10层2介HDI盲埋孔 MT6735方案智能手机PCB文件
NamePCB DecalValuePart TypeANT100ANT_AOSP-110501-01GANT_AOSP-110501-01GB0901B0402BLM15HG102SN1B0402CON0301RF-TEST_818000291818000291RF-TEST_818000291CON0401RF-TEST_818000291818000291RF-TEST_818000291CON1101AUDIO_PH19-2B05F35APH17-4B05F35BPH19-2B05F35ACS_NTP_1.0TPTP_1.0D0901SOD323-1PZ3D4V2HSOD323-1D1301SOD323_UDZS6.2BPMEG4010EJSOD323_UDZS6.2BDMTP_1.0TPTP_1.0DPTP_1.0TPTP_1.0F1FIDUCIALFIDUCIALFIDUCIALF2FIDUCIALFIDUCIALFIDUCIALF3FIDUCIALFIDUCIALFIDUCIALF4FIDUCIALFIDUCIALFIDUCIALF1201SAW_TP2012-A1255DATTP2012-A1255DATSAW_TP2012-A1255DATFPC1FPC-2PIN-2.5X0.4FPC-2PIN-2.5X0.4FPC1451FPC-2PIN-2.5X0.4FPC-2PIN-2.5X0.4FPC1452FPC-2PIN-2.5X0.4FPC-2PIN-2.5X0.4GNDTP_1.0TPTP_1.0J101RF_20369-001ERF-20369RF_20369-001EJ102ECF031025G-RECF031025G-RJ104USB_U06-6B05F253USB00910-416WJ0301RF_20369-001EECT818000500RF_20369-001EJ0902SIM/TF-S176-2B21F13FS176-2B21F13FJ1301FH26-31S-03SHWFH26-31S-03SHWFH26-31S-03SHWJ130313PIN-ZIFZIF_13PINJ1306FH26-31S-03SHWFH26-31S-03SHWFH26-31S-03SHWJ1307FPC_6PINFPC_6P_0425X08MMJ1401FH26-31S-03SHWFH26-31S-03SHWFH26-31S-03SHWJ1403FH26-31S-03SHWFH26-31S-03SHWFH26-31S-03SHWJ1442ZIF_6PECF051006GLB-3ZIF_6PL0901WPN252010HR33MTY010.33uH/2520WPN252010HR33MTY01L0902WPN201610HR47MT0.47uH/2016WPN201610HR47MTL0903WPN201610HR47MT0.47uH/2016WPN201610HR47MTL0904SPH201610HR47MT0.47uH/2016SPH201610HR47MTL0905VLS252010ET-2R2M2.2uH/2520VLS252010ET-2R2ML0999L/IND/SMD/25201.0uHINDUCTORL1202L02011pF/0201L0201L1208L040282nH/0402L0402L1210L02011pF/0201L0201L1301L/IND/SMD/LVS252010-2R210uHL/IND/SMD/LVS252010-2R2MIC1100CON2_1215X2MMMIC_NCMIC-SMDMT0901CON2_1015X18MMCON2_1015X18MMNTCTP_1.0TPTP_1.0NTC0201R0402100KR/NTCR0402PWRKEYTP_1.0VBUSTP_1.0Q1452SOT_DTC143ZMPNM723T201E0SOT_DTC143ZMREC1101CON2_1015X18MMCON2_1015X18MMSH1SH_10MILBSH_10MILBSH1106SH_10MILBSH_10MILBSI901MIC_NSM0402AT-ULMIC-1SPK100PAD_2PIN_1.5X0.6spk_NCCON2_1218X22MMSR1322ESD9B5VLESD9B5VLESD9B5VLT1ESD9B5VLESD9B5VLESD9B5VLT100ICVS0518270FRICVS0518270FRT0301ESD9B5VLESD9B5VLESD9B5VLT0901ESD9B5VLESD9B5VLESD9B5VLT1111ESD9B5VLESD9B5VLESD9B5VLT1190ICVS0518270FRNCICVS0518270FRT1191ICVS0518270FRNCICVS0518270FRT1314ESD9B5VLESD9B5VLESD9B5VLT1315ESD9B5VLESD9B5VLESD9B5VLT1316ESD9B5VLESD9B5VLESD9B5VLT1317ESD9B5VLESD9B5VLESD9B5VLT1320ESD9B5VLESD9B5VLESD9B5VLTP203TP60MILNAT_POINT_60MILTP204TP60MILMAT_POINT_60MILTP0905TP60MILMBNTCTP60MILTP0906TP60MILMBAAVBATTP60MILTP0907TP60MILNBAMIN_GNDTP60MILTP1340TP_1.0MMSDATP_1.0MMU100BGSA14GN10BGSA14GN10U0101MT6169MT6169U0102VCTCXO_2520NCVCTCXO_2520U0201QFN_PA_AP7219SKY77643/AP7219QFN_PA_AP7219U0202SAW/UNBALANCE/1109NCSAW/UNBALANCE/1109U0301QFN_PA_AP6716AP6716QFN_PA_AP6716U0302DPX/1814SAYEY1G95HA0F0ADPX/1814U0303SAW-1109SAFFB1G84FL0F0ASAW-1109U0304BALUN/0605BALUN/0605U0305DPX/1814SAYEY1G74CA0B0ADPX/1814U0306DPX/1814SAYEY836MCA0F0ADPX/1814U0307DPX/1814SD18-2535R8UBM1DPX/1814U0308DPX/1814DPX / SAYEY897MCA0B0ADPX/1814U0309DPX/UNBALANCE/1814DPX/UNBALANCE/1814U0310BALUN/0605BALUN/0605U0312DPX/UNBALANCE/1814DPX/UNBALANCE/1814U0322DPX/1814SAYEY1G95HA0F0ADPX/1814U0399SOT_RDASW293CRDASW293CU0401QFN_AW9108AW9108QFN_AW9108U0408BALUN/0605BALUN/0605U0410BALUN/0605BALUN/0605U0412BALUN/0605BALUN/0605U0501MT6735/VFBGA641/P0.4/B0.25/12.6X12.6U / IC-MT6735-LP3-E1-SBS_MAP0827IC-MT6735-LP3-E1-SBS_MAP0827U0901MT6328/TMP/SMDU / MT6328E1IC/MT6328-E1/XXXMM_41U0999PSC5425PSC5425EPSC5425U1000FBGA221/P0.5/B0.27/11.5X13/SAMSUNGU / H9TP32A4GDCCPR-KGMxFBGA221/P0.5/B0.27/11.5X13/SAMSUNGU1101TQFN3X3-20-NS4733(AW8733ATQR)TQFN3X3-20-NS4733(AW8733ATQR)U1201MT6625/SQFN40/SMD/P0.4/5X5MT6625LNMT6611_SMD_WLCSP-61_0U1202TCXO_2520NCTCXO_2520U1203SAW/1411HDF1575A-B2SAW/1411U1204GPS_LNA_AR8159AR8159GPS_LNA_AR8159U1205SAW/1109SAW/1109U1301DFN_6L_AW9962AP3129BCT3756U1344QFN_AW9201QFN_AW9201U1401TDFN_SGM3141BSGM3141BTDFN_SGM3141BU1402MXC6255XCMXC6255XCMXC6255XCU1440SC7A20SC7A20VBATTP_1.0TPTP_1.0VBUSTP_1.0VBUSTP_1.0X0101TSX_3225RakonTSX_3225 PCB文件,没原理图。回复可见。
**** Hidden Message ***** PCB文件,没原理图。回复可见
