RK3128 方案画的还不错的PCB文件和原理图共享
NamePart TypePCB DecalValueANT1CON_IPEX_2RF101-003CON_IPEXANT2CON_IPEX_1RF101-003CON_IPEX PA1575MZ50Q4GANT4CON_IPEX_1RF101-003CON_IPEX PA1575MZ50Q4GANT5CON_IPEX_1RF101-003CON_IPEX PA1575MZ50Q4GANT6CON2MINI_TI_ANTNC/Copper PCB AntBT2100BATTERY_0CON3_2.54LI_3.7VC23373CAP_0603_2.2UF_6.3V_CERAMICC040210uCN3CON3CON3_2.0CON3D1BZX84C18/SOT_0_2SOD128M1/1N4001D3DIODESOD123NC/1N5819D4DIODESOD1231N5819D6DIODE_2SOD-123B5819WD7LEDD0402LEDD8LEDD0402LEDD2100DIODE_1SOT23BAT54CD21041.5KE120ASMA5V/5918B/ONSEMID2105BZX84C18/SOT_0SOD128M1/1N4001D2112LEDD0402LEDED2ESD_1SOT23ESDA6V8UL/AZC199-02SED13TVSE0402NESD9B5VLED14TVSE0402NESD9B5VLED15TVSE0402NESD9B5VLED16TVSE0402NESD9B5VLED17TVSE0402NESD9B5VLED2100DIODE_BI-DIR_TRIGE0402NESD5451NED2101DIODE_BI-DIR_TRIGE0402NAZ5725-01FED2102DIODE_BI-DIR_TRIGE0402NESD5451NED4600DIODE_TVSE0402NESD5451NED4602DIODE_TVSE0402NESD5451NED4603DIODE_TVSE0402NESD5451NED4604ESD_1SOT23ESDA6V8UL/AZC199-02SED4605DIODE_TVSE0402NESD5451NED4606DIODE_TVSE0402NESD5451NED4607DIODE_TVSE0402NESD5451NED4608DIODE_TVSE0402NESD5451NFB1INDUCTOR-COML0603DNC/SDCW2012-2-900IGBT-1TEST_2PAD7.0MMeFUSEIGBT-2TEST_2PAD7.0MMeFUSEIGBT-3TEST_2PAD7.0MMeFUSEIGBT-4TEST_2PAD7.0MMeFUSEJ1CON31FH26-31S-0.3SHW(05)FH26-31S-0.3SHW(05)J3CON8BL509-08G31-MIRRORCON8J2000MINI_USBMICROUSB-B-H4USB_JACKJ8253HDMI_A_3A151902-B-15-RNC/A151902-B-15-R HDMI 19PJ8254SIM_2XKSIM-304XKSIM-304 / NANO SIMJ8255CON12FPC0510HX-12PCON12J8257CON10FPC0510HX-10PACON10J8258CON10FPC0510HX-10PCON10L10INDUCTOR_1IND-3X3SWPA3015S3R3NT/1AL11INDUCTOR_3L0603BLM18PG181SN1L16INDUCTOR_1SLF60284.7uH/1.6AL52INDUCTOR_2L0603BLM18PG181SN1L53INDUCTOR_2L0603BLM18PG181SN1L2100INDUCTOR_2IND-4X41uH/3.5AL2101INDUCTOR_2IND-3X31uH/2AL2102INDUCTOR_2IND-3X31uH/2AL2103INDUCTOR_2IND-3X31uH/2AL2104INDUCTOR_2IND-4X41uH/3.5AL2105INDUCTOR_2IND-4X41uH/3.5AL2308INDUCTORS_OF_FERRITEIND_2520102.2uHL5101L_CDRH3D16IND_50502010uH_1.5AMIC1MICMIC-4020MICQ31NPN_0SOT23S8050Q34MOSFET_PSOT23WPM2341Q36NPN_0SOT23S8050Q37MOSFET_PSOT23WPM2341Q46MOSFET_PSOT23WPM2341Q47MOSFET_PSOT23WPM2341Q48NPN_0SOT23S8050Q49MOSFET_PSOT23WPM2341Q50NPN_0SOT23S8050Q51MOSFET_PSOT23WPM2341Q52NPN_0SOT23S8050RP1RESISTOR_4PACKR0402S410KRP2RESISTOR_4PACKR0402S4NC/10KRXLLED1LEDD0603GREENSW1SW4P_2IT-1185SNC/RESETSW2401SW4P_2IT-1185SNC/VOL+(RECOVERY)SW4603SW4P_2IT-1185SNC/VOL-SW4604CON2CON2_2P0CON2T19TEST_2T-0.7FALSH_DQS/EMMC_CLKOU1RK3128_6BGA316-14X14_0.65RK3128U5DDRII_4FBGA96-10X14DDR3-128X16bitU6DDRII_4FBGA96-10X14DDR3-128X16bitU14CH340GCH340GCH340GU16GL850G/GL852GSSOP-28GL850G/GL852GU20INAND_1INAND_169_AeMMCU21DS8008_6SLP2510P8RClamp0524J/ESDA6V8UDU22DS8008_7SLP2510P8RClamp0524J/ESDA6V8UDU27U_MP3202SOT26SY7201ABCU2100RK818_0QFN68_7R00X7R00X0R80_TRK818U2304DCDC_SY8088SOT25SY8089AACU4601RT7295A_0TSOT-23-6RT7295AU8004MAX809SD_3SOT23NC/TT8809U8006LM1086_2TSOP-6NC/NL27WZU04U8007AP6493_0AP6XXXNC/AP6335U8020G8100G8100_PKGG8100U8021XC6420AB19SOT-26XC6420AB19MR-GU8023CH340GCH340GCH340GU8024NT50198_0TDFN-12NT50198U8025BME280BME280BME280U8026ATMEGA328P-AU_032M1-AATMEGA328P-MUY1CRYSTAL-4_1CRY-D322524M-20ppmY4CRYSTAL-4_0CRY-D322526MHz-10ppmY6CRYSTAL_DSX321G252016MY2301CRYSTAL_2P_1GCRY2_6R90X1R40X1R3032.768KHzY2305CRYSTAL-4_1CRY-D322512MHzY2306CRYSTAL-4_1CRY-D322512MHzY2307CRYSTAL-4_1CRY-D322512MHz PCB文件和原理图共享。回复可见
**** Hidden Message ***** 好板子 学习学习一下
