armclub 发表于 2020-9-2 14:37
全志A80+GM7121+GM7122+RTL8211E+AC100 做的平板电脑PCB和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1DIODE_SCHOTTKY_1_SOD123_XBS104SXBS104S14SOD123D2DIODE_SCHOTTKY_1_SOD123_XBS104SXBS104S14SOD123D3DIODE_SCHOTTKY_1_SOD123_1N41481N4148SOD123D4DIODE_SCHOTTKY_1_SOD123_1N41481N4148SOD123D5DIODE_SCHOTTKY_1_SOD123_1N41481N4148SOD123D3_U1DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13D3_U2DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13D3_U3DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13D3_U4DDR3_1_FBGA96C80P9X13_DDR3-FBGADDR3-FBGA96FBGA96C80P9X13DX_R2R_R0402_240R-1%240R-1%R0402EC4CAPACITORPOL_2_C_3528_H19_100U100uFC_3528_H19EC5CAPACITORPOL_2_C_3528_H19_100U100uFC_3528_H19EC6CAPACITORPOL_2_C_3528_H19_47UF47uF/4VC_3528_H19EC7CAPACITORPOL_2_C_3528_H19_100U100uFC_3528_H19EC8CAPACITORPOL_2_C_3528_H19_220U220uFC_3528_H19ESD11_1.5KE100A_TVS0402_ESD9B5V-2/TESD9B5V-2/TRTVS0402ESD151_1.5KE100A_TVS0402_ESD9B5VL-2/ESD9B5VL-2/TRTVS0402ESD161_0.5KE100A_SMB_SPD82152BSPD82152BSMBESD171_1.5KE100A_TVS0402_ESD9B5VL-2/ESD9B5VL-2/TRTVS0402ESD181_1.5KE100A_TVS0402_ESD9B5VL-2/ESD9B5VL-2/TRTVS0402ESD191_1.5KE100A_TVS0402_ESD9B5V-2/TESD9B5V-2/TRTVS0402ESD201_1.5KE100A_TVS0402_ESD9B5V-2/TESD9B5V-2/TRTVS0402ESD211_1.5KE100A_TVS0402_ESD9B5V-2/TESD9B5V-2/TRTVS0402ESD251_1.5KE100A_TVS0402_NC/ESD9B5V-NC/ESD9B5V-2/TRTVS0402ESD261_1.5KE100A_TVS0402_NC/ESD9B5V-NC/ESD9B5V-2/TRTVS0402ESD27DIODE_SCHOTTKY_2_TVS0402_ESD9X7ESD9X7VTVS0402ESD28DIODE_SCHOTTKY_2_TVS0402_ESD9X7ESD9X7VTVS0402ESD29DIODE_SCHOTTKY_2_TVS0402_ESD9X7ESD9X7VTVS0402ESD30RRCLAMP0524P_RCLAMP0524P_RRCLAMrRClamp0524PRCLAMP0524PESD31RRCLAMP0524P_RCLAMP0524P_RRCLAMrRClamp0524PRCLAMP0524PESD32AZ1065-06F_1_QFN10P0_80B2_00X4_AZ1065-06FQFN10P0_80B2_00X4_00H0_55ESD331_1.5KE100A_ESD0402_ESD9B5V-2/TESD9B5V-2/TRESD0402FB1INDUCTOR_0805_L0603_0R0RL0603FB8R_0805600R/1.5AR_0805FB9R_0805600R/1.5AR_0805J1SK10056619_1_SK10056619_WGQ_SK1SK10056619SK10056619_WGQJ2SATA_22P_H06_ALLTOPSATASATA_22P_H06_ALLTOPJ4HFJ11-1G01E_2_HY911130C-DIP_HY9HY911130AHY911130C-DIPJ5SMA/RF_0_SOT3P3_00B4_5X3_8_ANT1ANT1SOT3P3_00B4_5X3_8J6HDMI19_PLUG_HDMI_HDMI_19PLUGTYHDMI_19plug