完整全套微软英特尔 skylake 双路服务器主板电脑主板 pcb, sch bom 包
送给大家, 希望有帮助. PCB 是 allegro .brd格式, 电路图是 pdf 格式, bom 是 .xlsx 格式1LED BLUE LTL42TB6NHBPLTL42TB6NHBPLED47
2LED BLUE 1H0301B10000CA04 DIP1H0301B10000CA04
3CONN EDGE 98P G630H9821210EUG630H9821210EUCN31,CN32
4CONN EDGE PCIE 98P 10108777-10002TLF10108777-10002TLF
5CONN EDGE 98P 87715-920687715-9206
6CONN PCIE 164P G630HAA23810EUG630HAA23810EUCN33,CN34,CN35
7HEAD ML 1R4P CI0104P1VK0-NH,NYLON 6TCI0104P1VK0-NHUSB1
8HEAD FML 1R4P 50312-0040N-002, NYLON HTN50312-0040N-002
9HEAD FML 1R4P 9-440054-1,PAT69-440054-1
10HEADER ML 2R24P RT C23229-1243N-L RTC23229-1243N-LCNC7
11HEAD WTB FML 2R4P ST 10127820-0422LLF10127820-0422LLFCN57,CN58
12CONN CTR 4P ST G874D04110PTEUG874D04110PTEU
13HEAD WTB FML 2R8P ST 10127820-0822LLF10127820-0822LLFCN101,CN102
14CONN CTR 8P ST G874D081200CEUG874D081200CEU
15CONN CTR SATA ST 7P G16AD2210K1EU ,LCPG16AD2210K1EUCN51,CN52,CN53,CN54
16CONN MICRO FIT 4P 43650-0415 LCP43650-0415CNC6
17CONN MINTEK PWR 4P 10136656-0411LF LCP10136656-0411LF
18CONN MICRO FIT 4P CP3504P1V00-S-LF,PA6TCP3504P1V00-S-LF
19HEAD ML 1R2P ST 22-28-402422-28-4024JP21,JP23,JPB2
20HEAD ML 1R2P ST G800LQ306018EUG800LQ306018EU
21SKT USB3.0 9P UEA1113-44123-7H, HTNUEA1113-44123-7HUSB2,USB3
22SKT USB3.0 9P GSB31113495H4HR,PA9TGSB31113495H4HR
23SKT DIMM DDR4 288P 78726-1039 ,PA4678726-1039CN10,CN12,CN14,CN16,CN18,CN2,CN20,CN22,CN24,CN4,CN6,CN8
24SKT DIMM DDR4 288P DDR4288V0513TFDDR4288V0513TF
25SKT DIMM DDR4 288P 10124632-1031103LF10124632-1031103LF
26SKT DIMM DDR4 288P 78726-104078726-1040CN1,CN11,CN13,CN15,CN17,CN19,CN21,CN23,CN3,CN5,CN7,CN9
27SKT DIMM DDR4 288P DDR4288V0523TFDDR4288V0523TF
28SKT DIMM DDR4 288P 10124632-1031003LF10124632-1031003LF
29BACK PLATE FOR CPU PT44P11-4801PT44P11-4801TP1324,TP1327
30BACK PLATE ASSEMBLY AHSK0010-P003CAHSK0010-P003C
31BACKPLATE SKX EP NRW 2299805-12299805-1
32BOLSTER SKX EP FOR WNMEL60-80N00-EHWNMEL60-80N00-EHTP1322,TP1328
33ILM PLATE+COVER FOR CPU AZIF0090-P002CAZIF0090-P002C
34PLATE SKX-EP NRW-NF 2299804-12299804-1
35SOLDER PASTE PF606-P (TYPE 4:20~38UM)P0606X409504200
36SOLDER BAR PF529-BB1529X10KX413
37SOLDER BAR PF531-B MAIN ALLOY SN/AG0.3/XB1531X10KX413
38LED D2.9 AMB/GRN LTL-14CAJHBPLTL-14CAJHBPLED45
39LED AMB/GRN 1H0302A1G100MA01 DIP1H0302A1G100MA01
40XTOR PN2907AL-AT/P PNP TO-92PN2907AL-T92-BQ11,Q12
41XTOR PNP 2SB2907A_B0_00001 TO-92 AMMO2SB2907A_B0_00001
42LED RED LTL-4221NHBPLTL-4221NHBPLED46
43LED RED 1H0301I10000DA01 DIP1H0301I10000DA01
44HEAD ML 2R24P ST 87831-2420 ,PA6T87831-2420CNC4,CNC5
45HEAD ML 2R24P ST G8232412YBEU ,NYLON4TG8232412YBEU
46HEAD ML 2R14P ST 87831-142887831-1428CN99,CNC1
47HEAD ML 2R14P ST A2005WV0-2CX7P-6T-00A2005WV0-2CX7P-6T-00
48HEAD ML 2R14P A2003WV0-2AX7PAA2003WV0-2Ax7PA-6T-GPCN91
49HEAD ML 2R14P 220-H97-07GB25 G/F BLACK220-H97-07GB25
50HEAD ML 2R18P ST 87831-182187831-1821CN71,CN97
51HEAD ML 2R18P G8231813YBEU MP, NY4TG8231813YBEU
52HEAD ML 1R3P 21S-91-03GB01 W/JUMPER G/F21S-91-03GB01JP10,JP11,JP12,JP13,JP15,JP19,JP2,JP9,JPB1,JPC1,JPC2,JPC3,JPC4
53HEAD ML 1R3P CH31032V2S6 W/JUMPER G/FCH31032V2S6
54HEAD ML 1R4P ST 210-91-04GB01 ,PA9T210-91-04GB01JP17,JP18
55HEAD ML 1R4P ST A2541WV0-1LX4PA-6TA2541WV0-1Lx4PA-6T
56HEAD ML 1R4P ST 50426-00471-001 ,PA6T50426-00471-001JP3
57HEAD ML 1R4P ST 53290-048053290-0480
58HEAD ML 2R16P(-1#14) 210-92-08GB69 BLACK210-92-08GB69CN107
59HEAD ML 2R16P ST A2541WV0-2CX8PA-6T-Q4A2541WV0-2Cx8PA-6T-Q4
60HEAD ML 1R3P ST 210-91-03GB01 ,PA9T210-91-03GB01JP1,JP16,JP25,JP26,JP27,JP28,JP29
61HEAD ML 1R3P ST D2.54 A2541WV0-1QX3PA-6TA2541WV0-1Qx3PA-6T
62SKT RJ45 12P ABA-JKM-008-P03ABA-JKM-008-P03CN106
63HOLDER BTY CR2032 KB6666BP5L-BKB6666BP5L-BBATCN1
64HOLDER BATTERY CR2032, PA9TBB7020E-T
65BTY RTC CR2032 MITSUBISHI (NICKEL-PLATEDCR2032 MITSUBISHITP1412
66BTY RTC CR2032 JHT 210MAH (NICKEL-PLATEDCR2032 JHT
67LBL POLYIMIDE31.8*6.35 BARCODE40.58D03.001TP1419,TP1466
68SPACER PCB NYLON 66 WINDMILLQLK-10TP1396,TP1397
69HSINK_53X53X10_PUSHPIN_PCH_CMECC-01324-01-GPTP1411
70HSINK_53X53X10_PUSHPIN_PCH_AAVID651393
71MYLAR_MB_SERVICE_OLYMPUS
72LATCH M2 CLIP OLYMPUSULCNA2.5-1.8GRTP1413,TP1414,TP1415,TP1416
73CONN CTR 11P 91932-32111LF SMD91932-32111LFCN103
74CONN CTR 60P BSH-030-01-H-D-A-TR SMDBSH-030-01-H-D-A-TRXDP1
75CONN NPIO 80P 173162-0338 SMD173162-0338CNB3
76CONN PCIE 80P LDN2803-57CH0-9H SMD,LCPLDN2803-57CH0-9H
77CONN WTB WAFER 1R4P 10114828-10204LF LCP10114828-10204LFCNC3
78HEAD SMD ML 4P CI4404M1VRG-NHCI4404M1VRG-NH
79SKT MINI PCIE 67P G633B067034MEU SMDG633B067034MEUCN41,CN42,CNB1,CNB2
80SKT MINI PCIE/SATA KEY:M 67P 80159-422580159-4225
81SKT MINI PCIE 67P 10130616-067RDLF SMD10130616-067RDLF
82SKT LGA3647-P0 B PE36473-01NK4-1H V1.0PE36473-01NK4-1HSKU1B1,SKU2B1
83SKT LGA3647-P0 LEFT 2-2129710-5 BLACK2-2129710-5
84SKT LGA3647-P0 A PE36473-01NK3-1H V1.0PE36473-01NK3-1HSKU1A1,SKU2A1
85SKT LGA3647-P0 RIGHT 2-2129710-6 YELLOW2-2129710-6
86CHIP RES 0.0005 F 3W 2512 HFLR2512-23R0005F4PAD1,PAD2
87PR2512FKE7T0U5Z
88RLM25FEGMR50M
89CHIP RES 249R B 1/16W 0402RE0402BRE07249RLR36,R72
90RM04BTN2490
91RTT022490BTH
92WF04H2490BTL
93CHIP BEAD 22N K MLH2012F22NKTMLH2012F22NKTL8
94CHIP BEAD 22N K BKPB002012C522NKA2BKPB002012C522NKA2
95CHIP IND 150NH K HCUVE966490D-151(FIONA)HCUVE966490D-151
PL10,PL11,PL14,PL15,PL16,PL21,PL22,PL23,PL29,PL3,PL30,PL31,PL32,PL33,PL34,PL4,PL40,PL41,PL42,PL47,PL48,PL49,PL5,PL57,PL6,PL61,PL7,PL8
96CHIP IND 150NH K PG1712.151HLPG1712.151HL
97CHIP IND 150NH K FB13A-150K SMDFB13A-150K
98CHIP CHOKE 3.3U M PCMB053T-3R3MSPCMB053T-3R3MSPL63
99CHIP IND 3.3UH J MHCI05030C-3R3M-R8WNMHCI05030C-3R3M-R8WN
100CHIP IND 0.68UH M CMME104T-R68MS1R607CMME104T-R68MS1R607PL73,PL74
101CHIP IND 0.68UH M MHCC10040-R68M-R7AWNMHCC10040-R68M-R7AWN
102IC ADC SYS ADC128D818CIMTX/NOPB TSSOP16PADC128D818CIMTX/NOPBU73
103IC CLK 9FGP204BKLF MLF 40P9FGP204BKLFU37
104IC BUFFER 9ZXL1231AKLFT MLF 64P9ZXL1231AKLFTU38
105IC BUFFER NB3W1200LMNTXG QFN 64PNB3W1200LMNTXG
106IC PCH LEWISBURG EY82C627 FCBGA1310957627 EY82C627 SR3HGU5
107IC SER FLASH MEMORY W25Q256JVFIQ SOIC16PW25Q256JVFIQU58,U59,U71,UB2
108IC FEROM MX25L25673GMI-08G SOP 16PMX25L25673GMI-08G
109IC SDRAM NT5CC128M16IP-DI FBGA96P DDR3LNT5CC128M16IP-DIU56
110IC SDRAM H5TC2G63GFR-PBA FBGA96P 1.35VH5TC2G63GFR-PBA
111IC SDRAM K4B2G1646F-BYK0 FBGA96P DDR3LK4B2G1646F-BYK0
112IC CPLD LCMXO2-2000HC-4FTG256C 256P CHECKSUM: 0X6033LCMXO2-2000HC-4FTG256CU99
113IC SWAP CTRL ADM1278-2ACPZ-RL LFCSP 32PADM1278-2ACPZ-RLU110
114IC SWAP CTRL ADM1278-1ACPZ LFCSP 32PADM1278-1ACPZ
115IC D-CAP TPS53659RSBR QFN 40PTPS53659RSBRPU12,PU16,PU22,PU36,PU40,PU46,PU54
116IC D-CAP TPS53679 QFN 40PTPS53679PU28,PU4
117IC LDO TPS74801DRCR DRC 10PTPS74801DRCRPU61
118IC LDO NCP59748MN1ADJTBG DFN 10PNCP59748MN1ADJTBG
119IC LDO POWER RTQ2522AGQW(2) WDFN-10LRTQ2522AGQW(2)
120IC BUCK CON CSD95480RWJ SON 41P(MONICA)CSD95480RWJ
PU10,PU13,PU14,PU17,PU18,PU19,PU23,PU24,PU25,PU29,PU30,PU31,PU32,PU33,PU34,PU37,PU41,PU42,PU43,PU47,PU48,PU49,PU5,PU56,PU6,PU7,PU8,PU9
121IC SPS FDMF3170 PQFN 41P RVE.D3(MONICA)FDMF3170
122IC BUCK CONVERTER CSD95492QVM SON18P MPCSD95492QVMPU11,PU20,PU26,PU35,PU44,PU50
123IC DIODE SW BAS70C_R1_00001 SOT-23BAS70C_R1_00001D15
124IC DIODE SW BAS70-05,215 SOT-23BAS70-05,215
125IC DIODE S.B BAS70-05-7-F SOT-23 3PBAS70-05-7-F
126IC DIODE ESD PROT RF3077-000 1004 DFNRF3077-000U84,U85
127IC ESD ARR AZ1045-04F.R7 DFN2510P10E 10PAZ1045-04F.R7G
128IC FET MOS SSM6N7002KFU NC US6 ESD 2KVSSM6N7002KFU
PU55,U100,U101,U102,U103,U207,U221,U252,U255,U262,U47,U50,U51,U52,U53,U54,U62,U63,U64,U65,U66,U67,U89,U92,UB5,UB6,UC10,UC3,UC4,UC5,UC9
129IC FETMOS DMN63D1LDW-7 NC SOT-363 ESD 2KDMN63D1LDW-7
130IC FET MOS 2N7002KDW NC SOT-363 2KV2N7002KDW
131IC FET MOS CSD87350Q5D SON 8PCSD87350Q5DPU1,PU3
132CHIP CAP C 1UF 25V K0402 X6SGRM155C81E105KE11DPC1441,PC1443
133TMK105AC6105KV-F
134CHIP CAP C 1U 16V K0402 X6SC1005X6S105KET
135GRM155C81C105KE15D
