老吴 发表于 2020-10-7 21:29
飞思卡尔P1022 demo 板PCB和原理图 IBIS等资料共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECR1DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123MBR0540T1GSOD-123CR2DIODE_2PIN_SOD-123-480-30006-SOD123MBR140SFTSOD123CR3DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123MBR0540T1GSOD-123CR4DIODE_2PIN_SOD-123-480-75176-SOD123MBR0520LT1GSOD123CR5DIODE_2PIN_SOD-123-480-75176-SOD123MBR0520LT1GSOD123CR6DIODE_2PIN_SOD-123-TMP-WF-9174-SOD-123MBR0540T1GSOD-123D1LED_LED_0603_C1-370-75078-LED_0603_C1BLUELED_0603_C1F46FERRITE_IND_0603-180-75106-IND_060360 OHM 100MHZIND_0603GVDDTP_COLORS_TP040-210-75685-TEST_LOOPTEST POINT WHITETEST_LOOPJ1DDR3_240P_CON_240_DDR3_DIMM_SKT-TMP-WF-6058-CON_240_DDR3_DIMM_SKTCON_240_DIMMCON_240_DDR3_DIMM_SKTJ2CONN_DVI_RTANGLE_CONN_DVI_24POS_RA_TH-210-76354-CONN_DVI_24POSDVI_D_24CONN_DVI_24POSJ3CONN_RJ45_2X1VERT_LED_RA_CONN_RJ45_2X1VERT_LED-210-76036-CON_RJ45_2X1_MAG_LEDRJ45 13X2PORTSCON_RJ45_2X1_MAG_LEDJ4HDR_1X4_FRICTION_HEADER_1X4-210-79420-HDR4_2P54_THHDR 1X4 WLOCKHDR4_2P54_TH_CUSTJ5HEADER_1X2_WLOCK_HEADER_1X2-TMP-WF-12516-HDR102_EHDR 1X2 WLOCKHDR102_EJ6CONN_DF14_20P_125_20POS_CONN_1X20_RA_SMT-211-75624-CONN_1X20_RA_SMTCON_20CONN_1X20_RA_SMTJ7PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049-CONN_2X32_THRUHOLEPCI EXPRESS 64CONN_2X32_THRUHOLEJ8PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049PCI EXPRESS 64CONN_2X32_THRUHOLEJ9PCIEXPRESS_CONN_X4_PEX_4X_VERT-210-76049-CONN_2X32_THRUHOLEPCI EXPRESS 64CONN_2X32_THRUHOLEJ10CONN_MINIPCIE_RA_SMT-211-78711-CON_2X26_0P8_SMTCON 2X26 MINI PCIEXPRESSCON_2X26_0P8_SMTJ11HDR_2X5_SHROUDED_HDR_2X5-210-76356-HDR205_4WCON_2X5HDR205_4WJ12CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SMHDR 1X7CON_7_SATA_V_SMJ13CONN_SATA_7PIN_VERT_SATA_VERT-211-75318-CON_7_SATA_V_SMHDR 1X7CON_7_SATA_V_SMJ14CONN_SDC013_19P_CON19_SDCARD_28X16_SM-TMP-WF-6202-CON19_SDCARD_28X16_SMCONN CRD 19CON19_SDCARD_28X16_SMJ15CONN_SDC013_19P_CON19_SDCARD_28X16_SM-TMP-WF-6202-CON19_SDCARD_28X16_SMCONN CRD 19CON19_SDCARD_28X16_SMJ16HEADER_2X5_HEADER_2X5-210-76042HDR_2X5HDR205J17PCIEXPRESS_CONN_X16_CONN_PCIEXPRESS16-210-76047-CONN_PCIEXPRESS16PCI EXPRESS 164CONN_PCIEXPRESS16J18ATXPWR_2X12VERT_NOPEG_ATXPWR_2X12_VERT-TMP-WF-6398CON_2X12_PWRCON_ATXPWR_2X12_AJ19HEADER_2X5_HEADER_2X5-210-76042-HDR205HDR_2X5HDR205J20HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102J21HEADER_1X2_HEADER_1X2-210-76037-HDR102HDR 1X2HDR102J22HEADER_1X3_HEADER_1X3_PTH-210-76038HDR_1X3HDR103J23HEADER_RISCWATCH_HEADER_RISCWATCH-210-30058-HDR208_BCON_2X8HDR208_BJ24HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102J25CONN_MEC6_DV_2X20_STRAIGHT-TMP-WF-9353-CONN2X20_20X7MMCONN MICRO EDGE 