TC358870XBG+ICN6211,4层板,包含2种供电方案-4V、1.15V、1.2V、1.8V、3.3V、5VDCDC
以下内容由管理员整理补充
已有 1 人购买 本主题需向作者支付 5 枚金币 才能浏览 购买主题
谢谢分享!!!!
谢谢分享
谢谢分享
谢谢分享
以下内容由管理员整理补充
| Comment | Pattern | Quantity | Components | |
| 0.01uF | 402 | 2 | C93, C94 | 贴片电容 |
| 0.1uF/25V | LC-0805_C | 1 | C73 | 贴片电容 |
| 0.1uF | 402 | 18 | C01, C14, C24, C34, C44, C61, C62, C63, C65, C67, C69, C75,C88, C96, C98, C611, C613, C615 | 贴片电容 |
| 1.4KΩ | 402 | 1 | R73 | 贴片电阻 |
| 100K | 402 | 1 | R010 | 贴片电阻 |
| 100K | LC-SMD-3P | 1 | R72 | 电位器 |
| 100KΩ 1% | 402 | 3 | R11, R91, R96 | 贴片电阻 |
| 100KΩ | 402 | 3 | R71, R81, R612 | 贴片电阻 |
| 10KΩ | 402 | 7 | R13, R21, R31, R41, R95, R614, R615 | 贴片电阻 |
| 10nF | 402 | 3 | C3, C4, C79 | 贴片电容 |
| 10uF | 805 | 5 | C11, C21, C31, C41, C91 | 贴片电容 |
| 13KΩ 1% | 402 | 1 | R14 | 贴片电阻 |
| 15KΩ 1% | 402 | 2 | R22, R33 | 贴片电阻 |
| 15KΩ | 402 | 1 | R82 | 贴片电阻 |
| 18.7KΩ 1% | 402 | 1 | R32 | 贴片电阻 |
| 18KΩ 1% | 402 | 1 | R43 | 贴片电阻 |
| 1KΩ | 402 | 5 | R03, R04, R09, R51, R613 | 贴片电阻 |
| 1uF | 603 | 8 | C1, C2, C64, C66, C68, C610, C612, C614 | 贴片电容 |
| 2.2nF | 402 | 1 | C78 | 贴片电容 |
| 2.2uH 3A | L4020 | 4 | L1, L2, L3, L4 | 贴片电感 |
| 20KΩ 1% | 402 | 3 | R12, R92, R97 | 贴片电阻 |
| 220pF | 402 | 1 | C77 | 贴片电容 |
| 22uF | 805 | 4 | C13, C23, C33, C43 | 贴片电容 |
| 22uF | LC-0805_C | 7 | C81, C82, C83, C84, C85, C86, C87 | 贴片电容 |
| 2KΩ | 402 | 1 | R61 | 贴片电阻 |
| 3.3nF | 402 | 4 | C12, C22, C32, C42 | 贴片电容 |
| 3.3uH 1.3A | L3015 | 3 | L6, L7, L8 | 贴片电感 |
| 3.3uH 3A | L4020 | 2 | L5, L9 | 贴片电感 |
| 30KΩ 1% | 402 | 2 | R15, R23 | 贴片电阻 |
| 30Ω @ 100MHz | 603 | 17 | R012, R013, R014, R015, R016, R017, R018, R62, R63, R64, R65,R66, R67, R68, R69, R610, R611 | 铁氧体磁珠30Ω @ 100MHz |
| 3296W | LC-SMD-3P | 1 | R011 | 3296W,可调电阻 |
| 33Ω | 402 | 1 | R08 | 贴片电阻 |
| 4.02K | 402 | 1 | R94 | 贴片电阻 |
| 4.7uF | 603 | 2 | C76, C92 | 贴片电容 |
| 45FPC | PCBComponent_1 | 1 | P1 | 间距0.3mm 45pin FPC座 |
| 47KΩ | 402 | 3 | R05, R06, R07 | 贴片电阻 |
| 47uF | LC-1210_C | 4 | C71, C72, C74, C97 | 贴片电容 |
| 47uF | LC-CASE-D_7343 | 1 | C02 | 钽电容 |
| 56.2KΩ 1% | 402 | 1 | R42 | 贴片电阻 |
| 80.6K | 402 | 1 | R93 | 贴片电阻 |
| BSS123LT1 | LC-SOT-23-3L | 2 | Q1, Q2 | MOS(场效应管) |
| DC-5V | DC-6mm | 1 | DC-12V | DC电源插座 |
| HDMI CON | HDMI | 1 | P4 | HDMI connector |
| HDR2*7 | HDR2X7 | 1 | P3 | |
| ICN6211 | QFN48 - duplicate | 1 | U5 | |
| IIC | HDR1X3 | 1 | IIC | |
| LTC7149EUFD | LC-QFN-28_4x5x05P | 1 | U7 | DC-DC芯片 |
| open | 402 | 1 | C95 | 贴片电容 |
| power switch | 钮子开关 | 1 | P5 | 钮子开关 源丰 ST-1-102-C03-N003-RS |
| RCLAMP0524P | DFN2.5x1-10L | 3 | D2, D3, D4 | |
| RLED | LC-0603_LED_S1 | 1 | D1 | 发光二极管 |
| SI2301 | LC-SOT-23-3L | 1 | Q3 | MOS(场效应管) |
| TC358870XBG | VFBGA80 | 1 | U6 | |
| TLV62130RGTR | LC-QFN-16_3x3x05P | 4 | U1, U2, U3, U4 | 开关电源 |
| TPS54620 | VQFN_14 | 1 | U9 | |
| TPS650243RHB | LC-VQFN-32_5x5x05P | 1 | U8 | DC-DC芯片 |
| YSO690PR 50MHZ 3.3V 20PPM | LC-SMD-3225_4P | 1 | Y1 | 贴片晶振 |