1360402S105K160CT
137CHIP CAP C 10UF 25V M0805 X7SC2012X7S106MFPCB39,CB40,CB41,CB42,CB43,CB44,CB45,CB46,CB47,CB48,CB49,CB50
138GRM21BC71E106ME11L
139CHIP CAP C 10UF 16V M0805 X7R0805B106M160CT
140C2012X7R106MEP
141GRM21BR71C106ME51L
142EMK212BB7106MG-T
143CHIP CAP C 100U 4V M0805 X5RGRM21BR60G107ME15LPC1075,PC1076,PC192,PC193,PC194,PC336,PC337,PC494,PC495,PC773,PC774,PC775,PC917,PC918
144AMK212BBJ107MG-T
145CHIP CAP C 22U 25V K1206 X6SGRM31CC81E226KE11KPC1194,PC1195,PC1401,PC1402,PC1403,PC1412,PC1431,PC1432,PC1461,PC1467,PC207
146CHIP CAP C 22U 25V K1206 X6SGRM31CC81E226KE11L
1471206S226K250CT
148CHIP CAP C 22UF 16V K1206 X6SGRM31CC81C226KE15L
149CL31X226KOHN3NE
150EMK316BC6226KL-T
151CHIP CAP C 47U 16V M1206 X5RGRM31CR61C476ME44LC988,C995
152CC1206MKX5R7BB476
153EMK316BBJ476ML-T
154CHIP CAP C 47UF 16V M1210 X6SGRM32EC81C476ME15L
PC261,PC262,PC263,PC264,PC265,PC266,PC267,PC268,PC269,PC270,PC271,PC272,PC273,PC274,PC275,PC288
155EMK325AC6476MM-P
156C3225X6S476MEP
157CHIP CAP EL 1000U 16V M 10*10.5 TPV16TPV1000M10X10.5TC2,TC4,TC6,TC8
158CHIP CAP EL 1000U 16V M 10*10.5VZH102M1CTR-1010
159CHIP CAP 270UF 16V M 6.3*9.9 SVPG OS-CON16SVPG270MPTC1,PTC14,PTC20,PTC24,PTC6
160CHIP CAP EL POLY 270UF 16V M 6.3*9.7160AV5K271M0610CE10
161XTAL 25MHZ 20PF 20PPM SMD TXC7M25020015X1,XC1
162XTAL 25MHZ 20PF 20PPM TSX-3225 SMDX1E000021098400
163XTAL 48MHZ 30PPM 10.0PF 7M48020003 SMD7M48020003X3
164XTAL 48MHZ 10PF 3.2*2.5 X3S048000FA1H-HVX3S048000FA1H-HV
165XTAL 48MHZ 10P30PPM E3SB48E00001KEE3SB48E00001KE
166DIODE S.B SS1020FL 1A20V SOD-123FLSS1020FL_R1_00001PD1,PD2
167DIODE S.B. LMBR120FT1G SOD-123FLLMBR120FT1G
168FET MOS PH0925CL,115 NC LFPAK 4PPH0925CL,115Q24,Q25,Q28,Q30,Q33,Q34,Q51
169FET MOS IRFH8201TRPBF PQFN 5X6 8PIRFH8201TRPBF
170XTOR MMBT3904FN3 NPN DFN 3PMMBT3904FN3PQ6
171XTOR PMBT3904M,315 NPN SOT883PMBT3904M,315
172SCRW_THUMB_M3X0.5X5.6_T8_C2010YSMTPF-56415-ETH9
173SCRW_THUMB_MB_T8_SOUTH_C2010J-4C-SM-99-153
174SCRW_THUMB_M3X0.5_T8_FIVE_RMB_C201029-150-301-5-RL
175CONN CTR 36P MINI SAS G40H2132212HR-WG40H2132212HR-WCN100,CN56
176CONN MINI-SAS HD 36P C29711-13633-L, LCPC29711-13633-L
177CONN MINI-SAS HD 36P 10127912-1102LF10127912-1102LF
178CHIP RES 0 J 1/10W 0603RM06JTN0PR1011,PR1958,PR505,PR512,PR514,PR521,PR818,PR836,PR901,RB88
179RTT03000JTP
180RC0603JR-070RL
181WR06X000PTL
182CHIP RES 150K J 1/16W 0402RM04JTN154R1546
183RTT02154JTH
184RR-0510S-154-JN
185RC0402JR-07150KL
186CHIP RES 1 J 1/8W 0805RM10JTN1R0PR826,PR844
187RTT051R0JTP
188RC0805JR-071RL
189WR08X1R0JTL
190CHIP RES 2 J 1/16W 0402RTT022R0JTHR220,R221,R222,R229,R230,R231,R276,R277,R278,R285,R286,R287
191RR0510S-2R0-JN
192RM04JTN2R0
193WR04X2R0JTL
194RC0402JR-072RL
195CHIP RES 2.7 J 1/10W 0603RM06JTN2R7PR823,PR841
196RTT032R7JTP
197RC0603JR-072R7L
198CHIP RES 0 J 1/4W 1206 (ROHS)RM12JTN0PR944,PR945,PR953,PR956,PR997,PR998
199RTT06000JTP
200RC1206JR-070RL
201WR12X000 PTL
202CHIP RES 0 J 1/10W 0603 13" REELRC0603JR-130RLPR1005,PR1010
203RTT03000JP4
204WR06X000PGL
205RM06JHN0
206CHIP RES 0 J 1/16W 0402 13" REELRC0402JR-130RLPR15,PR1956,PR28,PR29
207RTT02000JH5
208WR04X000 PHL
209RM04JLN0
210CHIP RES 0.0005 F 1W 2512PR2512FKE070U5ZPR18,PR418
211LR2512-21R0005F4
212CHIP RES 0.0005 F 1W 0612WSK0612L5000FEAPADC1,PADC2
213RL1632L4-0R5M-FN
214CHIP RES 100 F 1/10W 0603RM06FTN1000PR125,PR525,R1573
215RTT031000FTP
216RC0603FR-07100RL
217CHIP RES 100 F 1/16W 0402RM04FTN1000
PR151,PR160,PR31,PR32,PR362,PR40,PR41,PR431,PR432,PR440,PR441,PR457,PR551,PR560,PR57,PR762,R1009,R103,R1034,R112,R121,R1529,R1530,R154,R180,R1894,R191,R2,R2164,R2165,R2166,R2167,R2168,R2169,R2174,R235,R236,R291,R292,R39,R4,R41,R427,R434,R435,R441,R442,R443,R444,R470,R471,R491,R493,R736,R94,R981,RB48,RC139,RC157,RC172,RC173
218RTT021000FTH
219RR0510S-1000-FN
220RC0402FR-07100RL
221WR04X1000FTL
222CHIP RES 1K F 1/16W 0402RM04FTN1001
PR261,PR265,PR302,PR323,PR329,PR358,PR661,PR759,R1075,R1081,R1082,R1088,R1089,R1109,R1133,R1134,R1421,R1553,R158,R187,R197,R202,R203,R2063,R208,R209,R2103,R214,R217,R218,R219,R223,R224,R225,R226,R227,R228,R232,R233,R234,R273,R274,R275,R279,R280,R281,R282,R283,R284,R288,R289,R290,R322,R335,R336,R347,R409,R410,R411,R418,R419,R420,R421,R428,R429,R430,R440,R446,R502,R507,R514,R516,R517,R520,R522,R523,R525,R526,R528,R529,R550,R552,R557,R563,R568,R569,R571,R574,R575,R578,R582,R583,R733,R734,R741,R766,R767,R768,R769,R783,R817,R818,R819,R915,R926,R927,R928,R931,R935,R936,R937,RB85,RB86,RC108,RC129,RC135,RC140,RC141,RC142,RC144,RC145,RC147,RC149,RC150,RC152,RC175,RC53,RC55,RC92
223RTT021001FTH
224RR0510S-102-FN
225RC0402FR-071KL
226WR04X1001FTL
227CHIP RES 1K B 1/16W 0402RR0510Q-102-BNR478,R479
228RTX021001BETH
229RB04BTS1001
230RT0402BRE071KL
231WF04T1001BTL
232CHIP RES 10K F 1/10W 0603RM06FTN1002PR13,PR1951
233RTT031002FTP
234RC0603FR-0710KL
235CHIP RES 10K F 1/16W 0402RM04FTN1002
PR1001,PR135,PR137,PR138,PR139,PR1957,PR1959,PR227,PR228,PR229,PR23,PR230,PR231,PR24,PR25,PR26,PR27,PR309,PR314,PR317,PR324,PR325,PR326,PR327,PR328,PR406,PR411,PR414,PR423,PR424,PR425,PR426,PR427,PR535,PR537,PR538,PR539,PR627,PR628,PR629,PR630,PR631,PR709,PR714,PR717,PR724,PR725,PR726,PR727,PR728,PR806,PR811,PR814,PR822,PR835,PR840,PR853,PR868,PR871,PR874,PR876,PR877,PR878,PR879,PR902,PR915,PR951,PR954,R10,R1019,R1030,R1080,R1097,R1098,R1099,R1100,R1591,R1706,R1709,R1711,R1828,R1871,R1872,R1873,R1900,R1939,R2040,R2041,R2173,R447,R448,R449,R45,R46,R47,R480,R497,R498,R499,R501,R521,R527,R530,R531,R534,R535,R536,R547,R548,R553,R561,R573,R577,R580,R586,R587,R588,R645,R646,R653,R663,R666,R671,R673,R7,R752,R753,R757,R762,R771,R9,R953,R977,R979,R980,R983,R984,R996,RB111,RB24,RB42,RB7,RB73,RB74,RC109,RC160,RC180,RC19,RC20,RC21,RC22,RC97,RD1,RD2,RD3,RD4,RD5,RD6,RD7,RD8,RD9,RF10
236RTT021002FTH
237RR0510S-103-FN
238RC0402FR-0710KL
239WR04X1002FTL
240CHIP RES 100K F 1/16W 0402RM04FTN1003
PR1000,R1537,R1560,R1563,R1566,R2046,R2049,R2053,R2054,R2055,R2056,R2061,R2071,R2089,R2114,R2117,R2118,R2119,R2123,R37,R85,R933,RC64,RC65,RC67,RC69,RC73,RC74
241RTT021003FTH
242RR0510S-104-FN
243RC0402FR-07100KL
244WR04X1003FTL
245CHIP RES 1M F 1/10W 0603RM06FTN1004R1578,R1580,R537
246RTT031004FTP
247RC0603FR-071ML
248WR06X1004FTL
249CHIP RES 10M F 1/10W 0603RM06FTN1005R468
250RTT031005FTP
251RC0603FR-0710ML
252CHIP RES 10.2K F 1/16W 0402RM04FTN1022PR1006,PR1960
253RTT021022FTH
254RR0510S-1022-FN
255RC0402FR-0710K2L
256CHIP RES 10 F 1/10W 0603RM06FTN10R0PR1014
257RTT0310R0FTP
258RC0603FR-0710RL
259WR06X10R0FTL
260CHIP RES 10 F 1/16W 0402RM04FTN10R0
PR1007,PR1961,PR312,PR409,PR712,PR809,PR825,PR843,PR859,PR860,PR905,R1129,R1532,R1540,R1541,R1544,R1545,R1555,R1556,R213,R245,R247,R253,R255,R261,R263,R269,R271,R464,R476,R670,R674,R775,R776,R777,R778,R779,R780,R781,R782
261RTT0210R0FTH
262RR0510S-100-FN
263RC0402FR-0710RL
264WR04X10R0FTL
265CHIP RES 110K F 1/16W 0402RM04FTN1103
PR100,PR109,PR112,PR118,PR131,PR273,PR282,PR291,PR370,PR379,PR388,PR473,PR482,PR491,PR500,PR509,PR518,PR673,PR682,PR691,PR73,PR74,PR770,PR779,PR788,PR82,PR91,PR94
266RTT021103FTH
267RR0510S-1103-FN
268RC0402FR-07110KL
269WR04X1103FTL
270CHIP RES 113 F 1/16W 0402RM04FTN1130R469
271RTT021130FTH
272RR0510S-1130-FN
273RC0402FR-07113RL
274CHIP RES 120 F 1/10W 0603RM06FTN1200PR298,PR395,PR698,PR795
275RTT031200FTP
276RC0603FR-07120RL
277CHIP RES 12.1K F 1/16W 0402RM04FTN1212R1543
278RTT021212FTH
279RR0510S-1212-FN
280RC0402FR-0712K1L
281WR04X1212FTL
282CHIP RES 121K F 1/16W 0402RM04FTN1213PR851
283RTT021213FTH
284RR0510S-1213-FN
285RC0402FR-07121KL
286CHIP RES 124 F 1/16W 0402RM04FTN1240PR235,PR332,PR640,PR732
287RTT021240FTH
288RR0510S-1240-FN
289RC0402FR-07124RL
290CHIP RES 1.24K F 1/16W 0402RM04FTN1241R1822,R1823,R607,R608,RC18
291RTT021241FTH
292RR0510S-1241-FN
293RC0402FR-071K24L
294WR04X1241FTL
295CHIP RES 13K F 1/16W 0402RM04FTN1302R1564
296RTT021302FTH
297RR0510S-1302-FN
298RC0402FR-0713KL
299WR04X1302FTL
