TSUMV59XU 液晶电视PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEA1AHOLE138_AHOLE138_AHOLE138AHOLE138AHOLE138CA9ELCAPD8_CD110D5L12_100U/16V/NC100u/16V/NCCD110D5L12CON1PHONOJACK_CK35-215_PHONOJACKPHONOJACKCK35-215CON3VGA_DB15-1_VGAVGADB15-1CON5VGA_DB15-1_VGAVGADB15-1D11N4148_LL34_1N41481N4148LL34D3SK34_0_DO214AA_SS24/NCSS24/NCDO214AAJ1HEAD1X2_2.5_PANEL POWER_SIP_JUHEAD1x2_2.5/NCSIP_JUMP2J2HEAD2X15_LVDS_HEADER2X15_2MM_LHEAD2x15_LVDSHEADER2X15_2MM_LVDSJ3HEAD1X3_0.5_PANEL POWER_SIP_JUHEAD1x3_2.5SIP_JUMP3-PANELPOWERJ4PH-6A_INVERTER_PH-6A-INVERTER_PPH-6APH-6A-INVERTERJ5PH-3A_PH-3A_PH-3APH-3APH-3AJ6XH-4A_SPEAKER_SE_PH-4A_PH-4A_SPPH-4A_SPEAKER_SEPH-4AJ7PH-14A_KEY&IR_3_PH-14A_KEY_IRBOPH-14APH-14A_KEY_IRBOARDJ8PH-4A_USB_PH-4A_USB_PH-4A_USB/NPH-4A_USB/NCPH-4A_USBJ9HEADER2X7_HEADER2X7_2MM_HEADERHEADER2x7HEADER2X7_2MMJ11DC3AIN_DC3AIN_DC3AINDC3AINDC3AINJ12PHONOJACK-PJ339_PJ-339_PHONOJACPHONOJACK-PJ339PJ-339J13HDMI_HDMI_HDMIHDMIHDMIJ14USB-H_USB_H_USB-HUSB-HUSB_HJ15PH-4A_PH-4A_PH-4APH-4APH-4AL3INDUCTOR_SMD_FB0402_0R0RFB0402L4INDUCTOR_SMD_FB0402_0R0RFB0402L5INDUCTOR_SMD_FB0402_0R/NC0R/NCFB0402L6INDUCTOR_L0810_WSA43-6R8M-RA_6.6.8uH/1.5AWSA43-6R8M-RAL7INDUCTOR_L0810_WSA43-6R8M-RA_4.4.7uH/3.1AWSA43-6R8M-RAL8FB0603_FB0402_600R/FB600R/FBFB0402L9FB0603_FB0402_600R/FB600R/FBFB0402L11INDUCTOR_R0402_180NH180nHR0402M1MARK_MARK_ORIENTPADorientpadMARKM2MARK_MARK_ORIENTPADorientpadMARKM3MARK_MARK_ORIENTPADorientpadMARKQ13401_SOT23L_34073407SOT23LQ2MMBT3904_SOT23_39043904SOT23Q3MMBT3904_SOT23_39043904SOT23Q43401_SOT23L_34073407SOT23LQ5MMBT3904_SOT23_MMBT3904MMBT3904SOT23Q6MMBT3904_SOT23_MMBT3904MMBT3904SOT23Q7MMBT3904_SOT23_MMBT3904/NCMMBT3904/NCSOT23Q8MMBT3904_SOT23_MMBT3904/NCMMBT3904/NCSOT23Q10MMBT3904_SOT23_MMBT3904MMBT3904SOT23TP1TESTPOINT_TEST1_5MM_3.3VU3.3VUTEST1_5MMTP2TESTPOINT_TEST1_5MM_5VA5VATEST1_5MMTP3TESTPOINT_TEST1_5MM_1.8V1.8VTEST1_5MMTP4TESTPOINT_TEST1_5MM_12VU12VUTEST1_5MMTP6TESTPOINT_TEST1_5MM_5VU5VUTEST1_5MMTP7TESTPOINT_TEST1_5MM_1.32VU1.32VUTEST1_5MMU1TPA1517P_DIP18_TPA1517PTPA1517PDIP18U2SY8120B_SOT23_6_SY8120BSY8120BSOT23_6U3LDO-1117_0_SOT223_BL1117-1.8BL1117-1.8SOT223U4FLASH25X32_SOP8_GD25Q32CGD25Q32CSOP8U5G5628_SOT23_5_SY8088SY8088SOT23_5U6LDO-1084_TO252_BL1117-1.2VBL1117-1.2VTO252U7TSUMV39LU_0_TSUMV39LU_EPTQFP_14TSUMV59XUTSUMV39LU_EPTQFP_14X14Y1CRYSTAL_XTAL_HC49_F_24MHZ24MHZXTAL_HC49_F PCB文件。回复可见下载
**** Hidden Message ***** 学习学习布局 挺好的 学习了啊
