armclub 发表于 2021-6-28 15:02
QCA9531-DL1A +AR9582-AR1A+MAXM17546ALJ+SE2576L_SE2565T+MAX17504ATP 做的无
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEA7HMC580ST89_HMC580ST89_GALI-51F+GALI-51F+HMC580ST89ATT1PAT1220-C-XDB_PAT1220_PAT1220-CPAT1220-C-3dBPAT1220ATT2PAT1220-C-XDB_PAT1220_PAT1220_1PAT1220-C-9dBPAT1220ATT3PAT1220-C-XDB_PAT1220_PAT1220_2PAT1220-C-2dBPAT1220C1824NFM21PC475B1A3_NFM21PC_NFM21PC4NFM21PC475B1A3NFM21PCD10DIODEREVERSED_0_SMA_SMBJ60SMBJ60SMAD30DIODEREVERSED_0_SMA_D340AD340ASMAD31SRV05-4_SOT-26_SP1004SP1004SOT-26D32SRV05-4_SOT-26_SP1004SP1004SOT-26D35SRV05-4_SOT-26_SP1004SP1004SOT-26D40DIODEREVERSED_0_0402_TVS DIODETVSDiode402DS1LED-0603-LTST-C190GKT_LED-0603_LEDLED-0603J36A1009AWRR-10-C1MB-R_A1009AWRR-1A1009AWRR-10-C1MB-RA1009AWRR-10J37A1009AWRR-04-C1MB-R_A1009AWRR-0A1009AWRR-04-C1MB-RA1009AWRR-04-C1MB-RJ39DT01-030S-T_DT01-030S-T_DT01-03DT01-030S-TDT01-030S-TJ41SSMP5_SSMP5_SSMP5SSMP5SSMP5J42A1009AWRR-10-C1MB-R_A1009AWRR-1A1009AWRR-10-C1MB-RA1009AWRR-10J43A3962AWG-02-A5WA-P-D_A3962AWG-0A3962AWG-02-A5WA-P-DA3962AWG-02-AW5A-P-DJ44MCX-KWHD_MCX-KWHD_MCX-KWHDMCX-KWHDMCX-KWHDL1IND-FERRITE_IND-SM-3X3_2.2UH2.2uHIND-SM-3X3L11IND_7_IND-0402_3.0NH3.0nHIND-0402L13INDUCTOR_0603_BLM15EG221SN1BLM15EG221SN1603L17IND_7_IND-0402_49.9R49.9RIND-0402L18IND_7_IND-0402_49.9R49.9RIND-0402L19IND_3_0402_1.5NH1.5nH402L20INDUCTOR_0603_BLM21PG331SN1PBLM21PG331SN1p603L21INDUCTOR_0603_BLM21PG331SN1PBLM21PG331SN1p603L25IND_3_0603_220220603L26IND_3_0805_220220805L27IND_3_IND-0201_2.2NH2.2nHIND-0201L47IND_5_0402_DNPDNP402L49INDUCTOR_0603_270NH270nH603L50INDUCTOR_0603_270NH270nH603L51INDUCTOR_0603_82NH82nH603L57IND_2_IND-0201_2.4NH2.4nHIND-0201L63IND_1_0805_2525805L68IND_1_FDSD0630_FDSD0630-H-4R7MFDSD0630-H-4R7MFDSD0630L608IND_4_0402_2.2NH2.2nH402L609IND_4_0402_2.2NH2.2nH402L610IND_1_FDSD0630_FDSD0630-H-4R7MFDSD0630-H-4R7MFDSD0630PT1TPOINT R_HOLE-150R102A_T POINTTPOINT RHOLE-150R102AQ4TRA-SOT23-MMBT2907A_TRA-SOT23_MMMBT2907ATRA-SOT23Q6TRA-BFP740ESD_1_BFP740_TRA-BFP7TRA-BFP740ESDBFP740S8SWI-UPG2163T5N_0_SWI-6P-DFN_SKYSKY13370SWI-6P-DFNT1LF8505_LF8505_S16116GS16116GLF8505T2LF8505_LF8505_S16116GS16116GLF8505U6QCA9531-DL1A_QFN-DR-156-EP_(S1+QCA9531-DL1AQFN-DR-156-EPU7SDRAM-DDR2-512MB_5_BGA-84-9X15-SDRAM-DDR2-512MBBGA-84-9X15-3U9N25Q128A-SO8W_SO8-200_N25Q064A1N25Q064A13ESE40FSO8-200U42SE2576L_SE2565T_1_WQFN-16_SE257SE2576L_SE2565TWQFN-16U92AR9582-AR1A_AR9582_AR9582-AR1AAR9582-AR1AAR9582X1OM11F8Z3-40M000_OM11F8Z3_OM11F8OM11F8Z3-40M000OM11F8Z3X2TX7050D9F3-40M000_7050_TX7050D9TX7050D9F3-40M0007050Y1XTAL-TH-HC49-25MHZ_1_CRY-SMD4-C25MHzCRY-SMD4-CX101FZE7LP38798SD-ADJ_WSON_LP38798SD-ADLP38798SD-ADJWSONZE9TPS82130SIL_USIP_TPS82130SILTPS82130SILUSIPZE10TPS82130SIL_USIP_TPS82130SILTPS82130SILUSIPZE12MAXM17546ALJ_SIP29_MAXM17546ALJMAXM17546ALJSIP29ZE13MAX17504ATP_TQFN20_MAX17504ATPMAX17504ATPTQFN20ZE14MAX17504ATP_TQFN20_MAX17504ATPMAX17504ATPTQFN20ZE15TPS82130SIL_USIP_TPS82130SILTPS82130SILUSIPZE16TPS82130SIL_USIP_TPS82130SILTPS82130SILUSIPZE19NCP160AMX450TBG_NCP160D_NCP161BNCP161BMX500TBGNCP160D
armclub 发表于 2021-6-28 15:04
PCB文件。回复可见
**** Hidden Message *****
gc1021 发表于 2021-6-28 15:35
想下载来看下,学习学习,奈何积分不够啊
sunjq 发表于 2021-6-28 16:01
非凡 发表于 2021-6-28 16:49
cml_l 发表于 2021-6-28 16:53
好板子呀
单枪舞九州 发表于 2021-6-28 17:18
支持
bidezhi7777 发表于 2021-6-28 20:41
a6682100 发表于 2021-6-28 21:35
童雯 发表于 2021-6-28 22:35
页: [1] 2 3 4 5 6
查看完整版本: QCA9531-DL1A +AR9582-AR1A+MAXM17546ALJ+SE2576L_SE2565T+MAX17504ATP 做的无