300CHIP RES 133K F 1/16W 0402RM04FTN1333PR243
301RTT021333FTH
302RR0510S-1333-FN
303RC0402FR-07133KL
304CHIP RES 13.7K F 1/16W 0402RM04FTN1372PR1002
305RTT021372FTH
306RR0510S-1372-FN
307RC0402FR-0713K7L
308CHIP RES 14K F 1/16W 0402RM04FTN1402R1132,R1579,R2048
309RTT021402FTH
310RR0510S-1402-FN
311RC0402FR-0714KL
312CHIP RES 140K F 1/16W 0402RM04FTN1403PR833
313RTT021403FTH
314RR0510S-1403-FN
315RC0402FR-07140KL
316CHIP RES 1.43K F 1/16W 0402RC0402FR-071K43LRF9
317RR0501S-1431-FN
318RTT021431FTH
319RM04FTN1431
320CHIP RES 150 F 1/16W 0402RM04FTN1500
PR167,PR251,PR348,PR447,PR47,PR567,PR651,PR747,R1101,R1102,R1103,R1104,R1105,R1106,R1107,R1108,R12,R13,R170,R171,R174,R175,R176,R189,R210,R211,R423,R424,R425,R426,R432,R433,R436,R437,R438,R44,R48,R50,R737,R738,R739,R740,R8,RC32,RC33,RC34
321RTT021500FTH
322RR0510S-1500-FN
323RC0402FR-07150RL
324WR04X1500FTL
325CHIP RES 1.5K F 1/16W 0402RM04FTN1501R1987,R2015,R2031,R2032,R2039,R820,R821
326RTT021501FTH
327RR0510S-152-FN
328RC0402FR-071K5L
329WR04X1501FTL
330CHIP RES 154K F 1/16W 0402RM04FTN1543PR44,PR444
331RTT021543FTH
332RR0510S-1543-FN
333RC0402FR-07154KL
334CHIP RES 169 F 1/16W 0402RM04FTN1690R461
335RTT021690FTH
336RR0510S-1690-FN
337RC0402FR-07169RL
338CHIP RES 1.74K F 1/16W 0402RM04FTN1741R1317,R1321,R1350,R1535,R1979,R1981,R2000,R2002,R2059,RB13
339RTT021741FTH
340RR0510S-1741-FN
341RC0402FR-071K74L
342CHIP RES 1.8K F 1/16W 0402RM04FTN1801PR824,R42,R43,R5,R6,R925,R930
343RTT021801FTH
344RR0510S-182-FN
345RC0402FR-071K8L
346CHIP RES 19.6K F 1/16W 0402RTT021962FTHPR912
347RR0510S-1962-FN
348RM04FTN1962
349RC0402FR-0719K6L
350CHIP RES 1 F 1/10W 0603RM06FTN1R00PR171,PR256,PR353,PR451,PR51,PR571,PR656,PR753,PR890
351RTT031R00FTP
352RC0603FR-071RL
353WR06W1R00FTL
354CHIP RES 1 F 1/16W 0402RTT021R00FTHPR162,PR244,PR267,PR341,PR364,PR42,PR442,PR562,PR644,PR667,PR741,PR764,PR873,PR888
355RR0510S-1R0-FN
356RM04FTN1R00
357RC0402FR-071RL
358WR04W1R00FTL
359CHIP RES 200 F 1/16W 0402RM04FTN2000R130,R152,R157,R167,R1977,R1978,R2004,R2005,R439,R681,R682,R683,R684,R685,R686,R687,R688
360RTT022000FTH
361RR0510S-201-FN
362WR04X2000FTL
363RC0402FR-07200RL
364CHIP RES 20K F 1/16W 0402RM04FTN2002PR313,PR410,PR713,PR810,PR834,PR852,R570,R576,R581,RC52,RC54
365RTT022002FTH
366RR0510S-203-FN
367RC0402FR-0720KL
368WR04X2002FTL
369CHIP RES 200K F 1/16W 0402RM04FTN2003R467,R929
370RTT022003FTH
371RR0510S-204-FN
372RC0402FR-07200KL
373WR04X2003FTL
374CHIP RES 20 F 1/16W 0402RM04FTN20R0R246,R248,R254,R256,R262,R264,R270,R272
375RTT0220R0FTH
376RR0510S-200-FN
377RC0402FR-0720RL
378CHIP RES 220 F 1/16W 0402RM04FTN2200R1022,R1125,R1278,R1279,R1497,R1498,R18,R21,R489,R55,R58,R680,R960,R982,R990,RB26,RB27,RD15
379RTT022200FTH
380RR0510S-221-FN
381RC0402FR-07220RL
382CHIP RES 2.21K F 1/16W 0402RM04FTN2211
PR842,PR904,R141,R1428,R1429,R1625,R1629,R1635,R1639,R1645,R1649,R1674,R1675,R1676,R1677,R1678,R1679,R1682,R1683,R1684,R1685,R1688,R1689,R1690,R1691,R1694,R1695,R1696,R1697,R1700,R1701,R1704,R1705,R2050,R2051,R2064,R402,R457,R458,R482,R555,R556,RC13,RC15,RG2,RG4,RG6,RG8
383RTT022211FTH
384RR0510S-2211-FN
385RC0402FR-072K21L
386CHIP RES 22 F 1/16W 0402(ROHS)RM04FTN22R0
R1720,R2171,R321,R323,R324,R325,R326,R466,R647,R655,R656,R658,R659,RB1,RC1,RC11,RC12,RC16,RC2,RC24,RC25,RC26,RC3,RC4,RC5,RC6,RC95
387RTT0222R0FTH
388RR0510S-220-FN
389RC0402FR-0722RL
390CHIP RES 240 F 1/16W 0402(ROHSRM04FTN2400
R215,R216,R241,R242,R249,R250,R257,R258,R265,R266,R378,R380,R382,R386,R395,R398,R400,R459,R460,R462,R463,R732
391RTT022400FTH
392RR0510S-241-FN
393RC0402FR-07240RL
394CHIP RES 243K F 1/16W 0402RM04FTN2433PR128,PR528
395RTT022433FTH
396RR0510S-2433-FN
397RC0402FR-07243KL
398CHIP RES 26.1K F 1/16W 0402RM04FTN2612R1777
399RTT022612FTH
400RR0510S-2612-FN
401RC0402FR-0726K1L
402CHIP RES 2.67K F 1/16W 0402RM04FTN2671PR1963
403RTT022671FTH
404RR0510S-2671-FN
405RC0402FR-072K67L
406CHIP RES 2.7K F 1/16W 0402RM04FTN2701PR946,R677,R724,R725,R726,R785,R787,R788,R932,RB20,RB21,RC35,RC38
407RTT022701FTH
408RR0510S-2701-FN
409RC0402FR-072K7L
410CHIP RES 27K F 1/16W 0402RM04FTN2702R1577
411RTT022702FTH
412RR0510S-273-FN
413RC0402FR-0727KL
414CHIP RES 274 F 1/16W 0402RTT022740FTHR626
415RC0402FR-07274RL
416WR04X2740FTL
417RM04FTN2740
418CHIP RES 27.4 F 1/16W 0402RM04FTN27R4R1300,R1301,R356,R357,R358,R359,R360,R361,R362,R363,R364,R365,R366,R367,RB40,RB41
419RTT0227R4FTH
420RR0510S-27R4-FN
421RC0402FR-0727R4L
422WR04X27R4FTL
423CHIP RES 280 F 1/16W 0402RM04FTN2800PR22
424RC0402FR-07280RL
425RR0510S-2800-FN
426WR04X2800FTL
427RTT022800FTH
428CHIP RES 2.2 F 1/10W 0603RM06FTN2R20
PR1003,PR101,PR108,PR117,PR119,PR12,PR127,PR132,PR136,PR272,PR281,PR290,PR300,PR304,PR308,PR369,PR378,PR387,PR397,PR401,PR405,PR472,PR481,PR490,PR499,PR508,PR517,PR527,PR532,PR672,PR681,PR690,PR700,PR704,PR708,PR72,PR769,PR778,PR787,PR797,PR801,PR805,PR81,PR83,PR90,PR900,PR99,R317,R318,R319,R331,R334
429RC0603FR-072R2L
430RTT032R20FTP
431WR06W2R20FTL
432CHIP RES 2.2 F 1/16W 0402RM04FTN2R20
PR104,PR105,PR113,PR122,PR123,PR144,PR276,PR285,PR294,PR373,PR382,PR391,PR477,PR486,PR495,PR504,PR513,PR522,PR676,PR685,PR694,PR77,PR773,PR782,PR791,PR86,PR87,PR95
433RC0402FR-072R2L
434RTT022R20FTH
435RR0510S-2R2-FN
436WR04W2R20FTL
437CHIP RES 30.1K F 1/16W 0402RM04FTN3012PR1012,PR14
438RTT023012FTH
439RR0510S-3012-FN
440RC0402FR-0730K1L
441CHIP RES 309K F 1/16W 0402RM04FTN3093PR443
442RTT023093FTH
443RR0510S-3093-FN
444RC0402FR-07309KL
445CHIP RES 3.16K F 1/16W 0402RM04FTN3161R1594
446RTT023161FTH
447RR0510S-3161-FN
448RC0402FR-073K16L
449WR04X3161FTL
450CHIP RES 3.3K F 1/16W 0402RM04FTN3301
PR958,R1419,R1420,R1422,R1423,R1436,R1437,R1439,R1833,R1834,R2113,R692,R696,R697,R699,R700,R701,R705,R707,R710,R711,R712,R713,R717,R833,R834,RC158,RC159
451RTT023301FTH
452RR0510S-332-FN
453RC0402FR-073K3L
454CHIP RES 33 F 1/16W 0402RM04FTN33R0
R1037,R1038,R1040,R1041,R1417,R1418,R1424,R1425,R160,R163,R165,R166,R1805,R181,R182,R183,R184,R1868,R1899,R192,R193,R194,R195,R2018,R2074,R2075,R2110,R297,R416,R483,R484,R485,R486,R490,R494,R495,R546,R558,R572,R623,R627,R628,R629,R630,R631,R632,R633,R634,R649,R650,R660,R722,R723,R731,R742,R743,R744,R745,R748,R749,R750,R751,R758,R759,R760,R761,R764,R765,R770,R772,R784,R796,R829,R830,R837,R838,R843,R844,R845,R846,R855,R856,R880,R896,R951,R955,RB110,RB121,RB75,RC98
455RTT0233R0FTH
456RR0510S-330-FN
457RC0402FR-0733RL
458WR04X33R0FTL
459CHIP RES 348 F 1/16W 0402RM04FTN3480R243,R244,R251,R252,R259,R260,R267,R268,R902
460RR0510S-3480-FN
461RC0402FR-07348RL
462RTT023480FTH
463CHIP RES 3.57K F 1/16W 0402RM04FTN3571PR960
464RTT023571FTH
465RR0510S-3571-FN
466RC0402FR-073K57L
467CHIP RES 3.74K F 1/16W 0402RM04FTN3741R1551
468RTT023741FTH
469RR0510S-3741-FN
470RC0402FR-073K74L
471WR04X3741FTL
472CHIP RES 37.4K F 1/16W 0402RM04FTN3742PR163,PR342,PR563,PR742,PR865,PR866,R2156
473RTT023742FTH
474RR0510S-3742-FN
475RC0402FR-0737K4L
476CHIP RES 39.2K F 1/16W 0402RM04FTN3922R1778
477RTT023922FTH
478RR0510S-3922-FN
479RC0402FR-0739K2L
480WR04X3922FTL
481CHIP RES 3.01 F 1/8W 0805RM10FTN3R01PR1008,PR16
482RTT053R01FTP
483CHIP RES 402 F 1/16W 0402RM04FTN4020RF3,RF6
484RTT024020FTH
485RR0510S-4020-FN
486RC0402FR-07402RL
487CHIP RES 422 F 1/16W 0402RTT024220FTHPR870
488RR0510S-4220-FN
489RM04FTN4220
490RC0402FR-07422RL
491CHIP RES 442 F 1/16W 0402RM04FTN4420R1061,R1065,R1069
492RTT024420FTH
493RR0510S-4420-FN
494RC0402FR-07442RL
495CHIP RES 4.42K F 1/16W 0402(RORR0510S-4421-FNR1316,R1349
496RTT024421FTH
497RM04FTN4421
498WR04X4421FTL
499RC0402FR-074K42L
500CHIP RES 44.2K F 1/16W 0402RTT024422FTHPR830
501RR0510S-4422-FN
502RM04FTN4422
503RC0402FR-0744K2L
504WR04X4422FTL
505CHIP RES 442K F 1/16W 0402RM04FTN4423PR301,PR398,PR701,PR798
506RTT024423FTH
507RR0510S-4423-FN
508RC0402FR-07442KL
509CHIP RES 45.3K F 1/16W 0402RM04FTN4532PR909
510RTT024532FTH
511RR0510S-4532-FN
512RC0402FR-0745K3L
513WR04X4532FTL
