500INDUCTORS_OF_FERRITEIND_6060284.7uHL501INDUCTOR_1IND-4X41.0uH/2AL502INDUCTOR_1IND-4X41.0uH/2AL503INDUCTORS_OF_FERRITEIND3X33.3uHL504INDUCTORS_OF_FERRITEIND3X33.3uHL1001INDUCTOR_2L0805330R-100ML1002INDUCTOR_2L0805330R-100ML1200INDUCTOR_2L0603180R-100ML1201INDUCTOR_2L06031RL2000INDUCTOR_COML0603D90R-100ML2001INDUCTOR_COML0603D90R-100ML2002INDUCTOR_COML0603D90R-100ML2003INDUCTOR_COML0603D90R-100ML2004INDUCTOR_COML0603D90R-100ML2005INDUCTOR_COML0603D90R-100ML2400INDUCTOR_2L0603180nH/NCL2402INDUCTOR_2L0603180R-100MLED500LED_1LED-19-22319-223LED501LED_0LED-19-213IR_LEDLED502LED_1LED-19-22319-223PJ1RJ45-LED-LY-RG_1RJ45RJ45-LED-LYRGQ700MOSFET_PSOT_23WPM2015-3/TRQ1600MOSFET_PSOT_23WPM2015-3/TRQ2100MOSFET_NSOT_323WNM2021-3/TRQ2101MOSFET_NSOT_323WNM2021-3/TRQ2102MOSFET_NSOT_323WNM2021-3/TRQ2204NPNSOT_23S8050SW1100SW4P_0SW4-SKQG-5_2X5_2H1_5BRECOVERSW1101SW4P_0SW4-SKQG-5_2X5_2H1_5BRESETT2TP_2TP_0.4MMTPU2DDRII_0FBGA96_14R00X11R00X1R20DDR3-512MBU3DDRII_0FBGA96_14R00X11R00X1R20DDR3-512MBU4DDRII_0FBGA96_14R00X11R00X1R20DDR3-512MBU5DDRII_0FBGA96_14R00X11R00X1R20DDR3-512MBU6RTL8703BS_0QFN40RTL8703BS/RTL8723CSU500DCDC_MP1495TSOT_23_8MP1495SU501LDO_TT2102SOT_23_5TT2102U502DS8008_6SOT25SY8089AAC/ETA3409A/TCS4201U503DS8008_6SOT25SY8087A/ETA3409A/TCS4201U504DCDC_SY8088SOT_23_5ETA3486U505LDO_PT5108SOT_23_5PT5108E23E-18U506DCDC_SY8088SOT_23_5ETA3486U508VOLTAGE_DETECTOR_CE8809SOT_23CE8809C263MAU600RK3228_4BGA316_14R00X14R00X1R20RK3228U1700LDO_PT5108SOT_23_5PT5108E23E-18U1800INAND_EMMC_169BGA153_18R00X14R00X1R20KLM8G1GEAC-B031U1900NANDFLASH_TSOP48TSOP48_1H27UBG8T2DTR-BC/NCU2000SWITCH_SY6280SOT_23_5SY6280AACU2002SWITCH_SY6280SOT_23_5SY6280AACU2100DS8008_3SLP2510P8ESD5304DU2101DS8008_3SLP2510P8ESD5304DU2400U_DRV602TSSOP14-0.65MMTPF632U2401GP1FD310TP1_0DLT2160ADIN_0421U2501LAN1102SOIC16HR601680U3201LDO_PT5108SOT_23_5PT5108E23E-33USB2000JP_USB2_3.0USB_AF_90USB_AF_90USB2001JP_USB2_4.0USB_AF_90USB_AF_90X29346_0X322524MHzY700CRYSTAL_4PCRY4_3R20X2R50X0R8024MHz 看看,学习一下。 PCB文件和原理图来了。回复可见下载。
**** Hidden Message ***** 谢谢分享 好东西啊 学习一下 谢谢分享 谢谢分享
