老吴 发表于 2020-10-4 23:40
MTK MT2523G参考板PCB和原理图共享和MT2523D原理图共享
NamePart TypePCB DecalValueANT5001ANTENNA_11PAD/SMD/2.3X1.0ANT sprintANT5002ANTENNA_11PAD/SMD/2.3X1.0ANT sprintBAT5201ML621SC0.22F3.3V/SMD/EN-RLML621SBEAD6001BEADBEAD0402L / BLM15AG100SN1 / 0402BEAD6004BEADBEAD0402L / BLM15BD182SN1 / 0402BEAD6007BEADBEAD0402L / BLM15BD182SN1 / 0402BEAD6010BEADBEAD0603L / BLM18BD252SN1 / 0603BEAD6011BEADBEAD0603L / BLM18BD252SN1 / 0603BEAD6012BEADBEAD0603L / BLM18BD252SN1 / 0603CON2101JMP3_2DIP6/P2.54HEAD_6PCON4101CON_/_12_/_TA-M017-012-07-811MICROSD/8P/SMD/TA-M017-012-07-811CON / 12 / TA-M017-012-07-811CON5001TST_PORT_0MM8430-2600BCar_Kit / MM8430-2610CON5203TST_PORT_0MM8130-2602Car_Kit / MM8130-2600CON6001JACK_CON/5P/EJ-3699M-GPAUDIOJACK/5P/SMD/EJ-3699M-GPJACK_CON/5P/EJ-3699M-GPCON6101QTH-060-01-F-D-A_(120_PIN)QTH-060-01-F-D-AQTH-060-01-FDA (120 pin)CON6102JUMPER_10X2_DIP/P2.54DIP10X2/P2.54JUMPER 10x2 DIP/P2.54CON6201CON20AP_1DIP7X2/P2.54HE7X2 MALE_TOPCON6301JUMPER_10X2_DIP/P2_1.54DIP12X2/P2.54JUMPER 12x2 DIP/P2.54CON6401USB_CON_MINI_AB_0MICROUSB/5P/SMD/P0.65/R/8791-N005-M1A0Proconn_8791-N005-M1A0CON6601USB_CON_MINI_AB_0MICROUSB/5P/SMD/P0.65/R/8791-N005-M1A0Proconn_8791-N005-M1A0CON6602CON20APJP10X2/P2.54/RHE10X2 RA HOUSINGD2001LED_1LED190CL190YGD2003LED_1LED190CL190YGD2004D_/_PMEG3015EH_1SOD323F/SMD/PMEG3015EHD / PMEG3015EHD2005D_/_PMEG3015EH_1SOD323F/SMD/PMEG3015EHD / PMEG3015EHD4101ESD_/_TVS_/_15PF_/_0402_0SOD923/SMD/AKESD5451NKM / NCD9209LED_1LED190LED_WhiteESD2101ESD_/_AZ5825-01FVR0402ESD / AZ5825-01F / NCESD2102ESD_/_AZ5325-01FVR0402ESD / AZ5725-01F / NCESD6401ESD_/_AZ5315-02FESD/SMD/AZ5315-02FESD / AZ5315-02FESD6402ESD_/_AZ5825-01FVR0402ESD / AZ5825-01FESD6601ESD_/_AZ5825-01FVR0402ESD / AZ5825-01FESD6602ESD_/_AZ5315-02FESD/SMD/AZ5315-02FESD / AZ5315-02FF2001FUSEFUSE/DIP/SMD2A FUSEF5001BL1608-05K2450_1DIPLEXER/6P/SMD/DP1608DP1608-V1524CAH2001PHONEJACK_2HOLE/PTH/R6D3.5STANDH2002PHONEJACK_2HOLE/PTH/R6D3.5STANDH2003PHONEJACK_2HOLE/PTH/R6D3.5STANDH2004PHONEJACK_2HOLE/PTH/R6D3.5STANDH2005PHONEJACK_2HOLE/PTH/R6D3.5STANDJ6106CON3_0R0402/(1-2)R / 0 / ohm / 0402-3P(1-2)L1101PL_/_MEKK2016T1R0M_/_SMD2016L/IND/SMD/2016PL / MEKK2016T1R0M / SMD2016L1102PL_/_MAKK2016T2R2ML/IND/SMD/MAKK2016PL / MAKK2016T2R2ML2002PL_/_MEKK2520T1R0ML/IND/SMD/2520PL / MEKK2520T1R0ML5001L_/_39_/_NH_/_0402L0402NCL5002L_/_39_/_NH_/_0402L0402NCL5201FERRITE_BEAD_SMD_0402L/IND/SMD/0402L / 3.3 / nH / 0402L5202INDUCTORL/IND/SMD/LQM2MPN1R0NG0L / 1 / uH / 0806L5203L_/_22_/_NH_/_0402L0402L / 22 / nH / 0402 / NCL5204L_/_5.6_/_NH_/_0402L0402L / 5.6 / nH / 0402LED6601LED_1LED190CL190YGMIC6001MIC_/_SPM0410HR5H-PB_0FILTER/SMD/SPU0410HR5H-PBMIC / SPU0410HR5H-PBMSC1MIC_/_PVN0109MIC/PAN-NUT/PVN0109MIC / PVN0109MSC2MIC_/_PVN0109MIC/PAN-NUT/PVN0109MIC / PVN0109MSC3MIC_/_PVN0109MIC/PAN-NUT/PVN0109MIC / PVN0109Q2101Q_/_PNMT6N1-LBDFN6/SMD/P0.65/PNMT6N1-LBQ / PNMT6N1-LBQ6602MOSFET_N_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ6603MOSFET_N_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9201MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9202MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9203MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9204MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9205MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVQ9206MOSFET_N_2_22-1L1B/SMD/SSM3K35MFVSSM3K35MFVSHORT2101NO_PAD_0402_SMD_1NC-4MILSHORT / NC-MMD-L6-4MILSHORT6001NO_PAD_0402_SMD_1NC-4MILSHORT / NC-MMD-L6-4MILSMA5001SMA_HSMA1SMA-1.66MMSMA5002SMA_HSMA1SMA-1.66MMSPK1MICSPEAKER/SMD/2403-260-00071SPK / 2403-260-00071-190-ENSW6501SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)SW6502SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)SW6503SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)SW6504SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)SW6505SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)SW6601SW_MEMBRANE_0SW/4P/SMD/SHOWMANKSW (DJT-1109S-2)TCXO5201TCXO_RAKON_SMD_4PTCXO/SMD/2.5X2.0/IT2205BETCXO / 16.368 / MHz / 7L16300006TP1001T_POINT_F_2TP30MILNCTVS6005TVS/SOD523SOD523/ESD5Z2.5T1ESD / 5Z5.0T1TVS6006TVS/SOD523SOD523/ESD5Z2.5T1ESD5Z5.0T1U1000MT2523GMT2523G/TFBGA246/P0.4/B0.25/9.2X6.0MT2523GU1101U_/_TPS62560_0SON6/SMD/P0.65/TPS62560TPS62560U2001U_/_TPS53318_/_SON22_0SON22/SMD/P0.5/TPS53318U / TPS53318 / SON22U2002RP110K081D-TRDFN0808/4P/SMD/RP110K081DRP110K081D-TRU2003U_/_TPS62560_0_2SON6/SMD/P0.65/TPS62560TPS780180300DRVU2004RP110K081D-TRDFN0808/4P/SMD/RP110K081DRP110K181B-TRU4001U_/_153_EMMC_/_H26M64103EMRFBGA153/P0.5/B0.27/11.5X13/SKHYNIXU / 153 eMMC / H26M64103EMRU5203_AME8812CEEVZ_SOT-25/SMDSOT23-5XC6210A332MRU5204RTCXTAL/2PRTC/SMD/2P/3.2X1.5FC-135 32.768KHZ 12.5pF / NCU5206SAFEB1G57KA0F00SAW/SMD/1.05X1.35U / EPOCOS_B8313U5207NJG1107HB3_0TSLP6/SMD/P0.4/BGA725L6/SBGA725L6U5208SAFEB1G57KA0F00SAW/SMD/1.05X1.35U / EPOCOS_B8313U6001U_/_TPA2010D1WCSP9/SMD/P0.5/B0.27/TPA2010D1U / TPA2010D1U660174ALVC164245_2QFN32/SMD/P0.5/98ARE10566DMK20DX128VFM5U6604CON_/_10_/_AXT510124_0DHVQFN14/SMD/P0.5/74LVC125ANXP_74LVC125AU6605X_/_26_/_MHZ_/_TZ2300A_0SOIC8/SMDATMEL_AT45DB161E-SHD2B-TX1101X_/_32_0.768KCRYSTAL/SMD/CM8V-T1AX / 32 / KHz / SC-20S / 7pFX5001X_/_26_/_MHZ_/_8Q26000008CRYS/SMD/D1.6X1.2/8Q26000008X / 26 / MHz / 8Q26000008X6601X_/_8_/_MHZ_/_S5032ACRYS/SMD/5X3.2/ABM3B-8.000MHZ-22-B2-TX / 8 / MHz / ABM3B-8.000MHZ-22-B2-T
老吴 发表于 2020-10-4 23:42
PCB 原理图和其他文档全部一起打包。回复可见下载。
**** Hidden Message *****
cityhu 发表于 2020-10-5 00:01
谢谢分享
nj20044 发表于 2020-10-5 00:19
mirage 发表于 2020-10-5 00:21
谢谢分享
清心如水 发表于 2020-10-5 06:44
kanxue_nmg 发表于 2020-10-5 06:46
hhbin634 发表于 2020-10-5 07:02
shuszhao 发表于 2020-10-5 08:48
yaodaoji 发表于 2020-10-5 08:59
谢谢分享
页: [1] 2 3 4 5 6 7
查看完整版本: MTK MT2523G参考板PCB和原理图共享和MT2523D原理图共享