514CHIP RES 45.3 F 1/16W 0402RM04FTN45R3PR861
515RTT0245R3FTH
516RR0510S-45R3-FN
517RC0402FR-0745R3L
518WR04X45R3FTL
519CHIP RES 46.4K F 1/16W 0402RM04FTN4642PR161
520RTT024642FTH
521RR0510S-4642-FN
522RC0402FR-0746K4L
523CHIP RES 4.7K F 1/16W 0402RM04FTN4701
PR947,R1018,R1062,R1066,R1070,R1074,R1084,R11,R1112,R1114,R1127,R1305,R1306,R132,R1320,R1353,R1354,R1365,R1366,R1376,R1377,R140,R1408,R1409,R1410,R142,R1448,R1449,R1452,R1455,R1489,R1491,R1531,R1536,R1571,R1572,R1587,R1598,R1623,R1624,R1698,R1708,R1712,R1713,R1767,R1768,R1771,R1772,R1775,R1776,R1780,R1787,R1808,R1809,R1810,R1811,R1814,R1861,R1862,R1864,R1865,R1866,R1867,R1874,R1885,R1901,R1902,R1904,R1905,R1913,R1959,R1960,R1961,R1962,R1963,R1980,R1982,R2058,R2176,R340,R341,R413,R454,R472,R487,R488,R49,R515,R518,R519,R524,R532,R538,R539,R541,R543,R584,R585,R591,R592,R664,R665,R672,R679,R730,R746,R755,R790,R791,R792,R793,R794,R795,R797,R798,R799,R800,R802,R803,R804,R805,R806,R807,R808,R809,R810,R815,R876,R877,R878,R894,R895,R897,R920,R921,R922,R950,R954,R988,R989,R991,R992,RB10,RB112,RB113,RB114,RB115,RB116,RB117,RB118,RB119,RB19,RB2,RB30,RB31,RB32,RB33,RB35,RB37,RB38,RB39,RB4,RB43,RB44,RB5,RC179,RC28,RC91,RD10,RD11,RG1,RG10,RG11,RG3,RG5,RG7
524RTT024701FTH
525RR0510S-472-FN
526RC0402FR-074K7L
527WR04X4701FTL
528CHIP RES 47K F 1/16W 0402RM04FTN4702PR999
529RTT024702FTH
我需要1RMB买文件,如有好心人可捐多谢
BOM (连续) BOM太长了, 一个帖子放不下
529RTT024702FTH530RR0510S-473-FN531RC0402FR-0747KL532WR04X4702FTL533CHIP RES 475 F 1/16W 0402RM04FTN4750R330,R422,R957,RC178534RTT024750FTH535RR0510S-4750-FN536RC0402FR-07475RL537WR04X4750FTL538CHIP RES 475K F 1/16W 0402RM04FTN4753PR43,PR828,PR846,PR906539RTT024753FTH540RR0510S-4753-FN541RC0402FR-07475KL542CHIP RES 49.9K F 1/16W 0402RM04FTN4992PR245,PR645,R1549,R1550,R678543RTT024992FTH544RR0510S-4992-FN545RC0402FR-0749K9L546WR04X4992FTL547CHIP RES 49.9 F 1/16W 0402RM04FTN49R9PR359,PR455,PR55,PR760,R1,R1303,R1393,R14,R15,R151,R179,R188,R198,R199,R204,R205,R22,R23,R24,R25,R3,R31,R32,R33,R34,R38,R40,R403,R405,R407,R408,R51,R52,R551,R59,R60,R61,R62,R67,R68,R69,R70,R735,R903,R904,R905,R906,R909,R910,R911,R912,RC138548RTT0249R9FTH549RR0510S-49R9-FN550RC0402FR-0749R9L551WR04X49R9FTL552CHIP RES 4.7 F 1/10W 0603RM06FTN4R70PR1964553RTT034R70FTP554RC0603FR-074R7L555WR06W4R70FTL556CHIP RES 510K F 1/16W 0402RM04FTN5103R1593557RTT025103FTH558RR0510S-514-FN559RC0402FR-07510KL560WR04X5103FTL561CHIP RES 51.1 F 1/16W 0402RM04FTN51R1PR186,PR586,R431,R445,R812562RTT0251R1FTH563RR0510S-51R1-FN564RC0402FR-0751R1L565CHIP RES 52.3K F 1/16W 0402RM04FTN5232PR561,R1570566RTT025232FTH567RR0510S-5232-FN568RC0402FR-0752K3L569CHIP RES 5.36K F 1/16W 0402RM04FTN5361R1552570RTT025361FTH571RR0510S-5361-FN572RC0402FR-075K36L573CHIP RES 5.62K F 1/16W 0402RM04FTN5621PR318,PR415,PR718,PR815,R934574RTT025621FTH575RR0510S-5621-FN576RC0402FR-075K62L577WR04X5621FTL578CHIP RES 5.76K F 1/16W 0402RTT025761FTHR1581579RR0510S-5761-FN580RM04FTN5761581RC0402FR-075K76L582CHIP RES 59K F 1/16W 0402RM04FTN5902PR740583RTT025902FTH584RR0510S-5902-FN585RC0402FR-0759KL586CHIP RES 6.19K F 1/16W 0402RM04FTN6191R1113587RTT026191FTH588RR0510S-6191-FN589RC0402FR-076K19L590WR04X6191FTL591CHIP RES 62K F 1/16W 0402(ROHSRC0402FR-0762KLPR1013592RM04FTN6202593RTT026202FTH594RR0510S-623-FN595CHIP RES 64.9 F 1/16W 0402RTT0264R9FTHR200,R201,R206,R207,R985596RC0402FR-0764R9L597RM04FTN64R9598RR0510S-64R9-FN599CHIP RES 68K F 1/16W 0402RM04FTN6802PR315,PR412,PR715,PR812600RTT026802FTH601RR0510S-683-FN602RC0402FR-0768KL603WR04X6802FTL604CHP RES 71.5K F 1/16W 0402RR0510S-7152-FNPR848605RTT027152FTH606RM04FTN7152607RC0402FR-0771K5L608CHIP RES 7.32K F 1/16W 0402RM04FTN7321PR1953,PR1962609RTT027321FTH610RR0510S-7321-FN611RC0402FR-077K32L612WR04X7321FTL613CHIP RES 7.5K F 1/16W 0402RM04FTN7501R1582614RTT027501FTH615RR0510S-7501-FN616RC0402FR-077K5L617WR04X7501FTL618CHIP RES 75 F 1/16W 0402RM04FTN75R0PR260,PR357,PR660,PR758,R155,R162,R164,R177,R190,RC10,RC7,RC8,RC9619RTT0275R0FTH620RR0510S-750-FN621RC0402FR-0775RL622WR04X75R0FTL623CHIP RES 8.2K F 1/16W 0402RM04FTN8201R667624RTT028201FTH625RR0510S-822-FN626RC0402FR-078K2L627CHIP RES 845 F 1/16W 0402RM04FTN8450PR867628RTT028450FTH629RR0510S-8450-FN630RC0402FR-07845RL631CHIP RES 86.6K F 1/16W 0402RM04FTN8662PR340632RTT028662FTH633RR0510S-8662-FN634RC0402FR-0786K6L635CHIP RES 88.7K F 1/16W 0402RM04FTN8872PR643636RTT028872FTH637RR0510S-8872-FN638RC0402FR-0788K7L639CHIP RES 90.9K F 1/16W 0402RM04FTN9092R1110640RTT029092FTH641RR0510S-9092-FN642RC0402FR-0790K9L643WR04X9092FTL644CHIP RES 909K F 1/16W 0402RM04FTN9093PR17645RTT029093FTH646RR0510S-9093-FN647RC0402FR-07909KL648CHIP RES 90.9 F 1/16W 0402RM04FTN90R9R237,R238,R239,R240,R293,R294,R295,R296649RTT0290R9FTH650RR0510S-90R9-FN651RC0402FR-0790R9L652CHIP RES 93.1K F 1/16W 0402RM04FTN9312R1561653RTT029312FTH654RC0402FR-0793K1L655CHIP RES 0 F 1/16W 0402RTT020000FTH
PR1,PR10,PR103,PR106,PR107,PR110,PR115,PR116,PR121,PR124,PR126,PR129,PR134,PR140,PR145,PR155,PR156,PR157,PR158,PR159,PR165,PR166,PR170,PR2,PR236,PR237,PR238,PR239,PR240,PR241,PR242,PR248,PR249,PR253,PR254,PR255,PR259,PR269,PR270,PR271,PR279,PR280,PR284,PR287,PR288,PR289,PR293,PR296,PR297,PR299,PR3,PR303,PR307,PR311,PR320,PR33,PR333,PR334,PR335,PR336,PR337,PR338,PR339,PR34,PR345,PR346,PR35,PR350,PR351,PR352,PR356,PR36,PR366,PR367,PR368,PR37,PR372,PR375,PR376,PR377,PR38,PR381,PR385,PR386,PR39,PR390,PR393,PR394,PR396,PR4,PR400,PR404,PR408,PR417,PR420,PR433,PR434,PR435,PR436,PR437,PR438,PR439,PR445,PR446,PR448,PR449,PR45,PR450,PR46,PR460,PR462,PR463,PR471,PR478,PR479,PR48,PR480,PR485,PR488,PR489,PR49,PR494,PR496,PR497,PR498,PR5,PR50,PR506,PR507,PR515,PR516,PR524,PR526,PR534,PR555,PR556,PR557,PR558,PR559,PR565,PR566,PR570,PR575,PR6,PR60,PR62,PR635,PR636,PR637,PR638,PR639,PR641,PR642,PR648,PR649,PR653,PR654,PR669,PR671,PR679,PR680,PR688,PR689,PR697,PR699,PR7,PR707,PR71,PR711,PR720,PR733,PR734,PR735,PR736,PR737,PR738,PR739,PR745,PR746,PR750,PR751,PR765,PR768,PR776,PR777,PR785,PR786,PR79,PR794,PR796,PR8,PR80,PR804,PR808,PR817,PR820,PR829,PR838,PR847,PR85,PR862,PR863,PR864,PR88,PR882,PR883,PR884,PR885,PR886,PR887,PR889,PR89,PR893,PR9,PR903,PR914,PR92,PR949,PR950,PR952,PR955,PR957,PR961,PR97,PR978,PR979,PR98,PR980,PR981,PR982,PR984,PR985,PR986,PR996,R1003,R1004,R1005,R1006,R1007,R1008,R1020,R1021,R1025,R1035,R1039,R104,R1057,R106,R1073,R1077,R1078,R1087,R1090,R113,R114,R116,R122,R124,R1277,R1280,R1281,R1282,R1283,R1285,R1286,R1287,R1288,R1289,R129,R1290,R1291,R1292,R1293,R1294,R1295,R1296,R1297,R1298,R1299,R1302,R1304,R1308,R1309,R1310,R1311,R1323,R1324,R1325,R1339,R1340,R1341,R1355,R1356,R1357,R1358,R1359,R1360,R1367,R1368,R1369,R1370,R1371,R1378,R1379,R1380,R1381,R1394,R1395,R1396,R1398,R1399,R1400,R1403,R1404,R1426,R1427,R1430,R1431,R1432,R1433,R1434,R1435,R1446,R1447,R1450,R1499,R1506,R1507,R1508,R1509,R1510,R1511,R1512,R153,R1533,R1534,R1538,R1539,R1547,R1558,R1559,R156,R1562,R1574,R1575,R1583,R1588,R159,R16,R1603,R1604,R1605,R1606,R161,R1615,R1616,R1617,R1618,R1619,R1620,R1621,R1622,R1626,R1627,R1628,R1630,R1631,R1632,R1636,R1637,R1638,R1640,R1641,R1642,R1644,R1646,R1647,R1648,R1650,R1651,R1652,R1667,R1668,R1670,R1671,R1672,R1673,R168,R1680,R1681,R1686,R1687,R169,R1692,R1693,R17,R1702,R1703,R1707,R1715,R1716,R1717,R1718,R1719,R172,R1721,R1722,R1723,R1724,R1726,R1727,R1728,R1729,R173,R1765,R1766,R1769,R1770,R1773,R1774,R178,R1782,R1783,R1784,R1785,R1786,R1788,R1789,R1790,R1791,R1797,R1798,R1799,R1800,R1801,R1802,R1803,R1806,R1807,R1815,R1819,R1820,R1821,R1824,R1825,R1826,R1827,R1829,R1830,R1831,R1832,R1835,R1836,R1837,R1838,R1839,R1840,R1841,R1842,R1843,R1844,R1845,R1846,R1847,R1848,R1849,R185,R1851,R1853,R1854,R1855,R1856,R1857,R1858,R1859,R186,R1860,R1863,R1870,R1875,R1876,R1877,R1878,R1879,R1886,R1887,R1888,R1889,R1890,R1891,R1892,R1893,R1895,R1896,R1897,R1898,R19,R1903,R1907,R1914,R1915,R1916,R1917,R1918,R1919,R1920