type AHDMIJ7USB_WIFI_0_PJ-327A_HP_JACKHP_JACKPJ-327AJ8USB3-MICRO-B_4_USB30AFDIP_USB3.USB3.0-AF-SIDEUSB30AFDIPJ10BNC-2_PWR_JACK_ACINACINPWR_JACKJ11HEADER_1X4-2MM_5_PJ-313B_PJ327PJ327PJ-313BJ26USBCON_USB1X2-A2M03H15_7A_USBCOUSBCONUSB1X2-A2M03H15_7AJ27USBCON_USB1X2-A2M03H15_7A_USBCOUSBCONUSB1X2-A2M03H15_7AL1INDUCTOR_INDP8X8_4.7UH@6ADCR<04.7uH@6A DCR<0.1RINDP8X8L2INDUCTOR_CD41_1.5UH@3ADCR<0.1R1.5uH@3A DCR<0.1RCD41L3INDUCTOR_CD41_1.5UH@3ADCR<0.1R1.5uH@3A DCR<0.1RCD41L4INDUCTOR_CD41_1.5UH@3ADCR<0.1R1.5uH@3A DCR<0.1RCD41L5INDUCTOR_CD21_1.5UH@2ADCR<0.1R1.5uH@2A DCR<0.1RCD21L6INDUCTOR_CD21_1.5UH@2ADCR<0.1R1.5uH@2A DCR<0.1RCD21L7INDUCTOR_CD77_0.33UH@20ADCR<0.0.33uH@20ADCR<0.1RCD77L8INDUCTOR_1_R0603_1.8UH1.8uHR0603L9INDUCTOR_CD21_4.7UH@1ADCR<0.1R4.7uH@1A DCR<0.1RCD21L10INDUCTOR_CD21_4.7UH@0.6ADCR<0.4.7uH@0.6ADCR<0.1RCD21L11INDUCTOR_1_R0603_600R-100M600R-100MR0603LED1LED_0_LED0805_LED_BLUELED_BLUELED0805LED2LED_0_LED0805_LED_BLUELED_BLUELED0805LED3LED_0_LED0805_LED_BLUELED_BLUELED0805LED4LED_0_LED0805_LED_BLUELED_BLUELED0805MIC+1T_POINT_R_PAD-C1_8_NCNCPAD-C1_8MIC-T_POINT_R_PAD-C1_8_NCNCPAD-C1_8Q4NMOS_0_SOT-23_BSN20BSN20SOT-23Q5NMOS_0_SOT-23_BSN20BSN20SOT-23Q8NMOS_0_SOT-23_BSN20BSN20SOT-23Q9NMOS_0_SOT-23_BSN20BSN20SOT-23Q10NMOS_0_SOT-23_BSN20BSN20SOT-23Q11NMOS_0_SOT-23_NC/BSN20NC/BSN20SOT-23Q12NMOS_0_SOT-23_NC/BSN20NC/BSN20SOT-23Q13NMOS_0_SOT-23_BSN20BSN20SOT-23Q14NPN_SOT-23_MMBT3904MMBT3904SOT-23Q15NPN_SOT-23_MMBT3904MMBT3904SOT-23Q16NPN_SOT-23_MMBT3904MMBT3904SOT-23Q26NPN_1_SOT-23_85508550SOT-23Q32FDS4935WM94358P_SOP_50SW4SW-_4_KEY4P4_0B5_2X5_2_UBOOTUBOOTKEY4P4_0B5_2X5_2SW5KEY_1_SW-EVQPF003M_IC_NC/RECOVENC/RECOVERYSW-EVQPF003MTP1T_POINT_R_TP_SMD_VDDFB-CPUAVDDFB-CPUATP_SMDTP2T_POINT_R_TP_SMD_VDDFB-CPUBVDDFB-CPUBTP_SMDTP3T_POINT_R_TP_SMD_VDDFB-GPUVDDFB-GPUTP_SMDTP4T_POINT_R_TP_SMD_GNDFB-CPUBGNDFB-CPUBTP_SMDTP5TEST POINTSURFACE_TP_SMD_CPU_3CPUS-UTXTP_SMDU1A80-BGA636_BGA636P0_65B19_00X19A80-BGA636BGA636P0_65B19_00X19_00U2AXP806_0_QFN56P0_40B7_00X7_00H0AXP808QFN56P0_40B7_00X7_00H0_75U5GPLV_CSPXX_0_BGA28P0_5B2_04X3_6OZ80120BGA28P0_5B2_04X3_65U6EMMC-BGA169_BGA169P0_50B12_00X1eMMC-BGA169BGA169P0_50B12_00X16_00H1_00U7NAND_FLASH_X8_TSOP-48_NAND_FLASNAND_FLASH_X8TSOP-48U8LP3985IM5-3_0.3_SOT23-5_AP2127KAP2127K-ADJSOT23-5U9LP3985IM5-3_0.3_SOT23-5_AP2127KAP2127K-ADJSOT23-5U12IR_MODULE_REM_2T18A_HS0038BHS0038BREM_2T18AU13ANX7150_1_LQFP44_GM7121GM7121LQFP44U14ANX7150_0_QFN5X5-32P_NC/GM7122NC/GM7122QFN5X5-32PU15SGM8900_TSSOP14_DIO2112H/SGM890DIO2112H/SGM89000TSSOP14U16AXP22X_13_QFN69P0_4B8X8_AC100AC100QFN69P0_4B8X8U17RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5U20RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5U21RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5U22AMPAK_SIPAP6335/AP6330QFN44P0_90B12_00X12_00H1_50U23LM1086_2_SOP6P0_95B3_00X1_50H1_NC/NL27WZU04SOP6P0_95B3_00X1_50H1_00U24RTL8169S_54_QFN48P0_40B6_00X6_0RTL8211EQFN48P0_40B6_00X6_00H0_85U25RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5U26RT9266PE_2_SOT23-5_SY6280SY6280SOT23-5U27GL830_0_LQFP48-GL830_GL830GL830LQFP48-GL830U28GL850G_SSOP28-GL850G_GL850GGL850GSSOP28-GL850GU29AS1117-3.3VC_SOT-223_AS1117-3.3AS1117-3.3VCSOT-223U30SI9433_0_SOT23-6_SY8105SY8105SOT23-6U31AS1117-3.3VC_SOT-223_AS1117-3.3AS1117-3.3VCSOT-223X1CRYSTAL-4_0_CRY-TSX3225_24M-20P24M-20pF-30PPMCRY-TSX3225X2CRYSTAL-4_3_CRY-TSX3225_NC/27MHNC/27MHZ-12PF-20PPMCRY-TSX3225X3CRYSTAL2_1_IN-CRYSTAL_0206H1_4A32.768KHzIN-CRYSTAL_0206H1_4AX4CRYSTAL-4_3_CRY-TSX3225_25M-10P25M-10PPMCRY-TSX3225X5CRYSTAL_0_CRY-TSX3225_E3SB37.40E3SB37.4000F16G11CRY-TSX3225X6CRYSTAL2_1_IN-CRYSTAL_0206H1__112MIN-CRYSTAL_0206H1_4AX7CRYSTAL-4_2_CRY-TSX3225_NC/3276NC/32768Hz-20pF-30PPMCRY-TSX3225X8CRYSTAL-4_3_CRY-TSX3225_25MHZ25MHZCRY-TSX3225ZD1DIODE_SCHOTTKY_4_SOD123_DL4734ADL4734ASOD123
armclub 发表于 2020-9-2 14:38
PCB 原理图一起打包。
1RMB 下载
907321 发表于 2020-9-2 14:44
walldwp 发表于 2020-9-2 15:51
看评测用a80不如上rk3288
a6682100 发表于 2020-9-2 16:23
bingo426 发表于 2020-9-2 17:35
页: [1] 2 3 4 5 6 7 8
查看完整版本: 全志A80+GM7121+GM7122+RTL8211E+AC100 做的平板电脑PCB和原理图
