AZ431AN-ATRE1 SOT-23 DIODES(美台)电压基准芯片
AZ431-A系列集成电路为40V电压型,其输出电压可设置为VREF(2.5V)之间的任何值36伏,AZ431-A精密基准提供两个带隙公差:0.4%和0.8%。https://p3-tt.byteimg.com/origin/pgc-image/ef4745e925104b3ca0c88beaea4d3146?from=pc
AZ431AN-ATRE1特点
■ Programmable Precise Output Voltage from 2.5V to 36V
■ Very Accurate Reference Voltage: 0.15% Typical
■ High Stability under Capacitive Load
■ Low Temperature Deviation: 4.5mV Typical
■ Low Equivalent Full-range Temperature Coefficient with 20PPM/℃ Typical
■ Low Dynamic Output Resistance: 0.2Ω Typical
■ Sink Current Capacity from 1mA to 100 mA
■ Low Output Noise
■ Wide Operating Range of -40 to 125℃
https://p6-tt.byteimg.com/origin/pgc-image/8ec753dc1aff4a55995dc48e48a5414f?from=pc
AZ431-A系列集成电路是三端可调的并联稳压器,保证热稳定性超过全工作范围。这些集成电路具有开通特性强、温度系数低、输出功率低等特点阻抗,被广泛应用于充电器、适配器、开关电源等领域,更多产品详细手册或者参考资料请向骊微电子申请。>>
