老吴 发表于 2020-6-14 20:48
MSTAR MST6M60 方案4K液晶电视PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME7Y1CRYSTAL-4P_0_Y-SMD4P3225_24MHZ_24MHz_33pF_20PPMY-SMD4P3225AU5CS4354_1_TSSOP16A_MAX232MAX232TSSOP16ACN1206HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20ACN1207HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20ACON12HDMI_J_2_VERTER_1_HDMI19P-90_HDHDMI_J_2_VERTER_1HDMI19P-90CR16DIODE_NORMAL_D0402_DIODE_NORMALDIODE_NORMALD0402D7BAV99_SMD_SOT-23_BAV99BAV99SOT-23D62BAV99_0_D0402_NCNCD0402D63BAV99_0_D0402_NCNCD0402D102DIODE_SCHOTTKY_DO-214_DIODE_SCHDIODE_SCHOTTKYDO-214D103DIODE_SCHOTTKY_DO-214_DIODE_SCHDIODE_SCHOTTKYDO-214D817BAV99_0_D0402_NCNCD0402D818BAV99_0_D0402_NCNCD0402D828DO-214 SS344A/60V_DO-214_SS34SS34DO-214D829LED_LED0805_LEDLEDLED0805D830LED_LED0805_LEDLEDLED0805D832DO-214 SS344A/60V_DO-214_SS34SS34DO-214H1CON3_3_TPAD_NCNCTPADHOLE5HOLE_3_3-6-HOLE_HOLEhole3_3-6-HOLEJ1CON122_0.0MM_CN12-20A_CN12-2.0CN12-2.0CN12-20AJ2CON6_1_CN6-20A_CN6_2.0CN6_2.0CN6-20AJ3CON3_CN3_20A_NC/HEADER/2.54MM/1NC/Header/2.54mm/180D/MaleCN3_20AJ4CON6_CN6-20A_CON6CON6CN6-20AJ16CPT_A_3_CON-FI-RE41S-HF_NC/FI-RNC/FI-RE41S-HFCON-FI-RE41S-HFJ17FI-RE51S-HF_2_CON-FI-RE51S-HF_NNC/FI-RE51S-HFCON-FI-RE51S-HFJ19CPT_A_4_CON-FI-RE41S-HF_NC/FI-RNC/FI-RE41S-HFCON-FI-RE41S-HFJ20FI-RE51S-HF_2_CON-FI-RE51S-HF_NNC/FI-RE51S-HFCON-FI-RE51S-HFJ105HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20AJ106HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20AJ107HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20AJ108HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20AJ1006CON20A_CON2X10_2_0_CON20ACON20ACON2X10_2_0J2003FI-RE51S-HF_2_CON-FI-RE51S-HF_NNC/FI-RE51S-HFCON-FI-RE51S-HFJ2008CON40A_CON40A_2X20_2_0_CON40ACON40ACON40A_2X20_2_0J2012CON24A_3_CON20X2_1_27_CON24A_3CON24A_3CON20X2_1_27J2013HEADER_1X4-2MM_180D_CN4-2_54A_HHEADER 1x4-180CN4-2_54AJ2029CON6X2-2_0_CON6X2-2_0_CON6X2-2_CON6X2-2_0CON6X2-2_0J2030HEADER_1X4-2MM_180D_CN4-20A_HEAHEADER 1x4-180CN4-20AJ2032HEADER_1X4-2MM_0_CN3_20A_HEADERHEADER 