armclub 发表于 2020-12-8 12:58
阿凡达AVATARMIND TMS320F28069PZPQ +L6226Q 做的机器人主板PCB和原
NamePart TypePCB DecalValueD101LED-BLUE-0603-ELED0603Blue (0603)D102LED-BLUE-0603-ELED0603Blue (0603)D201DUALDIODECS-BAT46SW-SOT323SOT323BAT46SWD202D-RB060M-SOD123-RSOD123-RB060MRB060M-30D203D-RB060M-SOD123-RSOD123-RB060MRB060M-30D204DUALDIODECS-BAT46SW-SOT323SOT323BAT46SWD205D-RB060M-SOD123-RSOD123-RB060MRB060M-30D206D-RB060M-SOD123-RSOD123-RB060MRB060M-30D301DUALDIODECS-BAT46SW-SOT323SOT323BAT46SWD302DUALDIODECS-BAT46SW-SOT323SOT323BAT46SWD304D-RB060M-SOD123-RSOD123-RB060MRB060M-30D305D-RB060M-SOD123-RSOD123-RB060MRB060M-30D501TVS-P6SMB27AT3G-27V-OND_403A03-SMBP6SMB27AT3GD5021SMA13CAT3GD_403D2-SMA1SMA13CAT3GE520ESD9B5.0ST5GSOD-923ESD9B5.0ST5GICT522ICTPOINT_SQ0.8MMSQ0.8MM_SMTJ101HEAD-2.54-1X2HEAD-2P-2.54YMAW025-02RJ401CON-2.0-1X4CON4-2.0-ZL2001A4P-DIPZL2001-A-4PJ501WAFER-2.0-2X5WAFER-2.0-2X5WX5943205091J502DEBUG_HEAD_2.54_4PINTP4-2P54YMAW025-04R/NCJ503CONNECTOR_2X7_2.54HEAD-2X7-2.54J504WAFER-2.0-2X5WAFER-2.0-2X5WX5943205091J505WAFER-2.0-2X5WAFER-2.0-2X5WX5943205091J509CON-2.0-2X3CON3X2_8X5_2PZL2001-A-2×3PJ510WAFER-2.0-2X5WAFER-2.0-2X5WX5943205091J511CON-2.0-2X3CON3X2_8X5_2PZL2001-A-2×3PJ512CON-WX-2.5-2PDIP-2.5-2PWX-2.5-2PJ513CON-2.0-1X2CON2-2.0-ZL2001A2P-DIPYMAW025-02RJ514HEAD-2.54-1X3HEAD-3P-2.54J515HEAD-2.54-1X3HEAD-3P-2.54J516CON-2.0-1X2CON2-2.0-ZL2001A2P-DIPYMAW025-02RL101LP22U-68X68-2A1-20-TDKIND-6.8X6.8X4.5-VLP6045L22uHL201L22U-6.6X6.4X6.1-XAL6060IND-6.6X6.4X6.1-XAL6060NCL202L22U-6.6X6.4X6.1-XAL6060IND-6.6X6.4X6.1-XAL6060NCL301L22U-6.6X6.4X6.1-XAL6060IND-6.6X6.4X6.1-XAL6060NCL401LP22U-68X68-2A1-20-TDKIND-6.8X6.8X4.5-VLP6045L22uHLS1PTHCIR3.2_REC3.2X1PTHCIR3.2_REC3.5X2LS2LS-MH5.5_2.4MH5.5-3.4/NCLS3LS-MH5.5_2.4MH5.5-3.4/NCLS4LS-MH5.5_2.4MH5.5-3.4/NCQ201TD-2N5551S-NPN-SOT23-KECSOT23_3212N5551SQ202PMOS-AO3401-SOT23-AOSOT23_312AO3401Q203TD-2N5551S-NPN-SOT23-KECSOT23_3212N5551SQ204PMOS-AO3401-SOT23-AOSOT23_312AO3401Q301TD-2N5551S-NPN-SOT23-KECSOT23_3212N5551SQ302PMOS-AO3401-SOT23-AOSOT23_312AO3401Q401Q-NPN-PBSS2515E-SOT146SOT416_PBSS2515EPBSS2515EQ402MOS-P-DMP2215L-DSOT23_312DMP2215LQ403TD-2N5551S-NPN-SOT23-KECSOT23_3212N5551SQ404PMOS-AO3401-SOT23-AOSOT23_312AO3401SMT3SMTMARK_FIDUCIALPADSMTMARK_FIDUCIALPADTP101TP_1MMTP1MMTP102TP_1MMTP1MMTP103ICTPOINT_SQ0.8MMSQ0.8MM_SMTTP104ICTPOINT_SQ0.8MMSQ0.8MM_SMTU1IMP811SIMP811SU101LDO-RT9013-33PBSOT-23-5RT9013-33PBU102TPS54335DDA-SOP8SOP8+EPADTPS54335DDARU103TMS320F28069PZPQPQFP100-14X14-0P5TMS320F28069PZPQU105EEPROM_AT24C16-SO8SO8-4.9X3.9-1P27AT24C16U108TJA1040SOIC8-3.9X4.9-1P27SN65HVD1040U109U-TLV272-SOIC8-TISO8-4.9X3.9-1P27TLV272IDRU201L6226QVFQFPN32-5X5P0.5-L6226QL6226QU202L6226QVFQFPN32-5X5P0.5-L6226QL6226QU203TPS54335DDA-SOP8SOP8+EPADNCU204TPS54335DDA-SOP8SOP8+EPADNCU301L6226QVFQFPN32-5X5P0.5-L6226QL6226QU302L6226QVFQFPN32-5X5P0.5-L6226QL6226QU303TPS54335DDA-SOP8SOP8+EPADNCU40174LVC4245ATSSOP24-7.8X6.4P0.65MMU402LDO-RT9013-33PBSOT-23-5RT9013-33PBU403LDO-RT9013-33PBSOT-23-5RT9013-33PBU404TPS54335DDA-SOP8SOP8+EPADTPS54335DDARU405MAX3232SOP16MAX3232U406SN74HC86SN74HC86SN74HC86
armclub 发表于 2020-12-8 13:00
PCB 原理图。回复可见下载。
**** Hidden Message *****
love欣 发表于 2020-12-8 13:36
bidezhi7777 发表于 2020-12-8 13:39
liulei84 发表于 2020-12-8 15:06
感谢分享
zzr1974418 发表于 2020-12-8 18:37
丁响820425 发表于 2020-12-8 19:10
回 armclub 的帖子
armclub:PCB 原理图。回复可见下载。
[内容隐藏]
 (2020-12-08 13:00) images/back.gif
好东西啊啊
画玖先生 发表于 2020-12-8 19:57
lc601257251 发表于 2020-12-8 22:08
学海无涯 发表于 2020-12-9 08:12
看看,涨点见识。
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 阿凡达AVATARMIND TMS320F28069PZPQ +L6226Q 做的机器人主板PCB和原
