armclub 发表于 2021-4-14 10:29
ASROCK华擎电脑主板PCB 采用英特尔BROADWELL 系列CPU
CommentPatternQuantityComponents2N7002BKS_AK_SOIC_6P_26_85X83_2AK_SOIC_6P_26_85X832Q2B2, Q8F17414_SOIC_14P_50_341X236_H69_ICSOIC_14P_50_341X236_H691BU1774AUP1G373GW_AK_SOT363_NXP_74AUAK_SOT363_NXP2BU19, BU2374AVC1T45GW_AK_SOT363_NXP_74AVCAK_SOT363_NXP6U4E1, U8, U19, U20, U21, U2274AVCH4T245PW_AK_SOIC_16P_26_20AK_SOIC_16P_26_201X2525U6E1, U11, U14, U17, U1874AVCH8T245PW_AK_SOIC_24P_26_31AK_SOIC_24P_26_311X2523U2R2, U7E2, U7E374HC74PW_SOIC_14P_26_201X252_74SOIC_14P_26_201X2521BU1474LVC1G06GV_NXP_AK_SOT753_74LVCAK_SOT7531BU2274LVC1G14GW_AK_SOT353_S5_74LVC1AK_SOT353_S53BU3, BU4, BU13ADM1815_AK_SOT23_2D4_H44_ADM181AK_SOT23_2D4_H441U8F1AON6428L_AK_DFN_5P_50_199X238_SAK_DFN_5P_50_199X2382Q7F1, Q7F2AST2400A1_GP_AK_BGA_408P_31_748AK_BGA_408P_31_748X7481BU10AT25HP512_SOIC_8P_50_197X236_ICSOIC_8P_50_197X2361BU5ATM_SO_8P_AK_SOIC_8P_50_197X236AK_SOIC_8P_50_197X236_INT1U7T1BATT_HOLDER_3P_AK_BATHOLDER_3P_AK_BATHOLDER_3P_LOTES_LFA1XBT6C1BEAD_L0402_DISCRETE_120OHM/100ML04022BL4, BL6BEAD_L0603_DISCRETE_120OHM/100ML06031BL1BOX_HD_2X5P_STD_AK_BOX_HD_2X5P_AK_BOX_HD_2X5P_100_PIN_LFA1CPLD_JTAG1BROADWELL_R0P70_EXT_BGA_6H_AK_BAK_BGA_1667P_39_S1476_6H1U4D1BTOB_CON_2X30P_2HOLD_AK_BTOB_2XAK_BTOB_2X30P_20_839X2852XDP_CPU1, XDP_PCH1CAP_CESMD_260X260_SAN_330UF/6.3CESMD_260X260_SAN1C22COMMON_CHOKE_12_43_CHOKE_4P_79XCHOKE_4P_79X47_FUKUI_H397L2, L4, L5, L8, L9, L10, L11CP2105_F01_GM_4VIA_AK_QFN_24P_2AK_QFN_24P_20_157_P_SIL_4V1U1L1CRYSTAL_SMD_23NC_AK_XTAL_4P_315AK_XTAL_4P_315X150_FUJ1Y5D1CRYSTAL_SMD_24GND_AK_XTAL_4P_12AK_XTAL_4P_126X98_ECERA1Y1CRYSTAL_SMD_24GND_FUJ_AK_XTAL_4AK_XTAL_4P_126X98_HOSON_H352BGX2, Y6E1D_SUB_15P_4HOLD_R_STD_AK_D_SUB_AK_D_SUB_15P3R_30_4HD_LFA1VGA1DDR4_DIMM_288P_3H_EMOVE_AK_DDR4AK_DDR4_DIMM_288P_3HOLD_LFA4CH0_A1, CH0_A2, CH1_B1, CH1_B2DIODE_PIN_2_NC_1_3_AK_SOT23_2D4AK_SOT23_2D4_H443CR1, CR2, CR8E1DUAL_DIODE_CONVERT_1ANODE_SOT32SOT3235BD1, BD2, BD3, BD4, BD5EN6337QI_4VIA_AK_QFN_38P_20_157AK_QFN_38P_20_157X276_P_4V1U3E1EPM1270F256C5N_AK_BGA_256P_39_6AK_BGA_256P_39_669X6691U9F1ESD5V3U4U_AK_TSLP_9P_INFIN_ESD3AK_TSLP_9P_INFIN2U5, U6FDMB3800N_AK_MICROFET_6P_26_118AK_MICROFET_6P_26_118X752PQ3, U7GTL2014PW_