1x3CN3_20AJ2033CON2_CN2-20A_CON2-2.0CON2-2.0CN2-20AJ2034HEADER_0_CON5X2-2_0_HEADER_0HEADER_0CON5X2-2_0J2036CON14_CON14-20A_CON14-20ACON14-20ACON14-20AJ2037CON9_0_CN6-20A_CON6-2.0CON6-2.0CN6-20AL1INDUCTORIRON_2_SMD08X08_SWPA80SWPA8040S1R0NT/8ASMD08X08L2INDUCTORIRON_2_SMD05X05_SWPA30SWPA3015S2R2NT/1.5ASMD05X05L33INDUCTOR_L0805_INDUCTORINDUCTORL0805L34INDUCTOR_L0805_INDUCTORINDUCTORL0805L36P-INDUCTOR_3_SMD03X03_15UH15uHSMD03X03L37P-INDUCTOR_3_SMD03X03_15UH15uHSMD03X03L38INDUCTOR_L0402_INDUCTORINDUCTORL0402L39P-INDUCTOR_3_SMD03X03_15UH15uHSMD03X03L41P-INDUCTOR_3_SMD03X03_15UH15uHSMD03X03L102INDUCTOR_L0402_INDUCTORINDUCTORL0402OPS-80P2TX25A_1_TX24-80R-LT-H1E_TX24-80TX24-80R-LT-H1ETX24-80R-LT-H1EQ3SOT-233904_SOT-23_IC_39043904SOT-23Q4SOT23-1003401_4_SOT23-100_34013401SOT23-100Q5NPN_BEC_3_SOT-23_NPN_BEC_3NPN_BEC_3SOT-23Q7AO3400_SOT23_SOT-23_AO3400AO3400SOT-23Q8SOT23-1003401_4_SOT23-100_34013401SOT23-100Q14N DSG_0_SOT-23_ NDSG_0N DSG_0SOT-23Q902NPN BEC_3_SOT-23_39043904SOT-23Q903PNP_BEC_SOT-23_PNP_BECPNP_BECSOT-23Q904NPN_BEC_3_SOT-23_NPN_BEC_3NPN_BEC_3SOT-23Q922SOT-233904_SOT-23_IC_39043904SOT-23Q929SOT-233904_SOT-23_IC_39043904SOT-23Q930SOT-233906_SOT-23_IC_39063906SOT-23Q931SOT-233904_SOT-23_IC_39043904SOT-23Q932SOT-233906_SOT-23_IC_39063906SOT-23Q9452NPN_BEC_3_SOT-23_NPN_BEC_3NPN_BEC_3SOT-23S2INDUCTOR_0_48X39MM_HEAT-SINK48XHeat-sink48X3948X39MMSW1508KEY_0_SW2_TS_037_PS_ONPS_ONSW2_TS_037SW1509KEY_1_SW2_TS_037_ANDROID_PWRAndroid_PWRSW2_TS_037TP6TESTPOINT_1_TP-0_6MM_DEODEOTP-0_6MMU1ULTRASONIC_27X27_2L_0917_0_IC-9ULTRASONIC_27X27_2L_0917_0IC-941P-P08U5AT24C21_2_SOP8-225-50_AT24C21_2AT24C21_2SOP8-225-50U6AT24C21_2_SOP8-225-50_AT24C21_2AT24C21_2SOP8-225-50U10AOZ1036_41_DFN3X3-12_AOZ1036_41AOZ1036_41DFN3X3-12U11SOT-223_SOT-223_AS1117L-3.3AS1117L-3.3SOT-223U12PAM2301_2_SOT-23-5_SY8089ASY8089ASOT-23-5U38TAS5708_0_HTQFP48_TAS5708PHPTAS5708PHPHTQFP48U103M24CXX_0_SOP8-255-50_MX25L1605MX25L1605SOP8-255-50U1213SGM7227_MSOP10-3_1X3_1H1_1-P0_5SGM7227MSOP10-3_1X3_1H1_1-P0_5U1214LDO TO-2521117-ADJ_SOT-223_AMSAMS1117-3.3_1ASOT-223USB2501USB20_TYPE_A_USB20A4_USB_AF_01_USB-HUB_PORTBAUSB20A4_USB_AF_01_001USB2508USB20_TYPE_A_USB20A4_USB_AF_USBUSB-HUB_PORTBAUSB20A4_USB_AF
老吴 发表于 2020-6-14 20:49
PCB文件。没原理图。回复可见
**** Hidden Message *****
清心如水 发表于 2020-6-15 08:33
zblin1987 发表于 2020-6-15 08:40
yyjccit 发表于 2020-6-15 08:52
ilovepcb 发表于 2020-6-15 08:52
回 老吴 的帖子
老吴:PCB文件。没原理图。回复可见
[内容隐藏]
 (2020-06-14 20:49) images/back.gif
看看先。
天翼麒麟 发表于 2020-6-15 08:55
轻微1213 发表于 2020-6-15 09:45
o桃花岛主o 发表于 2020-6-15 10:33
带刀的老鼠 发表于 2020-6-15 10:45
页: [1] 2 3 4 5 6 7
查看完整版本: MSTAR MST6M60 方案4K液晶电视PCB文件共享
