老吴 发表于 2021-4-6 10:34
HI3556V200行车记录仪 PCB 和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1SD0402CD_ASD0402CD2HSD0603-LEDLEDHSD0603-LEDD3SOD323D_ASOD323D4SD0402CD_ASD0402CD5HSOD882PESD5V0S1BL315HSOD882D6HSOD882PESD5V0S1BL315HSOD882D7SD0402CD_ASD0402CD8SOD323D_ASOD323D9HSOD882PESD5V0S1BL315HSOD882D10HSOD882PESD5V0S1BL315HSOD882D11HSOD882ESD8V0R1B_02LRHHSOD882D12HSOD882ESD8V0R1B_02LRHHSOD882D13HSOD882ESD8V0R1B_02LRHHSOD882D14HSOD882*/NCHSOD882D15SD0402CD_ASD0402CD16SOD323D_ASOD323D26HSOD882ESD8V0R1B_02LRHHSOD882D27SD1710A1SMA13CAT3GSD1710AD28HSOD882ESD8V0R1B_02LRHHSOD882J1CON3-5_5X4_25-P1-H3_2-BVTBATCON3-5_5X4_25-P1-H3_2-BVTJ2CON2-4_5X4_25-P1-H3_2-BVTC5320CON2-4_5X4_25-P1-H3_2-BVTJ3SHEAD-4P-4953398_0471SHEAD-4P-49J4USB5-5_9X2_15-P0_65-H2_95-BVTZX62D-B-5PA8USB5-5_9X2_15-P0_65-H2_95-BVTJ5PH6-AJ-3957C-W-BVT03957CPH6-AJ-3957C-W-BVTJ6CON6-P0_5-H2TPCON6-P0_5-H2J7CON40-P0_5-H2FPC-40CON40-P0_5-H2J8HSDC10-1614BDM3A-SF-PEJHSDC10-1614BJ9HSCOX-I-PEXANT_CON_4HSCOX-I-PEXJ10CON6-P0_5-H2TPCON6-P0_5-H2J11USB5-7_7X9-P0_8-H3_9-BVTMUC1F-538200USB5-7_7X9-P0_8-H3_9-BVTJ12CON6-P0_5-H2TPCON6-P0_5-H2J13CON18-12_5X5_32-P0_5-H2_0520PINCON18-12_5X5_32-P0_5-H2_05L1SL04021NHSL0402L2HSL1008C4.7UHHSL1008CL3HSL10082.2UHHSL1008L4SL1008H1UHSL1008HL5SL1008H1UHSL1008HL6HSL10082.2UHHSL1008L9HSPL0202A1UHSPL0202ALB1SL0402BLM15PD121SN1DSL0402M1HOLE95-115HOLEHOLE95-115M2HOLE95-115HOLEHOLE95-115M3HOLE95-115HOLEHOLE95-115M21H-C1_2D1_2HOLEH-C1_2D1_2M22H-C1_2D1_2HOLEH-C1_2D1_2OSC1001HSX4-0302B27MHZHSX4-0302BQ1SOT23PMOS-GSDSOT23Q2SOT23NPN-BECSOT23Q3SOT23NPN-BECSOT23Q4SOT23PMOS-GSDSOT23Q5SOT23NPN-BECSOT23Q6SOT23NPN-BECSOT23Q11SOT23PMOS-GSDSOT23Q13SOT23NPN-BECSOT23S1STSW2-R-AYK-12TS-ASTSW2-R-AS2STSW2-R-AYK-12TS-ASTSW2-R-AS3STSW2-R-AYK-12TS-ASTSW2-R-AU1BGA306-26-2021HI3556V200BGA306-26-2021U2LGA12-0202CMC3416-PLGA12-0202CU3SOP8-50-208AMX25L6435EM2Q-12GHSOP8-50-208AU4HMLF54-035-0606LN123_54HUQFNHMLF54-035-0606LU5SOT23-5ETA3446SOT23-5U6SOT23-5ETA3409SOT23-5U7SOT23-6STI9287SOT23-6U8TSOT23-5RT9078TSOT23-5U9SOT23-5ETA3496SOT23-5U10SOT23-5ETA3496SOT23-5U11QFN44-090-1212_BVTRTL8189QFN44-090-1212_BVTU12HBGA9-16-0303AFAN48610UC50XHBGA9-16-0303AU13SOT23-6ETA7014SOT23-6U14TSOT23-5RT9078TSOT23-5U15SOP8-26-118NS4150SOP8-26-118U16TSOT23-5RT9078TSOT23-5U17SOT23-5AC5054BSOT23-5U18SBAT2-0807-BVTBR_1225F1ANSBAT2-0807-BVTU19BGA153-20-1414H26M41204HPRBGA153-20-1414X1HSX4-030224MHZHSX4-0302X2HSX2-030232.768KHZHSX2-0302
yfchen1003 发表于 2021-4-6 10:37
精品!
老吴 发表于 2021-4-6 10:37
PCB 原理图。回复可见下载。
**** Hidden Message *****
mr踏雪无痕 发表于 2021-4-6 10:40
qjw50 发表于 2021-4-6 11:34
学习学习
单枪舞九州 发表于 2021-4-6 12:59
加油
as3218710 发表于 2021-4-6 13:50
cml_l 发表于 2021-4-6 14:26
roezw 发表于 2021-4-6 16:02
liuhongbbs 发表于 2021-4-6 16:58
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: HI3556V200行车记录仪 PCB 和原理图