2X20CONN2X20_20X7MMJ26CONN_DUAL_DE9M_STACKED_RA_CONN_DUAL_STACKED_DB9-210-76331-DUALDB-9M_RA2XDB9DUALDB-9M_RAJ27ATXPWR_12V_2X2VERT_CONN_ATX12V_2X2-211-30025-CONN_ATX12V_2X2CON_2X2CONN_ATX12V_2X2J28SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J29SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J30CONN_BATTERY_VERT_BATTERY_VERT-801-75534-SKT_BAT_225X886_3VWBA-3B2 USKT_BAT_225X886_3VJ31HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102J32HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_THHDR 1X3HDR1X3_THJ33CONN_SMA_CONN_SMA-210-30138-CON_SMACON 1 SMACON_SMAJ34SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J35HEADER_1X2_HEADER_1X2-210-76037HDR 1X2HDR102J36SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J37HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_THHDR 1X3HDR1X3_THJ39HDR_1X3_FRICTION_HEADER_1X3-TMP-WF-10415-HDR1X3_THHDR 1X3HDR1X3_THJ40CONN_8PIN_SMT_RA_CON20-211-77725-CONN_HDR_RA853261-0871CONN_HDR_RA8J41SIG_TIE_100X200_SIG_TIE-211-78786-SIG_TIE_100X200PLANE SHORT TIESIG_TIE_100X200J42HDR_2X4_TH-TMP-WF-12518-HDR_2X4_SHRD_THCON 8 PLUGHDR_2X4_SHRD_THL1INDUCTOR_IND_IHLP-TMP-WF-9765-IND_IHLP-50500.47UHIND_IHLP-5050L2INDUCTOR_IND_0806-TMP-WF-10412-IND_0806_SM4.7UHIND_0806_SML3INDUCTOR_IND_0806-TMP-WF-10412-IND_0806_SM4.7UHIND_0806_SML4INDUCTOR_IND_IHLP-180-75018-IND_IHLP2.2UHIND_IHLPL5INDUCTOR_4PIN_CHOKE_0805-180-75108-CHOKE_080590OHMCHOKE_0805L6INDUCTOR_4PIN_CHOKE_0805-180-75108-CHOKE_080590OHMCHOKE_0805L7INDUCTOR_IND_IHLP-TMP-WF-4949-IND_IHLP1UHIND_IHLPL8INDUCTOR_IND_IHLP-TMP-WF-4949-IND_IHLP1UHIND_IHLPL9INDUCTOR_IND_IHLP-TMP-WF-6346-IND_IHLP0.68UHIND_IHLPMH1MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH2MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH3MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH4MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH5MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH6MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH7MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHMH8MOUNTING_HOLE_ATX_MTG156_PTH-TMP-WF-3725MOUNTING HOLEMTG156_PTHOVDDTP_COLORS_TP040-210-75685-TEST_LOOPTEST POINT WHITETEST_LOOPQ1MOSFET_N_8P_PG-TDSON-8-TMP-WF-10090-TDSON8_1P27_6X5MMBSC080N03MSGTDSON8_1P27_6X5MMQ2MOSFET_N_8P_PG-TDSON-8-TMP-WF-10090-TDSON8_1P27_6X5MMBSC080N03MSGTDSON8_1P27_6X5MMQ3MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q4MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q5MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23Q6MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23Q7MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23Q8MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q9MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q10MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23Q11MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q12MOSFET_N_8P_PG-TDSON-8-TMP-WF-9764-TDSON8_0P65_SQ3P4BSZ035N03LSGTDSON8_0P65_SQ3P4Q13MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23Q14TRANSISTOR_PNP_SOT23-480-76358-SOT23MMBT2907ASOT23Q15FDV301N_NFET-480-30061-SOT23-40X40FDV301NSOT23-40X40Q16IRF7821_SO8-480-30 