,R1921,R1922,R1923,R1924,R1927,R1928,R1929,R1931,R1932,R1933,R1934,R1935,R1936,R1937,R1938,R1943,R1947,R1950,R1951,R1952,R1953,R1954,R1955,R1956,R1958,R196,R1965,R1967,R1985,R1986,R20,R2012,R2014,R2016,R2017,R2019,R2020,R2021,R2022,R2023,R2024,R2025,R2027,R2028,R2030,R2033,R2037,R2038,R2042,R2044,R2057,R2060,R2062,R2065,R2066,R2067,R2068,R2069,R2070,R2072,R2078,R2079,R2080,R2081,R2086,R2088,R2090,R2091,R2092,R2093,R2094,R2095,R2096,R2097,R2098,R2099,R2100,R2101,R2102,R2104,R2105,R2106,R2107,R2108,R2109,R2111,R2115,R2116,R212,R2120,R2121,R2122,R2128,R2129,R2130,R2131,R2132,R2133,R2134,R2135,R2136,R2137,R2138,R2139,R2145,R2157,R2158,R2159,R2160,R2163,R2170,R298,R299,R327,R329,R337,R338,R344,R345,R404,R406,R412,R450,R451,R452,R453,R455,R456,R473,R474,R475,R481,R492,R496,R53,R54,R542,R545,R56,R57,R648,R654,R657,R661,R675,R676,R721,R86,R88,R900,R91,R95,R952,R956,R978,R98,R986,R987,RB100,RB101,RB102,RB109,RB11,RB123,RB15,RB17,RB18,RB25,RB34,RB36,RB45,RB46,RB47,RB57,RB58,RB59,RB60,RB61,RB62,RB63,RB64,RB65,RB66,RB67,RB68,RB69,RB70,RB71,RB72,RC100,RC101,RC102,RC103,RC104,RC105,RC106,RC107,RC118,RC119,RC120,RC121,RC124,RC125,RC153,RC154,RC155,RC156,RC163,RC164,RC165,RC166,RC167,RC168,RC169,RC170,RC176,RC177,RC23,RC27,RC29,RC30,RC44,RC45,RC46,RC47,RC48,RC49,RC50,RC51,RC56,RC57,RC58,RC59,RC60,RC61,RC62,RC63,RC76,RC80,RC82,RC83,RC84,RC85,RC86,RC87,RC88,RC89,RD16,RD17,RD18,RD19,RD20,RG9656RR0510S-000-FNH657RM04FTN0658RC0402FR-070RL659WR04X000 PTL660CHIP RES 0.001 F 1W 2512PA2512FKF070R001EPR247,PR344,PR647,PR744661RLM25FECR001662RL-3264-6-R001-FNH663CHIP RES 0.002 F 2W 2512RLM25FEER002PR19,PR224,PR321,PR419,PR624,PR721664RL-3264-9-R002-FN665PA2512FKF7W0R002E666CHIP BEAD 1.6*0.8Z30/100M BLM18PG300SN1DBLM18PG300SN1DL19,L20667CHIP BEAD MMZ1608R300A TDKMMZ1608R300A668CHIP BEAD BLM41PG600SN1L MURATBLM41PG600SN1LPL55,PL71669CHIP BEAD HCB4516KF-600T60(LF)HCB4516KF-600T60670CHIP BEAD BLM21PG600SN1D (GP)BLM21PG600SN1DL30,L32,LB1671CHIP BEAD HCB2012K-600T50HCB2012K-600T50672CHIP BEAD MLB-201209-0060P-N2MLB-201209-0060P-N2673CHIP BEAD BLM21PG220SN1D (LF)BLM21PG220SN1DPL18,PL25,PL44,PL51,PL53,PL59,PL60,PL62674CHIP BEAD BCMS201209A220BCMS201209A220675CHIP BEAD HCB2012KF-220T60HCB2012KF-220T60676CHIP BAED BLM15AG121SN1DBLM15AG121SN1DL1405,L1406,L1407,L1408,LC10,LC6,LC7,LC8,LC9677CHIP BEAD MCB1005S121FBPMCB1005S121FBP678CHIP BAED FCM1005KF-121T05FCM1005KF-121T05679CHIP BEAD BLM18PG121SN1D 0603BLM18PG121SN1DL10,L11,L12,L6,L7,L9680CHIP BEAD ACMS160808A121 2AACMS160808A121 2A681CHIP BEAD PBY160808T-121Y-NPBY160808T-121Y-N682CHIP BEAD MMZ2012S601ATA1N TDKMMZ2012S601ATA1NL15,L16,L17,L3,L4,LC1,LC2,LC3,LC4,LC5683CHIP BEAD HCB2012KF-601T20HCB2012KF-601T20684CHIP BEAD FCM2012KF-601T05FCM2012KF-601T05685CHIP BEAD BLM18PG600SN1DBLM18PG600SN1DL18686CHIP BEAD MHC1608S600QBPMHC1608S600QBP687CHIP BEAD BLM18SG331TN1DBLM18SG331TN1DL5688CHIP BEAD HCB1608KF-331T15HCB1608KF-331T15689CHIP BEAD MHC1608S301NBPMHC1608S301NBP690CHIP BEAD MPZ1608S331ATA00 TDKMPZ1608S331ATA00691CHIP CHOKE DLW21HN900SQ2LDLW21HN900SQ2LL21,L25,L28692CHIP CMM FILTER CMM21T-900M-NCMM21T-900M-N693CHIP FILTER MCM2012B900GBEMCM2012B900GBE694CHIP CHOKE DLW21HN670SQ2LDLW21HN670SQ2LL22,L23,L24,L26695CHIP COMMON MODE FILTER HCM2012GH670AEHCM2012GH670AE696CHIP IND 105NH K FP0705R1-R10-RFP0705R1-R10-RPL1,PL27697CHIP IND 0.1UH PA0512.101NLTPA0512.101NLT698CHIP IND 1.00UH PCMC135T-1R0MFPCMC135T-1R0MFPL56699CHIP IND 1.0UH M MHCB12035-1R0M-C1WNMHCB12035-1R0M-C1WN700CHIP IND 22UH M LZ.9U220.A0PLZ.9U220.A0PPL72701CHIP IND 22UH M LVS505040-220M-NWNLVS505040-220M-NWN702CHIP IND 2.2UH M HCM0703-2R2-RHCM0703-2R2-RPL54703CHIP IND 2.2UH M MHCI06030-2R2M-R8WNMHCI06030-2R2M-R8WN704CHIP IND 300NH K FP0906R1-R30-RFP0906R1-R30-RPL35,PL9705CHIP IND 300NH K HCB106480N-301HCB106480N-301706CHIP IND 65NH FP0404R1-R065-RFP0404R1-R065-RPL13,PL2,PL20,PL28,PL39,PL46,PL75707CHIP IND 65NH 24A 59PR65-65059PR65-650708CHIP IND 65NH 25A SL1616A-R06LUSL1616A-R06LU709XFORM 1000BASE-T IH-106-A SMDIH-106-AXFC1710XFORM GST5009B LF SMD 24PGST5009B LF711CHIP IND 0.25UH M SPM6530T-R25SPM6530T-R25M230PL19,PL26,PL45,PL52712CHIP IND 0.25UH M HPPC06030-R25M-Q8WNHPPC06030-R25M-Q8WN713CHIP IND 0.47UH HCM0703-R47-RHCM0703-R47-RPL17,PL24,PL43,PL50714CHIP IND 0.47UH M MHCI06030-R47M-R8AWNMHCI06030-R47M-R8AWN715IC BMC AST1250A1-GP TFBGA 408PAST1250A1-GPU6716IC XLATOR GTL2014PW,118 TSSOP 14PGTL2014PW,118U24,U25,U26,U27,U28,U57,UC12,UC13717IC XLATOR FXGL2014MTCX TSSOP 14PFXGL2014MTCX718IC XALTOR SN74GTL2014PWR TSSOP 14PSN74GTL2014PWR719IC XLATOR GTL2005PW,118 TSSOP14GTL2005PW,118720IC I2C SW TCA9548APWR TSSOP 24PTCA9548APWRU7,UB1721IC I2C SW PCA9548APW,118 TSSOP 24PPCA9548APW,118722IC REPEATER PCA9617ADPJ TSSOP 8PPCA9617ADPJU216,U217,U218,U219,U29,U30,U31,U32,UC16723IC I2C-BUS PI6ULS5V9617AUEX MSOP 8PPI6ULS5V9617AUEX724IC I2C SMBUS REPEATER NCT5927W MSOP 8PNCT5927W725IC I2C BUS TCA9617ADGKR VSSOP 8PTCA9617ADGKR726IC GIGA PHY BCM54612EB1KMLG(WIWYNN)BCM54612EB1KMLGUC1727IC EEPROM CAT24C64WI-GT3 SOIC 8PCAT24C64WI-GT3U76728IC EEPROM M24C64-WMN6TP SO8M24C64-WMN6TP729IC CMOS 74LVC1G07DCKR SC70-5SN74LVC1G07DCKRU55,U61730IC BUF NL17SZ07DFT2G SOT-353NL17SZ07DFT2G731IC COMS TC7SZ07FU,LJ(CT SSOP5-P-0.65ATC7SZ07FU,LJ(CT732IC CMOS 74LVC1G07GW,125 SOT353-174LVC1G07GW,125733IC CMOS SN74LVC1G08DCKRG4 DCKSN74LVC1G08DCKRG4U18,U194,U196,U198,U21,U223,U230,U237,U238,U245,U246,U247,U248,U259,U260,U261,U88,U90,UB4734IC CMOS NL17SZ08DFT2G SOT-353NL17SZ08DFT2G735IC CMOS TC7SZ08FU,LJ(CT SSOP5-P-0.65ATC7SZ08FU,LJ(CT736IC CMOS 74LVC1G86GW,125 SC-88A74LVC1G86GW,125U83737IC CMOS NL17SZ86DFT2G SC-88A 5P(MONICA)NL17SZ86DFT2G738IC CMOS SN74LVC1G86DCKR SC70-5SN74LVC1G86DCKR739IC CMOS SN74LVC2G14DCKR SC-70SN74LVC2G14DCKRUC11740IC CMOS NL27WZ14DFT2G SC70-6NL27WZ14DFT2G741IC CMOS NC7WZ14P6X SC70-6NC7WZ14P6X742IC CMOS SN74CBTLV3126DBQR QSOPSN74CBTLV3126DBQRU43,U44,UC15,UC17743IC CMOS PI3C3126QEX QSOPPI3C3126QEX744IC SW NC7SB3157P6X_NL SC-70 6PNC7SB3157P6X_NLU41,UC14745IC CMOS TC7SB3157CFU SSOP 6PTC7SB3157CFU746IC SW 74LVC1G3157GW,125 SC-88 6P74LVC1G3157GW,125747IC SPDT SW TS5A3159ADCKR SC-70 6PTS5A3159ADCKR748IC CMOS SN74LVC07APWR TSSOP 14SN74LVC07APWRU49749IC CMOS 74LVC07ADTR2G TSSOP 14P(MONICA)74LVC07ADTR2G750IC CMOS 74LVC07AT14-13 TSSOP 14P74LVC07AT14-13751IC CMOS 74LVC07APW TSSOP 14P74LVC07APW752IC CMOS 74LVC14APW,118 TSSOP 14P74LVC14APW,118U119753IC CMOS 74LVC14APWR TSSOP14(TISN74LVC14APWR754IC CMOS 74LCX14MTCX_NL TSSOP1474LCX14MTCX_NL755IC SW SN74CBTLV1G125DBVR SOT23SN74CBTLV1G125DBVRU220,U235,U236,U239,U240,U249,U250,U42756IC CMOS 74CBTLV1G125GV,125 SOT753 5P74CBTLV1G125GV,125757IC BUS BUF 74HC1G126GW TSSOP574HC1G126GWU48,UC19758IC CMOS TC7SZ126FU,LJ(CT SSOP5-P-0.65ATC7SZ126FU,LJ(CT759IC CMOS NC7SZ126P5X SC70-5NC7SZ126P5X760IC CMOS SN74LVC1G126DCKR SC70SN74LVC1G126DCKR761IC BUF/DRV SN74LVC2G07DBVR SOT23-6SN74LVC2G07DBVRU212762IC BUFFER 74LVC2G07GV TSOP674LVC2G07GV763IC BUS SW PI3B3257QE QSOP 16PPI3B3257QEU251,UC7,UC8764IC SW 74CBTLV3257DBQRG4 QSOP1674CBTLV3257DBQRG4765IC PWR MONI INA219AIDCNR SOT23INA219AIDCNRPU63,PU64,PU65,PU66766IC V.C LM393DR SO-N 8P (ROHS)LM393DRU208,U211767IC V.C LM393DR2G SOIC 8PLM393DR2G768IC V.C AS393MTR-G1 SOIC 8PAS393MTR-G1769IC V.C BA10393F-GE2 SOP 8PBA10393F-GE2770IC A.R TL431BIDBZR SOT-23 (GP)TL431BIDBZRD44771IC A.R NCP432BVSNT1G SOT-23NCP432BVSNT1G772IC V.R TS2431BILT SOT-23TS2431BILT773IC V.R ADM1085AKSZ-REE7 SC70-6ADM1085AKSZ-REE7U104774IC PWR ADM1172-2AUJZ-RL7 TSOT8ADM1172-2AUJZ-RL7U35,U60775IC PWM SW TPS2062DGN MSOP 8PTPS2062DGNU87,U93776IC PWR SW AP2162MPG-13 MSOP 8PAP2162MPG-13777IC ESD MAX3207EAUT+T SOT23-6MAX3207EAUT+TD12,D13,D14778IC DIODE ESD PJUSBLC6-2 SOT23-6LPJUSBLC6-2_R1_00001779IC RESET TPS3809K33DBVT SOT-23TPS3809K33DBVTU193,U195,U197,UB3780IC RESET MAX809SN293D3T1G SOT-23MAX809SN293D3T1G781IC RST MONI MAX809TEUR+T SOT23MAX809TEUR+T782IC RESET APX809-29SAG-7 SOT-23APX809-29SAG-7783IC TEMP SEN TMP421AIDCNRG4 SOT23 8PTMP421AIDCNRG4U74,U75784IC DC/DC REGULATOR SY8201ABC SOT23-6SY8201ABCPU67785IC BUCK CTRL TPS40140RHHR VQFN 36PTPS40140RHHRPU2786IC S.R TPS53317RGBR QFN 20PTPS53317RGBRPU21,PU27,PU45,PU51787IC S.R RT2660DLGQV VQFN 20PRT2660DLGQV788IC PWR CTRL TPS53318DQPR QFN 22PTPS53318DQPRPU57789IC PWR CTRL TPS53319DQPR QFN 22PTPS53319DQPRPU52790IC PWM CTRL TPS53355DQPR QFN 22PTPS53355DQPRPU53791IC LDO TPS74801RGW QFN 20PTPS74801RGWPU60792IC LDO POWER RTQ2522BGQW(2) WQFN-20LRTQ2522BGQW(2)793CHIP POSCAP 470U 4V 4TPF470ML4TPF470MLPC1135,PC1136,PC396,PC397,PC554,PC555,PC977,PC978794CHIP CAP T 470UF 4V M7343 ESR10T520D477M004ATE010795CHIP CAP C 10P 50V J0402 NPOUMK105CH100JV-FCG1796GRM1555C1H100JZ01D797223886915109798C1005NP0100JGT799GRM1555C1H100JA01D8000402N100J500CT801CL05C100JB5NNNC802CC0402JRNPO9BN100803CHIP CAP C 100P 50V J0402 NPOCM05CG101J50AHC1027,C1029,C1034,C612,C626,C636,C638,CC35804C1005NP0101JGT805GRM1555C1H101JA01D806223886915101807CL05C101JB5NNNC808UMK105CH101JV-F8090402N101J500CT810CC0402JRNPO9BN101811CHIP CAP C 1000P 50V K0402 X7RCM05X7R102K50AH
