老吴 发表于 2021-7-16 15:23:13
MT8392+MT6166 MT6322 MT6333 MT6625 2个DDR3X16 通话平板电脑PCB 和原
NamePCB DecalPart TypeValueANT701PAD_3PINCAR_KIT_/_MM8430-2610B_1ECT818000117ANT1201ANT/1P/SMD/818000378/ECTANTENNAECT 818000378ANT1202ANT/1P/SMD/818000378/ECTANTENNAECT 818000378BEAD401L0603BEADBLM18BD252SN1CON401J301T05GAGZL2CXJC-PJ2_1PJ-S3142CON600MM8130-2602CAR_KIT_/_MM8130-2600_2MM8130-2602CON803BBL1MM0.23MMW0.4MMPH30PIN-ZOV7645FB_13_2MAIN CAMERA CONNECTORCON804BBL1MM0.23MMW0.4MMPH24PINSUB_CAMSUB CAMERA CONNECTORCON807H3/SMD/P1.25/1.25A-WTT-3P/ZHENGHEOV7645FB_131.25A-WTT-3P(JD1)H1.85CON903LCD_40_0.5P_2.8H_HJ080NA-04FIPEX-20455-040E_440P-0.5PITCH, BOTTOMCON1102ZIF_H51/SMD/P0.3-Z33PIN_2AXT340124CON1204BBL1MM0.23MMW0.4MMPH10PINOV7645FB_3Wisky camera connectorCON1211CAF11-08173-1514/9PIN/1.7HTF_CARD_8PINTF_CARD_8PINCON1212S01-4B08F19ATF_CARD_0SIMCON2001CON20X2/SMD/M/AXT440124HEADER_1AXT440124D6SOT23BAT54SBAT54SD8SOT23BAT54SBAT54SD105819DIODE_SCHOTTKY_2B5819WD302DIODE/SMD/MMSZ5221BDIODE/ZENERMMSZ5231BT1GD401VR0402PG05BSESC_0ESD9L5.0ST5GD805RB551V-30(UMD2)DIODE_SCHOTTKY_6RB551V-30D901RCLAMP0524P/10P/SMDRCLAMP0524PRClamp0524PD902RCLAMP0524P/10P/SMDRCLAMP0524PRClamp0524PD903VR0402DIODE_DIACESD0603/SMD/NCD904VR0402DIODE_DIACESD0603/SMD/NCD905VR0402DIODE_DIACESD0603/SMD/NCD1201D/SMD/UMD2DIODE_SCHOTTKY_0UDZV 12BD1401RB551V-30(UMD2)DIODE_SCHOTTKY_6BAT54WSD1611DIODE/SMD/RB521CS-30D_/_RB521CS-30RB521CS-30EMI801FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FREMI802FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FREMI803FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FREMI804FILTER/SMD/ICVE10184E150R101FREMIX21A390FNPE_0ICVE10184E070R100FRF201DIPLEXER/6P/SMD/DP1608BL1608-05K2450_0DIPLEXER/6P/SMD/DP1608H1301DH1_6MMNSCREW_HOLE_3_0.5MMTOOLING_HOLE/4MM/NCH1302DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NCH1303DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NCH1304DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NCH1305DH1_6MMNSCREW_HOLE_3_0.5MMHOLE/NPTH/D2.2/WS1962/NCJ902LK-A151902PORT_HDMI_TYPE-AHDMI-TYPE-MINIL6L/IND/SMD/IHLP-2020AB-01INDUCTORVishay IHLP2020ABER2R2M01 (2.2uH)L306L/IND/SMD/2520INDUCTORMPH252010S2R2MT/2.2uHL307L/IND/SMD/2520INDUCTOR0.47uHL402L0603BEADBLM18BD252SN1L731L0402IND0L802L/IND/SMD/LVS-S3016INDUCTOR_1LQH44PN4R7MPOL(4.7uH)L803L/IND/SMD/LVS252010-2R2INDUCTORVLS252010T-4R7M (4.7uH)L1004L0402L_/_39_/_NH_/_0402L / NC / nH / 0402L1006L0402L_/_27_/_NH_/_020182nHL1008L0402L_/_8.2_/_NH_/_04025.6nHL1009L0402INDUCTOR_3L / NC / nH / 0402L1201L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56JL1202L/IND/SMD/0603FERRITE_BEAD_SMD_0402560nH/MLF1608DR56JL1203L/IND/SMD/LVS252010-2R2INDUCTOR_1LQH2HPN4R7MG0L LED301LED/4P/SMD/19-237ADIODE_10SMLP36RGB1WMIC+1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINTNTC301R0402NTC_/_NCP15WF104F03RC_/_0402_NCNTC302R0402NTC_/_NCP15WF104F03RC_/_0402_NTC / NTCG103JF103F / 0402 PL1L/IND/SMD/2520L_/_MDMK2020TR68MM_/_SMD2520PMSB25201T-R47MSQ801SOT2340852_43904Q802SOT23P_DGS_1SI2305Q803SOT2340852_43904/NCREC12PIN-2.5-1.5-1.2AUDIO_JACK_0EAO-4015-PFAREC2_NANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINTREC2_PANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINTSPK+1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINTSPK-1PIN-1.2X2TEST_POINT_DIP0_4.6TEST POINTSW1201KEY_RESETKEY_1POWERSW1301DSWDKEY_0POWERSW1304DSWDKEY_0POWERSW1305DSWDKEY_0POWERTP1367TP/SMD/0.5MMTEST_POINT_DIP0.6TEST