027-SO_8_1P27_4X5IRF7821PBFSO_8_1P27_4X5Q17MMBT3904_SOT23-480-75757-SOT23MMBT3904SOT23SW1SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM218-8LPSTSW_DIP16_8POS_SMSW2SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM218-8LPSTSW_DIP16_8POS_SMSW3SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM218-8LPSTSW_DIP16_8POS_SMSW4SW_8SPST_SW_SOM16-510-30020-SW_DIP16_8POS_SM218-8LPSTSW_DIP16_8POS_SMSW5SW_8SPST_SW_SOM16-510-30020218-8LPSTSW_DIP16_8POS_SMSW6SW_8SPST_SW_SOM16-510-30020218-8LPSTSW_DIP16_8POS_SMSW7SW_8SPST_SW_SOM16-510-30020218-8LPSTSW_DIP16_8POS_SMSW8SW_8SPST_SW_SOM16-510-30020218-8LPSTSW_DIP16_8POS_SMSW9SW_8SPST_SW_SOM16-510-30020218-8LPSTSW_DIP16_8POS_SMSW10SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SMG3B15AH-XC-ROSW_3P_7P5X8P5_RA_SMSW11SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SMG3B15AH-XC-ROSW_3P_7P5X8P5_RA_SMSW12SW_1SPDT_SW_SM_SPDT_RA-510-30041-SW_3P_7P5X8P5_RA_SMG3B15AH-XC-ROSW_3P_7P5X8P5_RA_SMTP1TP_SMT_TPAD_015-TMP-WF-3724-TPAD_015TPAD_015TPAD_015TP100TP_COLORS_TP040-210-75683TEST POINT BLACKTEST_LOOPTP101TP_COLORS_TP040-210-75683TEST POINT BLACKTEST_LOOPTP103TP_SMT_TPAD_015-TMP-WF-3724-TPAD_015TPAD_015TPAD_015TP105TP_PTH_TP_PTH-TMP-WF-3719TP_PTHTP_PTHU1OSC_4PIN_7X5MM-230-77750-7X5MM11.2896MHZ7X5MMU27SZ08P5_SC70-5P-312-30302-SC70-5NC7SZ08P5SC70-5U3TXB0102_SOT70_8-TMP-WF-11423-PSOP8TXS0102PSOP8U4WM8776_TQFP48-TMP-WF-11277-TQFP48WM8776SEFTTQFP48U5OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_533.333MXTLOSC4_5X7_5U6OSC_4PIN_XTLOSC4_5X7_5-230-7548214.318MHZXTLOSC4_5X7_5U7ICS9FG108_TSSOP48-312-75881ICS9FG108TSSOP48U8P1022_TEPBGA689_1MM_31X31-TMP-WF-10934-TEPBGA689_1MM_31X31P1022TEPBGA689_1MM_31X31U9ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6ZL6100QFN36_0P5_6X6U10VSC8601_LQFP-312-77544-LQFP64_TAB_SQ158VSC8601XKNLQFP64_TAB_SQ158U11VSC8601_LQFP-312-77544-LQFP64_TAB_SQ158VSC8601XKNLQFP64_TAB_SQ158U12TI_TFP_410_64HTQFP-312-75880-64HTQFPTFP410PAP64HTQFPU13TXB0102_SOT70_8-TMP-WF-11423-PSOP8TXS0102PSOP8U1474ALVCH16373_TSSOP48-312-79574-TSSOP48_PH74ALVCH16373DGGRG4TSSOP48_PHU1574ALVCH16373_TSSOP48-312-79574-TSSOP48_PH74ALVCH16373DGGRG4TSSOP48_PHU16S29GL01GP_TSOP56-342-00096-TSOP56S29GL01GP11TFIR1TSOP56U178G_FLASH_1024MX8_TSOP_48P-TMP-WF-11658-TSOP48_12X20NAND08GW3B2CN1ETSOP48_12X20U18PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5PI3B16226BQSOP40_0P5U19PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