armclub 发表于 2021-10-12 10:13:05
RK3229(RK3228) 做的一个TVBOX  PCB文件和原理图共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECN601USB-B_2_FUSEUSB-AF-CH6-Z5_USB-AUSB-AFUSEUSB-AF-CH6-Z5D6BAT54S/SOT_0_SOT_23_BAT54CBAT54CSOT_23D8DIODE_SOD_323_IN5819IN5819SOD_323D111N4148_DO214AC_SS54SS54DO214ACD901DIODEZENER1_1_SOD123_BZT52C3V0BZT52C3V0SOD123D902DIODE_SOD_323_1N58191N5819SOD_323D1100DIODEBI_DIR TRIG_E0402N_ESD545ESD5451NE0402ND9318DIODE_DO214AC_SS54SS54DO214ACD9319DIODE_DO214AC_SS54SS54DO214ACD93201N4148_DO214AC_SS54SS54DO214ACD9325DIODE_SOD_323_IN5819IN5819SOD_323D9328DIODE_SOD_323_NC/IN5819NC/IN5819SOD_323D9329DIODE_SOD_323_IN5819IN5819SOD_323D9330DIODE_DO214AC_SS54SS54DO214ACDZ13PIN_PINBI_ICSRC6508SFR_3PIN_PI3PIN_PINBIICSRC6508SFRJ11CON4_1_BAT20_BATBATBAT20J12TF_SD_SOCKET_0_SK10056619_WGQ_TTF_SD_SOCKETSK10056619_WGQJ900HDMI_A_HDMI_TYPE_A_HDMI_A_GHDMI_A_GHDMI_TYPE_AJ6301ANT3_1_ANT_JACK_RFANT5220RFANT5220ANT_JACKJ8901USB31_TYPE_C_1_TPYE-C-24PIN_USBUSB_TYPEC_115H0TPYE-C-24PINJ90032CON4_SIP4_CON4CON4SIP4J90086CON4_5_1_25MM_SMDB_2PIN_MICMIC1_25MM_SMDB_2PINJ90088CON4_5_1_25MM_SMDB_2PIN_SPK_LSPK_L1_25MM_SMDB_2PINJ90089CON4_5_1_25MM_SMDB_2PIN_NC/SPK_NC/SPK_L1_25MM_SMDB_2PINJ90090PJ-3536_2_SMT-0_5-12P_FPC_0_5_1FPC_0_5_12PINSMT-0_5-12PJ90091CON4_5_1_25MM_SMDB_2PIN_LEDLED1_25MM_SMDB_2PINL5L_IND-6X6_3.3UH/5A3.3UH/5AIND-6X6L400INDUCTORSOF FERRITE_IND_3X3_2.2.2uHIND_3X3L401INDUCTORSOF FERRITE_IND_3X3_2.2.2uHIND_3X3L402INDUCTORSOF FERRITE_IND_3X3_3.3.3uHIND_3X3L900INDUCTOR_L0603_180R-100M180R-100ML0603L6100INDUCTORSOF FERRITE_IND-252012NC/SWPA3012S4R7MT/1AIND-252012L6503INDUCTOR_2_IND-4X4_2.2UH2.2uHIND-4X4L6504INDUCTORSOF FERRITE_IND_3X3_1.1.0uHIND_3X3LED1LED_0_R0603_REDREDR0603LED8LED_0_R0603_BLUEBLUER0603OQ1PMOS_0_SOT-23_NCE2333YNCE2333YSOT-23OQ3PMOS_0_SOT-23_WPM2341-3/TRWPM2341-3/TRSOT-23OQ4PMOS_0_SOT-23_WPM2341-3/TRWPM2341-3/TRSOT-23Q1NPN_SOT-23_S8050S8050SOT-23Q901MOSFETN_SOT_323_2SK30182SK3018SOT_323Q902MOSFETN_SOT_323_2SK30182SK3018SOT_323Q903MOSFETN_SOT_323_2SK30182SK3018SOT_323Q2206MOSFETP_SOT_23_NCE2333YNCE2333YSOT_23Q2207NPN_SOT23_S8050S8050SOT23Q2208MOSFETN_SOT_323_2SK30182SK3018SOT_323Q2209MOSFETN_SOT_323_2SK30182SK3018SOT_323Q7000MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q7001MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q65035NPN_SOT-23_S8050S8050SOT-23Q65036NPN_SOT-23_S8050S8050SOT-23Q65037MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q65038MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23Q65039NPN_SOT-23_S8050S8050SOT-23SW1KEY_4PIN_SW-PB