pads 安装问题
测试安装lib 发现这个问题。MGC SDD Configurator
NOTE: The attempted PATH size has exceeded the maximum
allowed for Windows since XP sp2.
The system path is limited to the maximum path length of 2047
characters.The user-defined path is limited to a maximum 5115
characters, but is limited to 2047 minus the system path. The
attempted PATH Length is: 229 You must reduce the size of your
user or system path and
add this value to your path:
C:\MentorGraphics\9.4PADS\SDD_HOME\common\win32\lib
This value will be stored in SDD_ADD_TO_PATH for easy editing.
问题很简单 系统 环境变量 path里面太多路径了,先复制备份一些。然后删除 再安装 。
完美。