C1013,C1076,C1083,C817,CC5,PC1020,PC1029,PC1211,PC1213,PC1466,PC19,PC202,PC281,PC290,PC439,PC448,PC600,PC783,PC862,PC871812C1005X7R102KGT813GRM155R71H102KA01D814223858715623815CL05B102KB5NNNC816UMK105B7102KV-F817WBM155R71H102KA01D81804025C102KAT2A819CC0402KRX7R9BB102820CHIP CAP C 1000P 50V J0603 X7RGRM188R71H102JA01DPC1187,PC120682122385861552382206035C102JAT2A823C1608X7R102JGT824CC0603JRX7R9BB102825CHIP CAP C 0.01U 50V K0402 X7RGRM155R71H103KA88D
C10,C1055,C106,C11,C110,C111,C1119,C1120,C1121,C1122,C12,C129,C13,C14,C15,C16,C17,C18,C19,C20,C21,C22,C23,C24,C25,C26,C27,C277,C278,C28,C287,C288,C289,C290,C291,C292,C3,C301,C302,C303,C304,C305,C306,C31,C312,C314,C317,C32,C4,C413,C414,C415,C418,C5,C6,C683,C684,C689,C692,C7,C718,C745,C746,C747,C748,C749,C750,C751,C752,C753,C754,C755,C756,C757,C758,C759,C760,C79,C8,C82,C83,C84,C882,C9,CC41,CC42,CC43,CC44,PC1004,PC1162,PC1422,PC423,PC581826223858715636827C1005X7R103KGT828CL05B103KB5NNNC8290402B103K500CT830WBM155R71H103KA01D831CC0402KRX7R9BB103832CHIP CAP C 0.1U 16V K0603 X7R0603YC104KAT2APC1449,PC1454833C1608X7R104KET834GRM188R71C104KA01D835223878615649836CL10B104KO8NNNC837EMK107B7104KA-T8380603B104K160CT839CC0603KRX7R7BB104840CHIP CAP C 0.1U 25V K0603 X7R06033C104KAT2APC1419,PC1460,PC1470841C1608X7R104KFT842GRM188R71E104KA01D843223891615649844CL10B104KA8NNNC845TMK107B7104KA-T8460603B104K250CT847CC0603KRX7R8BB104848CHIP CAP C 0.1U 25V K0402 X7RCC0402KRX7R8BB104
C1000,C1012,C102,C1026,C1028,C103,C1030,C1031,C1032,C1035,C104,C1047,C1048,C1049,C105,C1050,C1051,C1052,C1053,C1054,C107,C108,C1082,C1086,C1097,C1098,C1128,C1129,C1130,C1131,C1133,C1401,C1402,C1403,C1404,C1405,C1406,C1407,C1408,C1409,C1410,C1411,C1412,C1413,C1414,C1415,C1416,C1417,C1418,C1419,C1420,C1421,C1422,C1423,C1424,C1425,C1426,C1427,C1428,C1429,C1430,C1431,C1432,C1433,C1434,C1435,C1436,C1437,C1438,C1439,C1440,C1441,C1442,C1443,C1444,C1445,C1446,C1447,C1448,C1449,C1450,C1451,C1452,C1453,C1454,C1455,C1456,C1457,C1458,C1459,C1460,C1461,C1462,C151,C152,C153,C155,C195,C197,C198,C199,C29,C293,C294,C295,C296,C297,C298,C299,C30,C300,C308,C309,C310,C311,C321,C324,C326,C327,C328,C329,C330,C331,C332,C39,C408,C409,C410,C411,C419,C482,C483,C521,C605,C608,C609,C610,C611,C625,C637,C645,C646,C647,C648,C655,C656,C657,C658,C659,C660,C661,C662,C663,C664,C665,C666,C667,C668,C669,C670,C671,C672,C674,C675,C676,C677,C678,C679,C680,C681,C682,C686,C688,C691,C694,C695,C696,C698,C719,C723,C725,C726,C728,C729,C739,C80,C803,C806,C808,C81,C810,C811,C812,C813,C816,C818,C819,C821,C843,C844,C845,C846,C847,C848,C849,C850,C851,C861,C862,C863,C864,C865,C866,C868,C869,C870,C915,C989,C990,C991,C992,C993,C994,CB1,CB12,CB13,CB14,CB15,CB16,CB17,CB18,CB19,CB2,CB20,CB21,CB22,CB23,CB24,CB25,CB26,CB27,CB28,CB29,CB3,CB38,CC1,CC11,CC12,CC14,CC16,CC17,CC2,CC24,CC3,CC36,CC38,CC39,CC4,CC40,CC45,CC46,CC47,CC49,CC51,CC52,CC53,CC57,CC58,CC8,CC9,CD1,CD2,CD3,CD4,PC1015,PC1017,PC1018,PC1022,PC1024,PC1025,PC1026,PC1036,PC1046,PC1056,PC11,PC1129,PC1130,PC1156,PC1188,PC1207,PC1212,PC1221,PC1226,PC1228,PC1245,PC1271,PC1274,PC13,PC1310,PC1317,PC1320,PC1321,PC1324,PC1329,PC1352,PC1353,PC1354,PC1372,PC1373,PC1374,PC14,PC1424,PC1440,PC16,PC17,PC178,PC179,PC199,PC200,PC208,PC21,PC213,PC23,PC24,PC25,PC251,PC256,PC276,PC278,PC279,PC283,PC285,PC286,PC287,PC297,PC3,PC307,PC317,PC33,PC34,PC390,PC391,PC4,PC417,PC418,PC43,PC434,PC436,PC437,PC44,PC441,PC442,PC443,PC444,PC445,PC455,PC465,PC475,PC5,PC53,PC54,PC548,PC549,PC575,PC576,PC592,PC594,PC595,PC596,PC598,PC602,PC604,PC605,PC606,PC614,PC615,PC624,PC625,PC63,PC634,PC635,PC64,PC644,PC645,PC654,PC655,PC664,PC665,PC7,PC73,PC74,PC759,PC760,PC780,PC781,PC789,PC794,PC8,PC83,PC84,PC840,PC857,PC859,PC860,PC864,PC866,PC867,PC868,PC878,PC888,PC898,PC9,PC971,PC972,PC998,PC9998490402B104K250CT850GRM155R71E104KE14D851CL05B104KA5NNNC852TMK105B7104KV-FR853C1005X7R104KFT854CHIP CAP C 0.1U 10V K0402 X7RGRM155R71A104KA01DPC1428,PC1450,PC1451855CC0402KRX7R6BB104856CL05B104KP5NNNC857LMK105B7104KV-F858223824715649859C1005X7R104KDT8600402B104K100CT861WBM155R71A104KA01D862CHIP CAP C 0.1U 50V K0805 X7RGRM21BR71H104KA01LPC1438,PC145586308055C104KAT2A864UMK212B7104KG-T865223858015649866C2012X7R104KGT867CL21B104KBFNNNE8680805B104K500CT869CC0805KRX7R9BB104870CHIP CAP C 0.1U 50V K0603 X7RGRM188R71H104KA93D
C1023,C1036,C1037,C1039,C1040,C1042,C1043,C1136,C147,C148,C149,C150,C191,C192,C193,C194,C279,C281,C283,C35,C36,C37,C38,C883,C884,C885,C886,C887,C888,C889,C890,C891,C892,C893,C894,C895,C896,C897,C898,C899,C900,C901,C902,C903,C904,C905,C906,PC1035,PC1045,PC1055,PC1173,PC1186,PC1191,PC1205,PC1267,PC1406,PC296,PC306,PC316,PC454,PC464,PC474,PC877,PC887,PC89787106035C104KAT2A872223858615649873CL10B104KB8NNNC874C1608X7R104KGT8750603B104K500CT876CC0603KRX7R9BB104877CHIP CAP C 0.1U 50V K0402 X5RC1005X5R104KGTPC31,PC41,PC49,PC59,PC610,PC620,PC630,PC640,PC650,PC660,PC69,PC79878GRM155R61H104KE14D879UMK105BJ104KV-F880223858713649881CC0402KRX5R9BB104882CHIP CAP C 1U 6.3V K 0402 X6SGRM155C80J105KE15D
C534,C535,C536,C537,C538,C539,C540,C546,C547,C548,C549,C550,C551,C565,C568,C569,C570,C573,C574,C575,C578,C579,C580,C583,C584,C585,C588,C589,C590,C591,C592883CL05X105KQ5NNNC884JMK105C6105KV-F885C1005X6S105KCT886CC0402KRX6S5BB105887CHIP CAP C 1U 25V K1206 X7RGRM31MR71E105KC01LPC144888812063C105KAT2A889222291115663890TMK316B7105KL-T891CC1206KKX7R8BB105892CHIP CAP C 1U 25V K0603 X7RGRM188R71E105KA12D
C1022,C1400,C280,C282,C284,C285,C286,C315,C316,C318,C404,C405,C406,C412,C416,C417,C461,C464,C467,C470,C473,C476,C479,C606,C607,C614,C624,C628,C629,C630,C631,C632,C633,C634,C635,C639,C640,C641,C642,C643,C644,C653,C654,C685,C687,C690,C693,C717,C804,C807,CC34,CC48,CC50,PC1001,PC1016,PC1019,PC1021,PC1160,PC119,PC12,PC1210,PC1410,PC15,PC18,PC20,PC201,PC277,PC280,PC282,PC284,PC420,PC435,PC438,PC440,PC579,PC593,PC597,PC599,PC601,PC700,PC782,PC858,PC861,PC863893TMK107B7105KA-T8940603B105K250CT895CL10B105KA8NNNC896C1608X7R105KFT897CC0603KRX7R8BB105898CHIP CAP C 1UF 25V K0402 X5RGRM155R61E105KA12DC1139,C463,C466,C469,C472,C475,C478,C481,C507,C508,C509,C510,C522,C523,C524,C525,C526,C527899CC0402KRX5R8BB105900CL05A105KA5NQNC901C1005X5R105KFT902CHIP CAP C 1U 10V K 0402 X6SLMK105C6105KV-F
C1019,C1020,C313,C505,C514,CC21,CC22,CC54,PC1005,PC1023,PC1163,PC1189,PC1209,PC1214,PC1270,PC203,PC22,PC424,PC582,PC603,PC784,PC865903GRM155C81A105KA12D904CL05X105KP5NNNC905C1005X6S105KDT906CC0402KRX6S6BB1059070402S105K100CT908CHIP CAP C 10U 6.3V M0603 X5RC1608X5R106MCT
C307,C322,C323,C462,C465,C468,C471,C474,C477,C480,C498,C499,C500,C501,C502,C503,C504,C506,C511,C512,C513,C627,C649,C673,C722909GRM188R60J106ME47D910225520613776911CL10A106MQ8NNNC912JMK107BJ106MA-T913CV105X5R106M06AT914CC0603MRX5R5BB1069150603X106M6R3CT916CHIP CAP C 10UF 16V M0805 X7R0805B106M160CTCC13,CC18,CC20917C2012X7R106MEP918GRM21BR71C106ME51L919EMK212BB7106MG-T920CHIP CAP C 10U 16V K0805 X6SGRM21BC81C106KE15L921CL21X106KOQNNNE922EMK212BC6106KG-T923C2012X6S106KEP924CC0805KKX6S7BB106925CHIP CAP C 10U 4V M0603 X6SC1608X6S106MBT