5PI3B16226BQSOP40_0P5U20SN74LVC1G125_SC70-5P-312-75240-SC-70SN74LVC1G125DCKRSC-70U21TPS54310_HTSSOP20-312-75584-HTSSOP20TPS54310HTSSOP20U22TPS72515_DDPAK5-315-75431-DD-PAK5_420X625TPS72515KTTRDD-PAK5_420X625U2374LVT244_TSSOP20-312-75186-TSSOP2074LVT244APWTSSOP20U24DS90C387_TQFP100-312-75872-TQFP100DS90C387TQFP100U25TPS72515_DDPAK5-315-75431-DD-PAK5_420X625TPS72515KTTRDD-PAK5_420X625U26PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TABPI2PCIE2412TQFN42_TABU27PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TABPI2PCIE2412TQFN42_TABU28PI2PCIE2412_TQFN42_TAB-TMP-WF-4990-TQFN42_TABPI2PCIE2412TQFN42_TABU29OSC_4PIN_XTLOSC4_5X7_5-230-75794-XTLOSC4_5X7_533.333MXTLOSC4_5X7_5U30SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16SN74CB3Q3253TVSOP16U31A3P600_FGG484_BGA484_1MM-TMP-WF-7981-BGA_484_1MM_23X23A3P600-FGG484BGA_484_1MM_23X23U32IDTQS3VH257_TSSOP16-312-75284IDTQS3VH257PATSSOP16U33ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6U34ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6U35ECLAMP2357N_QFN16_3X3MM_1P6-312-76061-QFN16_3X3MM_1P6ECLAMP2357N.TCTQFN16_3X3MM_1P6U36S25FL128P_WSON_8-WSON_8S25FL128PWSON_8U37LT1331_SSOP28-312-75272-SSOP28LT1331CG#PBFSSOP28U38VBUS054B_LLP75_6A-TMP-WF-7575-LLP75_6AVBUS054B-HS3-GS08LLP75_6AU39USB3315C_QFN24-312-79159-QFN24_4X4MM_SLUGUSB3315QFN24_4X4MM_SLUGU40USB3315C_QFN24-312-79159-QFN24_4X4MM_SLUGUSB3315QFN24_4X4MM_SLUGU4174LVCH32244A_LFBGA_ZKE-312-75347-LFBGA-GKESN74LVCH32244AZKERLFBGA-GKEU4274LVCH32244A_LFBGA_ZKE-312-75347-LFBGA-GKESN74LVCH32244AZKERLFBGA-GKEU43SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70U44ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6ZL6100QFN36_0P5_6X6U45TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P61.8V/1.0ADDPAK5_1P7_10P6U46TPS72525_DDPAK5-315-75313-DDPAK5_1P7_10P6TPS72525DDPAK5_1P7_10P6U47OSC_4PIN_XTLOSC4_5X7_5-TMP-WF-6271-XTLOSC4_5X7_525MHZXTLOSC4_5X7_5U48PI3B16226BE_BQSOP40_0P5-TMP-WF-11069-BQSOP40_0P5PI3B16226BQSOP40_0P5U49TPS72518_DDPAK5-315-75312-DDPAK5_1P7_10P61.8V/1.0ADDPAK5_1P7_10P6U50AT24C64A_SO8-334-76379-SO_8AT24C64CSO_8U51TPS72525_DDPAK5-315-75313-DDPAK5_1P7_10P6TPS72525DDPAK5_1P7_10P6U52ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6ZL6100QFN36_0P5_6X6U53DS3232_SO20W-TMP-WF-6280-SO20WDS3232SO20WU54AT24C64A_SO8-334-76379-SO_8AT24C64CSO_8U55OSC_4PIN_XTLOSC4_CB3_SM-230-76093-XTLOSC4_CB3_SM12.288MHZXTLOSC4_CB3_SMU56ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5ICS8304AMLFSO8_1P27_4X5U57TPS74801_QFN20_THIN-315-78227-QFN20_THINTPS74801QFN20_THINU58ICS307_02_SO16-312-75752ICS307M-02SO16U59ICS307_02_SO16-312-75752ICS307M-02SO16U60OSC_4PIN_XTLOSC4_710_SM-230-75349-OSC4-86X79-EH26125MHZOSC4-86X79-EH26U61OSC_4PIN_7X5MM-TMP-WF-6976-7X5MM24