老吴 发表于 2020-9-26 22:33
全网首发MT6735M MTK6735M 智能手机PCB文件和原理图共享(MT6611
NamePCB DecalValuePart TypeANT3301ELJ_DZ_F2POGO PINELJ_DZ_F2ANT3302ELJ_DZ_F2POGO PINELJ_DZ_F2ANT3401ELJ_ANTPTH_LTPG-PT0H43-CB01ELJ_ANTPTH_LTPG-PT0H43-CB01ELJ_ANTPTH_LTPG-PT0H43-CB01B6003L0603BLM18BD252SN1B0603-2500RBEAD2001L0402BLM15BD102SN1DBEAD-0402BEAD5001B0402FB / BLM15AG601SN1FB_/_BLM15AG121SN1BEAD6010L0402BLM15BD102SN1DBEAD-0402BEAD6200R04020RBEAD-0402C1C0201AAL / 6.8 / nH / 0201C0201CN6001ELJ_CMUS-06505-097-03KM0004U5P-03-06ELJ_CMUS-06505-097-03CON1ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3FH26-39S-0.3ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3CON3301MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATACON3302ELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MMCON3401ELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MMCON6002ELJ_ADJ-312-P2.0-3.9X_H4.2ADJ-312-P2.0-3.9X(·´)ELJ_ADJ-312-P2.0-3.9X_H4.2D2000SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHMD6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45D6101SOD123MM1Z5VDIODE_SCHOTTKY_2D6102SOT23_3BAT54SBAT54SD6103SOD123MM1Z20VDIODE_SCHOTTKY_2D6108SOT23_3BAT54SBAT54SD6109SOD1231N5819DIODE_SCHOTTKY_2D6110SOD1231N5819DIODE_SCHOTTKY_2EMI6001FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1H1001PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MMJ23ELJ-KS270013ELJ-KS270013J25ELJ_HXQKTS-088_2_4HX-088 2*4ELJ_HXQKTS-088_2_4J26V30SIM(H3.0MM)ALP-SIMD618-01DUALSIMJ31ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5J32ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9NCELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9J6001ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85J6003REC_DYS-1506T2332-W01NCREC_DYS-1506T2332-W01J6006ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85J6101ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5J6102ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3FPC51P-0.3MMELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3J6502SOCKET-SIM-LK-SIM437-0615RS0DD-180006-01GSOCKET-SIM-LK-SIM437-0615RJ6503ELJ_YHTKP-1915-W_PHS_H1.9YHTKP-1915-CELJ_YHTKP-1915-W_PHS_H1.9J6601NC-PADX2-1X1.5NCNC-CON-2-0805J6602NC-PADX2-1X1.5NCNC-CON-2-0805L1L0201AAC / 1.2 / pF / 0201L0201L1302L04021.0nH_0.3nHL0402-1N0L2000L25200.33uH_252012L2520-22UL2001L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L/IND/SMD/VLS201610EL6101MPH252012NRH2410T4R7MNMPH252012L6103CD4310uHIND-CD43L6105MPH252012NRH2410T4R7MNMPH252012LED6201FLASHLED_SMD_EFF-D8CA-POOTFLASH LEDFLASHLED_SMD_EFF-D8CA-POOTMARK1000MARK_ALLDNIMARK_ALL_AMARK1001MARK_ALLDNIMARK_ALL_AMARK1002MARK_ALLDNIMARK_ALL_AMARK1003MARK_ALLDNIMARK_ALL_ANTC2000R0402NTCG104EF104FRES0402NTC3201R0402AANTC / NTCG064EF104FR0402-0RQ6101SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-DQ6102SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-DQ6103SOT23_3WPM2026IRF5210/TO_6Q6104SOT23_3MMBT3904NPN_BECSH2100KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7SH6100NC_SHORT_0402NC_SHORT_0402SHORT1KLINK_NO_PAD_0.1MM_LAYER7AASHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7TP1BAT_CON_2.2X3NFBAT_CON_2.2X3TP_MCU_JTMSTP/SMD/0.5MMTP_0.5TP_SYSRST_BTP/SMD/0.5MMTP_0.5TP_URXD1101TP_1.0TP1.0MMTP_UTXD1101TP_1.0TP1.0MMU2DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY1G74BC0B0ADUPLEXER/8P/SMD/SAYEY710MBA0F0AU1000MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735MMT6735/VFBGA641/P0.4/B0.25/12.6X12.6U2001FAN54015FAN54015U2002MT6328/VFBGA206/P0.4/B0.25/6.6X6.6MT6328V/AMT6328/VFBGA206/P0.4/B0.25/6.6X6.6U2305CP2155CP2155DN10-A1CP2155U3001FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bFBGA178/SMD/B0.4/3-IN-1U3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBAU3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U310226M_VTCXO_2520_2016_T_VVTCXO / 26 / MHz / KT2520F26000DCW28QAK26M_VTCXO_2520_2016_T_VU3203SKY77643SKY77643/HRSMAC001/RF5410SKY77643U3215BALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBBALUN/SMD/HHM22112A2U3302RF1628SPDT / RF1628ARF1628U3303RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2U3304DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY806MBA0F0ASAW-DPX-RX-BAL_2U3306SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYRF1G95CA0B0AR05SAW-SAYRF1G73CA0F0A-2016-1814U3307SKY77910SKY77910/HRTXAB008/RF5210SKY77910U3308SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYFH2G53CCOFOASAW-SAYRF1G73CA0F0A-2016-1814U3309DUPLEXER/8P/SMD/SAYEY710MBA0F0ANC SAYEY1G74BC0B0ASAW-DPX-RX-BAL_2U3311DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY710MBA0F0ASAW-DPX-RX-BAL_2U3312DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAYEY1G88BA0B0ASAW-DPX-RX-BAL_2U3315SAFEA2G60MA0F0ASAW / SAFEA2G60MA1F0ASAFEA2G60MA0F0AU3316SAW-SAYRF1G73CA0F0A-2016-1814SAYEY897MCA0B0ASAW-SAYRF1G73CA0F0A-2016-1814U3318BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_2U3329SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3338BALUN/SMD/TFSZ06052460-3310A2TFSZ06051897-3317A1BALUN/SMD/TFSZ06052460-3310A2U3339BALUN/SMD/TFSZ06052460-3310A2TFSZ06051897-3317A1BALUN/SMD/TFSZ06052460-3310A2U3401SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB2G14FA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3402SKY13414SP5T / SKY13416IC/SP6T/SKY13416_0U3408SAWFILTER/SMD/F6QB2G595P2BSSAW / B9898SAWFILTER/SMD/SAFFB1G90FB0F0AU3410BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2U3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB710MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB806MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0AU3420SAWFILTER/SMD/F6QB2G595P2BSSAW / SAFFB2G60AA1F0ASAWFILTER/SMD/F6QB2G595P2BSU3468BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_1U3474RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2U5101MT6625/SQFN40/SMD/P0.4/5X5U / MT6625L / QFN40MT6611_SMD_WLCSP-61_0U5102SAFEB1G57KE0F00NC SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATAU5103MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIMU5104KLJ_TPX205950MT-7110A1_1.1X2X0.9TRPX / TDK TPX205950MT-7110A1KLJ_TPX205950MT-7110A1_1.1X2X0.9U5105SAW-1411FBAR / ACPF-7124SAFEB1G57KA0F00U6103SOT23_6CP2121ST-B2/TCS23352AP3031_0U6105SOT23_5WD1013EA/TCS4150-ETCS4150-EU6109SOT23_6EUP2530/CP2123ST-B1AP3031_0U6305CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMU6401M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7U6402STK3171STK3171STK3171U6403TLE4917-TSOP-6-2OCH168TLE4917U6404BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCHU6705GSL915GSL3670DGSL915VR2001R0402SFI0402-180E10RPP-LFVR0402VR2002R0402SFI0402-180E10RPP-LFVR0402VR2003SOD323/SMD/MM3Z2V4T1NC PTVSHC3D4V5BPTVSHC3D4V5BVR6000MLV0402SFI0402-180E10RPP-LFVAR_0402VR6001MLV0402SFI0402-180E10RPP-LFVAR_0402VR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6004R0402SFI0402-180E10RPP-LFVR0402VR6005R0402SFI0402-180E10RPP-LFVR0402VR6006R0402EZJZ0V500AAVR0402VR6015R0402SFI0402-180E10RPP-LFVR0402VR6026ESD5641D07NC ESD5641D07ESD5641D07VR6501R0402EZJZ0V500AAVR0402VR6502R0402EZJZ0V500AAVR0402VR6503R0402EZJZ0V500AAVR0402VR6504R04020_5%VR0402VR6505R0402SFI0402-180E10RPP-LFVR0402VR6506R0402SFI0402-180E10RPP-LFVR0402VR6516R0402EZJZ0V500AAVR0402X2000CRYS/SMD/3.2X1.5/9H032000XX/TXCNC 32.768KHz¡À20ppmCRYS/SMD/3.2X1.5/9H032000XX/TXCX510126M_TCXO_2520TC7L26002015_2016L26421NC TCXO / 26 / MHz / IT2205AE26M_TCXO_2520TC7L26002015_2016L26421Z1BALUN/10P/SMD/BD2012RFBLN2012090BM6T16BAL_/_RFBLN2012090BM5T25Z3101BALUN/10P/SMD/BD2012RFBLN2012090BM6T16BAL_/_RFBLN2012090BM5T25
老吴 发表于 2020-9-26 22:36
全网首发资料,5RMB下载。有需要的下载。没需要的看看就好。
kanxue_nmg 发表于 2020-9-27 07:53
wangy2000 发表于 2020-9-27 07:53
谢谢分享
love欣 发表于 2020-9-27 08:00
bidinghong 发表于 2020-9-27 08:14
小鑫鑫 发表于 2020-9-27 08:27
清心如水 发表于 2020-9-27 08:31
zeosv 发表于 2020-9-27 08:38
好好学习,天天向上
wangyitu 发表于 2020-9-27 08:41
这个机型用的多吗~
页: [1] 2 3 4 5
查看完整版本: 全网首发MT6735M MTK6735M 智能手机PCB文件和原理图共享(MT6611
