Realtek RTL8367S-CG datasheet及用途功能简介
RTL8367S-CG是一颗高性价性的交换芯片,搭配组合方式多样,可以做4GE(4千兆电口)、5GE、5GE+1GX(光)、4GE+2GX。两颗8367S拼接组合,最多能做10GE+2GX(10口千兆+2口千兆光)。 该芯片内核RGMII口,可与RK、海思等主控对接,可用于IP电话、打卡机、智能网络设备、NVR等产品,datasheet及SCH不知道怎么上传如需详细文档资料请留言http://dl.ntpcb.com/attachment/thumb/diary/Mon_2003/93683_cf25935c2670bd3.png?83RTL8367S-CG是一款LQFP-128高性能5+2端口10/100/1000M 2层以太网交换机芯片,具有低功耗集成5端口GigaPHY,支持1000Base-T、100Base-TX和10Base-T。对于特定应用,RTL8367S支持一个额外的接口,可以配置为RGMII/MII接口。RTL8367S还支持一个可以配置为SGMII/HSGMII接口的Ser-Des接口。RTL8367S集成了高速交换系统的所有功能,包括用于数据包缓冲的SRAM、无阻塞交换结构,和内部寄存器管理到单个CMOS设备中。功能单芯片5+2端口10/100/1000M无阻塞交换机架构嵌入式5端口10/100/1000Base-T物理每个端口支持全双工10/100/1000M连接(仅在10/100M模式下支持半双工)额外接口(扩展GMAC1)支持GMII(1.25GHz)接口高SGMII(3.125GHz)接口Extra接口(扩展GMAC2)支持媒体独立接口(MII)减少10/100/1000M媒体独立接口(RGMII)全双工和半双工操作,支持IEEE802.3x流量控制和背压应用5端口1000Base-T路由器,支持SGMII/HSGMII和/或MII/RGMII
RTL8367S-CG LAYER 2 MANAGED 5+2-PORT 10/100/1000M SWITCH CONTROLLER General DescriptionThe RTL8367S-CG is a LQFP-128, high-performance 5+2-port 10/100/1000M Ethernet switch featuring a low-power integrated 5-Port Giga-PHY that supports 1000Base-T, 100Base-TX, and 10Base-T.For specific applications, the RTL8367S supports one extra interface that could be configured as RGMII/MII interfaces. The RTL8367S also supports one Ser-Des interface that could be configured as SGMII/HSGMII interfaces. The RTL8367S integrates all the functions of a high-speed switch system; including SRAM for packet buffering, non-blocking switch fabric, and internal register management into a single CMOS device.FeaturesSingle-chip 5+2-port 10/100/1000M nonblocking switch architectureEmbedded 5-Port 10/100/1000Base-T PHYEach port supports full duplex 10/100/1000M connectivity (half duplex only supported in 10/100M mode)Extra Interface (Extension GMAC1) supportsSGMII (1.25GHz) InterfaceHigh SGMII (3.125GHz) InterfaceExtra Interface (Extension GMAC2) supportsMedia Independent Interface (MII)Reduced 10/100/1000M Media Independent Interface (RGMII)Full-duplex and half-duplex operation with IEEE 802.3x flow control and backpressureApplications5-Port 1000Base-T Router with SGMII/HSGMII and/or MII/RGMIIhttps://img-blog.csdnimg.cn/20190530142942715.jpg?x-oss-process=image/watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3dlaXhpbl80MjcwNzk3NQ==,size_16,color_FFFFFF,t_70 学习 很不错的资料 学习了。 这个没有资料吗? 不错,不错,