.000MHZ7X5MMU62ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5ICS8304AMLFSO8_1P27_4X5U63ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5ICS8304AMLFSO8_1P27_4X5U64TPS51200_QFN_10-TMP-WF-9510-QFN_10_0P5_3X3TPS51200QFN_10_0P5_3X3U65SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5SN74LVC1G86SOT-23-5U66SN74LVC1G86_SOT23_5P-312-75582-SOT-23-5SN74LVC1G86SOT-23-5U67HEADER_2X25_05SP_HEADER_2X25_05SP_SMT-211-75181-CON_FTR-125-01-S-DHDR_2X25CON_FTR-125-01-S-DU68SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16SN74CB3Q3253TVSOP16U697SZ08P5_SC70-5P-312-30302-SC70-5NC7SZ08P5SC70-5U70NC7SB3157_SC70-6XP-312-30204-SC70-6NC7SB3157SC70-6U71NC7SB3157_SC70-6XP-312-30204-SC70-6NC7SB3157SC70-6U72MIC2076_1YM_SO8-312-75935-SOP8-1MIC2076-1YMSOP8-1U73ADG804_MSOP10-TMP-WF-9815-MSOP10_60X12ADG804YRMMSOP10_60X12U74ADG804_MSOP10-TMP-WF-9815-MSOP10_60X12ADG804YRMMSOP10_60X12U75ZL6100_QFN36-TMP-WF-11807-QFN36_0P5_6X6ZL6100QFN36_0P5_6X6U76SN74CB3Q3253_TVSOP16-TMP-WF-9400-TVSOP16SN74CB3Q3253TVSOP16U77IDTQS3VH257_TSSOP16-312-75284-TSSOP16IDTQS3VH257PATSSOP16U78AT24C02_TSSOP8-334-75798-TSSOP8AT24C02B-TH-BTSSOP8U79ADT7461_SO8-901-30002-SO8ADT7461SO8U80AT24C02_TSSOP8-334-75798-TSSOP8AT24C02B-TH-BTSSOP8U81LM96163_QFN10-312-79078-QFN10_0P5_3X3LM96163QFN10_0P5_3X3U82ICS8304_SO8_1P27_4X5-312-75767-SO8_1P27_4X5ICS8304AMLFSO8_1P27_4X5U83NC7SB3157_SC70-6XP-312-30204-SC70-6NC7SB3157SC70-6U8474CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U8574CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U8674CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U8774CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U8874CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U89SN74LVC1G04_SOT_5P-312-75339SN74LVC1G04DCKRE4SC-70U9074CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9174CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9274CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9374CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9474CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9574CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5U9674CBTLV1G125DBV_SOT23_5P-312-75233-SOT23-5SN74CBTLV1G125DBVRSOT23-5VDDTP_COLORS_TP040-210-75684-TEST_LOOPTEST POINT REDTEST_LOOPVDDCTP_COLORS_TP040-210-75684-TEST_LOOPTEST POINT REDTEST_LOOPVDDXTP_COLORS_TP040-210-75684-TEST_LOOPTEST POINT REDTEST_LOOP
老吴 发表于 2020-10-7 21:42
所有资料一起打包。
**** Hidden Message *****
chery 发表于 2020-10-7 21:54
感谢分享
lc_ 发表于 2020-10-7 22:06
感谢分享
hbjsss 发表于 2020-10-7 22:42
nj20044 发表于 2020-10-8 00:32
cityhu 发表于 2020-10-8 00:36
谢谢分享
kanxue_nmg 发表于 2020-10-8 06:40
yushibin 发表于 2020-10-8 06:41
清心如水 发表于 2020-10-8 07:26
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 飞思卡尔P1022 demo 板PCB和原理图 IBIS等资料共享