AK_SOIC_14P_26_201X25AK_SOIC_14P_26_201X2522BU16, BU20HEADER_1X2P_HD_1X2P_100_FXCN_LFHD_1X2P_100_FXCN_LFA2MANF_MODE1, NMI_BTN1HEADER_1X3P_AK_HD_1X3P_100_FULLAK_HD_1X3P_100_FULL_LFA10BIOS_RCRV1, CLRMOS1, J18, KR1, KR2, ME_RCRV1, SV1,TP_PVCCKRHV1, TP_VDDQ1, TP_VPP1HEADER_1X3P_HD_1X3P_100_JVE_LFAHD_1X3P_100_JVE_LFA2CHASSIS_ID0_1, CHASSIS_ID1_1HEADER_1X3P_TP3_PPROBEB_SET2DILTP3_PPROBEB12IMP1, IMP2, IMP3, IMP4, IMP5, IMP6, IMP7, IMP8, IMP9, IMP10,IMP11, IMP12HEADER_1X4P_HD_1X4P_100_PINREX_HD_1X4P_100_PINREX_LFA2DEBUG_1, SYS_SMB_1HEADER_1X5P_IR_WAFER_HD_1X5P_10WAFER_HD_1X5P_100_PIN_LFA1PSU_SMB1HEADER_2X10P_K3K6_AK_HD_2X10P_1AK_HD_2X10P_100_K3K6_LFA1AUX_PANEL1HEADER_2X4P_AK_HD_2X4P_50_HEADEAK_HD_2X4P_502LPC_1, SPI_1HEADER_2X4P_K7_AK_HD_2X4P_100_KAK_HD_2X4P_100_K7_PIN_LFA2SATA_SGPIO1, SATA_SGPIO2HEADER_2X5P_K10_HD_2X5P_100_K10HD_2X5P_100_K10_PIN_D46_LFA1PANEL1HEADER_2X5P_K9_HD_2X5P_100_K9_JHD_2X5P_100_K9_JVE_LFA1USB_1HEATSINK_2POST_AK_HSK_2P_1697X3AK_HSK_2P_1697X3431HEATSINK1HEATSINK_AK_HSK_2P_1069X429_HEAAK_HSK_2P_1069X4291HEATSINK2IC_SCK_8P_SOCKET_8P_50_LOT_SOCKSOCKET_8P_50_LOT1BU1ICS553MILFT_AK_SOIC_8P_50_197X2AK_SOIC_8P_50_197X2361U6E2IDSH51_04A1F1C_13H_AK_BGA_96P_3AK_BGA_96P_31_512X3541BU2INDUCTOR_AK_INDUCTOR_2P_118X118AK_INDUCTOR_2P_118X1182U3L7, U3L8INDUCTOR_AK_INDUCTOR_2P_154X157AK_INDUCTOR_2P_154X1574L2C1, L3G1, L4G2, L6D1INDUCTOR_AK_INDUCTOR_2P_197X197AK_INDUCTOR_2P_197X1972L3D2, L3D5INDUCTOR_AK_INDUCTOR_2P_274X260AK_INDUCTOR_2P_274X2601L6D2INDUCTOR_AK_INDUCTOR_2P_287X260AK_INDUCTOR_2P_287X260_CHIL1L1A1INDUCTOR_AK_INDUCTOR_2P_427X394AK_INDUCTOR_2P_427X394_H1571L3F1INDUCTOR_AK_INDUCTOR_2P_429X394AK_INDUCTOR_2P_429X3941L4G1INDUCTOR_AK_INDUCTOR_2P_453X394AK_INDUCTOR_2P_453X394_MAG1L17INDUCTOR_AK_INDUCTOR_2P_457X398AK_INDUCTOR_2P_457X3981L3F2INDUCTOR_AK_INDUCTOR_2P_465X374AK_INDUCTOR_2P_465X3741L1C1INDUCTOR_AK_INDUCTOR_2P_INT3_INAK_INDUCTOR_2P_INT31L1INDUCTOR_AK_INDUCTOR_2P_INTEL_IAK_INDUCTOR_2P_INTEL2L5E1, L5E2INDUCTOR_INDUCTOR_2P_146X114_DIINDUCTOR_2P_146X1141BL10IP4220CZ6_SOT23_S6_H43_DISCRETESOT23_S6_H433U1L2, U3, U4IP4223_CZ6_SOT457_DISCRETE_IP42SOT4572BD6, BD7IR3899MTRPBF_AK_PQFN_17P_197X23AK_PQFN_17P_197X2361U4G1IR3899MTRPBF_AK_PQFN_17P_20_157AK_PQFN_17P_20_157X197_IR1U2A4ISL6353CRTZ_T_12VIA_AK_QFN_40P_AK_QFN_40P_16_S197_PAD_12V1U2B1LAN_JACK_15P_2HD_UDE_STD_AK_LANAK_LAN_JACK_15P_2H_UDE_LFA1IPMI_LAN1LED_20P_LITE_AK_LED_20P_59_583XAK_LED_20P_59_583X4721DS9F1LED_4P_RED_GREEN_LITE_AK_LED_4PAK_LED_4P_63X592CR8F1, CR8F2LED_AK_LED_2P_63X31_H24_GREENAK_LED_2P_63X31_H242BMC_LED1, SB_PWR1LED_AK_LED_2P_63X31_REDAK_LED_2P_63X317FAN_LED1, FAN_LED2, FAN_LED3, FAN_LED4, FAN_LED5, FAN_LED6,FAN_LED7MINI_USB_1X5P_6H_AK_MINI_USB_5PAK_MINI_USB_5P_6H1DEBUG_USB1N_MOS_SO8_AK_SOIC_8P_50_197X236AK_SOIC_8P_50_197X2361Q8E1N_MOS_SOT23_ANPEC_SOT23_H43_DISSOT23_H4326BQ6, BQ7, BQ8, BQ9, BQ10, BQ12, BQ13, BQ14, BQ16, BQ17, BQ18,BQ20, BQ21, PQ6, Q1, Q3, Q3T1, Q4, Q7E3, Q7E4, Q13, Q14, Q15, Q17, Q7533,Q7535N_MOS_SOT23_SOT23_DISCRETE_2N70SOT232SQ6303, SQ6304N_MOS_SOT23_SOT23_H43_2N7002SOT23_H433BQ3, BQ4, BQ15N_MOS_SOT23_SOT23_H49_DISCRETE_SOT23_H491BQ11NCP5368MNTXG_8VIA_AK_QFN_32P_20AK_QFN_32P_20_S197_4PAD_8V3U3D1, U3D2, U10NCP81111MNTXG_12VIA_AK_QFN_32_1AK_QFN_32P_20_S197_PA_N_12V1U9NCP81111MNTXG_12VIA_AK_QFN_32P_AK_QFN_32P_20_S197_PA_N_12V1U3C1NPN_SOT23_SOT23_H43_DISCRETE_PMSOT23_H434BQ5, Q2, Q3C1, Q7N1OSC_4P_FUJICOM_AK_OSC_4P_126X98AK_OSC_4P_126X98_FUJICOM1U1R1OSC_4P_RD9_AK_OSC_4P_197X126__1AK_OSC_4P_197X126_FUJICOM1OSC2OSC_4P_RD9_AK_OSC_4P_197X126_FUAK_OSC_4P_197X126_FUJICOM1OSC1P_MOS_SO8_AK_SOIC_8P_50_197X236AK_SOIC_8P_50_197X2361Q18P_MOS_SO8_AK_SOIC_8P_50_209X236AK_SOIC_8P_50_209X2361PQ4PCA9545_AK_SOIC_20P_26_260X252_AK_SOIC_20P_26_260X252_FAIR1BU15PCA9556_AK_SOIC_16P_26_201X252_AK_SOIC_16P_26_201X2521BU12PCA9617ADP_AK_SOIC_8P_26_122X19AK_SOIC_8P_26_122X1933BU21, U8D2, U8L1PCI_EXPRESS_98P_SLOT_KORTAK_AK_AK_SLOT_PCI_98P_79_2H_K_LFA1J17PCI_EXPRESS_X16_SLOT_AK_SLOT_PCAK_SLOT_PCI_164P_79_2D_LFA1J16PNP_SOT23_SOT23_H43_DISCRETE_PMSOT23_H431BQ19POLY_FUSE_AK_POLYSWITCH_2P_0805AK_POLYSWITCH_2P_08051F17PWR_CON_2X6P_2HOLD_STD_AK_PWR_2AK_PWR_2X6P_118_2HD_JT_LFA1ATXPWR_1QS3VH125QG8_AK_SOIC_16P_25_197XAK_SOIC_16P_25_197X2361U8E5QS3VH126QG8_AK_SOIC_16P_25_197XAK_SOIC_16P_25_197X2361U9A1RT8008PB_AK_SOT23_S5_H43_RT8059AK_SOT23_S5_H432PTU6, PTU7RTL8211E_VB_CG_12VIA_AK_QFN_48PAK_QFN_48P_16_S236_PA_12V1BU9SATA_CON_7P_2HOLD_FXN_AK_SATA_7AK_SATA_