sisi9000 发表于 2020-4-27 16:02:25
VMM5210+VL170+VL103R+VL817+RTL8153+GL3224+FE8.1多功能HUB PCB文件共享
NamePCB DecalValuePart Type1V1TP1TTP13V1TP1TTP1CN1USB_C_UCB0015_000_YPTYPE_C_12P_12P_8.65USB_C_UCB0015_000_YPCN2USB_C_UCB0015_000_YPUSB_C_UCB0015_000_YPUSB_C_UCB0015_000_YPCN3TYPE_C_12P_12P_8.65TYPE_C_12P_12P_8.65TYPE_C_12P_12P_8.65CON1TF_10TFTF_10CON2SD_11SDSD_11CON3RJ45_JXQCB301188AB1W6DB1075_YPRJ45_H3.0RJ45_JXQCB301188AB1W6DB1075_YPD1STZ5.6N_SOT_23_3STZ5.6N_NCSTZ5.6N_SOT_23_3D2LED-DIPLED_WHITELED-DIPD3LED0603LED_LVLED0603D4LED0603LED_CHENGLED0603D5SOD-323CDBP0130L-GSOD-323D6SOD-3231N4148/SOD123SOD-323D7SOD-3231N4148/SOD123SOD-323D8LED0603LED/GRE/0805LED0603D9LED0603LED/GRE/0805LED0603D10LED0603LED/GRE/0805LED0603D11SOD-323SSA33L-E3/61TSOD-323D13SOD-323DIODE_SCHOTTKY/CRS08SOD-323FB1L0603ACMS160808A300_0603L0603J1AUDIO-DBAUDIO_3.5MMAUDIO-DBJ2USB30-DP-90AAUSB3.0A_2.45USB30-DP-90AAJ3USB30-DP-90AAUSB3.0A_2.45USB30-DP-90AAJ4USB30-DP-90AAUSB3.0A_2.45USB30-DP-90AAJ5USB2.0_620_10227_YPUSBA_2.0USB2.0_620_10227_YPJ6DP-F20DP_TX0DP-F20J7HDMIHDMI_TX1HDMIL13015_4X4MM2.2UH3015_4X4MML23015_4X4MM2.2UH3015_4X4MML3SSMD06304.7UH_NCSSMD0630L43015_4X4MM2.2UH3015_4X4MML53015_3X3MM2.2UH3015_3X3MML6RES0603BLM18AG102SNRES0603L7RES0603BLM18AG102SNRES0603L8RES0603BLM18AG102SNRES0603L9RES0603BLM18AG102SNRES0603L10L0603BLM18SG700TN1DL0603L11L0603BLM18AG102SNL0603L12L0603BLM18SG700TN1DL0603L13L0603BLM18AG102SNL0603L14L0603BLM18SG700TN1DL0603L15L0603BLM18SG700TN1DL0603L16L-4040121.2UHL-404012L18RES0603BLM18AG102SNRES0603L19RES0603BLM18AG102SNRES0603L20JTP04034.7UH_4.7UH/040_0_7MMJTP0403L21L-4040121.6UH/1.8AL-404012Q1PPAK-3X3-8TDM3307APPAK-3X3-8Q2PPAK-3X3-8TDM3307APPAK-3X3-8Q3SOT_23_32N7002SOT_23_3Q4SOT_23_32N7002SOT_23_3Q5SOT_23_32N7002SOT_23_3Q6SOT_23_32N7002SOT_23_3Q7SOT_23_3SMC3401SSOT_23_3Q8SOT23-GDS2N7002SOT23-GDSQ9SOT23-GDS2N7002SOT23-GDSQ10SOT23-GDS2N7002SOT23-GDSRXHPD1TP1TTP1SW1KEY-4.5_2.7SWTACT/SMD_NCKEY-4.5_2.7U1QFN28-VL170QFN28-VL170QFN28-VL170U2SOT23_5SY8088SOT23_5U3SOT23_5SY8088SOT23_5U4QFN16_5SC8721_QFN16_5QFN16_5U5SOT23_5SY8088SOT23_5U6VL103R_QFN48_6X6VL103R_QFN48VL103R_QFN48_6X6U7SOP_8FM25FQ04-SO-T-G/FMSOP_8U8GL3224_QFN48GL3224_QFN48GL3224_QFN48U9SOP_8GD25Q512SOP_8U10QFN32_SSS1530SSS1530QFN32_SSS1530U11SOP_824C0X_XSOP_8U12SOT23_524C0X_XSOT23_5U13SSOP_16FE8.1SSOP_16U14VL817_QFN76VL817_QFN76VL817_QFN76U15VL817_QFN76VL817_QFN76VL817_QFN76U16S7001_SOT23-6S7001S7001_SOT23-6U17SOP_8FM25FQ04-SO-T-G/FMSOP_8U18GST5009GST5009GST5009U19RTL8153_QFN48RTL8153RTL8153_QFN48U20SOP_8MX25L1606ESOP_8U2110-DFNNL/ESD800410-DFNU22120_SOCKET_TCBGA_0.65MMVMM5210_BGA120_0120_SOCKET_TCBGA_0.65MMU2310-DFNNL/ESD800410-DFNU24S7001_SOT23-6S7001S7001_SOT23-6U2510-DFNNL/ESD800410-DFNU2610-DFNNL/ESD800410-DFNU27SEMTECH/SC70-6LNL/RCLAMP0504SEMTECH/SC70-6LU28TSSOP_14PI3C3125LE/TSSOP14TSSOP_14U3010-DFNECMF04-4HSWM1010-DFNU3110-DFNECMF04-4HSWM1010-DFNU32SEMTECH/SC70-6LRCLAMP0504SEMTECH/SC70-6LU33SOP8GD25Q40CSOP8U34SOT23_5SY8089SOT23_5U35SY8003SY8003SY8003U36S7001_SOT23-6S7001S7001_SOT23-6X1322525MHZ3225X23225XTAL_25M3225Y1322512MHZ3225Y2322525MHZ3225Y3322525MHZ3225Y4X-322527MHZ/CTS406X-3225
sisi9000 发表于 2020-4-27 16:04:17
PCB 还有几个错误。仅供参考。
5金币下载。
bidezhi7777 发表于 2020-4-27 22:30:32
907321 发表于 2020-4-28 07:59:37
chuxiaobo 发表于 2020-4-28 08:12:30
zblin1987 发表于 2020-4-28 08:17:50
cityhu 发表于 2020-4-28 08:32:37
谢谢分享
allegro 发表于 2020-4-28 08:56:00
yeyongjicn 发表于 2020-4-29 08:25:42
谢谢分享!!!!
hlim89 发表于 2020-4-29 08:50:42
页: [1] 2 3 4 5 6 7 8 9
查看完整版本: VMM5210+VL170+VL103R+VL817+RTL8153+GL3224+FE8.1多功能HUB PCB文件共享