PC1139,PC1140,PC1141,PC1142,PC1143,PC1144,PC1145,PC1146,PC1285,PC1286,PC1287,PC1288,PC1289,PC1292,PC1293,PC1294,PC1295,PC1298,PC1299,PC1300,PC1301,PC228,PC229,PC230,PC231,PC232,PC233,PC234,PC235,PC236,PC237,PC238,PC239,PC240,PC241,PC242,PC400,PC401,PC402,PC403,PC404,PC405,PC406,PC407,PC558,PC559,PC560,PC561,PC562,PC563,PC564,PC565,PC809,PC810,PC811,PC812,PC813,PC814,PC815,PC816,PC817,PC818,PC819,PC820,PC821,PC822,PC823,PC855,PC856,PC869,PC981,PC982,PC983,PC984,PC985,PC986,PC987,PC988926GRM188C80G106ME47D927CL10X106MR8NNNC928AMK107AC6106MA-T929CHIP CAP C 10U 6.3V K0805 X7RGRM21BR70J106KE76LC1077,PC1312,PC1313,PC1316,PC1322,PC1325,PC1328930JMK212B7106KG-T931C2012X7R106KC932CM21X7R106K06AT933CHIP CAP C 100U 6.3V M1206 X5RGRM31CR60J107ME39LPC1181,PC1183934JMK316BJ107ML935CL31A107MQHNNNE9361206X107M6R3CT937CHIP CAP C 15P 50V J0402 NPO04025A150JAT2AC455,C456938C1005NP0150JGT939GRM1555C1H150JA01D940223886915159941CL05C150JB5NNNC942UMK105CH150JV-F9430402N150J500LT944CC0402JRNPO9BN150945CHIP CAP C 22P 50V J0402 NPO04025A220JAT2APC1407946C1005NP0220JGT947GRM1555C1H220JA01D948223886915229949CL05C220JB5NNNC950UMK105CH220JV-F9510402N220J500CT952CC0402JRNPO9BN220953CHIP CAP C 220P 50V K0402 X7RGRM155R71H221KA01DC1137,C1138,C114095404025C221KAT2A955UMK105B7221KV-F956223858715614957C1005X7R221KGT9580402B221K500CT959CC0402KRX7R9BB221960CHIP CAP C 2200P 50V K0603 X7RGRM188R71H222KA01DC922,C925,PC1417,PC144796122385861562796206035C222KAT2A963CL10B222KB8NNNC964C1608X7R222KGT9650603B222K500CT966CC0603KRX7R9BB222967CHIP CAP C 2200P 50V K0402 X7RGRM155R71H222KA01DPC1006,PC1164,PC1415,PC26,PC425,PC583,PC60796804025C222KAT2A969UMK105B7222KV-F970223858715627971C1005X7R222KGT972CL05B222KB5NNNC9730402B222K500CT974CC0402KRX7R9BB222975CHIP CAP C 0.022U 25V K0402 X7RGRM155R71E223KA61DC1015,C1038,C923,PC1028,PC205,PC245,PC289,PC447,PC786,PC870976223891715641977C1005X7R223KFT9780402B223K250CT979CC0402KRX7R8BB223980CHIP CAP C 0.22U 16V K0402 X7RGRM155R71C224KA12D
C100,C1004,C1005,C1006,C1007,C1008,C1009,C1010,C1011,C1106,C1108,C1109,C1110,C1111,C1112,C1113,C1114,C113,C114,C115,C116,C117,C118,C119,C120,C121,C122,C123,C124,C125,C126,C127,C128,C157,C158,C159,C160,C161,C162,C163,C164,C165,C166,C167,C168,C169,C170,C172,C173,C174,C175,C176,C177,C178,C179,C180,C181,C182,C183,C184,C185,C186,C187,C188,C201,C202,C203,C204,C205,C206,C207,C208,C209,C210,C211,C212,C213,C214,C215,C216,C217,C218,C219,C220,C221,C222,C223,C224,C225,C226,C227,C228,C229,C230,C231,C232,C261,C262,C263,C264,C265,C266,C267,C268,C269,C270,C271,C272,C273,C274,C275,C276,C340,C341,C342,C343,C344,C345,C346,C347,C348,C349,C350,C351,C352,C353,C354,C355,C356,C357,C358,C359,C360,C361,C362,C363,C364,C365,C366,C367,C368,C369,C370,C371,C372,C373,C374,C375,C376,C377,C378,C379,C380,C381,C382,C383,C384,C385,C386,C387,C388,C389,C390,C391,C392,C393,C394,C395,C396,C397,C398,C399,C400,C401,C402,C403,C41,C42,C43,C44,C45,C46,C47,C48,C49,C490,C491,C492,C493,C494,C495,C496,C497,C50,C51,C52,C53,C54,C55,C56,C57,C58,C59,C60,C61,C62,C63,C64,C65,C651,C652,C66,C67,C68,C69,C70,C71,C72,C787,C788,C789,C790,C791,C792,C793,C794,C85,C853,C854,C855,C856,C857,C858,C859,C86,C860,C87,C871,C872,C873,C874,C875,C876,C877,C878,C88,C89,C90,C91,C92,C93,C94,C95,C96,C97,C98,C99,C999,CB10,CB11,CB30,CB31,CB32,CB33,CB34,CB35,CB36,CB37,CB4,CB5,CB6,CB7,CB8,CB9981CL05B224KO5NNNC982C1005X7R224KET983EMK105B7224KV-FR9840402B224K160CT985CC0402KRX7R7BB224986CHIP CAP C 2.2U 10V K 0603 X5RGRM188R61A225KE34DPC1133,PC1153,PC1185,PC1204,PC394,PC414,PC552,PC572,PC975,PC995987LMK107BJ225KA-T988CL10A225KP8NNNC989223824613667990ECJ1VB1A225K991C1608X5R225KDT9920603X225K100CT993CC0603KRX5R6BB225994CHIP CAP C 2.2U 10V K0402 X5RC1005X5R225KDT
PC1039,PC1040,PC1049,PC1050,PC1059,PC1060,PC1134,PC1224,PC1227,PC182,PC211,PC214,PC254,PC257,PC300,PC301,PC310,PC311,PC320,PC321,PC36,PC37,PC395,PC458,PC459,PC46,PC468,PC469,PC47,PC478,PC479,PC553,PC56,PC57,PC617,PC618,PC627,PC628,PC637,PC638,PC647,PC648,PC657,PC658,PC66,PC667,PC668,PC67,PC76,PC763,PC77,PC792,PC795,PC86,PC87,PC881,PC882,PC891,PC892,PC901,PC902,PC976995LMK105BJ225MV-F9962238247136679970402X225K100CT998GRM155R61A225KE95D999CC0402KRX5R6BB2251000CHIP CAP C 22U 6.3V M0603 X5RGRM188R60J226MEA0D
C515,C516,C517,C518,C519,C520,C528,C529,C530,C531,C532,C533,C541,C542,C543,C544,C545,C552,C553,C554,C555,C556,C562,C563,C564,C566,C567,C571,C572,C576,C577,C581,C582,C586,C587,C594,C596,C597,C598,C599,C600,C601,C604,PC1151,PC1152,PC1154,PC1155,PC412,PC413,PC415,PC416,PC570,PC571,PC573,PC574,PC993,PC994,PC996,PC9971001CL10A226MQ8NRNC1002JDK107BBJ226MA-T1003C1608X5R226MCT10040603X226M6R3CT1005CC0603MRX5R5BB2261006CL10A226MQ8NRNE1007CHIP CAP C 22U 6.3V M0805 X6SGRM21BC80J226ME51L
PC1008,PC1012,PC1013,PC1065,PC1066,PC1067,PC1068,PC1069,PC1070,PC1086,PC1089,PC1091,PC1093,PC1096,PC1098,PC1099,PC1107,PC1108,PC1110,PC1112,PC1113,PC1115,PC1116,PC1119,PC1120,PC1123,PC1124,PC1147,PC1148,PC1149,PC1150,PC1157,PC1170,PC1171,PC1172,PC1178,PC1179,PC1180,PC1202,PC1215,PC1216,PC1252,PC1253,PC1255,PC1256,PC1257,PC1262,PC1273,PC1275,PC1278,PC1279,PC1280,PC1281,PC1282,PC1283,PC1284,PC1290,PC1291,PC1296,PC1297,PC1302,PC1303,PC1356,PC1357,PC1358,PC1359,PC1360,PC1361,PC1362,PC1363,PC1364,PC1365,PC1366,PC1367,PC1368,PC1369,PC1370,PC1371,PC1375,PC1376,PC1377,PC1378,PC1379,PC1380,PC1381,PC1382,PC1383,PC1384,PC1385,PC1386,PC1387,PC1388,PC1389,PC1390,PC1391,PC1394,PC1395,PC1398,PC1399,PC1400,PC1404,PC1405,PC1413,PC1416,PC1423,PC1433,PC1436,PC1445,PC1452,PC1458,PC1462,PC1468,PC186,PC187,PC188,PC189,PC190,PC191,PC221,PC222,PC223,PC224,PC225,PC226,PC227,PC326,PC327,PC328,PC329,PC330,PC331,PC338,PC341,PC347,PC358,PC359,PC361,PC365,PC373,PC379,PC381,PC382,PC408,PC409,PC410,PC411,PC427,PC431,PC432,PC484,PC485,PC486,PC487,PC488,PC489,PC500,PC503,PC504,PC516,PC518,PC519,PC520,PC524,PC525,PC529,PC531,PC538,PC539,PC566,PC567,PC568,PC569,PC585,PC586,PC590,PC591,PC767,PC768,PC769,PC770,PC771,PC772,PC787,PC802,PC803,PC804,PC805,PC806,PC807,PC808,PC832,PC833,PC834,PC835,PC836,PC837,PC838,PC839,PC843,PC844,PC845,PC846,PC847,PC848,PC849,PC850,PC851,PC852,PC853,PC854,PC907,PC908,PC909,PC910,PC911,PC912,PC920,PC921,PC922,PC926,PC930,PC931,PC937,PC938,PC943,PC944,PC945,PC946,PC951,PC953,PC955,PC961,PC962,PC964,PC989,PC990,PC991,PC9921008CL21X226MQQNNNE1009JDK212AC6226MG-T1010C2012X6S226MCP1011CC0805MKX6S5BB22610120805S226M6R3CT1013CL21X226MQQNNNG1014CHIP CAP C 22U 25V M0805 X5R T1.45GRM21BR61E226ME44L
C101,C109,C1115,C1116,C1117,C1118,C146,C1463,C190,C325,C33,C34,C75,C76,C761,C762,C914,C986,C987,CC10,CC15,CC37,PC1,PC10,PC1031,PC1032,PC1033,PC1041,PC1042,PC1043,PC1051,PC1052,PC1053,PC1125,PC1126,PC1127,PC1174,PC1175,PC1176,PC1177,PC1192,PC1193,PC1218,PC1219,PC1220,PC1222,PC1225,PC1236,PC1238,PC1239,PC1264,PC1265,PC174,PC175,PC176,PC2,PC209,PC212,PC216,PC244,PC246,PC247,PC248,PC249,PC250,PC252,PC255,PC259,PC29,PC292,PC293,PC294,PC30,PC302,PC303,PC304,PC312,PC313,PC314,PC32,PC386,PC387,PC388,PC39,PC40,PC42,PC450,PC451,PC452,PC460,PC461,PC462,PC470,PC471,PC472,PC50,PC51,PC52,PC544,PC545,PC546,PC6,PC60,PC61,PC611,PC612,PC613,PC62,PC621,PC622,PC623,PC631,PC632,PC633,PC641,PC642,PC643,PC651,PC652,PC653,PC661,PC662,PC663,PC70,PC71,PC72,PC755,PC757,PC758,PC790,PC793,PC797,PC80,PC81,PC82,PC873,PC874,PC875,PC883,PC884,PC885,PC893,PC894,PC895,PC967,PC968,PC9691015C2012X5R226MFP1016TMK212BBJ226MG-TT10170805X226M250CT1018CC0805MKX5R8BB2261019C2012X5R226MFW1020CHIP CAP C 22U 10V M0805 X5RCL21A226MPQNNNGPC1199,PC1200,PC140810212222240137811022GRM21BR61A226ME51L1023LMK212BJ226MG-T1024C2012X5R226MDP10250805X226M100CT1026CC0805MKX5R6BB2261027CHIP CAP 22U 4V M0603 X6SGRM188C80G226MEA0D