7P_50_2H_FOC_LFA6SATA0, SATA1, SATA2, SATA3, SATA4, SATA5SCHOTTKY_BAT54C_SOT323_DISCRETESOT3231CR4N1SCREWHOLE_160_ASUS_HOLE_160_SV_HOLE_160_SV6H2, H3, H4, MH1A1, MH1B1, MH1H1SI7840DP_AK_BSC022N03S_H43_BS_1AK_BSC022N03S_H431Q2C1SI7840DP_AK_BSC022N03S_H43_BSC0AK_BSC022N03S_H432Q2C2, Q16SLB9665_AK_SOIC_28P_26_386X252_AK_SOIC_28P_26_386X2521U7A1SLOT_PCI_80P_2HD_SAM_AK_SLOT_PCAK_SLOT_PCI_80P_31_2HD_SAM1J4SMDPAD_3P_AK_TP_SMD_1X3P_T_POINAK_TP_SMD_1X3P7TP2A1, TP3C1, TP3E1, TP6C1, TP6D2, TP6D3, TP22SMP_PLUG_SMT_2P_AK_SMP_PLUG_2P_AK_SMP_PLUG_2P_197X1975KR_CLK, KR_DFTDIG_0, KR_DFTDIG_1, KR_MON_N1, KR_MON_P1SN74LVC1G125DCKR_AK_SOT753_74LVAK_SOT7532BU7, BU8SN74LVC32A_AK_SOIC_14P_26_201X2AK_SOIC_14P_26_201X2521BU18SOCKET_16P_AK_SOCKET_16P_50_LOTAK_SOCKET_16P_50_LOTES1SPI_CON1TACT_SW_6P_2HD_AK_TACT_SW_6P_2HAK_TACT_SW_6P_2HD_LFA1UID1TACT_SWITCH_4P_2H_AK_TACT_SW_4PAK_TACT_SW_4P_2H_WEL_LFA1U9A2TEK_LAI_PROBE_SM_AK_TESTPIN_54PAK_TESTPIN_54P_5HD_LF31J6T1TPS2052DRG4_AK_SOIC_8P_50_197X2AK_SOIC_8P_50_197X236_INT1U2TPS2064DGN_AK_SOIC_8P_26_122X19AK_SOIC_8P_26_122X193_P_2V2U3N1, U8B2TPS2331IPWR_AK_SOIC_14P_26_201XAK_SOIC_14P_26_201X2521U7F1TPS51200DRCR_4VIA_AK_DFN_10P_20AK_DFN_10P_20_S118_P_4V_H391U2A1TPS53353DQPR_16V_AK_QFN_22P_236AK_QFN_22P_236X197_P_TI_16V2U4G2, U6D1TPS54620RGYR_4VIA_AK_QFN_14P_20AK_QFN_14P_20_S138_P_TI_4V1U3F2TPS74801DRCR_4VIA_AK_DFN_10P_20AK_DFN_10P_20_S118_P_4V_H392U4E3, U5D1TS3A24157DGSR_AK_SOIC_10P_20_12AK_SOIC_10P_20_122X1931U8D3USB_CON_19P_4HOLD_FOXCONN_AK_USAK_USBX2_18P_4HOLD_S_LFA1USB3_1_2W25Q32FVSSIG_AK_SOIC_8P_50_212XAK_SOIC_8P_50_212X3111U4G3WAFER_HD_1X5P_HR_AK_WAFER_HD_5PAK_WAFER_HD_5P_79_HR_LFA1BMC_SMB_1WTOB_CON_1X4P_L_STD_AK_WTOB_D_1AK_WTOB_D_1X4P_98_LFA1IPMB_1WTOB_CON_20P_K1_2HOLD_AK_WTOB_2AK_WTOB_2X10P_50_K1_2H_LFA1SPI_TPM1
armclub 发表于 2021-4-14 10:36
PCB文件 是转换成AD格式的,不是原版。。 仅供参考学习。 转换没修正。
**** Hidden Message *****
luchonghui74 发表于 2021-4-14 11:08
谢谢分享!
单枪舞九州 发表于 2021-4-14 11:19
支持
缘思竹08 发表于 2021-4-14 11:44
chery 发表于 2021-4-14 12:45
感谢分享
lock_lilu 发表于 2021-4-14 12:47
986720 发表于 2021-4-14 13:17
2592047508 发表于 2021-4-14 13:27
dsfgdsf 发表于 2021-4-14 13:43
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: ASROCK华擎电脑主板PCB 采用英特尔BROADWELL 系列CPU