POINTTP1378TP/SMD/0.5MMTEST_POINT_DIP0.6TEST POINTU1BGA64/SMD/P0.5/B0.27/SN65DSI83/SSN75LVDS83A_1SN65DSI83U2SC70/5P/SMD/P0.65/TLV70012DCKR1172X_5TLV70018DCKU3SC70/5P/SMD/P0.65/TLV70012DCKR1172X_5TLV70033DCKU5FBGA96/SMD/P0.8/3-IN-1IC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U6FBGA96/SMD/P0.8/3-IN-1IC_DDR3_X16_FBGA-96IC DDR3 x16 FBGA-96U12TSOT-23-6/SMD/P0.95/AT1316/SAPL5151_1TPS61165DBVTU13SOT23-6/SMDSY7208_2SY7208U201MT8392/VFBGA494/P0.4/B0.25/11.4X11.4MT8392_DDR3L_X16MT8392U301MT6323/VFBGA145/P0.4/B0.25/5.8X5.8MT6323_E1_1MT6322U302WLCSP20/P0.4/B0.25/2-IN-1NCP6335_1NCP6335 / FAN53555U503BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA169_BALL_EMMCSamsung KLM2G1HE3F-B001U605SKY77186SKY77701_0RF7241U608SKY77186SKY77701_1RF7242U609SKY77186SKY77701_2RF7248U610SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYRF1G88CA0B0AU611SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYRF1G95HQ0F0AU612SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH897MHA0F00U614SAW/8P/SMD/D2.0X1.6/SAY/MURATASAW-DPX-RX-BALSAYFH836MCA0F00U615XM0860SH-DL0601XM0860SH-DL0601XM0860SH-DL0672U616SKY77590PA_/_SKY77590_0PA / SKY77590U707SKY77186SKY77701_3RF7245U811MT6166/VFBGA104/P0.4/B0.25/4.6X4.6MT6166_3MT6166U901FILTER_EXC24CE_1FILTER_EXC24CE_2Filter_EXC24CEU903SOT23-6/SMDTEA1206T_0Onsemi CAT3200TDI-T3U906FILTER_EXC24CE_1FILTER_EXC24CE_3Filter_EXC24CEU907FILTER_EXC24CE_1FILTER_EXC24CE_4Filter_EXC24CEU909FILTER_EXC24CE_1FILTER_EXC24CE_5Filter_EXC24CEU910FILTER_EXC24CE_1FILTER_EXC24CE_6Filter_EXC24CEU1001MT6627-NS/MQFN40/SMD/P0.4/5X5MT6611_SMD_WLCSP-61_0MT6625_IPD_QFN40U1005TCXO/SMD/2.5X2.0/IT2205BETCXO_RAKON_SMD_4PMT6627 QVL TCXOU1006SAW/SMD/1.05X1.35SAFEB1G57KA0F00SAFEB1G57KE0F00U1010TSLP6/SMD/P0.4/BGA725L6/SNJG1107HB3_0BGA725L6U1101QFN52/SMD/P0.4/GT911/SGT800_0GT911U1201MT6605/MQFN32/SMD/P0.4/4X4/SMT3301-140_SMD_PBGA-140_0MT6605 QFN (32 Pins, 0.4mm pitch)U1208HALL_IC_AH1883HALL_IC_AH1883BU52011HFV/NCU1301MMA8452QADXL345_7KXCJK-1013U1302QFN30/SMD/MPU-300074ALVC74PW_1MPU-3050U1303WLCSP14/SMD/P0.4/B0.23/AK8963ADXL345_2AK8963CU1304ALS_APDS9930CM3623_2ADPS-9930U1401QFN72/SMD/P0.5/SII9022A/SAD9389BBCPZ-165_0SiI9024ACNUU1802MT6333/WLCSP30/P0.4/B0.25/2.1259X2.638YDA145_6MT6333U1904VQFN24/SMD/P0.5/BQ24196BQ24196_0bq24196U1905SOT23-5LED_DRIVER_SY8006SY8006AACU9307CSP16/SMD/P0.4/B0.25/TPS6128X/SIC/BUCK/TPS6128TPS61280AVIB_GND1ANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINTVIB_POWER1ANT-1.5-2.5TEST_POINT_DIP0_4.6TEST POINTVR301VR0402VR0402EZJZ0V500AAVR1310VR0402VR0402_1EZJZ0V500AAWIFI_BT_GPS_ANTPAD_3PINCAR_KIT_/_MM8430-2610B_0PAD_3PINX301CRYS/SMD/MS3V-T1RCRYSTAL_132K (MS3V-T1R)X600CRYS/SMD/D2.5X2.0/CT2520DB/KYOCERATCVCXO_2X / 26MHz / X1E000021043400X1201CRYS/SMD/FA-128QUARTZ_IQX0_1QUARTZ 27.12 Mhz /NCZ600BALUN/10P/SMD/BD2012SAW_1Balun / RFBLN2012090BM5T25
老吴 发表于 2021-7-16 15:25:17
8层 1介盲埋孔 PCB设计。 PCB 是PADS VX2 版本。原理图ORCAD格式 。里面有两份参考原理图。原理图和PCB 有一点点差异。但是总体参考没问题。
一起打包。回复可见下载。 独家发布。请不要转载网上。
**** Hidden Message *****
heming2216 发表于 2021-7-16 15:43:31
yangyida137324 发表于 2021-7-16 15:44:48
yfchen1003 发表于 2021-7-16 16:03:47
老大发精品
986720 发表于 2021-7-16 16:19:17
langjitianya丶 发表于 2021-7-16 21:49:34
朱新168 发表于 2021-7-16 21:55:06
zspdeyc 发表于 2021-7-16 22:53:42
wangy2000 发表于 2021-7-17 07:01:00
页: [1] 2 3 4 5 6 7 8 9
查看完整版本: MT8392+MT6166 MT6322 MT6333 MT6625 2个DDR3X16 通话平板电脑PCB 和原