PC1009,PC1166,PC1229,PC1230,PC1246,PC1247,PC128,PC129,PC130,PC131,PC132,PC133,PC134,PC135,PC136,PC137,PC138,PC139,PC140,PC141,PC142,PC143,PC144,PC145,PC146,PC147,PC148,PC149,PC150,PC151,PC152,PC153,PC154,PC155,PC156,PC157,PC158,PC159,PC160,PC161,PC162,PC163,PC164,PC165,PC166,PC167,PC168,PC169,PC170,PC171,PC172,PC173,PC195,PC196,PC197,PC198,PC346,PC360,PC369,PC433,PC709,PC710,PC711,PC712,PC713,PC714,PC715,PC716,PC717,PC718,PC719,PC720,PC721,PC722,PC723,PC724,PC725,PC726,PC727,PC728,PC729,PC730,PC731,PC732,PC733,PC734,PC735,PC736,PC737,PC738,PC739,PC740,PC741,PC742,PC743,PC744,PC745,PC746,PC747,PC748,PC749,PC750,PC751,PC752,PC753,PC754,PC776,PC777,PC778,PC7791028CL10X226MR8NUNE1029AMK107BC6226MA-T10300603S226M4R0CT1031C1608X6S226MBT1032CHIP CAP 33P50V J0402 NPO(ROHS04025A330JAT2AC319,C320,C459,C460,CC6,CC7,PC1003,PC1161,PC422,PC5801033C1005NP0330JGT1034GRM1555C1H330JZ01D10352238869153391036CL05C330JB5NNNC1037UMK105CH330JV-F1038GRM1555C1H330JA01D10390402N330J500CT1040CC0402JRNPO9BN3301041CHIP CAP C 3300P 50V K0402 X7RGRM155R71H332KA01D
PC1034,PC1044,PC1054,PC1128,PC1235,PC177,PC215,PC258,PC295,PC305,PC315,PC389,PC453,PC463,PC473,PC547,PC756,PC796,PC876,PC886,PC896,PC970104204025C332KAT2A1043UMK105B7332KV-F10442238587156291045C1005X7R332KGT10460402B332K500CT1047CC0402KRX7R9BB3321048CHIP CAP 0.033U 50V K0603 X7RGRM188R71H333KA61DC1021104906035C333KAT2A10502238586156431051C1608X7R333KGT1052CC0603KRX7R9BB3331053CHIP CAP C 47P 50V J0402 NPO04025A470JAT2AC730,C731,C732,C733,C734,C735,C736,C7371054C1005NP0470JGT1055GRM1555C1H470JZ01D10562238869154791057UMK105CG470JV-F10580402N470J500CT1059GRM1555C1H470JA01D1060CL05C470JB5NNNC1061CC0402JRNPO9BN4701062CHIP CAP C 470P50V K0402 X7R04025C471KAT2APC1190,PC1208,PC1272,PC1318,PC13301063C1005X7R471KGT1064GRM155R71H471KA01D10652238587156181066UMK105B7471KV-F1067CL05B471KB5NNNC10680402B471K500CT1069CC0402KRX7R9BB4711070CHIP CAP C 0.047U 16V K0402 X7GRM155R71C473KA01DC91610712238787156451072EMK105B7473KV-F10730402B473K160CT1074C1005X7R473KET1075CL05B473KO5NNNC1076CC0402KRX7R7BB4731077CHIP CAP C 4.7U 16V K0805 X7RGRM21BR71C475KA73LPC1457,PC14641078CM21X7R475K16AT1079C2012X7R475KEP1080EMK212B7475KG-T1081CC0805KKX7R7BB4751082CL21B475KOFNNNG1083CHIP CAP C 4.7U 25V K0805 X5RGRM21BR61E475KA12LC613,C650,CC19,PC1184,PC1203,PC1266,PC14091084CM21X5R475K25AT1085TMK212BJ475KG-T1086CL21A475KAQNNNG10872222910136721088CC0805KKX5R8BB4751089CHIP CAP C 47U 4V M0603 X5RGRM188R60G476ME15D
PC1027,PC1071,PC1072,PC1073,PC1074,PC1079,PC1080,PC1081,PC1082,PC1114,PC1121,PC1122,PC1260,PC1261,PC332,PC333,PC334,PC335,PC343,PC344,PC345,PC355,PC356,PC375,PC490,PC491,PC492,PC493,PC499,PC508,PC511,PC514,PC517,PC532,PC913,PC914,PC915,PC916,PC919,PC924,PC925,PC927,PC928,PC929,PC936,PC942,PC947,PC948,PC949,PC950,PC9631090CL10A476MR8NRNC1091ADK107BBJ476MA-R1092CHIP CAP C 47U 4V M0805 X6SGRM21BC80G476ME15L
C557,C558,C559,C560,C561,C593,C595,C602,C603,PC100,PC101,PC1010,PC1011,PC1014,PC102,PC103,PC104,PC105,PC106,PC107,PC1077,PC1078,PC108,PC1083,PC1084,PC1085,PC1087,PC1088,PC109,PC1090,PC1092,PC1094,PC1095,PC1097,PC110,PC1100,PC1101,PC1102,PC1103,PC1104,PC1105,PC1106,PC1109,PC111,PC1111,PC1117,PC1118,PC112,PC1137,PC1138,PC1167,PC1168,PC1169,PC120,PC121,PC122,PC123,PC124,PC125,PC1254,PC1258,PC1259,PC126,PC127,PC339,PC340,PC342,PC348,PC349,PC350,PC351,PC352,PC353,PC354,PC357,PC362,PC363,PC364,PC366,PC367,PC368,PC370,PC371,PC372,PC374,PC376,PC377,PC378,PC380,PC383,PC384,PC385,PC398,PC399,PC428,PC429,PC430,PC446,PC496,PC497,PC498,PC501,PC502,PC505,PC506,PC507,PC509,PC510,PC512,PC513,PC515,PC521,PC522,PC523,PC526,PC527,PC528,PC530,PC533,PC534,PC535,PC536,PC537,PC540,PC541,PC542,PC543,PC556,PC557,PC587,PC588,PC589,PC608,PC670,PC671,PC672,PC673,PC674,PC675,PC676,PC677,PC678,PC679,PC680,PC681,PC682,PC683,PC684,PC685,PC686,PC687,PC688,PC689,PC690,PC691,PC692,PC693,PC701,PC702,PC703,PC704,PC705,PC706,PC707,PC708,PC785,PC841,PC842,PC89,PC90,PC91,PC92,PC923,PC93,PC932,PC933,PC934,PC935,PC939,PC94,PC940,PC941,PC95,PC952,PC954,PC956,PC957,PC958,PC959,PC96,PC960,PC965,PC966,PC97,PC979,PC98,PC980,PC991093AMK212BC6476MG-T1094CL21X476MRYNNNE1095C2012X6S476MBP10960805S476M4R0CT1097CHIP CAP C 680P 50V K0402 X7RCM05X7R681K50ATPC14441098C1005X7R681KGT1099GRM155R71H681KA01D11002238587156211101UMK105B7681KV-F11020402B681K500CT1103CC0402KRX7R9BB6811104CHIP CAP C 8.2P 50V C0402 COG223886914828C457,C4581105UMK105CG8R2CV-F1106GRM1555C1H8R2CA01D11070402N8R2C500LT1108CC0402CRNPO9BN8R21109CHIP CAP EL 100U25V M 6.3*7.725CL100AXTC101110CHIP CAP EL 100U 25V M6.3*7.7EMZA250ADA101MF80G1111CHIP CAP EL 330U6.3V 6SVPC330M6SVPC330MPTC11,PTC12,PTC29,PTC30,PTC311112CHIP CAP EL 330U6.3V M 6.3*7.7APXE6R3ARA331MF80G1113CHIP CAP 470UF 2V EEFSX0D471XEEFSX0D471XE
PC1007,PC1061,PC1062,PC1063,PC1064,PC1165,PC322,PC323,PC324,PC325,PC426,PC480,PC481,PC482,PC483,PC584,PC903,PC904,PC905,PC9061114CHIP AP CAP 470UF 2V M7343 ESR6ACAH2R0S471E061115CHIP CAP EL 470U 2.5V M7343 ESR4.5 SXEEFSX0E471E4
PC113,PC114,PC115,PC116,PC117,PC118,PC1231,PC1232,PC1233,PC1234,PC1248,PC1249,PC1250,PC1251,PC184,PC185,PC218,PC219,PC220,PC694,PC695,PC696,PC697,PC698,PC699,PC765,PC766,PC799,PC800,PC8011116CHIP CAP EL 470U 2.5V M 7.3*4.3EEFGX0E471R1117CHIP CAP T220U 10V M7343 L(GP)T520D227M010ATE040TC1,TC11,TC141118CHIP CAP POS 220U 10V M734310TPE220ML1119OSC 48MHZ 50PPM 15PF 3.3V HSO321S SMDSSW048000I3CHOSC21120OSC 48MHZ 25PPM 15PF 3.3V 7X48000025 SMD7X480000251121XTAL 32.768KHZ 12.5P 20PPM 9H03200 SMD9H03200031X21122XTAL 32.768K 12.5P20PPM DST310S1TJF125DP1A000D1123XTAL 32.768KHZ 12.5PF 20PPM FC135 SMDFC-135 32.768000KHZ 12.5+20.0-20.01124DIODE TVS SMCJ13A-13-F SMCSMCJ13A-13-FD431125DIODE TVS 3.0SMCJ13A DO-214AB3.0SMCJ13A1126DIODE S.B BAT54_NL 30V SOT-23BAT54_NLPD431127DIODE S.B BAT54,215 SOT23(L/F)BAT54,2151128DIODE S.B BAT54 0.2A30V SOT-23BAT541129LED GREEN LTST-C190GKT SMDLTST-C190GKT
LED10,LED11,LED12,LED13,LED14,LED17,LED18,LED27,LED28,LED29,LED30,LED31,LED32,LED33,LED34,LED36,LED39,LED40,LED41,LED5,LED6,LED7,LED8,LED9,LEDB1,LEDB21130LED Y/G 19-21/G6C-BM2P1B/3T SM19-21/G6C-BM2P1B/3T1131LED GRN 19-213/G6C-DH1J2AX/3T19-213/G6C-DH1J2AX/3T1132LED GREEN 1.6*0.8 19-213-G6C-19-213-G6C-BN2P2B-3T1133LED G/Y LTST-S326KGJSKT SMDLTST-S326KGJSKTLED48,LED501134LED Y/G 12-22/Y2G6C-A30/2C SMD12-22/Y2G6C-A30/2C1135LED RED ET 12-21/R6C-AP1Q2L/2C SMD12-21/R6C-AP1Q2L/2CLED541136LED RED LTST-S320KRKT SMDLTST-S320KRKT1137DIODE S.B 1N5819HW-7-F SOD-1231N5819HW-7-FD11138DIODE S.B SS1040 40V1A SOD-123SS10401139DIODE SDMK0340L-7-F SOD-323SDMK0340L-7-FD45,D47,D48,D49,D50,D51,D52,D53,D54,D55,D56,D58,D59,D61,D62,D63,D64,D651140DIODE SD LRB501V-40T1G 40V1A SOD-323LRB501V-40T1G1141DIODE S.B RB751V-40H SOD-323RB751V-40H1142FET MOS DMN2004DWK-7 NC SOT363DMN2004DWK-7U12,UG1,UG2,UG3,UG4,UG51143IC MOSFET PJT138KA SOT-363PJT138KA1144XTOR MMBT3904 NPN SOT-23MMBT3904Q71145XTOR LMBT3904LT1G NPN SOT-23LMBT3904LT1G1146FET MOS 2N7002K NC SOT-23 ESD 2KV 300MA2N7002KQ10,Q19,Q2,Q20,Q21,Q3,Q4,Q49,Q5,Q50,Q54,Q56,Q6,Q8,Q9,QB7,QF1,QF21147FET MOS 2N7002ET1G NC SOT-232N7002ET1G1148FET MOS 2N7002K-7 NC SOT-23 2KV 300MA2N7002K-71149BOSS TPM BrassLeadFree L8.2 MatteSnF70M30-701450P1D4BMH141150BOSS TPM BRASSLEADFREE L8.2 SOUTHCOJ-N1-99-1791151BOSS_TPM_FIVE_RMB_C201082-150-22-070-03-RL1152PCB 15061-1B MT.OLYMPUS MB 8L HANNSTAR15061-1BPCBL11153PCB 15061-1B MT.OLYMPUS MB 8L TRIPOD15061-1B1154ASSY_HSINK_80X12X9_PUSHPIN_VR_CMECC-01323-01-GPTP1409,TP14101155ASSY_HSINK_80X12X9_PUSHPIN_VR_AA6506291156CHIP RES 1.02K B 1/16W 0402 TCR 50PPMRT0402BRE071K02LPR164,PR464,PR465,PR466,PR468,PR469,PR470,PR564,PR64,PR65,PR66,PR68,PR69,PR701157RB04BTS10211158RTX021021BETH1159WF04T1021BTL1160CHIP RES 1K B 1/16W 0402RR0510Q-102-BNPR246,PR250,PR257,PR343,PR347,PR354,PR646,PR650,PR657,PR743,PR748,PR754,PR880,PR8811161RTX021001BETH1162RB04BTS10011163RT0402BRE071KL1164WF04T1001BTL 谢谢分享!!! 牛,好东西,学习