3_KEY_12X12KEY_12X12SW-PB3SW1100SW4P_1_KEY-4X3X2_RECOVER2RECOVER2KEY-4X3X2SW2303SW4P_0_TS-1188E1_RESETRESETTS-1188E1SW2305KEY_4PIN_SW-PB3_KEY_12X12KEY_12X12SW-PB3TP101TP_TP90_TPTPTP90TP1103TP_TP90_TPTPTP90TP1107TP_TP_0R70_TP_0.7TP_0.7TP_0R70TP1108TP_TP_0R70_TP_0.7TP_0.7TP_0R70U23SY7201_0_SOP8-225-50-EPAD_XA501XA5012SOP8-225-50-EPADU401ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FSOT_23U402VOLTAGE_DETECTOR_CE8809_SOT_23_CE8809C263MASOT_23U403LDO_TT2102_SOT-23-5_TT2102BTT2102BSOT-23-5U404DCDC_SY8088_SOT-23-5_SY8089AACSY8089AACSOT-23-5U405DCDC_SY8088_SOT-23-5_SY8089AACSY8089AACSOT-23-5U406DCDC_SY8088_SOT-23-5_SY8088AACSY8088AACSOT-23-5U407LDO_PT5108_SOT-23-5_PT5108E23E-PT5108E23E-18SOT-23-5U408DS8008_4_SOT-23-5_PT5108E23E-33PT5108E23E-33/WL2801E-33SOT-23-5U800DSP_RK3228_BGA316_14R00X14R00X1RK3229BGA316_14R00X14R00X1R20U2000LPDDR3_32BIT_178P_FBGA178-12X12K4E8E304EE-EGCEFBGA178-12X12U2001LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-18SOT_23_5U2002GAUGE_CW2013_DFN8_3R00X2R50X0R9CW2015CASDDFN8_3R00X2R50X0R90U2503WS3221_CSP-6L_WS3221CWS3221CCSP-6LU2601SWITCH_FSUSB30MUX_MSOP10_3R00X3NC/FSUSB30MUXMSOP10_3R00X3R00X1R10U4100INAND_EMMC_169_BGA169_18R00X14RKLMAG2GEAC-B031BGA169_18R00X14R00X1R20U6100AMPAK_SIP6221/AP6255/AP6335/AP6330/XZ3660AP6XXXU6105RS0102_SOT23-8_NC/RS0102NC/RS0102SOT23-8U9001MXC6655XA_LGA12_2R0X2R0X1R0_MXCMXC6655XALGA12_2R0X2R0X1R0U90067GPR25L005B_4_SOP8_JX8016JX8016SOP8U90068SWITCH_SY6280_SOT-23-5_TCS9263TCS9263SOT-23-5U9007710PIN_1_20PIN_0_5MM_20PIN20PIN20PIN_0_5MMU90086DS8008_1_SLP2510P8_AZ1045-04F/EAZ1045-04F/ESD5304DSLP2510P8U90087DS8008_1_SLP2510P8_AZ1045-04F/EAZ1045-04F/ESD5304DSLP2510P8U90091MMA8452Q_0_LGA-12_2X2_0_9_DA218DA218B/SC7A20LGA-12_2X2_0_9U90092AMPLIFIER_CS8508E_0_QFN20_ES724ES7243QFN20U90110DCDC_SY8088_4_TDFN-2X3-8BL_SGM4SGM41524TDFN-2X3-8BLU90111LM4990_0_SOP16_XPT9503XPT9503SOP16U90112PJ-31006A_0_PJK-311S-40-D_PJ-31PJ-31006APJK-311S-40-DU90113DCDC_SY8088_SOT-23-5_TCS4201TCS4201SOT-23-5Y800CRYSTAL_4P_CRY-D3225_24MHZ24MHzCRY-D3225Y6100CRYSTAL-4_3_CRY-D3225_NC/37.4MHNC/37.4MHz-20ppmCRY-D3225
armclub 发表于 2021-10-12 10:14:18
PCB文件和原理图来了。回复可见
**** Hidden Message *****
i_333333 发表于 2021-10-12 10:29:09
非常感谢楼主非常感谢楼主大神分享大神分享
xiaozhang5184 发表于 2021-10-12 15:50:44
地沟油 发表于 2021-10-12 16:40:41
单枪舞九州 发表于 2021-10-12 17:39:56
加油
love欣 发表于 2021-10-12 17:52:03
roezw 发表于 2021-10-12 18:45:56
bidinghong 发表于 2021-10-12 19:53:06
csh009 发表于 2021-10-12 20:07:48
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: RK3229(RK3228) 做的一个TVBOX  PCB文件和原理图共享
