MTK MT7621 无线路由器 AP PCB和原理图共享
NamePart TypePCB DecalValueCT19CAPACITOR_POLCE_AX_6R3330uF/6.3VD4DIODE_SCHOTTKY_2SOD-123APFM6.0AD7LED/0603_1LED_2PIN_2R54LED_GREEND11DIODE_SK34AD/SMD/P3.325/SOD-123/1N41481N4148/NLD1440CPQ060/TO_1SOT-23BAT54C:NCD15LED/0603_1LED_2PIN_2R54LED_GREEND17LED/0603_1LED_2PIN_2R54LED_GREEND20LED/0603_1LED_2PIN_2R54LED_GREEND25LED/0603_1LED_2PIN_2R54LED_BLUED26LED/0603_1LED_2PIN_2R54LED_REDF1FUSE_0MINISMDC300F-2NANOSMDC075F-2J1WIFI_MODULEWIFI_5CMX3CMWIFI_MODULEJ6CON3DC-005ADC JACKJ8USB3_CONNUSB3.0/9P/DIP/MAINSUPERUSB3.0 TypeA_CONNJ454_HEADERSIP_4PIN_1R274 HEADERJ505BATTERY_SOCKETCR2032_SBattery Socket:NCJ5064_HEADERSIP_4PIN_2R04 HEADERJ5074_HEADERSIP_4PIN_2R04 HEADERJ508WAFER_6PIN_SOCKETSMD_JF6_S_1R25WAFER_6PIN_SOCKETJM2MMC_1TF_SLOT_PUSHPUSHTF_SLOT_PUSH_AU1UL360INDUCTORL06030L361INDUCTORL0402Bead,0402L729INDUCTOR_1SLPS40181.8uH 2.5AL730INDUCTOR_1SLPS40181.8uH 2.5AL732INDUCTOR_1SLPS40182.2uH 1.5A:NCRC1CAP/0603C080510uFS3SW_PUSHBUTTONSW-TACT\4.5MMIT-1102VS4SW_PUSHBUTTONKEY-SMDIT-1102VT300XMER_2P_G2PM109NTRANSFORMER/48P/SMD/GS5014LFGS5014T301XMER_2P_G2PM109NTRANSFORMER/48P/SMD/GS5014LFGS5014U6MT7621MT7621/LFBGA346/P0.65/B0.3/11.7X13.6MT7621U8SPIFLASH-WINBOND25P16_1SOP8/SMD/P1.27/MX25L3206EMX25L6406EM2IU17LDO_RT9164A-SOT223_1SOT223-3/SMD/P2.3/AX1007ZTP1117SAU19IRLML5103_1SOT23-5XC6210B122MRU23XTAL_3.2X2.5XTAL-SMD/3.2X2.5NC:40MHzU24XTAL_3.2X2.5XTAL-SMD/3.2X2.525MHz/NIU26F4P-2012/0402_2FILTER/4P/SMD/TCF0504H90002ATCF0504U30002:NCU27F4P-2012/0402_2FILTER/4P/SMD/TCF0504H90002ATCF0504U30002:NCU83IC_DET_SOT-143/SC-82ABSOT-143/SMD/G693G693L_R3132Q/NLU86RT9715AGBG_6SOT23-6SY8009BABCU400IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/MICRONDDR3-128Mx16U404HEADER_4X2_0SOP-8AT88SC0104U406HY991101CMJ88MJ88-BX11-HRVS2U1207RT9715AGBG_6SOT23-6SY8009BABCU1211RT9293B_0SOT23-5RT8059GJ5:NCU1212MCU_8PINSOP-8MCU_8PINU1213HYM8563SOP-8HYM8563:NCU1215HY991101CMJ88MJ88-BX11-HRVS2U1216HY991101CMJ88MJ88-BX11-HRVS2U1217IRLML5103_1SOT23-5XC6210B332MRY1CRYSTAL_0JU-2632.768KHz 20ppM:NC PCB 和原理图一起打包。回复可见下载。
**** Hidden Message ***** 学习 这是矿机吗 多谢分享
